DM-60
DM-60
    GREENLEECOMMUNICATIONS(格林利)
    MM 600V AC/DC
DM-60 数据手册
Heavy on the Features, Light on the Wallet! DM-60 DM-20, DM-40, DM-60 – Three New Manual Ranging Multimeters. The DM-20, DM-40 and DM-60 give you three more reasons to add a Greenlee tester to your tool portfolio. Manual ranging multimeters are used in many everyday electrical applications where the electrician does not require extended features or high accuracy. Measurement capabilities for the DM-20, DM-40 and DM-60 include: AC and DC voltage, DC current, temperature (K-type thermocouples only), and resistance. Other capabilities include checking diodes, verifying continuity, and testing 1.5V and 9V batteries. All three multimeters have been third party approved by UL. The safety measurement rating for the DM-40 and DM-60 are Category III 300V and Category II 600V. The DM-20 has a safety measurement rating of Category II 300V. When you purchase a DM-20, DM-40 or DM-60, you will receive everything you need to start using your meter including a rugged protective boot. As with all Greenlee test instruments, the DM-20, DM-40 and DM-60 carry the Lifetime Limited warranty. DM-20 DM-20 DM-40 • Use to measure voltage and check batteries. • Great for measuring current of small electronic circuits. • Includes elastomer boot to protect meter from damage. • AC/DC voltage, DC amperage measurement. • Resistance measurement. • Audible continuity and diode tests. • Tests 1.5V and 9V batteries. • Lifetime Limited Warranty. Contents/Accessories • (1) 9V Battery • Protective Boot DM-60 • Multi-purpose meter for most electrical needs. • Includes elastomer boot to protect meter from damage. • AC/DC voltage, DC amperage measurement. • Temperature measurement. • Audible continuity and diode tests. • Tests 1.5V and 9V batteries. • Lifetime Limited Warranty. Contents/Accessories • Test Leads • (1) 9V Battery • Protective Boot • Type K Thermocouple, 392 ˚F (250 ˚C) maximum • A perfect choice for residential and light commercial use. • Includes elastomer boot to protect meter from damage. • AC/DC voltage, AC/DC amperage measurement. • Resistance measurement. • Audible continuity and diode tests. • Frequency measurement in voltage mode. • Data hold to capture measurement. • Max feature for added versatility. • Lifetime Limited Warranty. DM-40 Contents/Accessories • Test Leads • (1) 9V Battery • Protective Boot DM-20 DM-40 DM-60 Voltage measurement AC V: 200.0, 300 V, DC V: 200.0, 2000 mV; 20.00, 200.0, 300 V Voltage measurement AC V: 200.0, 600 V; DC V: 200.0, 2000 mV; 20.00, 200.0, 600 V Voltage measurement 200.0 mV; 2.000, 20.00, 200.0; 600V Amperage measurement DC A: 2000 µA; 20.00, 200.0 mA Amperage measurement DC A: 20.00, 200.0 mA Amperage measurement 200.0 µA; 2.000, 20.00, 200.0 mA; 10.00 A Resistance measurement 200.0, 2000 Ω, 20.00, 200.0, 2000 kΩ Resistance measurement 200.0, 2000 Ω, 20.00, 200.0 kΩ; 20.00 MΩ Measurement Category CAT II, 300V Temperature measurement -40 to 1832 ˚F, (-40 to 1000 ˚C) UPC NO. DESCRIPTION DM-20 DM-40 DM-60 12037 12039 12040 DMM, 300V AC/DC DMM, 300V AC/DC W/ TEMP DMM, 600V AC/DC DISTRIBUTED BY Resistance measurement 200.0 Ω, 2.000, 20.00, 200.0 kΩ; 2.000, 20.00 MΩ Frequency measurement 2 k to 10 MHz Measurement Category CAT III, 300V; CAT II, 600V CAT. NO. DM-60 Measurement Category CAT III, 300V; CAT II, 600V QTY 1 1 1 USA Canada International 800-435-0786 815-397-7070 800-435-0786 +1-815-397-7070 Fax: Fax: Fax: Fax: 800-451-2632 815-397-1865 800-524-2853 +1-815-397-9247 4455 Boeing Drive • Rockford, IL 61109-2988 • USA • 815-397-7070 ©2005 Greenlee Textron Inc. • An ISO 9001 Company • Printed in USA Greenlee Textron Inc. is a subsidiary of Textron Inc. www.greenlee.com MA-4674 3/05
DM-60 价格&库存
很抱歉,暂时无法提供与“DM-60”相匹配的价格&库存,您可以联系我们找货
