NSI8266W0-DSWR
NSI8266W0-DSWR
    NOVOSENSE(纳芯微)
    SOP16_300MIL
    NSI8266W0-DSWR
NSI8266W0-DSWR 数据手册
NSI8266 High Reliability Reinforced Six-Channel Digital Isolators for IPM Datasheet (EN) 1.1 Product Overview Safety Regulatory Approvals NSi8266 is a high reliability six-channel digital isolator, The NSi8266 device is safety certified by UL1577 support several insulations withstand voltage(3kV,5kV), while providing high electromagnetic immunity and low emissions at low power consumption. The data rate of NSi8266 is up to 150Mbps, and the common-mode transient immunity (CMTI) is up to 200kV/us. NSi8266’s default output is low when input power is lost to prevent IPM switching during power on stage. Wide supply voltage of NSi8266 supports to connect with most digital interface directly. High system level EMC performance enhance reliability and stability of use. NSi8266 has the interlock function for adjacent channels to provide the shoot-through protection, to eliminate the short-circuit risk of IGBT inside the IPM, to enhance system robust.  UL recognition: up to 5000Vrms for 1 minute per UL1577 Key Features  CQC certification per GB4943.1-2011  CSA component notice 5A approval IEC60950-1 standard  DIN VDE V 0884-11:2017-01 Applications  Industrial automation system  Isolated SPI, RS232, RS485  General-purpose multichannel isolation  Motor Control Device Information Part Number NSI8266W0-DSWR Package SOP16(300mil) Body Size 10.30mm × 7.50mm NSI8266S0-DSSR SSOP16 4.90mm × 3.90mm  Up to 5000Vrms Insulation voltage  Date rate: DC to 150Mbps  Power supply voltage: 2.5V to 5.5V  High CMTI: 200kV/us Functional Block Diagrams VDD 1 1 16 VDD 2 AH_IN 2 15 AH_OUT AL_IN 3 14 AL_OUT BH_IN 4 13 BH_OUT BL_IN 5 12 BL_OUT  Low power consumption: 1.5mA/ch (1 Mbps) CH_IN 6 11 CH_OUT  Low propagation delay: 60 years  RoHS-compliant packages: SOP16(300mil) NSi8266 Figure 1. NSi8266 Block Diagram SSOP16 Copyright © 2019, NOVOSENSE Page 1 NSi8266 Datasheet (EN) 0.1 INDEX 1. PIN CONFIGURATION AND FUNCTIONS ............................................................................................................................... 3 2. ABSOLUTE MAXIMUM RATINGS .......................................................................................................................................... 4 3. RECOMMENDED OPERATING CONDITIONS ......................................................................................................................... 4 4. THERMAL INFORMATION .................................................................................................................................................... 5 5. SPECIFICATIONS .................................................................................................................................................................. 5 5.1. ELECTRICAL CHARACTERISTICS .............................................................................................................................................. 5 5.2. SUPPLY CURRENT CHARACTERISTICS – 5V SUPPLY ..................................................................................................................... 5 5.3. SUPPLY CURRENT CHARACTERISTICS –3.3V SUPPLY................................................................................................................... 