MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS
KMG
Series
Standard, 105℃
KMQ
Downsized
・Endurance with ripple current : 1,000 to 2,000 hours at 105℃
・Solvent resistant type except 350 to 450Vdc
(see PRECAUTIONS AND GUIDELINES)
・RoHS2 Compliant
KMG
◆SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
-55 to +105℃(6.3 to 100Vdc) -40 to +105℃(160 to 400Vdc) -25 to +105℃(450Vdc)
6.3 to 450Vdc
±20% (M)
6.3 to 100Vdc
I=0.03CV or 4µA, whichever is greater.
(at 20℃, 120Hz)
160 to 450Vdc
Time After 1minute
After 5minutes
CV
CV≦1,000
I=0.1CV+40 max.
I=0.03CV+15 max.
(after 1 minute) CV>1,000
I=0.04CV+100 max.
I=0.02CV+25 max.
Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V)
(at 20℃)
Rated voltage (Vdc)
6.3V 10V 16V 25V 35V 50V 63V 100V 160 to 250V 350 to 400V 450V
tanδ (Max.)
0.34 0.24 0.20 0.16 0.14 0.12 0.10 0.08
0.20
0.24
0.24
When nominal capacitance exceeds 1,000µF, add 0.02 to the value above for each 1,000µF increase.
(at 20℃, 120Hz)
Rated voltage (Vdc)
Z(-25℃)/Z(+20℃)
5
4
3
2
2
2
2
2
3
6
6
Z(-40℃)/Z(+20℃)
12
10
8
5
4
3
3
3
4
6
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple
current is applied (the peak voltage shall not exceed the rated voltage) for 1,000 hours (2,000 hours to meet the following two conditions
1): 160Vdc and larger, 2) :φ12.5 and larger) at 105℃.
Capacitance change
≦±20% of the initial value
D.F. (tanδ)
≦200% of the initial specified value
Leakage current
≦The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without
voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4.
Rated voltage
6.3 to 100Vcd
160 to 450Vdc
Capacitance change
D.F. (tanδ)
Leakage current
≦500% of the initial specified value
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
Endurance
Shelf Life
◆DIMENSIONS [mm]
F±0.5
Code : E
φD'
φd
Sleeve (PET : Brown)
F±0.5
●Terminal
L'
15min.
4min.
(φ5 toφ10)
Vent
(exceptφ5)
(φ12.5 to φ18)
φD
φd
F
φD'
L'
5
0.5
2.0
6.3
0.5
2.5
10 12.5
8
0.6 0.6 0.6
3.5 5.0 5.0
φD+0.5max
L+1.5max
16
0.8
7.5
18
0.8
7.5
Gas escape end seal
◆PART NUMBERING SYSTEM
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
E KMG A A A E A A A A A M A A A N
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 1.0µF:1R0,10µF:100,100µF:101)
Lead forming·taping code
Terminal code
Voltage code (ex. 6.3V:6R3,35V:350,100V:101)
Series code
Category
Please refer to "Product code guide (radial lead type)"
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
CAT. No. E1001U
Standard, 105℃
KMGSeries
◆STANDARD RATINGS
WV
(Vdc)
6.3
10
16
25
35
50
Cap
(µF)
220
330
470
1,000
2,200
3,300
4,700
6,800
10,000
15,000
22,000
220
330
470
1,000
2,200
3,300
4,700
6,800
10,000
15,000
100
220
330
470
1,000
2,200
3,300
4,700
6,800
10,000
47
100
220
330
470
1,000
2,200
3,300
4,700
6,800
47
100
220
330
470
1,000
2,200
3,300
4,700
1.0
2.2
3.3
4.7
10
22
33
47
100
220
330
470
1,000
2,200
3,300
Rated ripple
current
Case size
tanδ
(mArms/
φD×L(mm)
105℃, 120Hz)
5 ×11
6.3×11
6.3×11
8 ×11.5
10 ×20
10 ×20
12.5× 20
12.5× 25
16 ×25
16 ×35.5
18 ×40
6.3×11
6.3×11
8 ×11.5
10 ×12.5
10 ×20
12.5× 20
12.5× 25
16 ×25
16 ×35.5
18 ×35.5
5 ×11
6.3×11
8 ×11.5
8 ×11.5
10 ×16
12.5× 20
12.5× 25
16 ×25
16 ×31.5
18 ×35.5
5 ×11
6.3×11
8 ×11.5
8 ×11.5
10 ×12.5
10 ×20
12.5× 25
16 ×25
16 ×31.5
18 ×35.5
5 ×11
6.3×11
8 ×11.5
10 ×12.5
10 ×16
12.5× 20
16 ×25
16 ×35.5
18 ×35.5
5 ×11
5 ×11
5 ×11
5 ×11
5 ×11
5 ×11
5 ×11
6.3×11
8 ×11.5
10 ×12.5
10 ×16
10 ×20
12.5× 25
16 ×35.5
18 ×35.5
0.34
0.34
0.34
0.34
0.36
0.38
0.40
0.44
0.52
0.62
0.76
0.24
0.24
0.24
0.24
0.26
0.28
0.30
0.34
0.42
0.52
0.20
0.20
0.20
0.20
0.20
0.22
0.24
0.26
0.30
0.38
0.16
0.16
0.16
0.16
0.16
0.16
0.18
0.20
0.22
0.26
0.14
0.14
0.14
0.14
0.14
0.14
0.16
0.18
0.20
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.14
0.16
140
190
230
380
710
840
1,090
1,350
1,650
2,010
2,350
170
200
250
460
760
1,000
1,260
1,570
1,890
2,180
110
180
260
310
560
920
1,170
1,480
1,780
2,060
80
130
230
310
380
680
1,090
1,400
1,710
2,040
90
150
270
350
460
810
1,260
1,610
1,910
13
30
40
65
90
110
180
300
410
530
950
1,470
1,770
Part No.
