INTEGRATED CIRCUITS
74LVC573A
Octal D-type transparent latch with 5-volt
tolerant inputs/outputs (3-State)
Product specification
1998 Jul 29
Philips Semiconductors
74LVC573A
The 74LVC573A is an octal D-type transparent latch featuring
separate D-type inputs for each latch and 3-State outputs for
bus-oriented applications. A latch enable (LE) input and an output
enable (OE) input are common to all internal latches.
FEATURES
• 5-volt tolerant inputs/outputs, for interfacing with 5-volt logic
• Supply voltage range of 2.7V to 3.6V
• Complies with JEDEC standard no. 8-1A
• Inputs accept voltages up to 5.5V
• CMOS low power consumption
• Direct interface with TTL levels
• High impedance when VCC = 0V
• Flow-through pin-out architecture
The ’573A’ consists of eight D-type transparent latches with 3-State
true outputs. When LE is HIGH, data at the Dn inputs enters the
latches. In this condition, the latches are transparent, i.e. a latch
output will change each time its corresponding D-input changes.
When LE is LOW, the latches store the information that was present
at the D-inputs one setup time preceding the HIGH-to-LOW
transition of LE. When OE is LOW, the contents of the eight latches
are available at the outputs. When OE is HIGH, the outputs go to the
high impedance OFF-state. Operation of the OE input does not
affect the state of the latches.
DESCRIPTION
The ’573A’ is functionally identical to the ’373A’, but the ’373A’ has a
different pin arrangement.
The 74LVC573A is a high-performance, low-power, low-voltage,
Si-gate CMOS device, superior to most advanced CMOS
compatible TTL families.
Inputs can be driven from either 3.3V or 5V devices. In 3-State
operation, outputs can handle 5V. This feature allows the use of
these devices as translators in a mixed 3.3V/5V environment.
QUICK REFERENCE DATA
SYMBOL
tPHL/tPLH
PARAMETER
CONDITIONS
Propagation delay
Dn to Qn;
LE to Qn
CL = 50pF
VCC = 3.3V
CI
Input capacitance
CPD
Power dissipation capacitance per latch
TYPICAL
4.3
4.6
Notes 1 and 2
UNIT
ns
5.0
pF
pF
NOTE:
1. CPD is used to determine the dynamic power dissipation (PD in W):
PD = CPD x VCC2 x fi + (CL x VCC2 x fo) where:
fi = input frequency in MHz; CL = output load capacity in pF;
fo = output frequency in MHz; VCC = supply voltage in V;
(CL x VCC2 x fo) = sum of outputs.
2. The condition is VI = GND to VCC
ORDERING INFORMATION
TEMPERATURE
RANGE
OUTSIDE
NORTH AMERICA
NORTH AMERICA
PKG. DWG. #
20-Pin Plastic Shrink Small Outline (SO)
–40°C to +85°C
74LVC573A D
74LVC573A D
SOT163-1
20-Pin Plastic Shrink Small Outline (SSOP) Type II
–40°C to +85°C
74LVC573A DB
74LVC573A DB
SOT339-1
20-Pin Plastic Thin Shrink Small Outline (TSSOP) Type I
–40°C to +85°C
74LVC573A PW
7LVC573APW DH
SOT360-1
PACKAGES
1998 Jul 29
2
853-1862 19804
PIN DESCRIPTION
74LVC573A
LOGIC SYMBOL (IEEE/IEC)
PIN NUMBER
SYMBOL
1
OE
FUNCTION
11
Output enable input (active-Low)
C1
2, 3, 4, 5,
6, 7, 8, 9
D0-D7
Data inputs
