XC53G2-8.000-F20LJDT 数据手册
HANG CRYSTAL INTERNATIONAL (HK) LIMITED
杭 晶 国 际 (香 港) 有 限 公 司
产 品 规 格 书
Product Specification
客户:
CUSTOMER
CUSTOMER PN
HANG CRYSTAL P/N
客户 PN:
杭晶物料编码:
产品型号:
MODEL
Crystal SMD 5.0x3.2 glass seal, 2 pads
NOMINAL FREQUENCY
频率:
8.000MHz
ISSUE DATE
日期:
2017 / 10 / 23
CUSTOMER’S APPROVAL
APPROVED
QA
Peter Y.
Shen S.
客户确认
苏州杭晶电子科技有限公司
(PLEASE RETURN A COPY WITH APPOVAL)
(请将确认的复印件返回我司)
SUZHOU HANG CRYSTAL ELECTRONICS CO. ,LTD.
No. 207, Blk. B, Chenlei Science &
Technology Park, No. 1, First Qunxing Road,
Suzhou Industrial Park, Jiangsu, China
TEL.86 (0)512 65916689
Revision
1
2
3
4
HCI-FRM-Spec-2
Description / ECN
Initial release
Not issued
Not issued
Not issued
Prepared
MB
FAX 86 (0)512 65918005
Approved
S. Shen
Date
2017-10-23
Page 1 of 5
1. NOMINAL AND MAXIMUM RATINGS, OPERATING AND STORAGE CONDITIONS
PARAMETER
SYMB.
MIN
TYP
MAX
1 Nominal frequency
FN
8.000
2 Vibration mode
FUNDAMENTAL
3 Load capacitance
CL
20.0
4 Drive level
DL
100
5 Operating temperature range
TOP
–40
+25
6 Storage Temperature Range
TST
–25
Unit
MHz
Conditions / Remarks
pF
300
µW
+85
°C
Note 1
+125 °C
Note 1: Unit stays within all relevant parameter limits as specified under point 2 below.
2. ELECTRICAL PARAMETER LIMITS
PARAMETER
1 Frequency tolerance
2 Frequency stability
3 Aging first year
4 Shunt capacitance
5 Equivalent series resistance
6 Insulation resistance
SYMB.
MIN
TYP
MAX
Unit
∆f/FN
–20
+20
ppm
∆f/f
–30
+30
ppm/°C2 Note 1
(∆f/f)A1
–3.0
+3.0
ppm
at +25°C and 100µW
Offset from FN at +25°C
C0
5.0
pF
at +25°C and 100µW
ESR
100
Ω
at +25°C / 100µW / @Series
MΩ
at 100±15VDC
IR
500
Note 1: Frequency stability is the frequency deviation over operating temperature range T OP in reference to the frequency
reading at +25°C..
HCI-FRM-Spec-2
Page 2 of 5
3. OUTLINE DRAWING
Package description
Package model Remarks
1 Seam seal SMD package 5.0x3.2mm with 2 pads
CSX5032p2
4. RELIABILITY TEST INFORMATION
Test item
1 Temperature Cycle (GB/T2423.22-2002,
Test method
Criteria
10 cycles from -55°C to +125°C.
Tested after 24±2h at room temperature.
±5.0ppm
72h at -55°C±3°C constant temperature.
±5.0ppm
72h at +125°C±3°C constant temperature.
±5.0ppm
96h at +40 °C ± 3 °C, with 90± 3% RH.
±5.0ppm
Apply 0.75mm vibration at frequency 10~500 Hz, for 2h. 10 cycles in
each direction of 3 axis, test after 1h.
±5.0ppm
6 Shock (GB/T 2423.5-1995,Method Ea)
Peak 1000m/s2, with 6ms half sine wave, 3.7m/s, in 3 perpendicular axis,
3 cycles /direction, test after 1h.
±5.0ppm
7 Drop (GB/T 2423.8-1995, M. Ed)
Free drop onto wooden plate from 1.0 m height for 3times.
±5.0ppm
Method Nb)
2 Low Temperature Storage (GB/T 2423.12001, Method Aa)
3 High Temperature Storage(GB/T 2423.22001, Method Ba)
4 Humidity (GB/T 2423.3-2006, Method
Cab)
5 Vibration (GB/T 2423.10-1995, Method
Fc)
8 Solderability (GB/T2423.28-2005, Method Dip into 245 ± 5℃ solder bath for 2 ± 0.5 seconds. Inspection under 8-12X >95% cover.
Tc)
magnifier.
9 Terminal Strength (JIS-C-6429 Method 1 & Mount on a glass-epoxy board (100x50x1.6mm), then bend to 2mm
2)
10 Resistance to Solder Heat (GB/T
2423.28-2005,Test Tb Meth. 1B)
HCI-FRM-Spec-2
No damage
displacement (velocity 1mm/sec) and keep for 5 seconds. or pulling force
0.5 kg for at least 60seconds
Reflow at Preheat to 150°C±5°C for 60 to 120sec,and peak 265°C±5°C for
10s±3sec, Tested after 24±2h at room temp.
±5.0ppm
Page 3 of 5
5. ENVIRONMENTAL COMPLIANCE INFORMATION
Compliance information
1 RoHS
This product is fully RoHS compliant, 6/6 compliant per DIRECTIVE 2011/65/EU.
The product is considered LEAD-FREE, Pb contamination guarantied
XC53G2-8.000-F20LJDT 价格&库存
很抱歉,暂时无法提供与“ XC53G2-8.000-F20LJDT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.12000
- 30+1.08000
- 100+1.04000
- 500+0.96000
- 1000+0.92000
- 2000+0.89600
