ELECTRIC DOUBLE LAYER CAPACITOR
Low
DKA series
TM
DLCAP
Resistance
-40
RoHS2
+70
Compliant
・Increase flexibility of module design.
・Space saving with smaller volume when moduled.
・Very low DCIR even at low and high temperature.
◆ SPECIFICATIONS
Items
Specifications
Operating Temperature
-40℃ ~ +70℃
Capacitance Tolerance
±10% (K)
Temperature Characteristics
Capacitance Change
≦ ±30% of the measured value at 20℃
Internal Resistance Change
≦ 600% of the internal resistance maximum value given in the ratings tables
Load Life Test
(25℃ )
(-40℃ )
After the capacitors are subjected to the rated DC voltage at 70℃ for 1000 hours, the following
specifications shall be satisfied when they are restored to 20℃ .
Capacitance Change
≦ ±30% of the initial measured value at 20℃
≦ 200% of the internal resistance maximum value given in the ratings tables
After the capacitors are subjected to the rated DC voltage at 60℃ for 2000 hours, the following specifications shall be
Bias Humidity Test
Capacitance Change
After the capacitors are left at 40℃ and 90 to 95%RH for 500 hours, the following specifications shall be satisfied when they
Capacitance Change
◆ STANDARD RATINGS
● DKA series
Capacitance
Nominal Case Size
Internal Resistance
Rated Voltage
[V]
Typ. (rated) [F]
φ D [mm]
L [mm]
Typ. [mΩ]
2.5
50
18
50
11.0
Max. [mΩ]
Weight*1
[g]
Energy Storage
[Wh]
Part No.
13.2
18
0.04
DDKA2R5ELL500KM50S
* 1 Reference data
◆ PART NUMBERING SYSTEM
1
2
3
4
D DKA
5
6
7
8
AAA E
9
10
11
12
13
14
15
16
17
AAA K AAA
18
G
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 50F:500)
Lead forming code
Terminal code
Voltage code (ex. 2.5V:2R5)
Series code
Category
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
4
CAT. No. E1009G
DKA series
TM
DLCAP
◆ DIMENSIONS [mm]
Sleeve (PET)
φD+0.5Max.
φd
F±0.5
L+0.5Max.
Vent
20Min.
3Min.
Do not use sealing rubber's orientation of this drawing to identify polarity of the actual part.
Orientation of sealing rubber and safety vent are not associated.
Part No.
DDKA2R5ELL500KM50S
φD [mm]
18
L [mm]
50
F [mm]
7.5
φd [mm]
0.8
120
100
100
80
80
DCIR [mΩ]
⊿Cap [% vs (at20℃)]
◆ Temperature Dependance of Capacitance & DCIR
60
40
60
40
DKAφ18×50L
-40
-20
Temp [℃]
60
80
100
-20
Temp [℃]
60
80
100
◆ 70℃ Load Life Test
2.5V 70℃
-20
-30
2.5V 70℃
25
DCIR [mΩ]
⊿Cap [%]
-10
-40
-50
DKAφ18×50L
30
10
5
1000
1000
1500
Time [hrs]
Time [hrs]
◆ 60℃ Load Life Test
2.5V 60℃
-20
-30
2.5V 60℃
25
DCIR [mΩ]
⊿Cap [%]
-10
-40
-50
DKAφ18×50L
30
10
5
1000
1500
Time [hrs]
2000
2500
1000
1500
Time [hrs]
2000
2500
3000
5
CAT. No. E1009G
很抱歉,暂时无法提供与“DDKA2R5ELL500KM50S”相匹配的价格&库存,您可以联系我们找货
