MMC5883MA-B
MMC5883MA-B
    MEMSIC(美新)
    DEVELOPMENTBOARDFORMMC5883MA
MMC5883MA-B 数据手册
h ±8Gauss, High Performance, Low Cost 3-axis Magnetic Sensor MMC5883MA FEATURES  Fully integrated 3-axis magnetic sensor and electronic circuits requiring fewer external components  Superior Dynamic Range and Accuracy:  ±8G FSR with 16bits operation  0.25mG per LSB resolution  0.4mG total RMS noise  Enables heading accuracy of 1º  Max output data rate of 600Hz  Industrial Standard Low profile package 3.0x3.0x1.0mm  Degaussing with built-in SET/RESET function  Eliminates thermal variation induced offset error (Null field output)  Clears the residual magnetization resulting from strong external fields  On-chip sensitivity compensation  On-chip temperature sensor  Motion_Detection and Data_Ready Interrupt  Low power consumption  1µA power down current  I2C Slave, FAST(≤400KHz) mode  2.5V single low power supply  1.8V I2C interface  RoHS compliant  P2P compatible with HMC5883L APPLICATIONS  Electronic Compass & Navigation  Position Sensing  General Purpose Magnetic Field Measurements DESCRIPTION The MMC5883MA is a complete 3-axis magnetic sensor with on-chip signal processing and integrated I2C bus suitable for use in various applications. The device can be connected directly to a microprocessor, eliminating the need for A/D converters or timing resources. It can measure magnetic fields within the full scale range of 8Gauss (G), with 0.25mG per LSB resolution at 16bits operation mode and 0.4mG total Information furnished by MEMSIC is believed to be accurate and reliable. However, no responsibility is assumed by MEMSIC for its use, or for any infringements of patents or other rights of third parties which may result from its use. No license is granted by implication or otherwise under any patent or patent rights of MEMSIC. MEMSIC MMC5883MA Rev.B FUNCTIONAL BLOCK DIAGRAM RMS noise level, enabling heading accuracy of 1º in electronic compass applications. Contact MEMSIC for access to advanced calibration and tilt-compensation algorithms. An integrated SET/RESET function provides for the elimination of error due to Null Field output change with temperature. Temperature information from the integrated temperature sensor is available over the I2C Interface. The SET/RESET function can be performed for each measurement, periodically, or when the temperature changes by a predetermined amount as the specific application requires. In addition, the SET/RESET function clears the sensors of any residual magnetic polarization resulting from exposure to strong external magnets. The MMC5883MA is packaged in a low profile LGA package (3.0 x 3.0 x 1.0 mm) and an operating temperature range from -40C to +85C. The MMC5883MA provides an I2C digital output with 400 KHz, fast mode operation. MEMSIC, Inc. One Technology Drive, Suite 325, Andover, MA01810, USA Tel: +1 978 738 0900 Fax: +1 978 738 0196 www.memsic.com Page 1 of 15 Formal release date: 10/31/2016 SPECIFICATIONS (Measurements @ 25C, unless otherwise noted; VDD=2.5V unless otherwise specified) Parameter Field Range (Each Axis) Supply Voltage Conditions Min Typ 8 Total applied field Units G VDD 2.16 2.5 3.6 V VDDIO(I Cinterface and INT) 1.62 1.8 3.6 V 5.0 ms 2 Supply Voltage Rise Time Supply Current1 (7 measurements/second) Max BW=00 120 µA BW=01 60 µA BW=10 30 µA BW=11 20 µA Power Down Current 1.0 µA Operating Temperature -40 85 C Storage Temperature Linearity Error (Best fit straight line) Hysteresis -55 125 C Repeatability Error Alignment Error Transverse Sensitivity Total RMS Noise FS=±8G Happlied=±4G 3 sweeps across ±8G 3 sweeps across ±8G BW=00 BW=01 BW=10 BW=11 Output Resolution Max Output data rate Heading Accuracy2 Sensitivity Sensitivity Change Over Temperature3 BW=00 BW=01 BW=10 BW=11 8 G -40~85 C Delta from 25 C 8 G Null Field Output Null Field Output Change Over Temperature Using SET/RESET -40~85 C Delta from 25 C Temperature Sensor Output Disturbing Field4 0.2 %FS 0.2 %FS 0.2 1.0 2.0 0.4 0.6 1.0 1.2 16 100 200 400 600 1.0 5 4096 %FS Degrees % mG mG mG mG Bits Hz Hz Hz Hz Degrees % counts/G 3.0 5 % 0.1 G 32768 Counts 2 mG 128 Counts 0.7 C/Count 10 G Maximum Exposed Field 10,000 SET/RESET Repeatability 2 G mG 1 Supply current is proportional to how many measurements performed per second 2 MEMSIC product enables users to utilize heading accuracy to be 1.0 degree typical when using MEMSIC’s proprietary software or algorithm 3 Determined by 77pcs x 3 lot characterization 4 This is the magnitude of external field that can be tolerated without changing the sensor characteristics. If the disturbing field exceeds, a SET/RESET operation is required to restore proper sensor operation MEMSIC MMC5883MA Rev.B Page 2 of 15 Formal release date: 10/31/2016 DIGITAL INTERFACE (VIO = 1.8V) Symbol VIH Parameter (Units) High Level Input Voltage (Volts) Minimum 0.7*VIO VIL Low Level Input Voltage (Volts) VHYS IIL Hysteresis of Schmitt Trigger Input (Volts) Input Leakage, All Inputs (uA) VOH VOL High Level Output Voltage (Volts) Low Level Output Voltage (Volts) Typical Maximum 0.3*VIO 0.1 -10 10 0.8*VIO 0.2*VIO I2C INTERFACE I/O CHARACTERISTICS (VIO=1.8V) Parameter Symbol Test Condition Min. Typ. Max. Unit Logic Input Low Level VIL -0.5 0.3* VIO V Logic Input High Level VIH 0.7*VIO VIO V Hysteresis of Schmittinput Vhys 0.2 Logic Output Low Level VOL Input Leakage Current Ii SCL Clock Frequency fSCL 0.1VIO
MMC5883MA-B 价格&库存
很抱歉,暂时无法提供与“MMC5883MA-B”相匹配的价格&库存,您可以联系我们找货