6 5.4. SUPPLY CURRENT CHARACTERISTICS–2.5V SUPPLY ................................................................................................................... 6 5.5. SWITCHING CHARACTERISTICS - 5V SUPPLY ............................................................................................................................. 8 5.6. SWITCHING CHARACTERISTICS - 3.3V SUPPLY .......................................................................................................................... 8 5.7. SWITCHING CHARACTERISTICS - 2.5V SUPPLY .......................................................................................................................... 9 5.8. TYPICAL PERFORMANCE CHARACTERISTICS ............................................................................................................................ 10 5.9. PARAMETER MEASUREMENT INFORMATION .......................................................................................................................... 10 6. HIGH VOLTAGE FEATURE DESCRIPTION ............................................................................................................................. 11 6.1. INSULATION AND SAFETY RELATED SPECIFICATIONS ................................................................................................................. 11 6.2. SAFETY-LIMITING VALUES ................................................................................................................................................. 12 6.3. REGULATORY INFORMATION............................................................................................................................................... 13 7. FUNCTION DESCRIPTION ................................................................................................................................................... 15 7.1. OVERVIEW..................................................................................................................................................................... 15 7.2. OOK MODULATION ......................................................................................................................................................... 15 7.3. SHOOT THROUGH PROTECTION .......................................................................................................................................... 16 8. APPLICATION NOTE ........................................................................................................................................................... 17 8.1. TYPICAL APPLICATION CIRCUIT ........................................................................................................................................... 17 8.2. PCB LAYOUT .................................................................................................................................................................. 17 8.3. HIGH SPEED PERFORMANCE .............................................................................................................................................. 18 8.4. TYPICAL SUPPLY CURRENT EQUATIONS ................................................................................................................................. 18 9. PACKAGE INFORMATION ................................................................................................................................................... 