1000 Eaton Boulevard
Cleveland, OH 44122
United States
±120VDC External Battery Cabinet for Select 1030K S3M-Series 3-Phase UPS - 20x 40Ah VRLA
(AGM) Batteries
Highlights
Ideal for IT applications
requiring high capacity, high
availability and longer runtime
Supports daisy-chaining to
additional battery packs of same
model for even more runtimes
Steel cabinet with locking front
door for easy access to
recyclable VRLA (AGM)
batteries
Fuses and output breaker
protect against potentially
hazardous overcurrent
Pre-installed rolling casters
allow easy adjustment at
installation location
MODEL NUMBER: BP240V40
Applications
Extend the runtime of your
compatible Tripp Lite UPS
system to maintain operation
during all power conditions
Daisy-chain to additional battery
cabinets to provide even longer
extended-run operation for
backing up essential equipment
External battery pack provides extended backup runtime for select Tripp Lite 10-30K S3M-Series 3-phase
UPS systems.
Features
System Requirements
±120VDC External Batteries Give Your Compatible 3-Phase UPS Extended Runtime
This external battery pack connects to a compatible SmartOnline® S3M-Series 3-phase UPS system to
provide long-lasting battery backup for data centers, telecommunications, networks, industrial facilities,
security, emergency systems and other mission-critical applications that require high capacity, high
availability and extended runtime. In addition to battery backup and extended runtime, the BP240V40 can
also be daisy-chained to other external battery cabinets for even longer extended-run operation.
Rugged Steel Construction Designed to Last in Demanding IT Applications
The cabinet is made from heavy-gauge steel with a baked powder-coated finish that helps prevent
chipping and corrosion. The hinged front door provides easy access to the recyclable internal batteries.
The door locks securely to help prevent damage, tampering or theft. Fuses and output breaker protect
against potentially hazardous overcurrent.
Ships Ready for Immediate Deployment
Pre-installed rolling casters allow easy adjustment at the installation location. Adjustable levelers support
secure long-term deployment on a stable surface. Includes heavy-gauge cabling with high-current DC
connectors for simple installation with 10-20K UPS models. Battery cables feed into the cabinet through
conduit knockouts built into the bottom panel.
Specifications
OVERVIEW
UPC Code
037332257703
INPUT
1/2
3-phase 208V UPS models
S3M10K-NIB, S3M15K-NIB,
S3M20K-NIB, S3M25K, S3M30K
or other UPS specifying
compatibility
Package Includes
BP240V40 External Battery
Cabinet for Select 10-30K S3MSeries 3-Phase UPS
(2) Battery cables, 3 m
Owner’s manual
Cleveland, OH 44122
United States
Input Phase
3-Phase
BATTERY
Expandable Runtime
Yes
DC System Voltage (VDC)
+/- 120VDC
UPS Connection
Hardwire (contractor supplies wiring - see Owner's Manual for gauge recommendations and complete installation
instructions)
PHYSICAL
Material of Construction
Steel
Rack Height
0U
External Battery Pack Form Factor
Tower
Installation Form Factors Supported
with Included Accessories
Tower
Shipping Dimensions (hwd / in.)
55.60 x 22.20 x 38.20
Shipping Weight (kg)
375.30
Unit Dimensions (hwd / in.)
47.200 x 17.400 x 33.500
Unit Dimensions (hwd / cm)
119.89 x 44.2 x 85.09
Unit Weight (lbs.)
728.1
Unit Weight (kg)
330.26
STANDARDS & COMPLIANCE
Product Compliance
RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“BP240V40”相匹配的价格&库存,您可以联系我们找货
