1000 Eaton Boulevard
Cleveland, OH 44122
United States
45U SmartRack 4-Post Mid-Depth Open Frame
Rack
MODEL NUMBER: SR45UBMDEXPND
Description
The SR45UBMDEXPND is part of our new line of mid-depth rack enclosures. Our new line offers 36"
(927mm) depth opposed to the standard 42" (1050mm).
The SR45UBMDEXPND is a 45U SmartRack enclosure with NO doors and NO side panels. The 'EXP'
version is an expansion model used when several cabinets are bayed together. Its integrated baying tabs
make it easy to combine multiple enclosures in rows for data center applications. This enclosure is also
compatible with hot-aisle/cold-aisle configurations.
The SR45UBMDEXPND houses 3000 lbs (1360.8 kgs) of standard 19-inch rack equipment in 45U. Its
front and rear pairs of vertical rails have square mounting holes that are adjustable in quarter-inch
increments from 4 to 28.75 inches. Adjustment is quick and an easy-view depth index ensures consistent
rail placement without requiring time-consuming measurements. Each rack space within the enclosure is
numbered for ready reference.
Two of the adjustable vertical mounting rails support toolless button-mount 0U installation of up to four
compatible PDUs and cable managers. This feature makes it easier to route cabling to rack equipment
and reduces cord clutter.
All components of the SR45UBMDEXPND are grounded to the enclosure frame. Front and rear threaded
grounding points are provided for connection to the facility earth ground.
To simplify deployment, the SR45UBMDEXPND comes with preinstalled casters that enable it to be easily
maneuvered into the desired location, where it can be secured by adjusting the preinstalled levelers. Note:
the casters are intended for minor position adjustments and are not designed for moving the enclosure
over long distances.
The SR45UBMDEXPND comes with a 5-year product warranty. As part of the SmartRack family, the
SR45UBMDEXPND is compatible with Tripp Lite's extensive range of rackmount accessories, enabling
you to customize your solution to meet any requirement.
Features
Ships fully assembled for rapid deployment and roll into place on pre-installed casters, allowing the
enclosures to be pre-configured and rolled to the final installation location. Casters are removable.
Front and rear sets of equipment mounting rails adjust in 1/4" increments. Adjustment is quick and
convenient. The easy-view depth index ensures consistent rail placement without requiring timeconsuming measurements.
Tool-less accessory mounting rails (2 rails per enclosure) include slots for quick installation of
compatible PDUs and vertical cable managers. Mounting slots are arranged in an industry-standard
pattern compatible with a wide variety of accessories. Each rail can accommodate two vertical PDUs or
cable managers side-by-side (four items per enclosure).
Enclosure includes mounting hardware of 50 pieces of M6 cage nuts and 50 pieces of M6 screws
1/3
Highlights
45U SmartRack Premium open
frame rack
36" (927mm) depth (with
mounting depth increments from
4 to 28.75") and standard 24"
(600mm) width
4 interior vertical posts with
unthreaded square hole
openings
3000 lbs (1360.8 kgs) stationary
/ 2250 lbs (1020.6 kgs) rolling
load capacity
Preinstalled casters and leveling
feet
Includes 50 pieces of M6 cage
screws (equipment mounting
hardware)
Cleveland, OH 44122
United States
Textured powder coat finish for tough resistance to environmental concerns such as deployment in
warehouses.
Maximum usable internal depth of 31 inches/79 cm (front to rear frame).
Weight ratings of 3000 lbs (1360.8 kgs) stationary and 2250 lbs (1020.6 kgs) rolling.
Built in baying tabs allow premium open frame racks to be combined securely in rows. Center-to-center
width can be set at 600mm or 24" to match standard data center floor tiles.
Leveling feet extend to allow premium open frame racks to be positioned on uneven floors. Levelers are
removable.
Convenient grounding system. All components are grounded to the premium open frame rack structure
which includes multiple connections for facility ground.
Open bottom for cable access.
Included stabilizing brackets are used for shipment and can be reattached at the bottom of the premium
open frame rack on the inside or outside of the rack.
Compatibility with all cable management accessories.
Specifications
OVERVIEW
UPC Code
037332174765
Device Compatibility
Patch Panel; Network Switch; UPS
Rack Type
Open-Frame
PHYSICAL
Color
Black
Rack Height
45U
Rack Depth
Mid
Maximum Device Depth (cm)
78.74
Maximum Device Depth (in.)
31
Maximum Device Depth (mm)
787
Minimum Device Depth (cm)
10.16
Minimum Device Depth (in.)
4
Minimum Device Depth (mm)
102
Shipping Dimensions (hwd / in.)
90.25 x 26.00 x 37.80
Shipping Dimensions (hwd / cm)
229.24 x 66.04 x 96.01
Shipping Weight (lbs.)
190.00
Shipping Weight (kg)
86.18
Unit Dimensions (hwd / in.)
83.750 x 23.630 x 36.000
Unit Dimensions (hwd / cm)
212.725 x 60.02 x 91.44
Unit Weight (lbs.)
140
2/3
Cleveland, OH 44122
United States
Unit Weight (kg)
63.50
Weight Capacity - Rolling (kg)
1,021
Weight Capacity - Rolling (lbs.)
2250
Weight Capacity - Stationary (kg)
1,361
Weight Capacity - Stationary (lbs.)
3000
Number of Vertical Mounting Rails
4
FEATURES & SPECIFICATIONS
Grounding Lug
Front and Back door frames
Built-in Cable Management
No
Extra Wide
No
Pre-Installed Casters
Yes
STANDARDS & COMPLIANCE
Product Certifications
UL 60950-1
Product Compliance
RoHS; CE (Europe); UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“SR45UBMDEXPND”相匹配的价格&库存,您可以联系我们找货
