1000 Eaton Boulevard
Cleveland, OH 44122
United States
Safe-IT Conference Power Surge Protector, 4
Rotating 5-15R Outlets, USB-C & 3 USB-A Ports,
10 ft. (3 m) Cord, Antimicrobial Protection
Highlights
4 NEMA 5-15R rotating outlets
designed to accommodate bulky
transformers
1080 joules protect your
valuable electronics against
dangerous surges and spikes
4 USB ports supply power for
fast charging of phones, tablets
and other mobile devices
Built-in Micro-USB cord powers
Echo Dot, Google Mini or other
smart speaker
Antimicrobial protection helps
resist the growth of bacteria,
viruses, fungi, mold and mildew
MODEL NUMBER: TLP410UCUFOAM
Package Includes
Safely charges and powers up to 8 devices, including laptops and tablets, during important workplace
meetings and conferences.
Features
Keep Your Team’s Devices Powered and Charged During Important Meetings
Workplace meetings involve a variety of devices – laptops, smartphones, tablets – to keep everyone
coordinated and up to date with the information necessary to make important decisions. Guaranteeing
those devices remain charged and powered is this Safe-IT™ Conference Power Surge Protector.
Rounded to ensure equal access to everyone at the table, this UL-certified surge protector delivers ample
power and reliable protection to as many as eight mobile devices at the same time.
NEMA 5-15R Outlets Accept a Wide Range of Electronic Devices
Plug your laptops, projector, printer and other conference-table electronics into four NEMA 5-15R outlets
to protect them against dangerous surges, spikes and line noise. Each rotating outlet is located far
enough apart from the others to accept bulky transformers without blocking adjacent outlets.
4 USB Ports Provide Plenty of Charging Power
One USB-C and three USB-A ports are available for charging your smartphones, tablets and other USB
mobile devices. The USB-A ports share 4.8A of charging power, which is plenty for delivering ample
power to demanding devices. The USB-C charging port supplies up to 3A.
Keeps Your Smart Speaker Fully Powered and at Your Disposal
A center device cradle is specially designed to fit an Amazon Echo Dot, Google Nest Mini or other smart
speaker that allows access to instant information, external team members or just a little light thinking
music. A built-in Micro-USB cable keeps the speaker powered.
1080 Joules Safeguard Your Sensitive Electronics
This surge protector features a surge suppression rating of 1080 joules to defend your sensitive electronic
components against even the strongest power surges and spikes. Because residential power outlets have
three wires—hot line (H), neutral (N) and ground (G)—the TLP410UCUFOAM protects all three, covering
the two protection modes: full normal mode (H-N) and common mode (N-G/H-G).
Filtering EMI/RFI Line Noise Helps Your Equipment Perform Better
This surge protector filters out disruptive electromagnetic and radio frequency interference that can inflict
1/4
TLP410UCUFOAM Conference
Owner’s manual
Cleveland, OH 44122
United States
hardware damage or data loss. This EMI/RFI filtering also helps your connected components perform
better and last longer.
Antimicrobial Protection Helps Provide a Safer, Cleaner and Healthier Work Environment
The Safe-IT TLP410UCUFOAM features antimicrobial protection that helps resist the growth of bacteria,
viruses, fungi, mold and mildew.
Premium Safety Features Protect Your Valuable Equipment
The on/off switch provides one-touch control over all connected equipment. Automatic shutoff
permanently cuts power to outlets if protection circuit is incapacitated, preventing equipment damage and
indicating replacement is required. A green LED confirms your connected equipment is protected.
Versatile Surge Protector Provides Flexible Installation Options
A 10-foot cord with NEMA 5-15P plug is long enough to give you plenty of options for placing the unit
away from a wall outlet.
Specifications
OVERVIEW
UPC Code
037332265777
Device Compatibility
Phone; Tablet
INPUT
Nominal Input Voltage(s) Supported
120V AC
Recommended Electrical Service
120V
Input Plug Features
Right Angle (36D)
Input Cord Gauge Type
14 gauge
Voltage Compatibility (VAC)
120
Input Plug Type
NEMA 5-15P
Input Cord Length (ft.)
10
Right-Angle Plug
No
Input Cord Length (m)
3.05
Integrated Cord Clip
No
OUTPUT
Frequency Compatibility
60 Hz
Output Receptacles
(4) 5-15R
Circuit Breaker (amps)
15
Overload Protection
Yes (2-in-1 switch)
Transformer Accommodation
(4) Yes
Right-Angle Outlets
No
2/4
Cleveland, OH 44122
United States
USER INTERFACE, ALERTS & CONTROLS
Diagnostic LED(s)
Yes
Diagnostic LED Details
Yes
CHARGING
Number of Charging Ports
4
Total Charging Amps
4.8A
Total Charging Watts
24
Charging Method
USB
Charging Port Type
(3) USB A (FEMALE); (1) USB C (FEMALE)
Charging Ports / Amps
(3) 2.4A; (1) 3A
Overcharge Protection
No
SURGE / NOISE SUPPRESSION
AC Suppression Joule Rating
1080
AC Suppression Response Time
< 1 ns
Protection Modes
Includes full normal mode (H-N) and common mode (N-G / H-G) line suppression
UL1449 Let Through Rating
500, 500, 600
EMI / RFI Filtering
Yes
Immunity
Conforms to IEE 587/ANSI C62.41
Automatic Shut-Off
Yes
DATALINE SURGE SUPPRESSION
Cable (Coax) Protection
No
Network (Ethernet) Protection
No
Telephone/DSL Protection
No
PHYSICAL
Material of Construction
Plastic
Power Cord Color
White
Mounting Holes or Slots
No
Receptacle Color
White
Unit Dimensions (hwd / in.)
7.720 x 7.060 x 1.900
Unit Dimensions (hwd / cm)
19.3 x 17.6 x 4.9
Unit Weight (lbs.)
1.87
Unit Weight (kg)
0.85
3/4
Cleveland, OH 44122
United States
FEATURES & SPECIFICATIONS
Rotatable Outlets
No
Antimicrobial
Yes
GaN Technology
No
STANDARDS & COMPLIANCE
Product Certifications
CAN/CSA-C22.2 No. 269.3 (Canada); CAN/CSA-C22.2 No. 308 (Canada); UL 1449; UL 1363
Product Compliance
RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
$100,000 Ultimate Lifetime
Insurance
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“TLP410UCUFOAM”相匹配的价格&库存,您可以联系我们找货
