MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS
KYA
Series
Low impedance, 105℃
KYA
・Downsized from KY series
・Newly innovative electrolyte is employed to minimize impedance
・Endurance with ripple current : 4,000 to 10,000 hours at 105℃
・Non solvent resistant type
・RoHS2 Compliant
Downsized
KY
◆SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
-40 to +105℃
6.3 to 100Vdc
(at 20℃, 120Hz)
±20% (M)
I=0.01CV or 3µA, whichever is greater.
Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V)
(at 20℃ after 2 minutes)
Rated voltage (Vdc)
6.3V 10V 16V 25V 35V 50V 63V 100V
tanδ (Max.)
0.22 0.19 0.16 0.14 0.12 0.10 0.09 0.08
When nominal capacitance exceeds 1,000µF, add 0.02 to the value above for each 1,000µF increase.
(at 20℃, 120Hz)
Rated voltage (Vdc)
Z(-25℃)/Z(+20℃)
4
3
2
2
2
2
2
2
8
6
4
3
3
3
3
3
(at 120Hz)
Z(-40℃)/Z(+20℃)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated
ripple current is applied (the peak voltage shall not exceed the rated voltage) for the specified period of time at 105℃.
Time
6.3 to 10Vdc
φ5 & 6.3 : 4,000hours φ8 & 10 : 6,000hours φ12.5 to 16 : 8,000hours
16 to 100Vdc
φ5 & 6.3 : 5,000hours φ8 & 10 : 7,000hours φ12.5 to 16 : 10,000hours
Capacitance change
≦±25% of the initial value
D.F. (tanδ)
≦200% of the initial specified value
Leakage current
≦The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 500 hours at 105℃ without
voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4.
Capacitance change
D.F. (tanδ)
Leakage current
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
Endurance
Shelf Life
◆DIMENSIONS [mm]
φd
Sleeve (PET : Brown)
F±0.5
Code : E
F±0.5
●Terminal
φD
φd
φD'
F
φD'
L'
Vent
(Exceptφ5 &φ6.3)
15min.
4min.
(φ5 to φ10)
(φ12.5 to φ16)
L'
5
0.5
2.0
6.3
0.5
2.5
10 12.5
8
0.6 0.6 0.6
3.5 5.0 5.0
φD+0.5max.
L+1.5max.
16
0.8
7.5
Gas escape end seal
◆PART NUMBERING SYSTEM
1
2
3
4
E KYA
5
6
7
8
E
9
10
11
12
13
14
M
15
16
17
18
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 1.0µF:1R0,10µF:100,100µF:101)
Lead forming·taping code
Terminal code
Voltage code (ex. 6.3V:6R3,50V:500)
Series code
Category
Please refer to "Product code guide (radial lead type)"
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
CAT. No. E1001W 2022
Low impedance, 105℃
KYASeries
◆STANDARD RATINGS
WV
(Vdc)
Cap
(µF)
Case size
φD×L(mm)
20℃
6.3
10
16
25
100
180
220
330
470
820
1,200
1,200
1,500
1,800
2,700
3,300
3,900
4,700
5,600
10,000
12,000
