CLLE1AX7S0G225M/0.55 数据手册
CLL Series
Ultra Low Inductance Capacitors
Type:
CLLC1A
CLLE1A
Issue date:
April 2011
TDK MLCC
US Catalog
Version B11
REMINDERS
Please read before using this product
SAFETY REMINDERS
REMINDERS
1.
2.
3.
4.
5.
6.
7.
If you intend to use a product listed in this catalog for a purpose that may cause loss of life or other
damage, you must contact our company’s sales window.
We may modify products or discontinue production of a product listed in this catalog without prior
notification.
We provide “Delivery Specification” that explain precautions for the specifications and safety of each
product listed in this catalog. We strongly recommend that you exchange these delivery specifications
with customers that use one of these products.
If you plan to export a product listed in this catalog, keep in mind that it may be a restricted item according
to the “Foreign Exchange and Foreign Trade Control Law”. In such cases, it is necessary to acquire export
permission in harmony with this law.
Any reproduction or transferring of the contents of this catalog is prohibited without prior permission from
our company.
We are not responsible for problems that occur related to the intellectual property rights or other rights of
our company or a third party when you use a product listed in this catalog. We do not grant license of
these rights.
This catalog only applies to products purchased through our company or one of our company’s official
agencies. This catalog does not apply to products that are purchased through other third parties.
TDK MLCC US Catalog
Page 230
Version B11
CLL Series
Type: CLLC1A (C1608), CLLE1A (C2012)
Features
• Features a unique internal structure that cancels
magnetic fields to reduce equivalent series inductance
• Eight side terminal electrodes in one capacitor
Structure
Applications
• Decoupling CPU power line
• High speed digital IC/decoupling
• GPU/CPU
Shape &
Dimensions
ULI
Chip Size
C1608
C2012
FLIP
STD
C1632
C2012
Cap.
1µF
1µF
1µF
1µF
W.V.
0G (4V)
0G (4V)
1A (10V)
1A (10V)
ESL
65pH
70pH
180pH
850pH
Dimensions in mm
L
W
T
C
P
Body Length
Body Width
Body Height
Terminal Width
Terminal Spacing
Part Number
Construction
CLLC1A X7R 0J 105 M T XXXX
Internal Codes
Series Name
Case Code
CLLC1A
CLLE1A
Length
1.60 ± 0.10
2.00 ± 0.15
Width
0.80 ± 0.10
1.25 ± 0.15
Packaging Style
Capacitance
Change
± 15%
± 22%
Temperature
Range
-55 to +125ºC
-55 to +125ºC
Tolerance Code
M
Tolerance
± 20%
Nominal Capacitance (pF)
The capacitance is expressed in three digit
codes and in units of pico Farads (pF). The first
and second digits identify the first and second
significant figures of the capacitance. The third
digit identifies the multiplier. R designates a
decimal point.
Rated Voltage (DC)
Voltage Code
0G
0J
1A
Style
Tape & Reel
Capacitance Tolerance
Temperature Characteristic
Temperature
Characteristics
X7R
X7S
Packaging Code
T
Voltage (DC)
4V
6.3V
10V
Capacitance Code
0R5
010
102
105
TDK MLCC US Catalog
Page 231
Capacitance
0.5pF
1pF
1,000pF (1nF)
1,000,000pF (1µF)
Version B11
Capacitance
Range Chart
CLLC1A [EIA CC0603]
Capacitance Range Chart
Temperature Characteristics: X7S (± 22)
Rated Voltage: 4V (0G)
Capacitance
(pF)
330,000
470,000
680,000
1,000,000
X7S
Cap
Code
334
474
684
105
Tolerance
0G
(4V)
M: ± 20%
Standard Thickness
0.50 mm
Capacitance
Range Table
CLLC1A [EIA CC0603]
Class 2 (Temperature Stable)
Temperature Characteristics: X7S (-55 to +125ºC, ±22%)
TDK Part Number
Temperature
Rated
(Ordering Code)
Characteristics
Voltage
Capacitance
(pF)
Capacitance
Tolerance
Thickness
(mm)
CLLC1AX7S0G334M
X7S
4V
330,000
± 20%
0.50 ± 0.10
CLLC1AX7S0G474M
X7S
4V
470,000
± 20%
0.50 ± 0.10
CLLC1AX7S0G684M
X7S
4V
680,000
± 20%
0.50 ± 0.10
CLLC1AX7S0G105M
X7S
4V
1,000,000
± 20%
0.50 ± 0.10
TDK MLCC US Catalog
Page 232
Version B11
Capacitance
Range Chart
CLLE1A [EIA CC0805]
Temperature Characteristics: X7R (± 15%), X7S (± 22)
Rated Voltage: 10V (1A), 6.3V (0J), 4V (0G)
Capacitance
(pF)
100,000
150,000
220,000
