SOT-89Plastic-Encapsulate Transistors
SS8050 TRANSISTOR (NPN)
FEATURES
Compliment to SS8550
MARKING: Y1
MAXIMUM RATINGS (Ta=25℃ unless otherwise noted)
Symbol
Parameter
Value
Unit
VCBO
Collector-Base Voltage
40
V
VCEO
Collector-Emitter Voltage
25
V
VEBO
Emitter-Base Voltage
5
V
IC
Collector Current -Continuous
1.5
A
PC
Collector Power dissipation
0.5
W
RΘJA
Thermal Resistance From
Junction To Ambient
250
℃/W
TJ
Storage Temperature
150
Tstg
Storage Temperature
-55~150
ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified)
Parameter
Symbol
Test conditions
Min
Typ
Max
Unit
Collector-base breakdown voltage
V(BR)CBO
IC=100uA, IE=0
40
V
Collector-emitter breakdown voltage
V(BR)CEO
IC=0.1mA, IB=0
25
V
Emitter-base breakdown voltage
V(BR)EBO
IE=100μA, IC=0
5
V
Collector cut-off current
ICBO
VCB=40V, IE=0
0.1
μA
Emitter cut-off current
ICEO
VCE=20V, IE=0
0.1
μA
IEBO
VEB=5V, IC=0
0.1
μA
hFE(1)
VCE=1V, IC=100mA
120
hFE(2)
VCE=1V, IC=800mA
40
Collector-emitter saturation voltage
VCE(sat)
IC=800mA, IB=80mA
0.5
V
Base-emitter saturation voltage
VBE(sat)
IC=800mA, IB=80mA
1.2
V
1
V
1.55
V
DC current gain
Base-emitter voltage
VBE
VCE=1V, IC=10mA
Base-emitter positive favor voltage
VBEF
IB=1A
fT
Transition frequency
Cob
output capacitance
VCE=10V,IC=50mA,f=30MHz
400
100
VCB=10V,IE=0,f=1MHz
MHz
15
CLASSIFICATION OF hFE(1)
Rank
Range
C
D
D1
120-200
160-300
1
200-350
D2
300-400
pF
Static Characteristic
0.30
h
DC CURRENT GAIN
0.8mA
0.20
0.7mA
0.6mA
0.15
0.5mA
0.4mA
0.10
IC
Ta=100℃
FE
0.9mA
IC(A)
COLLECTOR CURRENT
COMMON
EMITTER
Ta=25℃
1mA
0.25
hFE
1000
300
Ta =25℃
100
0.3mA
0.2mA
0.05
COMMON EMITTER
VCE
= 1V
IB=0.1mA
0.00
2
3
4
5
COLLECTOR-EMITTER VOLTAGE
VCEsat
10
7
1
10
100
1000 1500
COLLECTOR CURRENT I (mA)
C
IC
VBEsat ——
1200
IC
BASE-EMITTER SATURATION
VOLTAGE V
(mV)
1000
Ta=100 ℃
Ta=25℃
10
1
800
Ta=25℃
BEsat
100
CEsat
COLLECTOR-EMITTER SATURATION
VOLTAGE V
(mV)
1000
6
V CE (V)
600
Ta=100 ℃
400
β=10
1
10
100
β=10
1000 1500
1
10
I
C
VBE
Cob/C
ib
100
VCB/VEB
f=1MHz
IE=0/I C=0
1000
Ta=25 ℃
(pF)
(mA)
Cib
IC
100
CAPACITANCE C
COLLECTOR CURRENT
1000 1500
COLLECTOR CURREMT I (mA)
C
C
1500
100
10
Cob
10
COMMON EMITTER
VCE
= 1V
1
0.1
1200
IC
1
REVERSE VOLTAGE
PC
0.6
100
C
fT(MHz)
600
fT
1000
TRANSITION FREQUENCY
300
BESE-EMMITER VOLTAGE V (mV)
BE
COLLECTOR POWER DISSIPATION
P (W)
1
10
COMMON EMITTER
VCE
=10V
—— T
V
(V)
10
a
0.5
0.4
0.3
0.2
0.1
Ta=25℃
1
2
10
COLLECTOR CURRENT
IC
(mA)
0.0
100
2
50
75
100
AMBIENT TEMPERATURE T (℃)
a
125
150
SS8050
SOT-89 PACKAGE OUTLINE
3
很抱歉,暂时无法提供与“SS8050 Y1”相匹配的价格&库存,您可以联系我们找货
