SPECIFICATION
Part No.
: MA603.A.ABK.001
Product Name
: Spartan Antenna 3in1 MA603
Low Profile Screw-Mount (Permanent Mount)
GPS/GLONASS/GALILEO Cellular/915MHz
combination antenna
Features
: Cellular
850/900/1700/1800/2100MHz
GSM/CDMA/UMTS/HSPA
GPS/GLONASS/GALILEO
1575~1602MHz 5dBiC
915MHz (902MHz~928 MHz) 3dBi
(incl. 3m cable)
IP67 Waterproof
High Efficiency / Peak Gain Outdoor Antenna
Advanced RF Design and Materials
Heavy Duty – Integrated Metal Base/
Ground-plane
Standard 3 meters low loss cables
Custom cables and connectors available
RoHS Compliant
SPE-12-8-039/D/SS
Page 1 of 20
MA603.A301111.B305111.K305111
1. Introduction
The Spartan MA603 antenna is a low profile, heavy-duty, fully IP67 waterproof
external M2M antenna for use in telematics, transportation and remote monitoring
applications.
The Spartan MA603 antenna is unique in the market because it combines 3in1
GPS/GLONASS/GALILEO, Cellular (3G/2G) and 915MHz antennas in a heavy-duty
structure with high efficiency in a low profile compact format at 35mm (1.38”) profile
Height. The antenna screws down permanently onto a roof or metal panel and can be
pole or wall-mounted.
For industries such as commercial vehicle telematics, remote monitoring, smart meter
systems, construction equipment, at only 35mm high, the Spartan provides an
unobtrusive, robust, rugged antenna that is durable even in extreme environments.
Custom designed integrated wall mounted and pole mounted brackets are available for
the Spartan antennas. These patent pending mounts allow for 180 degrees freedom of
movement of the antennas for ease of positioning while also preventing access to the
cables so they cannot be cut by vandals or thieves and also protecting the cables from
long term weather exposure. The removal of unsightly cables also leads to a cleaner
more professional installation and look, and makes the antenna less identifiable and
more unobtrusive. Customized cable sleeves can be supplied for extra protection
where required.
SPE-12-8-039/D/SS
Page 2 of 20
2. Specification
GPS-GLONASS-GALILEO
Centre Frequency
1575.42MHz / 1602MHz
Bandwidth
10MHz
Radiation Efficiency
50(without cable)
Passive Gain @ Zenith
4.0 typ(with ψ=140mm ground)
VSWR
2
Impedance
50Ω
DC Power Input Range
3 ~ 5V
DC input
3.3V
4.0V
5.5V
MHz
1575.42
1602
1575.42
1602
1575.42
1602
VSWR
2
2
2
2
2
2
LNA Gain
29.2
29
31
31
32.3
32
Noise Figure
3.1
3.1
3.2
3.2
3.4
3.4
Power Consumption
7.5
7.5
9.4
9.4
15
15
Band Attenuation
1520MHz: -20dB
1520MHz: -20dB
1520MHz: -20dB
1642MHz: -20dB
1642MHz: -20dB
1642MHz: -20dB
Cable
3m RG-174 standard, fully customizable
Connector
SMA(M) standard, fully customizable
CELLULAR
Frequency (GHz)
824 ~ 896
880 ~ 960
1710 ~ 1880
1850 ~ 1990
1710 ~ 2170
Peak Gain (dBi)
2.1
-0.2
2.9
3.0
5.1
Average (dBi)
-4.7
-7.5
-2.7
-3.1
-3.1
Efficiency
35%
20%
51%
49%
49%
Impedance
50Ω
Polarization
Linear
Radiation Pattern
Omni
Cable
3m CFD200 standard, fully customizable
Connector
SPE-12-8-039/D/SS
Page 3 of 20
ELECTRICAL – 915MHz
Frequency (MHz)
902MHz
915MHz
929MHz
Gain (dBi) *
3.2
2.3
2.7
Efficiency (%) *
49
44
42
VSWR
1.92 Max
*Including 3 meters cable loss
Cable
Connector
MECHANICAL
Antenna Dimensions
Height 35.1mm(1.38”) x Diameter 145.6mm(5.73”)
Housing
UV resistant ABS
Base and thread
Zinc
Waterproof
IP67
ENVIRONMENTAL
Operating Temperature
-40°C to 85°C
Storage Temperature
-40°C to 80°C
Humidity
Non-condensing 65°C 95% RH
SPE-12-8-039/D/SS
Page 4 of 20
3. GPS/GLONASS/GALILEO Antenna
Characteristics
3.1. Block diagram
3.2. Return Loss
SPE-12-8-039/D/SS
Page 5 of 20
3.3. GPS/GLONASS/GALILEO Antenna Radiation Pattern
MA.600 tested in CTIA approved 3D chamber
XYZ co-ordinate for reference.
