74LV245AT
Octal bus transceiver; 3-state
Rev. 2 — 4 November 2016
Product data sheet
1. General description
The 74LV245AT is an 8-bit transceiver with 3-state outputs. The device features an output
enable (OE) and send/receive (DIR) for direction control. A HIGH on OE causes the
outputs to assume a high-impedance OFF-state.
The 74LV245AT is designed to operate over a VCC range from 4.5 V to 5.5 V. The inputs
are TTL compatible, which allows the device to be used to translate from 3.3 V to 5 V.
Schmitt-trigger action at all inputs makes the circuit tolerant of slower input rise and fall
times.
This device is fully specified for partial Power-down applications using IOFF.
The IOFF circuitry disables the output, preventing the damaging backflow current through
the device when it is powered down.
2. Features and benefits
Direct interface with TTL levels
Supply voltage range from 4.5 V to 5.5 V
Typical tpd of 3.1 ns at 5 V
Typical VOL(p) < 0.8 V at VCC = 5 V, Tamb = 25 C
Typical VOH(v) > 2.3 V at VCC = 5 V, Tamb = 25 C
Supports mixed-mode voltage operation on all ports
IOFF circuitry provides partial Power-down mode operation
Latch-up performance exceeds 250 mA per JESD 78 Class II
ESD protection:
HBM ANSI/ESDA/JEDEC JS-001 Class 2 exceeds 3 kV
MM JESD22-A115-A exceeds 200 V
CDM JESD22-C101E exceeds 2 kV
Specified from 40 C to +85 C and from 40 C to +125 C
74LV245AT
Nexperia
Octal buffer/line driver; 3-state
3. Ordering information
Table 1.
Type number
Package
74LV245ATPW
Temperature range Name
Description
Version
40 C to +125 C
plastic thin shrink small outline package; 20 leads;
body width 4.4 mm
SOT360-1
TSSOP20
4. Functional diagram
',5
2(
(1
(1
Logic symbol
74LV245AT
Product data sheet
PQD
PQD
Fig 1.
Fig 2.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 13
74LV245AT
Nexperia
5. Pinning information
5.1 Pinning
/9$7
',5
9&&
2(
*1'
DDD
Fig 3.
Pin configuration TSSOP20
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
DIR
1
direction control
A0 to A7
2, 3, 4, 5, 6, 7, 8, 9
data input/output
GND
10
ground (0 V)
B0 to B7
18, 17, 16, 15, 14, 13, 12, 11
data input/output
OE
19
output enable input (active LOW)
VCC
supply voltage
74LV245AT
Product data sheet
3 of 13
74LV245AT
Nexperia
6. Functional description
Table 3.
Function table[1]
Input
Input/output
OE
DIR
An
Bn
L
L
A=B
input
L
H
input
B=A
H
X
Z
Z
[1]
H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state.
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Conditions
active mode
Min
Max
Unit
0.5
+7.0
V
[1]
0.5
+7.0
V
[2][3]
0.5
VCC + 0.5
V
[2]
0.5
+7.0
V
mA
power-down or 3-state mode
IIK
input clamping current
VI < 0 V
IOK
output clamping current
VO < 0 V
50
mA
IO
output current
VO = 0 V to VCC
35
mA
ICC
supply current
70
mA
IGND
ground current
70
mA
Tstg
storage temperature
65
+150
C
Ptot
total power dissipation
500
mW
Tamb = 40 C to +125 C
[4]
[1]
If the input current ratings are observed, the minimum input voltage ratings may be exceeded.
[2]
If the output current ratings are observed, the output voltage ratings may be exceeded.
[3]
This value is limited to 7.0 V maximum.
[4]
For TSSOP20 package: above 100 C, the value of Ptot derates linearly with 10 mW/K.
74LV245AT
Product data sheet
4 of 13
74LV245AT
Nexperia
8. Recommended operating conditions
Table 5.
Symbol
Parameter
Conditions
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
ambient temperature
t/V
input transition rise and fall rate
Min
Max
Unit
4.5
5.5
V
V
active mode
VCC
V
V
40
+125
C
VCC = 5.0 V 0.5 V
ns/V
9. Static characteristics
Table 6.
Symbol Parameter
25 C
Conditions
40 C to +85 C 40 C to +125 C Unit
Min
Typ
Max
Min
Max
Min
Max
VIH
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
2
2
2
V
VIL
LOW-level
input voltage
0.8
0.8
0.8
V
VOH
HIGH-level
VI = VIH or VIL; VCC = 4.5 V
output voltage
IO = 50 A
IO = 16 mA
VOL
LOW-level
output voltage
IO = 50 A
IO = 16 mA
4.4
4.5
4.4
4.4
V
3.94
3.8
3.8
V
0.1
0.1
V
0.44
0.55
0.55
V
IOZ
OFF-state
VCC = 5.5 V; VI = VIH or VIL;
output current VO = GND to 5.5 V
0.25
2.5
2.5
A
IOFF
power-off
leakage
current
VI or VO = GND to 5.5 V;
VCC = 0 V
0.5
5
5
A
II
input leakage
current
VI = VCC or GND;
VCC = 0 V to 5.5 V
0.1
1
1
A
ICC
supply current VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
2
A
ICC
additional
per input pin; VI = 3.4 V;
supply current IO = 0 A; other pins at VCC or
GND; VCC = 5.5 V
1.35
1.5
1.5
mA
74LV245AT
Product data sheet
5 of 13
74LV245AT
Nexperia
10. Dynamic characteristics
Table 7.
GND = 0 V. For test circuit, see Figure 6.
