1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartRack 45U Standard-Depth 4-Post Premium
Open Frame Rack
MODEL NUMBER: SR45UBEXPND
Highlights
45U SmartRack Premium open
frame rack
4 interior vertical posts with
unthreaded square hole
openings
Standard 24" (600mm) width
and 42" (1050mm) depth for
optimizing floor space
Ships fully assembled
3000 lbs (1360.8 kgs) stationary
/ 2250 lbs (1020.6 kgs) rolling
load capacity
Preinstalled casters and leveling
feet
Includes 50 pieces of M6 cage
nuts and 50 pieces of M6
screws (equipment mounting
hardware)
Package Includes
4-Post Premium Open Frame
Rack
Owner's manual
Description
The SmartRack 45U Standard-Depth 4-Post Premium Open Frame Rack has NO doors and NO side
panels. The 'EXP' version is an expansion model used when several cabinets are bayed together. Its
integrated baying tabs make it easy to combine multiple enclosures in rows for data center applications.
This enclosure is also compatible with hot-aisle/cold-aisle configurations.
The SR45UBEXPND houses 3000 lbs (1360.8 kgs) of standard 19-inch rack equipment in 45U. Its front
and rear pairs of vertical rails have square mounting holes that are adjustable in quarter-inch increments
from 4 to 37 inches. Adjustment is quick and an easy-view depth index ensures consistent rail placement
without requiring time-consuming measurements. Each rack space within the enclosure is numbered for
ready reference.
Two of the adjustable vertical mounting rails support toolless button-mount 0U installation of up to four
compatible PDUs and cable managers. This feature makes it easier to route cabling to rack equipment
and reduces cord clutter.
All components of the SR45UBEXPND are grounded to the enclosure frame. Front and rear threaded
grounding points are provided for connection to the facility earth ground.
To simplify deployment, the SR45UBEXPND comes with preinstalled casters that enable it to be easily
maneuvered into the desired location, where it can be secured by adjusting the preinstalled levelers. Note:
the casters are intended for minor position adjustments and are not designed for moving the enclosure
over long distances.
The SR45UBEXPND comes with a 5-year product warranty. As part of the SmartRack family, the
SR45UBEXPND is compatible with Tripp Lite's extensive range of rackmount accessories, enabling you to
customize your solution to meet any requirement.
Features
Ships fully assembled for rapid deployment and roll into place on heavy-duty pre-installed casters
(casters are removable)
Front and rear sets of equipment mounting rails adjust in 1/4" increments. Adjustment is quick and
convenient. The easy-view depth index ensures consistent rail placement without requiring timeconsuming measurements.
Toolless accessory mounting rails (2 rails per enclosure) include slots for quick installation of compatible
PDUs and vertical cable managers. Mounting slots are arranged in an industry-standard pattern
compatible with a wide variety of accessories. Each rail can accommodate two vertical PDUs or cable
managers side-by-side (four items per enclosure).
Mounting hardware of 50 pieces of M6 cage nuts and 50 pieces of M6 screws included
Textured powder coat finish for tough resistance to environmental concerns such as deployment in
1/3
Cleveland, OH 44122
United States
warehouses
Maximum usable internal depth of 37 inches/94 cm (front to rear rail).
Weight ratings of 3000 lbs (1360.8 kgs) stationary and 2250 lbs (1020.6 kgs) rolling.
Built in baying tabs allow premium open frame racks to be combined securely in rows. Center-to-center
width can be set at 600mm or 24" to match standard data center floor tiles.
Leveling feet extend to allow premium open frame racks to be positioned on uneven floors. Levelers are
removable.
Convenient grounding system. All components are grounded to the premium open frame rack structure
which includes multiple connections for facility ground.
Open bottom for cable access.
Included stabilizing brackets are used for shipment and can be reattached at the bottom of the premium
open frame rack on the inside or outside of the rack.
Compatibility with all cable management accessories.
Specifications
OVERVIEW
UPC Code
037332174567
Device Compatibility
Patch Panel; Network Switch; UPS; Server
Rack Type
Open-Frame
PHYSICAL
Color
Black
Rack Height
45U
Rack Depth
Standard
Maximum Device Depth (cm)
93.98
Maximum Device Depth (in.)
37
Maximum Device Depth (mm)
940
Minimum Device Depth (cm)
10.16
Minimum Device Depth (in.)
4
Minimum Device Depth (mm)
102
Shipping Dimensions (hwd / in.)
90.50 x 26.00 x 45.00
Shipping Dimensions (hwd / cm)
229.87 x 66.04 x 114.30
Shipping Weight (lbs.)
197.00
Shipping Weight (kg)
89.36
Unit Dimensions (hwd / in.)
83.750 x 23.630 x 43.000
Unit Dimensions (hwd / cm)
212,725 x 60,02 x 109,22
Unit Weight (lbs.)
147
Unit Weight (kg)
66.68
2/3
Cleveland, OH 44122
United States
Weight Capacity - Rolling (kg)
1,021
Weight Capacity - Rolling (lbs.)
2250
Weight Capacity - Stationary (kg)
1,361
Weight Capacity - Stationary (lbs.)
3000
Number of Vertical Mounting Rails
4
FEATURES & SPECIFICATIONS
Grounding Lug
Front and Back door frames
Pre-Installed Casters
Yes
STANDARDS & COMPLIANCE
Product Certifications
UL 60950-1
Product Compliance
RoHS; CE (Europe)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“SR45UBEXPND”相匹配的价格&库存,您可以联系我们找货