SPE-12-8-039/D/SS
Page 6 of 20
3.4. Radiation Pattern
XZ Plane Free Space @1575.42MHz
YZ Plane Free Space @1575.42MHz
SPE-12-8-039/D/SS
Page 7 of 20
XZ-plane Free Space @1602MHz
YZ-plane Free Space @1602MHz
SPE-12-8-039/D/SS
Page 8 of 20
3.5. GPS/GLONASS/GALILEO LNA
SPE-12-8-039/D/SS
Page 9 of 20
4. Cellular Antenna Characteristics
4.1. Return Loss
-4
-6
-8
-10
-12
(dB)
-14
-16
-18
-20
-22
-24
-26
-28
-30
600
800
1000
1200
1400
1600
1800
2000
2200
2400
2600
2800
3000 (MHz)
4.2. VSWR
8
7
6
5
4
3
2
1
600
800
1000
1200
1400
1600
1800
2000
2200
2400
2600
2800
SPE-12-8-039/D/SS
3000 (MHz)
Page 10 of 20
4.3. Cellular Antenna Efficiency
80
70
60
50
40
30
800
1000 1200 1400 1600 1800 2000 2200 2400 2600 2800 3000 (MHz)
4.4. Cellular Antenna Peak Gain
6
5
4
3
2
1
(dBi)
-1
-2
-3
-4
-5
-6
-7
-8
-9
-10
600
800
1000
1200
1400
1600
1800
2000
2200
2400
2600
2800
SPE-12-8-039/D/SS
3000 (MHz)
Page 11 of 20
4.5. Cellular Antenna 3D Average Gain
-2
-3
(dBi)
-4
-5
-6
-7
-8
-9
-10
600
800
SPE-12-8-039/D/SS
Page 12 of 20
5. Cellular Antenna Radiation Pattern
5.1. XY Plane
330
5
15
30
315
45
-10
300
60
-15
-20
285
75
-25
-30
270
-35
90
255
105
240
700MHz
120
850MHz
225
135
210
900MHz
1800MHz
150
195
1900MHz
165
180
2200MHz
5.2. XZ Plane
330
5
15
30
315
45
-10
300
60
-15
-20
285
75
-25
-30
270
-35
90
255
105
240
120
700MHz
850MHz
225
135
210
150
195
165
180
900MHz
1800MHz
1900MHz
2200MHz
SPE-12-8-039/D/SS
Page 13 of 20
6. 915MHz Antenna
6.1. Return Loss
SPE-12-8-039/D/SS
Page 14 of 20
6.2. Antenna Radiation Patterns – Free Space
XY Plane
XZ Plane
SPE-12-8-039/D/SS
Page 15 of 20
6.3. 915MHz Antenna – on metal ground plane
XY Plane
XZ Plane
SPE-12-8-039/D/SS
Page 16 of 20
7. Mechanical Drawing
SPE-12-8-039/D/SS
Page 17 of 20
8. Installation
SPE-12-8-039/D/SS
Page 18 of 20
9. Packaging
SPE-12-8-039/D/SS
Page 19 of 20
Part No. : MA603
Description: GPS/GLONASS/GALILEO Cellular/915MHz 3-in-1
Antenna
Q’ty : 8
Cable: 3m, RG-174 & CFD-200
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and
reserves the right to make changes to specifications and product descriptions at any time without notice.
Taoglas reserves all rights to this document and the information contained herein.
Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
Copyright © Taoglas Ltd.
SPE-12-8-039/D/SS
Page 20 of 20
很抱歉,暂时无法提供与“MA603.A.ABK.001”相匹配的价格&库存,您可以联系我们找货
