74LV541A
Octal buffer/line driver; 3-state
Rev. 2 — 1 November 2016
Product data sheet
1. General description
The 74LV541A is an 8-bit buffer/line driver with 3-state outputs. The device features two
output enables (OE1 and OE2). A HIGH on OEn causes the associated outputs to
assume a high-impedance OFF-state.
Inputs are overvoltage tolerant. This feature allows the use of these devices as translators
in mixed voltage environments.
Schmitt-trigger action at all inputs makes the circuit tolerant of slower input rise and fall
times.
This device is fully specified for partial power down applications using IOFF. The IOFF
circuitry disables the output, preventing the potentially damaging backflow current through
the device when it is powered down.
2. Features and benefits
Wide supply voltage range from 2.0 V to 5.5 V
Maximum tpd of 6 ns at 5 V
Typical VOL(p) < 0.8 V at VCC = 3.3 V, Tamb = 25 C
Typical VOH(v) > 2.3 V at VCC = 3.3 V, Tamb = 25 C
Supports mixed-mode voltage operation on all ports
IOFF circuitry provides partial Power-down mode operation
Latch-up performance exceeds 250 mA per JESD 78 Class II
ESD protection:
HBM ANSI/ESDA/JEDEC JS-001 Class 2 exceeds 3kV
MM JESD22-A115-A exceeds 200 V
CDM JESD22-C101E exceeds 2kV
Specified from 40 C to +85 C and from 40 C to +125 C
74LV541A
Nexperia
3. Ordering information
Table 1.
Type number
74LV541APW
Package
Temperature range
Name
Description
Version
40 C to +125 C
TSSOP20
plastic thin shrink small outline package; 20 leads;
body width 4.4 mm
SOT360-1
4. Functional diagram
很抱歉,暂时无法提供与“74LV541ATPWJ”相匹配的价格&库存,您可以联系我们找货