15,000
100
120
330
560
820
820
1,000
1,200
1,200
1,800
2,200
3,300
3,900
6,800
10,000
12,000
47
100
220
270
470
680
680
820
1,000
1,500
1,800
2,200
3,300
4,700
5,600
6,800
8,200
10,000
33
47
68
150
330
390
470
560
680
1,000
1,200
1,500
2,200
5×11
5×11
5×11
6.3×11
6.3×11
8×11.5
10×12.5
8×15
8×20
10×16
10×20
10×25
12.5×20
12.5×25
12.5×25
16×25
16×31.5
16×35.5
5×11
5×11
6.3×11
8×11.5
8×15
10×12.5
10×12.5
8×20
10×16
10×20
10×25
12.5×20
12.5×25
16×25
16×31.5
16×35.5
5×11
5×11
6.3×11
6.3×11
8×11.5
8×15
10×12.5
8×20
10×16
10×20
10×25
12.5×20
12.5×25
16×25
16×25
16×31.5
16×31.5
16×35.5
5×11
5×11
5×11
6.3×11
8×11.5
8×15
10×12.5
8×20
10×16
10×20
10×25
12.5×20
12.5×25
Rated
ripple
current
(mArms/
-10℃ 105℃,
100kHz)
Impedance
(Ω max./100kHz)
0.90
0.40
0.40
0.22
0.22
0.13
0.080
0.087
0.069
0.060
0.046
0.042
0.035
0.027
0.027
0.021
0.017
0.015
0.90
0.40
0.22
0.13
0.087
0.080
0.080
0.069
0.060
0.046
0.042
0.035
0.027
0.021
0.017
0.015
0.40
0.40
0.22
0.22
0.13
0.087
0.080
0.069
0.060
0.046
0.042
0.035
0.027
0.021
0.021
0.017
0.017
0.015
0.40
0.40
0.40
0.22
0.13
0.087
0.080
0.069
0.060
0.046
0.042
0.035
0.027
3.6
1.6
1.6
0.87
0.87
0.52
0.32
0.35
0.27
0.24
0.18
0.17
0.12
0.089
0.089
0.060
0.050
0.044
3.6
1.6
0.87
0.52
0.35
0.32
0.32
0.27
0.24
0.18
0.17
0.12
0.089
0.060
0.050
0.044
1.6
1.6
0.87
0.87
0.52
0.35
0.32
0.27
0.24
0.18
0.17
0.12
0.089
0.060
0.060
0.050
0.050
0.044
1.6
1.6
1.6
0.87
0.52
0.35
0.32
0.27
0.24
0.18
0.17
0.12
0.089
150
250
250
400
400
640
865
840
1,050
1,300
1,400
1,650
1,900
2,230
2,230
2,930
3,450
3,610
150
250
400
640
840
865
865
1,050
1,300
1,400
1,650
1,900
2,230
2,930
3,450
3,610
250
250
400
400
640
840
865
1,050
1,300
1,400
1,650
1,900
2,230
2,930
2,930
3,450
3,450
3,610
250
250
250
400
640
840
865
1,050
1,300
1,400
1,650
1,900
2,230
Part No.
WV
(Vdc)
Cap
(µF)
Case size
φD×L(mm)
20℃
EKYA6R3E□□101ME11D
EKYA6R3E□□181ME11D
25
EKYA6R3E□□221ME11D
EKYA6R3E□□331MF11D
EKYA6R3E□□471MF11D
EKYA6R3E□□821MHB5D
EKYA6R3E□□122MJC5S
EKYA6R3E□□122MH15D
EKYA6R3E□□152MH20D
EKYA6R3E□□182MJ16S
EKYA6R3E□□272MJ20S
EKYA6R3E□□332MJ25S
35
EKYA6R3E□□392MK20S
EKYA6R3E□□472MK25S
EKYA6R3E□□562MK25S
EKYA6R3E□□103ML25S
EKYA6R3E□□123MLN3S
EKYA6R3E□□153MLP1S
EKYA100E□□101ME11D
EKYA100E□□121ME11D
EKYA100E□□331MF11D
EKYA100E□□561MHB5D
EKYA100E□□821MH15D
EKYA100E□□821MJC5S
EKYA100E□□102MJC5S
EKYA100E□□122MH20D
EKYA100E□□122MJ16S
EKYA100E□□182MJ20S
EKYA100E□□222MJ25S
EKYA100E□□332MK20S
EKYA100E□□392MK25S
