1000 Eaton Boulevard
Cleveland, OH 44122
United States
45U SmartRack Wide Standard-Depth Rack
Enclosure Cabinet with doors & side panels
MODEL NUMBER: SR45UBWD
Highlights
45U SmartRack enclosure with
doors and side panels
4 interior vertical posts with
unthreaded square hole
openings
30" (750mm) width for
optimizing airflow through
cabinet
Standard 42" (1050mm) depth
Ships fully assembled
Massive front to rear ventilation
capacity
3000 lbs (1360.8 kgs) stationary
/ 2250 lbs (1020.6 kgs) rolling
load capacity
Locking, removable, reversible
front and rear doors
Locking, removable side panels
keyed alike with doors
Meets all enclosure
requirements towards PCI DSS
(Payment Card Industry Data
Security Standard) Compliance
Description
The SR45UBWD is a WIDE version of our standard 45U SmartRack. This enclosure is 750mm wide (30")
compared to the standard 600mm wide (24"). This extra width allows for high density equipment
installations. It allows cable management and PDU mounting off to the sides of the rack in order to keep
these items out of the airflow for proper cooling.
The SR45UBWD features a massive front-to rear-ventilation capacity that meets or exceeds server
manufacturer requirements. Its integrated baying tabs make it easy to combine multiple enclosures in
rows for data center applications. This enclosure is also compatible with hot-aisle/cold-aisle
configurations.
With its locking, reversible, removable front and rear doors, and locking, removable side panels, the
SR45UBWD provides ultimate equipment safety. The side panels are half size for ease of removal and
reinstallation. The split rear door design allows the enclosure to be placed closer to a wall. The
SR45UBWD meets all requirements toward PCI DSS compliance.
The top panel of the SR45UBWD is vented to help remove warm air from the enclosure and draw in cool
air by convection. The top panel includes ports for cable routing, and can be quickly removed without
tools. To facilitate cable access, the SR45UBWD is open-bottom.
All components of the SR45UBWD are grounded to the enclosure frame. Front and rear threaded
grounding points are provided for connection to the facility earth ground. The removable front and rear
doors feature quick-release ground wires.
It houses 3000 lbs (1360.8 kgs) of standard 19-inch rack equipment in 45U. To simplify deployment, the
SR45UBWD comes with preinstalled casters that enable it to be easily maneuvered into the desired
location, where it can be secured by adjusting the preinstalled levelers. Note: the casters are intended for
minor position adjustments and are not designed for moving the enclosure over long distances.
The SR45UBWD comes with a 5-year product warranty. As part of the SmartRack family, the SR45UBWD
is compatible with Tripp Lite's extensive range of rackmount accessories, enabling you to customize your
solution to meet any requirement.
Features
Ships fully assembled for rapid deployment and roll into place on pre-installed casters that support a
rolling load of 2250 lbs, allowing the enclosure to be pre-configured and rolled to the final installation
location. (casters are removable.)
Front and rear sets of equipment mounting rails adjust in 1/4" increments. Adjustment is quick and
convenient. The easy-view depth index ensures consistent rail placement without requiring timeconsuming measurements.
Toolless accessory mounting rails (2 rails per enclosure) include slots for quick installation of compatible
PDUs and vertical cable managers. Mounting slots are arranged in an industry-standard pattern
1/4
Package Includes
SR45UBWD Rack Enclosure
(4) Side panels
(4) Side panel locks
(2) Door & side panel keys
(50) M6 screws
(50) M6 cage nuts
(50) M6 washers
Owner's Manual
Cleveland, OH 44122
United States
compatible with a wide variety of accessories. Each rail can accommodate two vertical PDUs or cable
managers side-by-side (four items per enclosure).
Enclosure includes mounting hardware of 50 pieces of M6 cage nuts and 50 pieces of M6 screws
Textured powder coat finish for tough resistance to environmental concerns such as deployment in
warehouses.
Massive front to rear ventilation capacity. 65+% open space in door perforation pattern meets or
exceeds server manufacturer requirements.
Maximum usable internal depth of 37 inches/94 cm (front to rear rail).
Weight ratings of 3000 lbs (1360.8 kgs) stationary and 2250 lbs (1020.6 kgs) rolling.
Front door is locking, reversible and removable.
Rear doors are locking and reversible. Split rear door design reduces clearance requirements for
service entry allowing the enclosure to be placed closer to a wall.
Locking removable side panels are 'half size' to make them smaller and lighter improving ease of
installation and servicing. Two side panels per side (4 panels total). Side panels are keyed alike to the
front and rear doors.
Built in baying tabs allow enclosures to be combined securely in rows. Center-to-center width can be set
at 750mm or 30".
Leveling feet extend to allow enclosure to be positioned on uneven floors. Levelers are removable.
Convenient grounding system. All components are grounded to the enclosure frame which includes
multiple connections for facility ground. Front and rear doors include quick-release ground wires.
Open bottom for cable access.
Top panel has generous cable access holes. Panel can be removed toollessly in seconds without
having to disconnect cables first.
Included stabilizing brackets are used for shipment and can be reattached at the bottom of the
enclosure frame on the inside or outside of the rack.
Meets all enclosure requirements towards PCI DSS (Payment Card Industry Data Security Standard)
Compliance
Compatibility with airflow optimization accessories as well as cable management accessories.
Specifications
OVERVIEW
UPC Code
037332175038
Device Compatibility
Patch Panel; Network Switch; UPS; Server
Rack Type
Enclosure
PHYSICAL
Color
Black
Rack Height
45U
Rack Depth
Standard
Factory Preset Rack Depth (in.)
27.75
Factory Preset Rack Depth (cm)
70.5
Factory Preset Rack Depth (mm)
705
Maximum Device Depth (cm)
93.98
2/4
Cleveland, OH 44122
United States
Maximum Device Depth (in.)
37
Maximum Device Depth (mm)
940
Minimum Device Depth (cm)
10.16
Minimum Device Depth (in.)
4
Minimum Device Depth (mm)
102
Shipping Dimensions (hwd / in.)
90.30 x 31.00 x 45.00
Shipping Dimensions (hwd / cm)
229.36 x 78.74 x 114.30
Shipping Weight (lbs.)
390.00
Shipping Weight (kg)
176.90
Unit Dimensions (hwd / in.)
83.750 x 29.530 x 43.000
Unit Dimensions (hwd / cm)
212.725 x 75.01 x 109.22
Unit Weight (lbs.)
340
Unit Weight (kg)
154.22
Weight Capacity - Rolling (kg)
1,021
Weight Capacity - Rolling (lbs.)
2250
Weight Capacity - Stationary (kg)
1,361
Weight Capacity - Stationary (lbs.)
3000
Number of Vertical Mounting Rails
4
FEATURES & SPECIFICATIONS
Grounding Lug
Front and Back door frames
Built-in Cable Management
Yes
Extra Wide
Yes
Pre-Installed Casters
Yes
STANDARDS & COMPLIANCE
Product Certifications
UL 60950-1
Product Compliance
RoHS; CE (Europe); UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
3/4
Cleveland, OH 44122
United States
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“SR45UBWD”相匹配的价格&库存,您可以联系我们找货
