1N4001G THRU 1N4007G
Reverse Voltage - 50 to 1000 Volts
Forward Current - 1.0 Ampere
GLASS PASSIVATED RECTIFIER
Features
DO-41/A-405
Flammability Classification 94V-0
Construction utilizes void-free
molded plastic technique
Low reverse leakage
Glass passivated junction
1.0 (25.4)
MIN.
0.107 (2.7)
0.080 (2.3)
DIA.
High forward surge current capability
High temperature soldering guaranteed
250℃/ 10 seconds at terminals
0.205(5.2)
0.166(4.2)
Mechanical Data
1.0 (25.4)
MIN.
Case : JEDEC DO-41 Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Color band denotes cathode end
Mounting Position : Any
Weight : 0.012 ounce, 0.33 grams
0.025 (0.65)
0.021 (0.55)
DIA.
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL=110℃
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
Maximum instantaneous forward voltage at 1.0A
Maximum DC reverse current
at rated DC blocking voltage
TA=25℃
TA=100℃
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction and storage temperature range
MDD
MDD
MDD
MDD
MDD
MDD
MDD
1N4001G 1N4002G 1N4003G 1N4004G 1N4005G 1N4006G 1N4007G
VRMM
50
VRMS
VDC
35
50
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
UNITS
V
V
V
I(AV)
1.0
A
IFSM
30
A
VF
1.10
5.0
50.0
V
IR
μA
CJ
RθJA
15.0
pF
50.0
TJ,TSTG
-65 to +150
℃/W
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.Thermal resistance from junction to ambient at 0.375 (9.5mm)lead
length,P.C.B. mounted
DN:T22407A1
http://www.microdiode.com
Rev:2022A1
Page :1
FIG. 1- FORWARD CURRENT DERATING CURVE
1.0
0.8
0.6
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
0.4
0.2
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
Ratings And Characteristic Curves
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
30
25
10
175
5.0
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
NUMBER OF CYCLES AT 60 Hz
1
TJ=25 C
PULSE WIDTH=300 µs
1%DUTY CYCLE
0.01
0.6
0.8
1.0
1.2
1.4
1.5
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MICROAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
0.1
1,000
100
TJ=100 C
1
0.1
TJ=25 C
0.01
60
80
100
200
TJ=25 C
10
TRANSIENT THERMAL IMPEDANCE,
C/W
PERCENT OF PEAK REVERSE VOLTAGE,%
FIG. 5-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE, pF
TJ=150 C
10
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
100
100
10
AMBIENT TEMPERATURE, C
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
1
0.1
1.0
10
REVERSE VOLTAGE,VOLTS
100
t,PULSE DURATION,sec.
The curve above is for reference only.
Rev:2022A1
Page :2
很抱歉,暂时无法提供与“1N4007G”相匹配的价格&库存,您可以联系我们找货
