USB-C to Gigabit Network Adapter with USB-C
PD Charging - Thunderbolt 3, White
MODEL NUMBER: U436-06N-G-C
Highlights
Connects a USB Type-C or
Thunderbolt™ 3 device to a
wired Ethernet network
Supports true 10/100/1000
Mbps network speeds
LEDs indicate activity and link
USB-C charge port connects to
wall charger to power device
Compatible with Windows, Mac
and Chromium
Plug-and-play—no software or
drivers required
System Requirements
Adds Gigabit Ethernet and USB-C charging ports to the USB-C or Thunderbolt™ 3 port on your computer,
laptop, tablet or other compatible device. Access true Gigabit network speeds without installing an internal
Ethernet card.
Description
The U436-06N-G-C USB 3.1 Gen 1 USB-C to Gigabit Ethernet NIC Network Adapter allows USB Type-C
or Thunderbolt™ 3 computers, laptops, tablets and other compatible devices without an NIC (Network
Interface Controller) to connect to a network or the Internet using an RJ45 cable. It’s a more convenient
and less expensive way to connect to a network than opening your device and installing an internal
Ethernet card.
No software or drivers are needed. Connect the adapter’s USB-C male plug to the USB-C or
Thunderbolt™ 3 port on your device. Then, connect the adapter’s RJ45 port to a network using a UTP
cable, such as Tripp Lite’s N201-Series Cat6 cables. The U436-06N-G-C allows you to transfer data
quickly and stream audio and video at true 10/100/1000 Mbps Ethernet speeds. Two status LEDs
illuminate when the adapter is successfully connected to the network (link) and transferring data (activity).
The USB-C charging port supports power input up to 20V 3A (60W). It powers the device that the U43606N-G-C is plugged into by connecting the charging port to a USB-C wall charger.
Compliant with IEEE 802.3, 802.3u, 802.3ab and 802.3az standards. Supports 10/100/1000 auto-sensing,
twisted-pair crossover detection, auto-correction and Wake-on-LAN power management. Compatible with
Windows, Mac and Chromium operating systems. Backward compatible with previous USB versions.
USB Type-C™ and USB-C™ are trademarks of USB Implementers Forum
Features
Saves You Time and Money
● Connects USB-C or Thunderbolt™ 3 devices to a network or the Internet without buying and installing
an internal Ethernet card
Plug-and-play engineering—no software or drivers necessary
Compact and lightweight for easy carrying in your laptop bag
Excellent Speed and Versatile Performance
● Sustains full 10/100/1000 Mbps network speeds for fast data transfer
2 LEDs indicate activity and link
Complies with IEEE 802.3, 802.3u, 802.3ab and 802.3az (Energy Efficient Ethernet) standards
1/4
Computer, tablet, laptop or
smartphone with USB Type-C or
Thunderbolt™ 3 port
Windows, Mac or Chromium
operating system
Package Includes
Network Adapter
Owner’s manual
Supports 10/100/1000 auto-sensing, twisted-pair crossover detection, auto-correction and Wake-onLAN
Compatible with Windows, Mac and Chromium
USB-C Port for Charging Portable Devices
● Supports power input up to 20V 3A (60W)
Connects to USB-C wall charger to power connected device
Specifications
OVERVIEW
UPC Code
037332193827
Technology
Cat5/5e; Cat6
INPUT
Bus Powered
Yes
Product Length (in.)
6
Product Length (cm.)
15.24
Product Length (ft.)
0.5
Product Length (m.)
0.15
BATTERY
Battery Charging (5V/1.5A Port)
No
POWER
Power Consumption (Watts)
0.9
USB Power Delivery (PD) Charging
Support
Yes
Specification
2.0
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
Green (Power), Orange (Activity)
CHARGING
Total Charging Watts
60
Charging Ports / Amps
3A
PHYSICAL
2/4
Color
White
Material of Construction
ABS, PVC
Cable Jacket Rating
VW-1
Shipping Dimensions (hwd / in.)
0.70 x 4.00 x 4.80
Shipping Weight (lbs.)
0.20
Unit Dimensions (hwd / in.)
0.000 x 0.000 x 0.000
Unit Packaging Type
Box
Unit Weight (lbs.)
0.1
Unit Weight (kg)
0.05
ENVIRONMENTAL
Operating Temperature Range
32 to 158 F (0 to 70 C)
Storage Temperature Range
14 to 158 F (-10 to 70 C)
Relative Humidity
5% to 90% RH, Non-Condensing
BTUs
3.1 BTU/Hr
Power Provided to Connected
Device(s)
Up to 20V 3A (60W) Input (USB-C)
COMMUNICATIONS
Network Compatibility
1 Gbps (Gigabit)
IEEE Standards Supported
802.3; 802.3az; 802.3u; 802.3x
CONNECTIONS
Number of Ports
2
Side A - Connector 1
USB C (MALE)
Side B - Connector 1
USB C (FEMALE)
Side B - Connector 2
RJ45 (FEMALE)
Connector Plating
Nickel
FEATURES & SPECIFICATIONS
USB Specification
USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps)
Driver Required
No
Recommended Category Cable
Cat5/5e/6 Cables
UASP Support
No
Auto MDIX Support
Yes
Full Duplex Support
Yes
Suspend Mode Support
Yes
3/4
Remote Wakeup Support
Yes
STANDARDS & COMPLIANCE
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA)
WARRANTY
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
4/4
很抱歉,暂时无法提供与“U436-06N-G-C”相匹配的价格&库存,您可以联系我们找货
