S9015
S9015
    BLUECOLOUR(蓝彩电子)
    SOT-23
    PNP Ic=-100mA Vceo=-45V hfe=200~450 fT=150MHz P=200mW SOT-23
S9015 数据手册
S9015 TRANSISTOR(PNP) FEATURES SOT-23 Complementary to S9014 1.BASE 2.EMITTER 3.COLLECTOR MARKING: M6 Parameter ou Symbol r MAXIMUM RATINGS (TA=25℃ unless otherwise noted) Value Units -50 V -45 V -5 V Collector-Base Voltage VCEO Collector-Emitter Voltage VEBO Emitter-Base Voltage IC Collector Current -Continuous -0.1 A PC Collector Power Dissipation 0.2 W Tj Junction Temperature 150 ℃ Tstg Storage Temperature -55-150 ℃ bl u ec ol VCBO ELECTRICAL CHARACTERISTICS (Tamb=25℃ unless otherwise specified) Parameter Symbol Test conditions MIN TYP MAX UNIT Collector-base breakdown voltage V(BR)CBO IC= -100µA, IE=0 -50 V Collector-emitter breakdown voltage V(BR)CEO IC = -0.1mA, IB=0 -45 V Emitter-base breakdown voltage V(BR)EBO IE=-100µA, IC=0 -5 V Collector cut-off current ICBO VCB= -50V, IE=0 -0.1 µA Emitter cut-off current IEBO VEB= -5V, IC=0 -0.1 µA DC current gain hFE VCE= -5V, IC= -1mA 200 450 Collector-emitter saturation voltage VCE(sat) IC= -100mA, IB= -10mA -0.3 V Base-emitter saturation voltage VBE(sat) IC= -100mA, IB=-10mA -1 V Transition frequency Page 1 f 3 fT VCE= -5V, f=30MHz IC= -10mA 150 MHz REV01: 09/2011 Typical Characteristics Static Characteristic -6 -14uA -12uA -10uA -8uA -6uA -2 IC Ta=25℃ 100 -4uA IB=-2uA -2 -4 -6 COLLECTOR-EMITTER VOLTAGE VCEsat -1 10 -0.1 -8 VCE -1 (V) -10 COLLECTOR CURRENT —— IC VBEsat -2 —— r -0 COMMON EMITTER VCE= -5V -1 -0.1 Ta=100℃ ol Ta=25℃ IC -100 (mA) IC Ta=25℃ ou -0 COLLECTOR-EMITTER SATURATION VOLTAGE VCEsat (V) DC CURRENT GAIN -16uA -4 — — Ta=100℃ hFE -20uA -18uA hFE 1000 COMMON EMITTER Ta=25℃ BASE-EMITTER SATURATION VOLTAGE VBEsat (V) COLLECTOR CURRENT IC (mA) -8 Ta=100℃ β=10 β=10 -1 -10 COLLECTOR CURRENT —— VBE COMMON EMITTER VCE=-5V -0.9 -1 —— VCB/ VEB CAPACITANCE Page 2 f 3 -10 VR (V) -20 —— IC -100 (mA) Ta (mW) 200 PC Cib -1 PC 250 f=1MHz IE=0/IC=0 Ta=25 ℃ REVERSE VOLTAGE -10 COLLECTOR CURRENT Cob 1 -0.1 IC COMMON EMITTER VCE=-5V Ta=25℃ 10 -0.1 -1.2 COLLECTOR POWER DISSIPATION (pF) C 10 Cob/ Cib (mA) 100 BASE-EMMITER VOLTAGE VBE (V) 30 — — -100 IC fT -1 -0.6 fT 1000 Ta=100℃ -0.3 -10 COLLECTOR CURRENT Ta=25℃ -0.1 -0.0 -1 (mA) bl u (mA) IC COLLECTOR CURRENT -10 IC -0.2 (MHz) IC -100 -0.1 -100 TRANSITION FREQUENCY -0.2 ec -0.01 150 100 50 0 0 25 50 75 AMBIENT TEMPERATURE 100 Ta 125 150 (℃ ) REV01: 09/2011 PACKAGE OUTLINE SOT-23 bl u ec ol ou r Plastic surface mounted package; 3 leads Page 3 f 3 REV01: 09/2011
S9015 价格&库存
很抱歉,暂时无法提供与“S9015”相匹配的价格&库存,您可以联系我们找货
S9015
    • 1+0.04510
    库存:50
    S9015
    • 10+0.03168
    • 50+0.02930
    • 200+0.02732
    • 600+0.02534
    • 1500+0.02376
    • 3000+0.02277
