1000 Eaton Boulevard
Cleveland, OH 44122
United States
±120VDC External Battery Cabinet for Select 1050K S3M-Series 3-Phase UPS - Requires 40x
40Ah Batteries (Not Included)
Highlights
Ideal for IT applications
requiring high capacity, high
availability and longer runtime
Supports daisy-chaining to
additional battery packs of same
model for even more runtime
Steel cabinet with locking door
for easy access to user-installed
VRLA (AGM) batteries
Fuses and output breaker
protect against potentially
hazardous overcurrent
Pre-installed rolling casters
allow easy adjustment at
installation location
MODEL NUMBER: BP240V40L-NIB
Applications
Extend the runtime of your
compatible Tripp Lite UPS
system to maintain operation
during all power conditions
Daisy-chain to additional battery
cabinets to provide even longer
extended-run operation for
backing up essential equipment
Customize your application with
the internal batteries of your
choice
External battery pack provides extended backup runtime for select Tripp Lite 10-50K S3M-Series 3-phase
UPS systems.
Features
±120VDC Battery Cabinet Gives Your Compatible 3-Phase UPS Extended Runtime
This external battery pack connects to a compatible SmartOnline® S3M-Series 3-phase UPS system to
provide long-lasting battery backup for data centers, telecommunications, networks, industrial facilities,
security, emergency systems and other mission-critical applications that require high capacity, high
availability and extended runtime. In addition to battery backup and extended runtime, the BP240V40LNIB can also be daisy-chained to other external battery cabinets for even longer extended-run operation.
Rugged Steel Construction Designed to Last in Demanding IT Applications
The cabinet is made from heavy-gauge steel with a baked powder-coated finish that helps prevent
chipping and corrosion. The hinged front door provides easy access to the user-installed internal batteries.
The door locks securely to help prevent damage, tampering or theft. Fuses and output breaker protect
against potentially hazardous overcurrent.
Ships Ready for Immediate Battery Installation
Pre-installed rolling casters allow easy adjustment at the installation location. Adjustable levelers support
secure long-term deployment on a stable surface. All required internal battery cabling is included. External
battery cables feed into the cabinet through conduit knockouts built into the bottom panel.
Specifications
OVERVIEW
UPC Code
037332257710
1/2
System Requirements
3-phase 208V UPS models
S3M10K-NIB, S3M15K-NIB,
S3M20K-NIB, S3M25K, S3M30K,
S3M50K or other UPS specifying
compatibility
Package Includes
BP240V40L-NIB External
(2) External battery cables, 3 m
(16) Internal battery cables
(28) Copper jumper bars
Owner’s manual
Cleveland, OH 44122
United States
INPUT
Input Phase
3-Phase
BATTERY
Expandable Runtime
Yes
DC System Voltage (VDC)
+/- 120VDC
UPS Connection
Hardwire (contractor supplies wiring - see Owner's Manual for gauge recommendations and complete installation
instructions)
PHYSICAL
Material of Construction
Steel
Rack Height
0U
External Battery Pack Form Factor
Tower
Installation Form Factors Supported
with Included Accessories
Tower
Shipping Dimensions (hwd / in.)
71.10 x 28.90 x 38.80
Shipping Weight (kg)
201.17
Unit Dimensions (hwd / in.)
63.000 x 23.600 x 33.500
Unit Dimensions (hwd / cm)
160 x 60 x 85
Unit Weight (lbs.)
346.4
Unit Weight (kg)
157.12
STANDARDS & COMPLIANCE
Product Compliance
RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“BP240V40L-NIB”相匹配的价格&库存,您可以联系我们找货