19 10. ORDERING INFORMATION .............................................................................................................................................. 20 11. DOCUMENTATION SUPPORT ........................................................................................................................................... 21 12. TAPE AND REEL INFORMATION ....................................................................................................................................... 22 13. REVISION HISTORY .......................................................................................................................................................... 24 Copyright © 2019, NOVOSENSE Page 2 NSi8266 Datasheet (EN) 1.1 1. Pin Configuration and Functions VDD 1 1 16 VDD 2 AH_IN 2 15 AH_OUT AL_IN 3 14 AL_OUT BH_IN 4 13 BH_OUT BL_IN 5 12 BL_OUT CH_IN 6 11 CH_OUT CL_IN 7 10 CL_OUT GND 1 8 9 GND 2 NSi8266 Figure 1.1 NSi8266 Package Table 1.1 NSi8266 Pin Configuration and Description NSi8266 PIN NO. SYMBOL FUNCTION 1 VDD1 Power Supply for Isolator Side 1 2 AH_IN High side Logic Input AH 3 AL_IN Low side Logic Input AL 4 BH_IN High side Logic Input BH 5 BL_IN Low side Logic Input BL 6 CH_IN High side Logic Input CH 7 CL_IN Low side Logic Input CL 8 GND1 Ground 1, the ground reference for Isolator Side 1 9 GND2 Ground 2, the ground reference for Isolator Side 2 10 CL_OUT Low side Logic Output CL 11 CH_OUT High side Logic Output CH 12 BL_OUT Low side Logic Output BL 13 BH_OUT High side Logic Output BH 14 AL_OUT Low side Logic Output AL 15 AH_OUT High side Logic Output AH 16 VDD2 Power Supply for Isolator Side 2 Copyright © 2019, NOVOSENSE Page 3 NSi8266 Datasheet (EN) 1.1 2. Absolute Maximum Ratings Parameters Power Supply Voltage Maximum Input Voltage Maximum Output Voltage Maximum Input/Output Pulse Voltage Output current Symbol Min Typ Max Unit VDD1, VDD2 -0.5 6.5 V VINA, VINB, VINC, VIND, VINE, VINF -0.4 VDD+0.4 V The maximum voltage must not exceed 6.5V VOUTA, VOUTB, VOUTC, VOUTD, VOUTE, VOUTF -0.4 VDD+0.4 V The maximum voltage must not exceed 6.5V ALL I/O Pin -0.8 VDD+0.8 V Pulse width should be less than 100ns, and the duty cycle should be less than 10% Io -15 15 mA 6.25 kV Maximum Surge Isolation Voltage VIOSM Operating Temperature Topr -40 125 ℃ Storage Temperature Tstg -40 150 ℃ HBM ±6000 V CDM ±2000 V Comments Electrostatic discharge 3. Recommended Operating Conditions Parameters Symbol Min VDD1, VDD2 2.5 High-level Input Voltage VIH 2 Low-level Input Voltage VIL Data Rate DR Ambient Temperature Ta Power Supply Voltage Copyright © 2019, NOVOSENSE Typ Max 5.5 Unit Comments V V 0.8 V 0 150 Mbps -40 125 ℃ Page 4 NSi8266 Datasheet (EN) 1.1 4. Thermal Information Parameters Symbol SOP16(300mil) SSOP16 Unit Junction-to-ambient thermal resistance θJA 60.3 86.5 °C/W Junction-to-case(top) thermal resistance θJC(top) 24.0 26.9 °C/W θJB 29.3 36.6 °C/W Junction-to-board thermal resistance 5. Specifications 5.1. Electrical Characteristics Parameters Symbol Power on Reset VDDPOR Input Threshold Min Typ Unit Comments 2.2 V POR threshold as during powerup VDD HYS 0.1 V POR threshold Hysteresis VIT 1.6 V Input Threshold at rising edge VIT_HYS 0.4 V Input Threshold Hysteresis High Level Input Voltage VIH Low Level Input Voltage VIL High Level Output Voltage VOH Low Level Output Voltage VOL Output Impedance Rout 50 Input Pull high or low