SUM60N10-17
www.VBsemi.com
N-Channel 100-V (D-S) MOSFET
FEATURES
PRODUCT SUMMARY
VDS (V)
100
RDS(on) (Ω)
ID (A)
0.010 at VGS = 10 V
100
0.023 at VGS = 4.5 V
85
• TrenchFET® Power MOSFET
• 175 °C Maximum Junction Temperature
• Compliant to RoHS Directive 2002/95/EC
D
TO-263
G
G D S
Top View
S
N-Channel MOSFET
ABSOLUTE MAXIMUM RATINGS TA = 25 °C, unless otherwise noted
Symbol
Parameter
Limit
Drain-Source Voltage
VDS
100
Gate-Source Voltage
VGS
± 20
TC = 25 °C
Continuous Drain Current (TJ = 150 °C)
Avalanche Current
L = 0.1 mH
Single Pulse Avalanche Energyb
Maximum Power Dissipationb
75 a
IDM
Pulsed Drain Current
TC = 25 °C (TO-220AB and TO-263)
TA = 25 °C (TO-263)d
A
300
IAS
75
EAS
280
250
PD
mJ
c
W
3.75
TJ, Tstg
Operating Junction and Storage Temperature Range
V
100
ID
TC = 125 °C
Unit
- 55 to 175
°C
THERMAL RESISTANCE RATINGS
Parameter
Junction-to-Ambient
Junction-to-Case
Symbol
PCB Mount
(TO-263)d
Free Air (TO-220AB)
RthJA
RthJC
Limit
Unit
40
62.5
°C/W
0.6
Notes:
a. Pulse test; pulse width ≤ 300 µs, duty cycle ≤ 2 %.
b. Guaranteed by design, not subject to production testing.
c. Independent of operating temperature.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
服务热线:400-655-8788
1
SUM60N10-17
www.VBsemi.com
SPECIFICATIONS TJ = 25 °C, unless otherwise noted
Parameter
Symbol
Test Conditions
Min.
Typ.
Max.
Unit
Static
VDS
VGS = 0 V, ID = 250 µA
100
VGS(th)
VDS = VGS, ID = 250 µA
2
Gate-Body Leakage
IGSS
VDS = 0 V, VGS = ± 20 V
VDS = 100 V, VGS = 0 V
1
Zero Gate Voltage Drain Current
IDSS
VDS = 100 V, VGS = 0 V, TJ = 125 °C
50
Drain-Source Breakdown Voltage
Gate-Threshold Voltage
4
± 100
VDS = 100 V, VGS = 0 V, TJ = 175 °C
On-State Drain
Currenta
Drain-Source On-State Resistancea
VDS = ≥ 5 V, VGS = 10 V
ID(on)
RDS(on)
VGS = 10 V, ID = 30 A
0.010
0.023
VGS = 10 V, ID = 30 A, TJ = 125 °C
0.020
VDS = 15 V, ID = 30 A
µA
A
VGS = 4.5 V, ID = 20 A
gfs
nA
250
120
VGS = 10 V, ID = 30 A, TJ = 175 °C
Forward Transconductancea
V
Ω
0.030
25
S
b
Dynamic
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Chargec
Gate-Source Charge
c
Gate-Drain Charge
Turn-On Delay Time
c
Timec
Turn-Off DelayTime
VGS = 0 V, VDS = 25 V, f = 1 MHz
Qgs
Fall Timec
pF
105
VDS = 50 V, VGS = 10 V, ID = 85 A
160
nC
17
Qgd
23
td(on)
12
25
90
135
55
85
130
195
tr
c
665
265
Qg
c
Rise
6550
td(off)
VDD = 50 V, RL = 0.6 Ω
ID ≅ 85 A, VGEN = 10 V, Rg = 2.5 Ω
tf
Source-Drain Diode Ratings and Characteristics TC = 25 °C
b
IS
85
Pulsed Current
ISM
240
Forward Voltagea
VSD
Continuous Current
Reverse Recovery Time
Peak Reverse Recovery Current
Reverse Recovery Charge
Qrr
A
IF = 85 A, VGS = 0 V
1.0
1.5
V
85
140
ns
IF = 50 A, dI/dt = 100 A/µs
4.5
7
A
0.35
µC
trr
IRM(REC)
ns
0.17
Notes:
服务热线:400-655-8788
2
SUM60N10-17
www.VBsemi.com
TYPICAL CHARACTERISTICS
200
250
VGS = 10 V thru 6 V
5V
200
I D - Drain Current (A)
150
150
100
4V
100
TC = 125 °C
50
50
- 55 °C
25 °C
3V
4
6
8
1
2
3
4
5
VDS - Drain-to-Source Voltage (V)
VGS - Gate-to-Source Voltage (V)
Output Characteristics
Transfer Characteristics
250
6
0.020
R DS(on) - On-Resistance (Ω)
g fs - Transconductance (S)
TC = - 55 °C
200
25 °C
150
125 °C
100
50
60
80
0.015
VGS = 6V
VGS = 10 V
0.010
0.005
0.000
