AO3401
SI2305
SI2301
AO3407
SOT-23 Plastic-Encap sulate MOSFETS
P-Channel Enhancement Mode Field Effect Transistor
SI2301
General Description
AO3407 uses advanced trench technology to provide excellent
The BC3407
RDS(on) with low gate charge. This device is suitable for use as a load
switch or in PWM applications.
MARKING
Equivalent Circuit
A1SHB
A19T
A09T
3407
1.GATE
2.SOURCE
3.DRAIN
Maximum ratings (Ta=25℃ unless otherwise noted)
Parameter
Symbol
Value
Unit
Drain-Source Voltage
VDS
-30
V
Gate-Source Voltage
VGS
±20
V
Continuous Drain Current
ID
-4.1
A
Power Dissipation
PD
350
mW
RθJA
357
℃/W
Junction Temperature
TJ
150
Storage Temperature
Tstg
-55~+150
Thermal Resistance from Junction to Ambient
www.tw-gmc.com
1
AO3407
AO3401
SI2305
SI2301
Electrical characteristics (Ta=25℃ unless otherwise noted)
Parameter
Symbol
Test Condition
Min
Typ
Max
Units
Static characteristics
Drain-source breakdown voltage
BVDSS
VGS = 0V, ID =-250µA
Zero gate voltage drain current
IDSS
VDS =-24V,VGS = 0V
-1
µA
Gate-source leakage current
IGSS
VGS =±20V, VDS = 0V
±100
nA
VGS =-10V, ID =-4.1A
60
mΩ
VGS =-4.5V, ID =-3A
87
mΩ
Drain-source on-resistance (note 1)
Forward tranconductance (note 1)
Gate threshold voltage
Diode forward voltage (note 1)
RDS(on)
gFS
VGS(th)
VSD
-30
VDS =-5V, ID =-4A
5.5
VDS =VGS, ID =-250µA
-1
V
S
IS=-1A,VGS=0V
-3
V
-1
V
Dynamic characteristics (note 2)
Input capacitance
Ciss
700
pF
Output capacitance
Coss
120
pF
Reverse transfer capacitance
Crss
75
pF
td(on)
8.6
ns
VGS=-10V,VDS=-15V,
5.0
ns
RL=3.6Ω,RGEN=3Ω
28.2
ns
13.5
ns
VDS =-15V,VGS =0V,f =1MHz
Switching Characteristics (note 2)
Turn-on delay time
Turn-on rise time
Turn-off delay time
Turn-off fall time
tr
td(off)
tf
Notes:
1.
2.
Pulse test: Pulse width ≤300µs, duty cycle ≤2%.
These parameters have no way to verify.
www.tw-gmc.com
2
AO3407
AO3401
SI2305
SI2301
Typical Characteristics
Output Characteristics
Transfer Characteristics
-25
-5
VGS=-10V
Ta=25℃
VGS=-4.5V
-8V
-5V
-20
-4
VGS=-3.5V
-10
ID
-15
-3
DRAIN CURRENT
DRAIN CURRENT
ID
(A)
(A)
VGS=-4V
-2
-5
-1
-0
-0
-0
-1
-2
-3
-4
DRAIN TO SOURCE VOLTAGE
RDS(ON)
VDS
-5
-0
(V)
-1
-2
GATE TO SOURCE VOLTAGE
-3
VGS
-4
(V)
RDS(ON) —— VGS
—— ID
140
100
Ta=25℃
Ta=25℃
120
(mΩ)
(mΩ)
80
100
RDS(ON)
60
ON-RESISTANCE
ON-RESISTANCE
RDS(ON)
VGS=-4.5V
VGS=-10V
40
80
ID=-4.3A
60
40
-2
-4
-6
DRAIN CURRENT
IS
ID
-8
-10
-2
(A)
VSD
-10
Ta=25℃
-0.1
SOURCE CURRENT
IS
(A)
-1
-0.01
-1E-3
-1E-4
-1E-5
-0.2
-0.4
-0.6
-0.8
SOURCE TO DRAIN VOLTAGE
www.tw-gmc.com
-1.0
VSD
-4
-6
-1.2
(V)
3
-8
VGS
(V)
-10
AO3407
AO3401
SI2305
SI2301
PACKAGE OUTLINE
Plastic surface mounted package; 3 leads
www.tw-gmc.com
SOT-23
3
4
很抱歉,暂时无法提供与“AO3407”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.23242
- 100+0.21692
- 300+0.20143
- 500+0.18594
- 2000+0.17819
- 5000+0.17354