Current Ipull 8 Start Up Time after POR trbs 10 Common Mode Transient Immunity CMTI Max 2 V 0.8 VDD0.4 0.4 ±200 V V IOH =- 4mA V IOL = 4mA ohm 15 µA µs ±250 kV/µs 5.2. Supply Current Characteristics – 5V Supply (VDD1=5V± 10%, VDD2=5V± 10%, Ta=-40℃ to 125℃. Unless otherwise noted, Typical values are at VDD1 = 5V, VDD2 = 5V, Ta = 25℃) Parameters Symbol Min Typ Max Unit Comments 1.39 3.09 mA All Input 0V NSi8266 Supply current IDD1(Q0) Copyright © 2019, NOVOSENSE Page 5 NSi8266 Parameters Datasheet (EN) 1.1 Symbol Min Typ Max Unit Comments IDD2(Q0) 3.41 5.63 mA IDD1(Q1) 7.37 12.16 mA IDD2(Q1) 3.49 5.76 mA IDD1(16k) 4.39 7.24 mA All Input with 16kbps, IDD2(16k) 3.67 6.06 mA CL=15pF IDD1(1M) 1.39 3.09 mA All Input with 1Mbps, IDD2(1M) 3.41 5.63 mA CL=15pF All Input at supply 5.3. Supply Current Characteristics –3.3V Supply (VDD1=3.3V± 10%, VDD2=3.3V± 10%, Ta=-40℃ to 125℃. Unless otherwise noted, Typical values are at VDD1 = 3.3V, VDD2 = 3.3V, Ta = 25℃) Parameters Symbol Min Typ Max Unit Comments IDD1(Q0) 1.33 3.00 mA All Input 0V IDD2(Q0) 3.36 5.54 mA IDD1(Q1) 7.26 11.98 mA IDD2(Q1) 3.43 5.66 mA IDD1(16k) 4.31 7.11 mA All Input with 16kbps, IDD2(16k) 3.55 5.86 mA CL=15pF IDD1(1M) 1.33 3.00 mA All Input with 1Mbps, IDD2(1M) 3.36 5.54 mA CL=15pF NSi8266 Supply current All Input at supply 5.4. Supply Current Characteristics–2.5V Supply (VDD1=2.5V± 10%, VDD2=2.5V± 10%, Ta=-40℃ to 125℃. Unless otherwise noted, Typical values are at VDD1 = 2.5V, VDD2 = 2.5V, Ta = 25℃) Copyright © 2019, NOVOSENSE Page 6 NSi8266 Parameters Datasheet (EN) 1.1 Symbol Min Typ Max Unit Comments IDD1(Q0) 1.29 2.94 mA All Input 0V IDD2(Q0) 3.33 5.49 mA IDD1(Q1) 7 11.55 mA IDD2(Q1) 3.39 5.59 mA IDD1(16k) 4.17 6.88 mA All Input with 16kbps, IDD2(16k) 3.47 5.73 mA CL=15pF IDD1(1M) 1.29 2.94 mA All Input with 1Mbps, IDD2(1M) 3.33 5.49 mA CL=15pF NSi8266 Supply current Copyright © 2019, NOVOSENSE All Input at supply Page 7 NSi8266 Datasheet (EN) 1.1 5.5. Switching Characteristics - 5V Supply (VDD1=5V± 10%, VDD2=5V± 10%, Ta=-40℃ to 125℃. Unless otherwise noted, Typical values are at VDD1 = 5V, VDD2 = 5V, Ta = 25℃) Parameters Symbol Min Data Rate DR 0 Minimum Pulse Width PW Propagation Delay t PLH 2.5 t PHL 2.5 Max Unit 150 Mbps 5.0 ns 6.54 15 ns See Figure 5.5 , CL = 15pF 8.30 15 ns See Figure 5.5 , CL = 15pF PWD 5.0 ns See Figure 5.5 , CL = 15pF Rising Time tr 5.0 ns See Figure 5.5 , CL = 15pF Falling Time tf 5.0 ns See Figure 5.5 , CL = 15pF Pulse Width Distortion Typ Comments |t PHL – t PLH | Peak Eye Diagram Jitter tJIT(PK) 350 ps Channel-to-Channel Delay Skew tSK(c2c) 2.5 ns Part-to-Part Delay Skew tSK(p2p) 5.0 ns 5.6. Switching Characteristics - 3.3V Supply (VDD1=3.3V± 10%, VDD2=3.3V± 10%, Ta=-40℃ to 125℃. Unless otherwise noted, Typical values are at VDD1 = 3.3V, VDD2 = 3.3V, Ta = 25℃) Parameters Symbol Min Data Rate DR 0 Minimum Pulse Width PW Propagation Delay t PLH 2.5 t PHL 2.5 Max Unit 150 Mbps 5.0 ns 8.0 15 ns See Figure 5.5 , CL = 15pF 8.7 15 ns See Figure 5.5 , CL = 15pF PWD 5.0 ns See Figure 5.5 , CL = 15pF Rising Time tr 5.0 ns See Figure 5.5 , CL = 15pF Falling Time tf 5.0 ns See Figure 5.5 , CL = 15pF Pulse Width Distortion Typ Comments |t PHL – t PLH | Peak Eye Diagram Jitter tJIT(PK) Channel-to-Channel Delay Skew tSK(c2c) Copyright © 2019, NOVOSENSE 350 ps 2.5 ns Page 8 NSi8266 Datasheet (EN) 1.1 Parameters Symbol Part-to-Part Delay Skew tSK(p2p) Min Typ Max