1
19, 18, 17, 16,
15, 14, 13, 12
Q0-Q7
Data outputs
2
10
GND
Ground (0V)
3
18
11
LE
Latch enable input (active-High)
4
17
VCC
Positive supply voltage
5
16
6
15
7
14
8
13
9
12
PIN CONFIGURATION
1D
19
OE
1
20 VCC
D0
2
19 Q0
D1
3
18 Q1
D2
4
17 Q2
D3
5
16 Q3
2
D0
D4
6
15 Q4
3
D1
Q1
18
D5
7
14 Q5
4
D2
Q2
17
D6
8
13 Q6
5
D3
D7
9
12 Q7
6
D4
11 LE
7
D5
8
GND 10
SA00397
FUNCTIONAL DIAGRAM
SA00395
LOGIC SYMBOL
2
D0
3
4
OE
Q0
19
D1
Q1
18
D2
Q2
17
5
D3
Q3
16
6
D4
Q4
15
7
D5
Q5
14
8
D6
Q6
13
9
D7
Q7
12
LE
Q0
19
Q3
16
Q4
15
Q5
14
D6
Q6
13
9
D7
Q7
12
11
LE
1
OE
LATCH
1 to 8
3-State
OUTPUTS
SA00398
1
11
SA00396
1998 Jul 29
EN1
3
74LVC573A
LOGIC DIAGRAM
D1
D0
D
D2
D
Q
D3
D
Q
D4
D
Q
D5
D
Q
D6
D
Q
D7
D
Q
D
Q
Q
LATCH
1
LATCH
2
LATCH
3
LATCH
4
LATCH
5
LATCH
6
LATCH
7
LATCH
8
LE LE
LE LE
LE LE
LE LE
LE LE
LE LE
LE LE
LE LE
LE
OE
Q0
Q1
Q2
Q3
Q4
Q5
Q6
Q7
SA00399
FUNCTION TABLE
INPUTS
OUTPUTS
OPERATING MODES
H
h
L
l
X
Z
INTERNAL LATCHES
OE
LE
Dn
Enable and read register
(transparent mode)
L
L
H
H
L
H
L
H
L
H
Latch and read register
L
L
L
L
l
h
L
H
L
H
Latch register and
disable outputs
H
H
L
L
l
h
L
H
Z
Z
= HIGH voltage level
= HIGH voltage level one setup time prior to the HIGH-to-LOW LE transition
= LOW voltage level
= LOW voltage level one setup time prior to the HIGH-to-LOW LE transition
= Don’t care
= High impedance OFF-state
1998 Jul 29
4
Q0 to Q7
74LVC573A
RECOMMENDED OPERATING CONDITIONS
LIMITS
SYMBOL
VCC
VI
VO
PARAMETER
CONDITIONS
UNIT
MIN
MAX
DC supply voltage (for max. speed performance)
2.7
3.6
DC supply voltage (for low-voltage applications)
1.2
3.6
DC Input voltage range
DC output voltage range; output HIGH or LOW
state
VCC
DC output voltage range; output 3-State
–40
+85
°C
ns/V
V
Tamb
Operating ambient temperature range in free-air
tr, tf
Input rise and fall times
VCC = 1.2 to 2.7V
VCC = 2.7 to 3.6V
V
V
ABSOLUTE MAXIMUM RATINGS1
In accordance with the Absolute Maximum Rating System (IEC 134)
Voltages are referenced to GND (ground = 0V)
PARAMETER
SYMBOL
VCC
CONDITIONS
UNIT
–0.5 to +6.5
V
IIK
DC input diode current
VI 0
–50
mA
VI
DC input voltage
Note 2
–0.5 to +6.5
V
IOK
DC output diode current
VO VCC or VO 0
50
mA
DC output voltage; output HIGH or LOW state
Note 2
–0.5 to VCC +0.5
DC output voltage; output 3-State
Note 2
–0.5 to 6.5
DC output source or sink current
VO = 0 to VCC
VO
IO
IGND, ICC
Tstg
PTOT
DC supply voltage
RATING
DC VCC or GND current
Storage temperature range
Power dissipation per package
– plastic mini-pack (SO)
– plastic shrink mini-pack (SSOP and TSSOP)
above +70°C derate linearly with 8 mW/K
above +60°C derate linearly with 5.5 mW/K
V
50
mA
100
mA
–65 to +150
°C
500
500
mW
NOTES:
1. Stresses beyond those listed may cause permanent damage to the device. These are stress ratings only and functional operation of the
device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to
absolute-maximum-rated conditions for extended periods may affect device reliability.