EKYA100E□□682ML25S
50
EKYA100E□□103MLN3S
EKYA100E□□123MLP1S
EKYA160E□□470ME11D
EKYA160E□□101ME11D
EKYA160E□□221MF11D
EKYA160E□□271MF11D
EKYA160E□□471MHB5D
EKYA160E□□681MH15D
EKYA160E□□681MJC5S
EKYA160E□□821MH20D
EKYA160E□□102MJ16S
EKYA160E□□152MJ20S
EKYA160E□□182MJ25S
EKYA160E□□222MK20S
EKYA160E□□332MK25S
EKYA160E□□472ML25S
EKYA160E□□562ML25S
EKYA160E□□682MLN3S
EKYA160E□□822MLN3S
EKYA160E□□103MLP1S
63
EKYA250E□□330ME11D
EKYA250E□□470ME11D
EKYA250E□□680ME11D
EKYA250E□□151MF11D
EKYA250E□□331MHB5D
EKYA250E□□391MH15D
EKYA250E□□471MJC5S
EKYA250E□□561MH20D
EKYA250E□□681MJ16S
EKYA250E□□102MJ20S
EKYA250E□□122MJ25S 100
EKYA250E□□152MK20S
EKYA250E□□222MK25S
3,300
3,900
4,700
5,600
33
47
100
220
270
330
390
470
680
820
1,000
1,500
2,200
2,700
3,300
3,900
1.0
2.2
3.3
4.7
10
22
27
47
56
100
150
180
180
220
330
470
470
560
820
1,000
1,200
1,800
2,200
10
15
33
56
82
100
120
120
220
330
330
390
470
560
1,000
1,200
1,500
1.0
2.2
3.3
4.7
6.8
16×25
16×25
16×31.5
16×35.5
5×11
5×11
6.3×11
8×11.5
8×15
10×12.5
8×20
10×16
10×20
10×25
12.5×20
12.5×25
16×25
16×25
16×31.5
16×35.5
5×11
5×11
5×11
5×11
5×11
5×11
5×11
6.3×11
6.3×11
8×11.5
8×15
10×12.5
8×20
10×16
10×20
10×25
12.5×20
12.5×20
12.5×25
16×25
16×25
16×31.5
16×35.5
5×11
5×11
6.3×11
8×11.5
8×15
10×12.5
8×20
10×16
10×20
10×25
12.5×20
12.5×20
12.5×25
12.5×25
16×25
16×31.5
16×35.5
5×11
5×11
5×11
5×11
5×11
Rated
ripple
current
(mArms/
-10℃ 105℃,
100kHz)
Impedance
(Ω max./100kHz)
0.021
0.021
0.017
0.015
0.40
0.40
0.22
0.13
0.087
0.080
0.069
0.060
0.046
0.042
0.035
0.027
0.021
0.021
0.017
0.015
4.0
2.5
2.2
1.9
1.5
0.70
0.70
0.30
0.30
0.17
0.12
0.12
0.091
0.084
0.060
0.055
0.045
0.045
0.034
0.025
0.025
0.022
0.019
0.88
0.88
0.35
0.22
0.16
0.11
0.12
0.076
0.056
0.046
0.041
0.041
0.031
0.031
0.025
0.021
0.019
4.5
3.0
2.7
2.5
1.4
0.060
0.060
0.050
0.044
1.6
1.6
0.87
0.52
0.35
0.32
0.27
0.24
0.18
0.17
0.12
0.089
0.060
0.060
0.050
0.044
16
10
8.8
7.6
6.0
2.8
2.8
1.2
1.2
0.68
0.48
0.48
0.36
0.34
0.24
0.22
0.15
0.15
0.11
0.075
0.075
0.066
0.057
3.5
3.5
1.4
0.88
0.64
0.44
0.48
0.31
0.23
0.19
0.13
0.13
0.093
0.093
0.075
0.063
0.057
15
13
11
10
5.6
2,930
2,930
3,450
3,610
250
250
400
640
840
865
1,050
1,300
1,400
1,650
1,900
2,230
2,930
2,930
3,450
3,610
30
43
53
88
100
180
250
295
295
555
730
760
910
1,050
1,220
1,440
1,660
1,660
1,950
2,555
2,555
3,010
3,150
173
173
278
500
665
725
820
950
1,200
1,350
1,570
1,570
1,990
1,990
2,730
2,850
2,900
40
65
125
Part No.