Unit 5.0 ns Comments 5.7. Switching Characteristics - 2.5V Supply (VDD1=2.5V± 10%, VDD2=2.5V± 10%, Ta=-40℃ to 125℃. Unless otherwise noted, Typical values are at VDD1 = 2.5V, VDD2 = 2.5V, Ta = 25℃) Parameters Symbol Min Data Rate DR 0 Minimum Pulse Width PW Propagation Delay t PLH 2.5 t PHL 2.5 Max Unit 150 Mbps 5.0 ns 9.0 15 ns See Figure 5.5 , CL = 15pF 9.3 15 ns See Figure 5.5 , CL = 15pF PWD 5.0 ns See Figure 5.5 , CL = 15pF Rising Time tr 5.0 ns See Figure 5.5 , CL = 15pF Falling Time tf 5.0 ns See Figure 5.5 , CL = 15pF Pulse Width Distortion Typ Comments |t PHL – t PLH | Peak Eye Diagram Jitter tJIT(PK) Channel-to-Channel Delay Skew tSK(c2c) 2.5 ns Part-to-Part Delay Skew tSK(p2p) 5.0 ns Copyright © 2019, NOVOSENSE 350 ps Page 9 NSi8266 Datasheet (EN) 1.1 5.8. Typical Performance Characteristics IDD1 IDD2 3.8 Supply Current(mA) Supply Current(mA) 6 3.6 4 5 3.3 2.5 2 0 0 500 1000 3.4 5 3.3 2.5 3.2 3 0 1500 500 Data Rate (bps) 1500 Data Rate(bps) Figure 5.1 NSi8266 VDD1 Supply Current vs Data Rate Figure 5.2 NSi8266 VDD2 Supply Current vs Data Rate 12 10 Prooagation Delay(ns) Prooagation Delay(ns) 1000 10 8 6 4 2.5 3.3 5 2 0 -40 10 60 110 6 4 2.5 3.3 5 2 0 160 Temperature(°C) 8 -40 10 60 110 160 Temperature(°C) Figure 5.3 Rising Edge Propagation Delay Vs Temp Figure 5.4 Falling Edge Propagation Delay Vs Temp 5.9. Parameter Measurement Information Input Generator VI 50Ω VO CL Figure 5.5 Switching Characteristics Test Circuit and Waveform Copyright © 2019, NOVOSENSE Page 10 NSi8266 Datasheet (EN) 1.1 VDD1 VDD2 IN OUT VO Battery DC CL GND2 GND1 VCM Figure 5.6 Common-Mode Transient Immunity Test Circuit 6. High Voltage Feature Description 6.1. Insulation and Safety Related Specifications Description Test Condition Symbol Value SSOP16 Unit SOP16 (300mil) Min. External Air Gap (Clearance) CLR 3.9 8 mm Min. External Tracking (Creepage) CPG 3.9 8 mm Distance through the Insulation DTI 32 CTI >600 Comparative Tracking Index DIN EN 60112 (VDE 0303-11) Material Group IEC 60112 um V I Installation Classification per DIN VDE 0110 For Rated Mains Voltage ≤ 150Vrms I to III I to IV For Rated Mains Voltage ≤ 300Vrms I to II I to IV For Rated Mains Voltage ≤ 600Vrms I I to IV For Rated Mains Voltage ≤ 1000Vrms / I to III Insulation Specification per DIN VDE V 0884-11:2017-011) Climatic Category 40/125/21 Pollution Degree per DIN VDE 0110, Table 1 Maximum Working Isolation Voltage AC voltage 2 VIOWM 400 1500 VRMS 565 2121 VDC VIORM 565 2121 Vpeak Vpd (m) 847 / Vpeak DC voltage Maximum Voltage Repetitive Isolation Vini. b = VIOTM, Vpd(m) = VIORM × 1.5, Copyright © 2019, NOVOSENSE Page 11 NSi8266 Datasheet (EN) 1.1 Description Input to Output Test Voltage, Method B1 Test Condition Symbol Value Unit tini = tm = 1 sec, qpd ≤ 5 pC, 100% production test Vini. b = VIOTM, Vpd(m) = VIORM × 1.875, Vpd (m) / 3977 Vpeak V pd (m) 678 / Vpeak V pd (m) / 3394 Vpeak V pd (m) 678 2545 Vpeak tini = tm =1 sec, qpd≤ 5 pC, 100% production test Input to Output Test Voltage, Method A. After Environmental Tests Subgroup 1 Vini. a = VIOTM, Vpd(m) = VIORM × 1.3, tini = 60 sec, tm = 10 sec, qpd ≤ 5 pC Vini. a = VIOTM, Vpd(m) = VIORM × 1.6, tini = 60 sec, tm = 10 sec, qpd ≤ 5 pC Input to Output Test Voltage, Method A. After Input and Output Safety Test Subgroup 2 and Subgroup 3 Vini. a = VIOTM, Vpd(m) = VIORM × 1.2, Maximum Transient Isolation Voltage t = 60 sec VIOTM 3000 8000 Vpeak