SealJackTM
USB 2.0 connectors
Harsh Environment Solutions
Reliability and functionality are a necessity when the need for Ethernet begins to
move outside the typical office environment. Moisture and other environmental
factors limit the capabilities of electronics in these environments thus requiring a
sealed yet reliable connector that protects against such factors.
Based on the reliability of Stewart Connector’s USB 2.0 jack coupled with a sealed
housing design, Stewart Connector’s SealJackTM provides reliable connectivity in
the most demanding environments. This unique sealed design is the lightest and
most compact on the market, which can be used to transmit up to 480 Mbit/s.
Main Characteristics
• Available in single port right angle configurations
• Allows for sealed protection from outside elements for IP67 applications
• The connector housing is comprised of a Zinc diecast alloy with tin plating
• A compact design that minimizes weight, volume and area over competitive products
• Minimum of 750 mating cycles
• Includes a gasket that allows for a front panel mounting
• POE compatible and RoHS Compliant
• Supports speeds up to 480 Mbit/s
Applications
• Rugged computing equipment
• Test Equipment
• Industrial Environments
• Military Communication
• Connectivity for
non-office environments
• Marine Equipment
• Renewable Energy Industry
• Medical devices
Part Number
Port Configuration
Description
SS-52200-001
1x1
Single Port Right Angle USB SealJack
W/ #4-40 Threads
SS-52200-002
1x1
W/ M3 x 0.5 Threads
+1 717.235.7512
techhelp@belf.com
belfuse.com/stewart-connector
© 2019 Stewart Connector
ds-stw-sealjack-2.0-connectors-v1
很抱歉,暂时无法提供与“SS-52200-001”相匹配的价格&库存,您可以联系我们找货