EKYA250E□□332ML25S
EKYA250E□□392ML25S
EKYA250E□□472MLN3S
EKYA250E□□562MLP1S
EKYA350E□□330ME11D
EKYA350E□□470ME11D
EKYA350E□□101MF11D
EKYA350E□□221MHB5D
EKYA350E□□271MH15D
EKYA350E□□331MJC5S
EKYA350E□□391MH20D
EKYA350E□□471MJ16S
EKYA350E□□681MJ20S
EKYA350E□□821MJ25S
EKYA350E□□102MK20S
EKYA350E□□152MK25S
EKYA350E□□222ML25S
EKYA350E□□272ML25S
EKYA350E□□332MLN3S
EKYA350E□□392MLP1S
EKYA500E□□1R0ME11D
EKYA500E□□2R2ME11D
EKYA500E□□3R3ME11D
EKYA500E□□4R7ME11D
EKYA500E□□100ME11D
EKYA500E□□220ME11D
EKYA500E□□270ME11D
EKYA500E□□470MF11D
EKYA500E□□560MF11D
EKYA500E□□101MHB5D
EKYA500E□□151MH15D
EKYA500E□□181MJC5S
EKYA500E□□181MH20D
EKYA500E□□221MJ16S
EKYA500E□□331MJ20S
EKYA500E□□471MJ25S
EKYA500E□□471MK20S
EKYA500E□□561MK20S
EKYA500E□□821MK25S
EKYA500E□□102ML25S
EKYA500E□□122ML25S
EKYA500E□□182MLN3S
EKYA500E□□222MLP1S
EKYA630E□□100ME11D
EKYA630E□□150ME11D
EKYA630E□□330MF11D
EKYA630E□□560MHB5D
EKYA630E□□820MH15D
EKYA630E□□101MJC5S
EKYA630E□□121MH20D
EKYA630E□□121MJ16S
EKYA630E□□221MJ20S
EKYA630E□□331MJ25S
EKYA630E□□331MK20S
EKYA630E□□391MK20S
EKYA630E□□471MK25S
EKYA630E□□561MK25S
EKYA630E□□102ML25S
EKYA630E□□122MLN3S
EKYA630E□□152MLP1S
EKYA101E□□1R0ME11D
EKYA101E□□2R2ME11D
EKYA101E□□3R3ME11D
EKYA101E□□4R7ME11D
EKYA101E□□6R8ME11D
□□ : Enter the appropriate lead forming or taping code.
are not recommended for new designs (NRND).
The products shown in
Low impedance, 105℃
KYASeries
◆STANDARD RATINGS
WV
(Vdc)
Cap
(µF)
Case size
φD×L(mm)
20℃
100
10
6.3×11
15
6.3×11
27
8×11.5
39
8×15
47
10×12.5
56
8×20
68
10×16
100
10×20
150
10×25
180 12.5×20
220 12.5×25
330
16×25
470
16×31.5
560
16×35.5
Rated
ripple
current
(mArms/
-10℃ 105℃,
100kHz)
Impedance
(Ω max./100kHz)
0.57
0.57
0.36
0.25
0.17
0.19
0.11
0.084
0.069
0.062
0.047
0.038
0.032
0.029
2.3
2.3
1.4
1.0
0.66
0.76
0.47
0.34
0.28
0.18
0.14
0.12
0.095
0.086
205
205
355
450
480
565
600
800
900
1,100
1,250
1,700
1,850
2,000
Part No.
EKYA101E□□100MF11D
EKYA101E□□150MF11D
EKYA101E□□270MHB5D
EKYA101E□□390MH15D
EKYA101E□□470MJC5S
EKYA101E□□560MH20D
EKYA101E□□680MJ16S
EKYA101E□□101MJ20S
EKYA101E□□151MJ25S
EKYA101E□□181MK20S
EKYA101E□□221MK25S
EKYA101E□□331ML25S
EKYA101E□□471MLN3S
EKYA101E□□561MLP1S
◆RATED RIPPLE CURRENT MULTIPLIERS
・Frequency Multipliers
Frequency(Hz)
Capacitance(µF)
1.0
220
680
2,200
4,700
to
to
to
to
to
180
560
1,800
3,900
120
0.40
0.50
0.60
0.75
0.85
1k
0.75
0.85
0.87
0.90
0.95
10k
0.90
0.94
0.95
0.95
0.98
100k
1.00
1.00
1.00
1.00
1.00
The deterioration of aluminum electrolytic capacitors accelerates their life due to the internal heating produced by ripple current. For details, refer
to Section "5-3 Ripple Current Effect on Lifetime" in the catalog, Technical Note.