EKMG6R3E□□221ME11D
EKMG6R3E□□331MF11D
EKMG6R3E□□471MF11D
EKMG6R3E□□102MHB5D
EKMG6R3E□□222MJ20S
EKMG6R3E□□332MJ20S
EKMG6R3E□□472MK20S
EKMG6R3E□□682MK25S
EKMG6R3E□□103ML25S
EKMG6R3E□□153MLP1S
EKMG6R3E□□223MM40S
EKMG100E□□221MF11D
EKMG100E□□331MF11D
EKMG100E□□471MHB5D
EKMG100E□□102MJC5S
EKMG100E□□222MJ20S
EKMG100E□□332MK20S
EKMG100E□□472MK25S
EKMG100E□□682ML25S
EKMG100E□□103MLP1S
EKMG100E□□153MMP1S
EKMG160E□□101ME11D
EKMG160E□□221MF11D
EKMG160E□□331MHB5D
EKMG160E□□471MHB5D
EKMG160E□□102MJ16S
EKMG160E□□222MK20S
EKMG160E□□332MK25S
EKMG160E□□472ML25S
EKMG160E□□682MLN3S
EKMG160E□□103MMP1S
EKMG250E□□470ME11D
EKMG250E□□101MF11D
EKMG250E□□221MHB5D
EKMG250E□□331MHB5D
EKMG250E□□471MJC5S
EKMG250E□□102MJ20S
EKMG250E□□222MK25S
EKMG250E□□332ML25S
EKMG250E□□472MLN3S
EKMG250E□□682MMP1S
EKMG350E□□470ME11D
EKMG350E□□101MF11D
EKMG350E□□221MHB5D
EKMG350E□□331MJC5S
EKMG350E□□471MJ16S
EKMG350E□□102MK20S
EKMG350E□□222ML25S
EKMG350E□□332MLP1S
EKMG350E□□472MMP1S
EKMG500E□□1R0ME11D
EKMG500E□□2R2ME11D
EKMG500E□□3R3ME11D
EKMG500E□□4R7ME11D
EKMG500E□□100ME11D
EKMG500E□□220ME11D
EKMG500E□□330ME11D
EKMG500E□□470MF11D
EKMG500E□□101MHB5D
EKMG500E□□221MJC5S
EKMG500E□□331MJ16S
EKMG500E□□471MJ20S
EKMG500E□□102MK25S
EKMG500E□□222MLP1S
EKMG500E□□332MMP1S
□□ : Enter the appropriate lead forming or taping code.
WV
(Vdc)
63
100
160
200
250
350
400
Cap
(µF)
10
22
33
47
100
220
330
470
1,000
1.0
2.2
3.3
4.7
10
22
33
47
100
220
330
470
1,000
3.3
4.7
10
22
33
47
100
220
330
3.3
4.7
10
22
33
47
100
220
2.2
3.3
4.7
10
22
33
47
100
220
1.0
2.2
3.3
4.7
10
22
33
47
100
1.0
2.2
3.3
4.7
10
22
33
47
100
Rated ripple
current
Case size
tanδ
(mArms/
φD×L(mm)
105℃, 120Hz)
5× 11
5× 11
6.3 × 11
6.3 × 11
10 × 12.5
10 × 16
10 × 20
12.5 × 20
16 × 25
5 × 11
5 × 11
5× 11
5× 11
6.3 × 11
8 × 11.5
8 × 11.5
10 × 12.5
10 × 20
12.5 × 25
16 × 25
16 × 31.5
18 × 40
6.3 × 11
6.3 × 11
10 × 12.5
10 × 20
10 × 20
12.5 × 20
16 × 25
16 × 31.5
18 × 35.5
6.3 × 11
8× 11.5
10 × 16
10 × 20
12.5 × 20
12.5 × 20
16 × 25
18 × 35.5
6.3 × 11
8 × 11.5
8× 11.5
10 × 16
12.5× 20
12.5 × 20
12.5 × 25
16 × 31.5
18 × 40
6.3 × 11
8 × 11.5
10 × 12.5
10 × 16
10 × 20
12.5× 20
16 × 25
16 × 25
18 × 31.5
6.3 × 11
8× 11.5
10 × 12.5
10 × 16
10 × 20
12.5 × 25
16 × 25
16 × 31.5
16 × 40
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
46
71
100
120
215
335
510
640
930
15
21
29
32
54
93
130
165
265
440
540
715
985
28
34
67
120
145
195
335
540
705
28
39
74
120
160
195
335
575
23
32
39
74
130
160
210
365
585
15
26
38
50
80
130
195
230
375
15
26
38
50
80
145
195
250
350
Part No.