Maximum Surge Isolation Voltage Test method per IEC62368-1, VIOSM 4500 / Vpeak / 6250 Vpeak tini = 60 sec, tm = 10 sec, qpd ≤ 5 pC 1.2/50us waveform, VTEST = 1.3 × VIOSM Test method per IEC62368-1, 1.2/50us waveform, VTEST = 1.6 × VIOSM Isolation Resistance VIO = 500 V, Tamb = TS RIO VIO = 500 V, 100 °C ≤ Tamb ≤ 125 °C Isolation Capacitance f = 1MHz CIO VTEST = 1.2 × VISO, t = 1 sec, VISO >109 Ω >1011 Ω 1.2 pF Insulation Specification per UL1577 Withstand Isolation Voltage 3000 5000 Vrms 100% production test 6.2. Safety-Limiting Values Reinforced isolation safety-limiting values as outlined in VDE-0884-11 of NSI8266-DSWR Description Test Condition Value Unit Safety Supply Power RθJA = 60.3 °C/W, TJ = 150 °C, TA = 25 °C 2073 mW Safety Supply Current RθJA = 60.3 °C/ W, VI = 5V, TJ = 150 °C, TA = 25 °C 414 mA 150 °C Safety Temperature2) 1) Calculate with the junction-to-air thermal resistance, RθJA, of SOP16(300mil) package (Thermal Information Table) which is that of a device installed on a low effective thermal conductivity test board (1s) according to JESD51-3. Copyright © 2019, NOVOSENSE Page 12 NSi8266 The maximum safety temperature has the same value as the maximum junction temperature (TJ) specified for the device. Safety Limiting Power (mW) 2) Datasheet (EN) 1.1 450 400 350 300 250 200 150 100 50 0 0 50 100 150 200 Ambient Temperature (°C) Figure 6.1 NSI826x-DSWR Thermal Derating Curve, Dependence of Safety Limiting Values with Case Temperature per DIN VDE V 0884-11 Basic isolation safety-limiting values as outlined in VDE-0884-11 of NSI8266-DSSR Description Test Condition Value Unit Safety Supply Power RθJA =86.5 °C/W, TJ = 150 °C, TA = 25 °C 1445 mW Safety Supply Current RθJA = 86.5 °C/ W, VI = 5V, TJ = 150 °C, TA = 25 °C 289 mA 150 °C Safety Temperature2) Calculate with the junction-to-air thermal resistance, RθJA, of SSOP16 package (Thermal Information Table) which is that of a device installed on a low effective thermal conductivity test board (1s) according to JESD51-3. 4) The maximum safety temperature has the same value as the maximum junction temperature (TJ) specified for the device. Safety Limiting Power (mW) 3) 350 300 250 200 150 100 50 0 0 50 100 150 200 Ambient Temperature (°C) Figure 6.1 NSI8266-DSSRThermal Derating Curve, Dependence of Safety Limiting Values with Case Temperature per DIN VDE V 0884-11 6.3. Regulatory Information The NSi8266W0-DSWR are approved or pending approval by the organizations listed in table. CUL Copyright © 2019, NOVOSENSE VDE CQC Page 13 NSi8266 Datasheet (EN) 1.1 UL 1577 Component Recognition Program1 Approved under CSA Component Acceptance Notice 5A Single Protection, 5000Vrms Isolation voltage File (pending) Single Protection, 5000Vrms Isolation voltage File (pending) DIN VDE V 088411(VDE V 088411):2017-012 Certified by CQC11471543-2012 GB4943.1-2011 Reinforce Insulation 2121Vpeak, VIOSM=6250Vpeak Reinforced insulation at 1500VRMS (2121Vpeak) File (5024579-48800002 / 276211) File (pending) The NSi8266S0-DSSR are approved or pending approval by the organizations listed in table. CUL UL 1577 Component Recognition Program1 Single Protection, 3000Vrms Isolation voltage File (pending) Copyright © 2019, NOVOSENSE VDE Approved under CSA Component Acceptance Notice 5A Single Protection, 3000Vrms Isolation voltage File (pending) DIN VDE V 088411(VDE V 088411):2017-012 CQC Certified by CQC11471543-2012 