SmartRack 12U UPS-Depth Wall-Mount Small
Rack Enclosure, Clear Acrylic Window, Hinged
Back
Highlights
Maximum load capacity of 200
lbs (90.7 kgs)
MODEL NUMBER: SRW12USDPG
Swings away from wall on hinge
for easy back-door access
Front door includes shatterresistant clear acrylic window
Locking steel cabinet vented at
sides, top and bottom
Secures 12U of 19 in. rack
equipment up to 24.5 in. deep
Package Includes
SRW12USDPG SmartRack 12U
UPS-Depth Wall-Mount Rack
Enclosure Cabinet
(20) M6 screws
Wall-mount cabinet secures and organizes 12U of 19-inch rack equipment up to 24.5 inches deep in
(20) M6 cage nuts
locations with limited floor space. Clear acrylic window allows you to monitor equipment without unlocking
(20) M6 washers
door.
(20) 12-24 screws
(2) Keys
Owner’s manual
Description
The SRW12USDPG SmartRack 12U UPS-Depth Wall-Mount Rack Enclosure Cabinet is designed to
house EIA-standard 19-inch rack equipment in network wiring closets, retail locations, classrooms, back
offices and other areas with limited floor space where you need equipment to be secure, organized and
out of the way. Constructed from heavy-duty steel with a durable black powder-coated finish, the cabinet
has a maximum load capacity of 200 lbs (90.7 kgs).
The front door features a shatter-resistant clear acrylic window that lets you monitor equipment readouts
without unlocking the enclosure. Not only does the window help prevent equipment tampering and reduce
acoustic noise, but it also adds visual flair to your IT installation.
The cabinet swings away from the wall on a sturdy hinge, allowing easy back-door access to equipment
and cabling during installation and maintenance. The doors and side panels lock securely to help prevent
damage, tampering or theft. The top, bottom and removable side panels are vented, which allows air to
flow freely and keep equipment cool. The reversible doors can open left or right by rotating the cabinet
180° before mounting. Convenient top and bottom ports allow easy cable routing.
The SRW12USDPG comes fully assembled and ready to mount to the wall, or use Tripp Lite's optional
SRCASTER rolling caster kit to make it a mobile rack. Square and 12-24 threaded mounting holes and
numbered rack spaces make equipment installation easy. The vertical mounting rails adjust in 7/8-inch
increments to accommodate equipment up to 24.5 inches deep, such as network switches, UPS systems
and related battery packs and cabling.
1/4
Features
Saves Valuable Workspace
Perfect for network wiring closets, retail locations, classrooms, back offices and other areas with limited
floor space where you need equipment to be secure, organized and out of the way
Houses EIA-standard 19 in. rack equipment in 12U of space
Maximum load capacity of 200 lbs (90.7 kgs)
Hinged Cabinet for Convenient Access
Swings away from the wall to allow easy back-door access to equipment and cabling during installation
and maintenance
Rotate cabinet 180° before mounting to open reversible doors left or right
Shatter-Resistant Clear Acrylic Front Window
Lets you monitor equipment without unlocking the enclosure
Prevents equipment tampering
Reduces acoustic noise
Provides extra visual flair
Keeps Important Equipment Secure
Side panels and doors lock securely to help prevent damage, tampering or theft
Vented panels allow generous airflow that keeps equipment cool
Convenient ports with removable covers allow cable routing through top and bottom
Easy Enclosure and Equipment Installation
Ships fully assembled for quick installation
Mounts to wall or rolls on floor with Tripp Lite's optional SRCASTER caster kit
Wall-mounting holes spaced 16 in. apart for standard wall stud placement
Vertical mounting rails adjust in 7/8 in. increments to accommodate equipment up to 24.5 in. deep, such
as network switches, UPS systems, battery packs and cabling
Rails support square-hole or 12-24 threaded-hole mounting
Rack spaces numbered for easy reference
Meets Payment Card Industry Standards
Provides physical equipment and media security required for PCI DSS (Payment Card Industry Data
Security Standard) compliance
Specifications
OVERVIEW
UPC Code
037332189721
2/4
Device Compatibility
Patch Panel; Network Switch; UPS
Rack Type
Enclosure
PHYSICAL
Color
Black
Factory Preset Rack Depth (in.)
10.42
Factory Preset Rack Depth (cm)
26.5
Factory Preset Rack Depth (mm)
265
Maximum Device Depth (cm)
62.23
Maximum Device Depth (in.)
24.5
Maximum Device Depth (mm)
622
Minimum Device Depth (cm)
7.62
Minimum Device Depth (in.)
3
Minimum Device Depth (mm)
76
Rack Height
12U
Shipping Dimensions (hwd / cm)
74.50 x 71.50 x 76.00
Shipping Dimensions (hwd / in.)
29.33 x 28.15 x 29.92
Shipping Weight (kg)
41.73
Shipping Weight (lbs.)
92.00
Unit Dimensions (hwd / cm)
63.65 x 60.02 x 64.77
Unit Dimensions (hwd / in.)
25.06 x 23.63 x 25.5
Unit Weight (kg)
29.03
Unit Weight (lbs.)
64
Weight Capacity - Stationary (kg)
91
Weight Capacity - Stationary (lbs.)
200
Rack Depth
Shallow
Number of Vertical Mounting Rails
4
SPECIAL FEATURES
Grounding Lug
Front and Back door frames
STANDARDS & COMPLIANCE
Approvals
EIA-310-D, IEC 60297-3-100, IP20 Protection, RoHS
WARRANTY
Product Warranty Period
(Worldwide)
5-year limited warranty
3/4
© 2021 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
4/4
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Tripp Lite:
SRW12USDPG
很抱歉,暂时无法提供与“SRW12USDPG”相匹配的价格&库存,您可以联系我们找货
