MMBT5551
MMBT5551
    TK(通科)
    SOT-23
    SOT-23塑料封装晶体管
MMBT5551 数据手册
东莞市通科电子有限公司 DongGuan Tongke Electronic Co.,LTD TKMMBT5551 TRANSISTOR (NPN) SOT-23 Plastic-Encapsulate Transistors SOT–23 FEATURES z Complementary to TK MMBT5401 z Ideal for Medium Power Amplification and Switching 1. BASE MARKING: G1 2. EMITTER 3. COLLECTOR MAXIMUM RATINGS (Ta=25℃ unless otherwise noted) Symbol Parameter Value Unit VCBO Collector-Base Voltage 180 V VCEO Collector-Emitter Voltage 160 V VEBO Emitter-Base Voltage 6 V IC Collector Current 600 mA PC Collector Power Dissipation 300 mW Thermal Resistance From Junction To Ambient 416 ℃/W Tj Junction Temperature 150 ℃ Tstg Storage Temperature -55~+150 ℃ RΘJA ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified) Parameter Symbol Collector-base breakdown voltage V(BR)CBO Collector-emitter breakdown voltage V(BR)CEO Emitter-base breakdown voltage V(BR)EBO Collector cut-off current ICBO Emitter cut-off current IEBO DC current gain Collector-emitter saturation voltage Base-emitter saturation voltage Min Typ Max Unit IC=100µA, IE=0 180 V IC=1mA, IB=0 160 V IE=10µA, IC=0 6 V VCB=120V, IE=0 50 nA VEB=4V, IC=0 50 nA hFE(1) * VCE=5V, IC=1mA 80 hFE(2) * VCE=5V, IC=10mA 100 hFE(3) * VCE=5V, IC=50mA 50 300 VCE(sat)1 * IC=10mA, IB=1mA 0.15 V VCE(sat)2 * IC=50mA, IB=5mA 0.2 V VBE(sat)1 * IC=10mA, IB=1mA 1 V VBE(sat)2 * IC=50mA, IB=5mA 1 V 300 MHz 6 pF fT Transition frequency Collector output capacitance * Test conditions Cob VCE=10V,IC=10mA, f=100MHz VCB=10V, IE=0, f=1MHz 100 *Pulse test: pulse width ≤300μs, duty cycle≤ 2.0%. CLASSIFICATION OF hFE (2) RANGE www.ctk-elec.com 100-300 1 400-6922-883 TKMMBT5551 Typical Characteristics Static Characteristic 18 COMMON EMITTER VCE=5V COMMON EMITTER Ta=25℃ 80uA 15 60uA 50uA 9 40uA 6 30uA Ta=25℃ 100 IB=20uA 3 0 10 0 2 4 6 8 10 COLLECTOR-EMITTER VOLTAGE VBEsat —— 1.0 VCE 12 1 COLLECTOR CURRENT IC 200 100 200 β=10 0.8 Ta=25℃ 0.6 Ta=100℃ 0.4 0.2 0.1 0.1 Ta=100℃ Ta=25℃ 0.01 1 10 COLLECTOR CURRENT VBE —— 100 IC 1 200 10 (mA) COLLECTOR CURRENT IC Cob / Cib 100 200 —— IC (mA) VCB / VEB COMMON EMITTER VCE=5V f=1MHz IE=0 / IC=0 CAPACITANCE C Ta=100℃ Ta=25℃ Cib (pF) IC (mA) 100 100 (mA) IC VCEsat —— B IC 0.3 COLLECTOR-EMITTER SATURATION VOLTAGE VCEsat (V) BASE-EMITTER SATURATION VOLTAGE VBEsat (V) 10 (V) β=10 COLLECTOR CURRENT Ta=100℃ hFE 70uA 12 DC CURRENT GAIN IC (mA) 90uA COLLECTOR CURRENT hFE —— IC 500 Ta=25℃ 10 1 0.2 0.4 0.6 BASE-EMITTER VOLTAGE fT —— 0.8 Cob 1 0.1 1.0 VBE(V) 10 1 10 REVERSE VOLTAGE IC PC 0.4 150 —— V 20 (V) Ta VCE=10V TRANSITION FREQUENCY fT COLLECTOR POWER DISSIPATION PC (W) (MHz) Ta=25℃ 100 50 0.3 0.2 0.1 0.0 1 COLLECTOR CURRENT www.ctk-elec.com 10 3 IC 20 0 30 25 50 75 AMBIENT TEMPERATURE (mA) 2 100 Ta 125 150 (℃ ) 400-6922-883 SOT-23 Package Outline Dimensions Symbol A A1 A2 b c D E E1 e e1 L L1 θ Dimensions In Millimeters Min Max 0.900 1.150 0.000 0.100 0.900 1.050 0.300 0.500 0.080 0.150 2.800 3.000 1.200 1.400 2.250 2.550 0.950 TYP 1.800 2.000 0.550 REF 0.300 0.500 0° 8° Dimensions In Inches Min Max 0.035 0.045 0.000 0.004 0.035 0.041 0.012 0.020 0.003 0.006 0.110 0.118 0.047 0.055 0.089 0.100 0.037 TYP 0.071 0.079 0.022 REF 0.012 0.020 0° 8° SOT-23 Suggested Pad Layout www.ctk-elec.com 3 400-6922-883
MMBT5551 价格&库存
很抱歉,暂时无法提供与“MMBT5551”相匹配的价格&库存,您可以联系我们找货
MMBT5551
    • 10+0.05440
    • 50+0.05032
    • 200+0.04692
    • 600+0.04352
    • 1500+0.04080
    • 3000+0.03910