Symbol Parameter
propagation
delay
tpd
25 C
Conditions
Min
Typ[1]
Max
Min
Max
Min
Max
CL = 15 pF
3.1
7.7
1
8.5
1
9.7
ns
CL = 50 pF
4.4
8.7
1
9.5
1
10.7
ns
CL = 15 pF
4.5
13.8
1
15
1
16.3
ns
CL = 50 pF
5.8
14.8
1
16
1
17.3
ns
CL = 15 pF
3.8
7.5
1
8
1
8.6
ns
CL = 50 pF
6.0
15.4
1
16.5
1
17
ns
An to Bn or Bn to An; see
Figure 4
[2]
enable time
ten
OE to An or OE to Bn; see
Figure 5
disable time OE to An or OE to Bn; see
Figure 5
tdis
[2]
tsk(o)
output skew VCC = 4.5 V to 5.5 V;
time
CL = 50 pF
1
1
1
ns
CI
input
capacitance
VI = VCC or GND;
VCC = 5 V
2
6
6
6
pF
CI/O
input/output
capacitance
VO = VCC or GND;
VCC = 5 V
5.5
pF
CPD
power
dissipation
capacitance
per buffer;
CL = 50 pF; f = 10 MHz;
VI = GND to VCC
10.3
pF
[3]
[1]
Typical values are measured at Tamb = 25 C and VCC = 5 V.
[2]
tpd is the same as tPLH and tPHL.
ten is the same as tPZL and tPZH.
tdis is the same as tPLZ and tPHZ.
[3]
CPD is used to determine the dynamic power dissipation PD (W).
PD = CPD VCC2 fi + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in Volts.
74LV245AT
Product data sheet
6 of 13
74LV245AT
Nexperia
Table 8.
Noise characteristics
Symbol
Parameter
Tamb = 25 C
Conditions
Unit
Min
Typ
Max
VCC = 5 V; CL = 50 pF
VOL(p)
LOW-level output voltage (peak)
0.6
1.5
V
VOL(v)
LOW-level output voltage (valley)
1.5
0.6
V
VOH(v)
HIGH-level output voltage (valley)
4.0
V
VIH(AC)
AC HIGH-level input voltage
dynamic
2
V
VIL(AC)
AC LOW-level input voltage
dynamic
0.8
V
11. Waveforms
9,
$Q%QLQSXW
*1'
90
90
W3/+
W3+/
92+
90
%Q$QRXWSXW
92/
90
PQD
Measurement points are given in Table 9.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig 4.
Propagation delay input (An, Bn) to output (Bn, An)
9,
2(LQSXW
90
*1'
W 3/=
W 3=/
9&&
RXWSXW
/2:WR2))
2))WR/2:
92/
90
9;
W 3+=
92+
W 3=+
9<
RXWSXW
+,*+WR2))
2))WR+,*+
90
*1'
RXWSXWV
HQDEOHG
RXWSXWV
GLVDEOHG
RXWSXWV
HQDEOHG
PQD
Fig 5.
Enable and disable times
74LV245AT
Product data sheet
7 of 13
74LV245AT
Nexperia
Table 9.
Measurement points
Input
Output
VM
VM
VX
VY
1.5 V
0.5VCC
VOL + 0.3 V
VOH 0.3 V
9,
W:
QHJDWLYH
SXOVH
90
9
9,
WI
WU
WU
WI
SRVLWLYH
SXOVH
9
90
90
90
W:
9&&
9&&
9,
92
5/
6
RSHQ
'87
57
DDG
Test data is given in Table 10.
Definitions test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator
CL = Load capacitance including jig and probe capacitance
RL = Load resistor
S1 = Test selection switch
Fig 6.
Table 10.
Test circuit for measuring switching times
Test data
Input
VI
Load
tr, tf
GND to 3.0 V 3.0 ns
74LV245AT
Product data sheet
S1 position
CL
RL
tPHL, tPLH
tPZH, tPHZ
tPZL, tPLZ
15 pF, 50 pF
1 k
open
GND
VCC
8 of 13
74LV245AT
Nexperia
12. Package outline
76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP
627
F
Y 0 $
4
SLQLQGH[
ș
/S
H
GHWDLO;
Z 0
ES
PP
VFDOH
',0(16,216PPDUHWKHRULJLQDOGLPHQVLRQV
81,7
PD[
ES
F
H
/S
4
Y
Z
ș
PP
R
R
1RWHV
3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG
3ODVWLFLQWHUOHDGSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG
287/,1(
9(56,21
627
Fig 7.
5()(5(1&(6
-(,7$
(8523($1
352-(&7,21
,668('$7(
02
Package outline SOT360-1 (TSSOP20)
74LV245AT
Product data sheet
9 of 13
74LV245AT
Nexperia
13. Abbreviations
Table 11.
Abbreviations
Acronym
Description
CDM
Charge Device Model
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
14. Revision history
Table 12.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74LV245AT v.2
20161104
Product data sheet
74LV245AT v.1
Modifications:
74LV245AT v.1
74LV245AT
Product data sheet
Type number 74LV245ATBQ removed.
20160603
Product data sheet
10 of 13
74LV245AT
Nexperia
15. Legal information
15.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
74LV245AT
Product data sheet
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer’s own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
11 of 13
74LV245AT
Nexperia
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of
non-automotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
15.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
16. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74LV245AT
Product data sheet
12 of 13
Nexperia
74LV245AT
17. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
11
12
13
14
15
15.1
15.2
15.3
15.4
16
17
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 3
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 4
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4
Recommended operating conditions. . . . . . . . 5
Static characteristics. . . . . . . . . . . . . . . . . . . . . 5
Dynamic characteristics . . . . . . . . . . . . . . . . . . 6
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10
Legal information. . . . . . . . . . . . . . . . . . . . . . . 11
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Contact information. . . . . . . . . . . . . . . . . . . . . 12
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Date of release: 04 November 2016