GB4943.1-2011 Basic Insulation 565Vpeak, VIOSM=5384Vpeak Basic insulation at 400Vrms (565Vpeak) File (pending) File (pending) Page 14 NSi8266 Datasheet (EN) 1.1 7. Function Description 7.1. Overview NSi8266 is high reliability six-channel digital isolator. NSi8266 is safety certified by UL1577 support 5kVrms insulation withstand voltages, while providing high electromagnetic immunity and low emissions at low power consumption. The data rate is up to 150Mbps, and the common-mode transient immunity (CMTI) is up to 200kV/us. NSi8266’s default output is low when input power is lost to prevent IPM switching during power on stage. Wide supply voltage of NSi8266 support to connect with most digital interface directly, easy to do the level shift. High system level EMC performance enhance reliability and stability of use. NSi8266 has a default output status when VDDIN is unready and VDDOUT is ready as shown in Table 4.1, which helps for diagnosis when power is missing at the transmitter side. The other outputs follow the same status with the input A after powering up respectively. Table 7.1 Output status vs. power status Input ENX VDD1 status VDD2 status Output Comment H H or NC Ready Ready H Normal operation. L H or NC Ready Ready L X L Ready Ready Z Output Disabled, the output is high impedance X H or NC Unready Ready L The output follows the same status with the input after input side VDD1 is powered on. X L Unready Ready Z Output Disabled, the output is high impedance X X Ready Unready X The output follows the same status with the input after output side VDD2 is powered on. Note: H=Logic high; L=Logic low; X=Logic low or logic high VDD1 is input side power;VDD2 is out side power. 7.2. OOK Modulation NSi8266 is based on a capacitive isolation barrier technique and the digital signal is modulated with RF carrier generated by the internal oscillator at the transmitter side, as shown in Fig7.1, then it is transferred through the capacitive isolation barrier and demodulated at the receiver side. The modulation uses OOK modulation technique with key benefits of high noise immunity and low radiation EMI. Isolation barrier VIN PWM TX signal conditioning RX signal conditioning envelope detection VOUT EN OSC Figure 7.1 Single Channel Function Block Diagram Copyright © 2019, NOVOSENSE Page 15 NSi8266 Datasheet (EN) 1.1 TX IN Signal through isolation barrier RX OUT Figure 7.2 OOK Modulation 7.3. Shoot Through Protection Channel 1 PWM1 AH_IN PWM2 AL_IN AH_OUT L O G I C HS Channel 2 AL_OUT L O G I C LS NSi8266W0 Figure 7.3 Typical IPM isolated driving Circuit As shown in Fig. 7.3, NSi8266 has the interlock function to provide the shoot through protection to prevent both high-side and low-side switches to be activated simultaneously, if one of the adjacent channels is in ON state, the counterpart PWM signal is inhibited, preventing it to turn high. Fig. 7.4 & Fig.7.5 show the test waveform. Figure 7.4 NSi8266 normal driving signal waveform Copyright © 2019, NOVOSENSE Figure 7.5 NSi8266 driving signal with interlock triggered Page 16 NSi8266 Datasheet (EN) 1.1 8. Application Note 8.1. Typical Application Circuit 隔离电源 VIN=5V/3.3V VOUT=5V/3.3V VDD2 VDD1 100nF PWM1 PWM2 PWM3 MCU 16 1 VDD 1 2 AH_IN AH_OUT 15 3 AL_IN AL_OUT 14 VDD 2 4 BH_IN BH_OUT 13 5 BL_IN BL_OUT 12 6 CH_IN CH_OUT 11 7 CL_IN CL_OUT 10 8 GND 1 PWM4 100nF PWM_AH PWM_AL PWM_BH PWM_BL IPM PWM_CH