EKMG630E□□100ME11D
EKMG630E□□220ME11D
EKMG630E□□330MF11D
EKMG630E□□470MF11D
EKMG630E□□101MJC5S
EKMG630E□□221MJ16S
EKMG630E□□331MJ20S
EKMG630E□□471MK20S
EKMG630E□□102ML25S
EKMG101E□□1R0ME11D
EKMG101E□□2R2ME11D
EKMG101E□□3R3ME11D
EKMG101E□□4R7ME11D
EKMG101E□□100MF11D
EKMG101E□□220MHB5D
EKMG101E□□330MHB5D
EKMG101E□□470MJC5S
EKMG101E□□101MJ20S
EKMG101E□□221MK25S
EKMG101E□□331ML25S
EKMG101E□□471MLN3S
EKMG101E□□102MM40S
EKMG161E□□3R3MF11D
EKMG161E□□4R7MF11D
EKMG161E□□100MJC5S
EKMG161E□□220MJ20S
EKMG161E□□330MJ20S
EKMG161E□□470MK20S
EKMG161E□□101ML25S
EKMG161E□□221MLN3S
EKMG161E□□331MMP1S
EKMG201E□□3R3MF11D
EKMG201E□□4R7MHB5D
EKMG201E□□100MJ16S
EKMG201E□□220MJ20S
EKMG201E□□330MK20S
EKMG201E□□470MK20S
EKMG201E□□101ML25S
EKMG201E□□221MMP1S
EKMG251E□□2R2MF11D
EKMG251E□□3R3MHB5D
EKMG251E□□4R7MHB5D
EKMG251E□□100MJ16S
EKMG251E□□220MK20S
EKMG251E□□330MK20S
EKMG251E□□470MK25S
EKMG251E□□101MLN3S
EKMG251E□□221MM40S
EKMG351E□□1R0MF11D
EKMG351E□□2R2MHB5D
EKMG351E□□3R3MJC5S
EKMG351E□□4R7MJ16S
EKMG351E□□100MJ20S
EKMG351E□□220MK20S
EKMG351E□□330ML25S
EKMG351E□□470ML25S
EKMG351E□□101MMN3S
EKMG401E□□1R0MF11D
EKMG401E□□2R2MHB5D
EKMG401E□□3R3MJC5S
EKMG401E□□4R7MJ16S
EKMG401E□□100MJ20S
EKMG401E□□220MK25S
EKMG401E□□330ML25S
EKMG401E□□470MLN3S
EKMG401E□□101ML40S
CAT. No. E1001U
Standard, 105℃
KMGSeries
◆STANDARD RATINGS
is not solvent resistant.
WV
(Vdc)
Cap
(µF)
Rated ripple
current
Case size
tanδ
(mArms/
φD×L(mm)
105℃, 120Hz)
450
2.2
3.3
4.7
10
22
33
47
10×12.5
10 ×16
10 ×20
12.5 ×20
16 ×25
16 ×31.5
16 ×35.5
0.24
0.24
0.24
0.24
0.24
0.24
0.24
23
31
40
65
115
155
185
Part No.
EKMG451E□□2R2MJC5S
EKMG451E□□3R3MJ16S
EKMG451E□□4R7MJ20S
EKMG451E□□100MK20S
EKMG451E□□220ML25S
EKMG451E□□330MLN3S
EKMG451E□□470MLP1S
◆RATED RIPPLE CURRENT MULTIPLIERS
・Frequency Multipliers
Capacitance(µF)
1.0
10
100
2,200
Frequency(Hz)
to 4.7
to 47
to 1,000
to
50
0.65
0.75
0.80
0.85
120
1.00
1.00
1.00
1.00
300
1.35
1.25
1.15
1.03
1k
1.75
1.50
1.30
1.05
10k
2.30
1.75
1.40
1.08
100k
2.50
1.80
1.50
1.08
The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise.
When long life performance is required in actual use, the rms ripple current has to be reduced.
CAT. No. E1001U