2. The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
1998 Jul 29
5
74LVC573A
DC ELECTRICAL CHARACTERISTICS
Over recommended operating conditions voltages are referenced to GND (ground = 0V)
LIMITS
SYMBOL
PARAMETER
TEST CONDITIONS
Temp = -40°C to +85°C
MIN
VIH
HIGH level Input voltage
VIL
LOW level Input voltage
VOH
O
VCC = 1.2V
VCC
VCC = 2.7 to 3.6V
2.0
TYP1
V
VCC = 1.2V
GND
V
VCC = 2.7 to 3.6V
HIGH level output voltage
0.8
VCC = 2.7V; VI = VIH or VIL; IO = –12mA
VCC*0.5
VCC = 3.0V; VI = VIH or VIL; IO = –100µA
VCC*0.2
VCC = 3.0V; VI = VIH or VIL; IO = –18mA
VCC*0.6
VCC = 3.0V; VI = VIH or VIL; IO = –24mA
VCC*0.8
VCC
V
VCC = 2.7V; VI = VIH or VIL; IO = 12mA
VOL
LOW level output voltage
0.40
VCC = 3.0V; VI = VIH or VIL; IO = 100µA
GND
0.20
VCC = 3.0V; VI = VIH or VIL; IO = 24mA
II
Input leakage
current2
UNIT
MAX
V
0.55
VCC = 3
3.6V;
6V; VI = 5
5.5V
5V or GND
"0 1
"0.1
"5
µA
IOZ
3-State output OFF-state current
VCC = 3.6V; VI = VIH or VIL; VO = 5.5V or GND
0.1
"10
µA
Ioff
Power off leakage supply
VCC = 0.0V; VI or VO = 5.5V
0.1
"10
µA
ICC
Quiescent supply current
VCC = 3.6V; VI = VCC or GND; IO = 0
0.1
10
µA
Additional quiescent supply current
per input pin
VCC = 2.7V to 3.6V; VI = VCC –0.6V; IO = 0
5
500
µA
∆ICC
NOTES:
1. All typical values are at VCC = 3.3V and Tamb = 25°C.
2. The specified overdrive current at the data input forces the data input to the opposite logic input state.
AC CHARACTERISTICS
GND = 0V; tr = tf v 2.5ns; CL = 50pF; RL = 500Ω; Tamb = –40°C to +85°C.
LIMITS
SYMBOL
tPHL
tPLH
tPHL
tPLH
tPZH
tPZL
tPHZ
tPLZ
tW
tSU
th
PARAMETER
Propagation delay
Dn to Qn
Propagation delay
LE to Qn
3-State output enable time
OE to Qn
3-State output disable time
OE to Qn
LE pulse width HIGH
Setup time
Dn to LE
Hold time
Dn to LE
WAVEFORM
VCC = 3.3V ±0.3V
VCC = 1.2V
UNIT
TYP1
MAX
MIN
MAX
TYP
1, 5
1.5
4.3
6.2
1.5
7.2
19
ns
2, 5
1.5
4.6
6.5
1.5
7.5
21
ns
2, 5
1.5
3.8
7.5
1.5
8.5
17
ns
3, 5
1.5
3.5
6.0
1.5
6.5
15
ns
2
3.2
1.6
3.2
ns
4
1.7
0.3
1.7
ns
4
1.4
0.2
1.5
ns
NOTE:
1. Unless otherwise stated, all typical values are at VCC = 3.3V and Tamb = 25°C.
1998 Jul 29
VCC = 2.7V
MIN
6
74LVC573A
ÉÉÉ
ÉÉÉÉÉÉÉÉ
ÉÉÉ
ÉÉÉ ÉÉÉÉÉÉÉÉ
ÉÉÉ
ÉÉÉ ÉÉÉÉÉÉÉÉ
ÉÉÉ
AC WAVEFORMS
VM = 1.5V at VCC w 2.7V; VM = 0.5 VCC at VCC t 2.7V.
VOL and VOH are the typical output voltage drop that occur with the
output load.
VX = VOL + 0.3V at VCC w 2.7V; VX = VOL + 0.1 VCC at VCC t 2.7V
VY = VOH –0.3V at VCC w 2.7V; VY = VOH – 0.1 VCC at VCC t 2.7V
VI
Dn
INPUT
VM
GND
th
th
tSU
tSU
VI
VI
INPUT
LE
INPUT
VM
VM
GND
GND
tPHL
VOH
tPLH
OUTPUT
NOTE: The shaded areas indicate when the input is permitted to change
for predictable output performance.
VM
SW00073
Waveform 4. Data setup and hold times for the Dn input to the
LE input.
VOL
SY00041
Waveform 1. Input (Dn) to output (Qn) propagation delays.
TEST CIRCUIT
S1
VCC
VI
2
很抱歉,暂时无法提供与“74LVC573AD,118”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2000+1.503152000+0.18234
- 4000+1.496134000+0.18149
- 8000+1.496108000+0.18148
- 10000+1.4960610000+0.18148
- 30000+1.4960330000+0.18148