100
80
100
120
ID - Drain Current (A)
On-Resistance vs. Drain Current
Transconductance
10 000
8000
C - Capacitance (pF)
60
Ciss
6000
4000
2000
Crss
VDS = 50 V
ID = 85 A
16
12
8
4
Coss
30
45
60
Capacitance
75
100
150
200
Qg - Total Gate Charge (nC)
Gate Charge
服务热线:400-655-8788
3
SUM60N10-17
www.VBsemi.com
TYPICAL CHARACTERISTICS TA = 25 °C, unless otherwise noted
2.5
100
VGS = 10 V
ID = 30 A
I S - Source Current (A)
(Normalized)
2.0
1.5
1.0
TJ = 150 °C
TJ = 25 °C
10
0.5
0.0
- 50
1
- 25
50
75
100
125
150
175
0.9
1.2
VSD - Source-to-Drain Voltage (V)
On-Resistance vs. Junction Temperature
Source-Drain Diode Forward Voltage
1000
140
130
100
IAV (A) at T A = 25 °C
VDS (V)
I Dav (a)
0.3
TJ - Junction Temperature (°C)
10
IAV (A) at T A = 150 °C
ID = 250 µA
120
110
1
100
0.1
0.00001
0.0001
0.001
0.01
0.1
1
90
- 50
- 25
50
75
100
125
tin (s)
Avalanche Current vs. Time
TJ - Drain-Source Breakdown
vs. Junction-Temperature
150
175
服务热线:400-655-8788
4
SUM60N10-17
www.VBsemi.com
THERMAL RATINGS
100
1000
10 µs
100
80
60
40
100 µs
10
Limited
by R DS(on)*
1 ms
10 ms
100 ms, DC
1
75
100
125
150
175
0.1
0.1
TC = 25 °C
Single Pulse
1
10
100
1000
* VGS > minimum VGS at which RDS(on) is specified
TC - Case Temperature (°C)
Maximum Avalanche and Drain Current
vs. Case Temperature
Safe Operating Area
2
Normalized Effective Transient
Thermal Impedance
1
Duty Cycle = 0.5
0.2
0.1
0.1
0.05
0.02
Single Pulse
0.01
10-4
10-3
10-2
10-1
1
10
Square Wave Pulse Duration (s)
Normalized Thermal Transient Impedance, Junction-to-Case
服务热线:400-655-8788
5
SUM60N10-17
www.VBsemi.com
TO-263 (D2PAK): 3-LEAD
L2
E1
K
6
D4
-A-
-Bc2
D2
D3
A
E
L3
L
D
D1
E3
A
A
b2
b
e
Detail “A”
c
E2
L4
0.010 M A M
2 PL
L1
DETAIL A (ROTATED 90°)
c*
c
c1
c1
M
b
b1
SECTION A-A
Notes
1. Plane B includes maximum features of heat sink tab and plastic.
2. No more than 25 % of L1 can fall above seating plane by max.
8 mils.
3. Pin-to-pin coplanarity max. 4 mils.
4. *: Thin lead is for SUB, SYB.
Thick lead is for SUM, SYM, SQM.
5. Use inches as the primary measurement.
6. This feature is for thick lead.
DIM.
A
b
b1
b2
Thin lead
Thick lead
Thin lead
Thick lead
c2
D
D1
D2
D3
D4
E
E1
E2
E3
e
K
L
L1
L2
L3
L4
M
INCHES
MILLIMETERS
MIN.
MAX.
0.160
0.190
0.020
0.039
0.020
0.035
0.045
0.055
0.013
0.018
0.023
0.028
0.013
0.017
0.023
0.027
0.045
0.055
0.340
0.380
0.220
0.240
0.038
0.042
0.045
0.055
0.044
0.052
0.380
0.410
0.245
0.355
0.375
0.072
0.078
0.100 BSC
0.045
0.055
0.575
0.625
0.090
0.110
0.040
0.055
0.050
0.070
0.010 BSC
0.002
MIN.
MAX.
4.064
4.826
0.508
0.990
0.508
0.889
1.143
1.397
0.330
0.457
0.584
0.711
0.330
0.431
0.584
0.685
1.143
1.397
8.636
9.652
5.588
6.096
0.965
1.067
1.143
1.397
1.118
1.321
9.652
10.414
6.223
9.017
9.525
1.829
1.981
2.54 BSC
1.143
1.397
14.605
15.875
2.286
2.794
1.016
1.397
1.270
1.778
0.254 BSC
0.050
ECN: T13-0707-Rev. K, 30-Sep-13
DWG: 5843
服务热线:400-655-8788
6
SUM60N10-17
www.VBsemi.com
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to the
product.(www.VBsemi.com)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability,
including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
RoHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