PWM5 PWM6 GND 2 PWM_CL 9 NSi8266W0 Figure 8.1 Typical IPM isolated driving Circuit 8.2. PCB Layout NSi8266 requires a 0.1 µF bypass capacitor between VDD1 and GND1, VDD2 and GND2. The capacitor should be placed as close as possible to the package. Figure 5.1 to Figure 5.2 show the recommended PCB layout, make sure the space under the chip should keep free from planes, traces, pads and via. To enhance the robustness of a design, the user may also include resistors (50–300 Ω) in series with the inputs and outputs if the system is excessively noisy. The series resistors also improve the system reliability such as latch-up immunity. The typical output impedance of an isolator driver channel is approximately 50 Ω, ±40%. When driving loads where transmission line effects will be a factor, output pins should be appropriately terminated with controlled impedance PCB traces. Figure8.2 Recommended PCB Layout — Top Layer Copyright © 2019, NOVOSENSE Figure8.3 Recommended PCB Layout — Bottom Layer Page 17 NSi8266 Datasheet (EN) 1.1 8.3. High Speed Performance 8.4. Typical Supply Current Equations The typical supply current of NSi8266 can be calculated using below equations. IDD1 and IDD2 are typical supply currents measured in mA, f is data rate measured in Mbps, CL is the capacitive load measured in pF NSi8266: IDD1 = 0.22 *a1+1.2*b1+0.7*c1. IDD2 = 3.3+ VDD1*f* CL *c1*10-9 Where a1 is the channel number of low inputs at side 1, b1 is the channel number of high inputs at side 1, c1 is the channel number of switch signal inputs at side 1. Copyright © 2019, NOVOSENSE Page 18 NSi8266 Datasheet (EN) 1.1 9. Package Information Figure 9.1 SOP16(300mil) Package Shape and Dimension in millimeters Copyright © 2019, NOVOSENSE Page 19 NSi8266 Datasheet (EN) 1.1 Figure 9.2 SSOP16 Package Shape and Dimension in millimeters 10. Ordering Information Part Number NSI8266W0 -DSWR NSI8266S0DSSR Isolation Rating (kV) 5 Number of side 1 inputs 6 Number of side 2 inputs 0 Max Data Rate (Mbps) 150 Default Output State Low Temperature MSL Package Type Package Drawing SPQ -40 to 125℃ 2 SOW16 1000 3 6 0 150 Low -40 to 125℃ 1 SOP16 (300mil) SSOP16 SSOP16 2500 Copyright © 2019, NOVOSENSE Page 20 NSi8266 Datasheet (EN) 1.1 Part Number Rule: NSi(82)(6)(6)(W)(0)-DSWR Series Number Total Channel Amount: N=N Channels N=1,2,4 N=0: I2C Part Reverse Channel Amount: N=N Channels N=0,1,2 D = Industrial Q1 = Auto Fail-Safe Output State: 0 = Logic Low 1 = Logic High Package Type: S= SSOP16 W= SOP16(300mil) 11. Documentation Support Part Number Product Folder Datasheet Technical Documents Isolator selection guide NSI8266 Click here Click here Click here Click here Copyright © 2019, NOVOSENSE Page 21 NSi8266 Datasheet (EN) 1.1 12. Tape and Reel Information Figure 12.1 Tape and Reel Information of SOP16(300mil) Copyright © 2019, NOVOSENSE Page 22 NSi8266 Datasheet (EN) 1.1 Figure 12.1 Tape and Reel Information of SSOP16(150mil) Copyright © 2019, NOVOSENSE Page 23 NSi8266 Datasheet (EN) 1.1 13. Revision History Revision 1.0 1.1 Description Initial version Changed tape and reel information Copyright © 2019, NOVOSENSE Date 2020/11/20 2020/12/20 Page 24
NSI8266W0-DSWR 价格&库存
很抱歉,暂时无法提供与“NSI8266W0-DSWR”相匹配的价格&库存,您可以联系我们找货
NSI8266W0-DSWR
    库存:89829
    NSI8266W0-DSWR
      • 1+18.07920
      • 10+15.36840
      • 30+13.67280
      • 100+11.93400
      • 500+11.14560
      • 1000+10.80000
      库存:273