330,000
470,000
680,000
1,000,000
1,500,000
2,200,000
4,700,000
X7R
Cap
Code
104
154
224
334
474
684
105
155
225
475
Tolerance
1A
(10V)
X7S
0J
(6.3V)
0G
(4V)
M: ± 20%
Standard Thickness
0.50 mm
0.85 mm
Capacitance
Range Table
CLLE1A [EIA CC0805]
Temperature Characteristics: X7R (-55 to +125ºC, ±15%), X7S (-55 to +125ºC, ±22%)
TDK Part Number
Temperature
Rated
Capacitance
Capacitance
(Ordering Code)
Characteristics
Voltage
(pF)
Tolerance
Thickness
(mm)
CLLE1AX7R1A104M
X7R
10V
100,000
± 20%
0.50 ± 0.10
CLLE1AX7R1A154M
X7R
10V
150,000
± 20%
0.50 ± 0.10
CLLE1AX7R1A224M
X7R
10V
220,000
± 20%
0.50 ± 0.10
CLLE1AX7R1A334M
X7R
10V
330,000
± 20%
0.50 ± 0.10
CLLE1AX7R0J474M
X7R
6.3V
470,000
± 20%
0.50 ± 0.10
CLLE1AX7R0J684M
X7R
6.3V
680,000
± 20%
0.50 ± 0.10
CLLE1AX7R0J105M
X7R
6.3V
1,000,000
± 20%
0.85 ± 0.10
CLLE1AX7R0J155M
X7R
6.3V
1,500,000
± 20%
0.85 ± 0.10
CLLE1AX7S0G105M
X7S
4V
1,000,000
± 20%
0.50 ± 0.10
CLLE1AX7S0G155M
X7S
4V
1,500,000
± 20%
0.50 ± 0.10
CLLE1AX7S0G225M/0.50
X7S
4V
2,200,000
± 20%
0.50 ± 0.10
CLLE1AX7S0G225M/0.85
X7S
4V
2,200,000
± 20%
0.85 ± 0.10
CLLE1AX7S0G475M
X7S
4V
4,700,000
± 20%
0.85 ± 0.10
TDK MLCC US Catalog
Page 233
Version B11
General
Specifications
CLL Series – ULI Capacitors
No.
Item
Performance
Test or Inspection Method
1
External
Appearance
No defects which may affect
performance.
Inspect with magnifying glass (3×).
2
Insulation
Resistance
100MΩ•μF min.
Apply rated voltage for 60s.
Measure 8 terminal electrodes at the same time.
3
Voltage Proof
Withstand test voltage without
insulation breakdown or other damage.
2.5 times rated voltage (DC) shall be applied for 1 to
5s. Charge / discharge current shall not exceed 50mA.
4
Capacitance
Within the specified tolerance at
1000hrs age (Per IEC-384-9).
Measuring
Frequency
1kHz±10%
Withstanding
Voltage
Measuring
voltage
10V
1.0 ± 0.2 Vrms
≤ 6.3V
0.5 ± 0.2 Vrms
5
6
7
Dissipation
Factor
(Class 2)
Temperature
Characteristics
of Capacitance
(Class 2)
Robustness of
Terminations
T.C.
D.F.
X7R
X7S
0.10 max.
See No.4 in this table for measuring condition.
Capacitance Change (%)
Capacitance shall be measured by the steps shown in
the following table after thermal equilibrium is obtained
for each step.
∆C be calculated ref. STEP 3 reading
No DC Voltage Applied
X7R: ± 15%
X7S: ± 22%
Step
No sign of termination coming off,
breakage of ceramic, or other abnormal
signs.
Temperature (ºC)
1
Reference temp. ± 2
2
Min. operating temp. ± 2
3
Reference temp. ± 2
4
Max. operating temp. ± 2
Reflow solder the capacitor on P.C. board (shown in
Appendix 1 and 2) and apply a pushing force of 2N for
10±1s.
2N
Capacitor
8
Solderability
All terminations shall exhibit a
continuous solder coating free from
defects for a minimum of 75% of the
surface area of any individual
termination. Anomalies other than
dewetting, non-wetting, and pin holes
are not cause for rejection. Ceramic
surface of A sections shall not be
exposed due to melting or shifting of
termination material.
P.C. Board
Completely soak both terminations in
solder at 235±5°C for 2±0.5s.
Solder : H63A (JIS Z 3282)
Flux : Isopropyl alcohol (JIS K 8839)
Rosin (JIS K 5902) 25% solid solution.
A section
TDK MLCC US Catalog
Page 234
Version B11
General
Specifications
No.
Item
9
Resistance to solder heat
External
appearance
Capacitance
Performance
No cracks are allowed and terminations
shall be covered at least 60% with new
solder
Characteristics
X7R
X7S
10
Change from the
value before test
± 7.5 %
D.F. (Class 2)
Meet the initial spec.
Insulation
Resistance
Capacitance
X7R
X7S
D.F. (Class 2)
Capacitance
Change from the
value before test
± 7.5 %
Vibrate the capacitor with amplitude of1.5mm P-P
sweeping the frequencies from 10Hz to 55Hz and back
to 10Hz in about 1 minute.
Repeat this for 2h each in 3 perpendicular directions
(6h in total).
Reflow solder the capacitors on a P.C. board (shown in
Appendix 1 and 2) before testing.
No mechanical damage.
Characteristics
X7R
X7S
Change from the
value before test
± 7.5 %
D.F. (Class 2)
Insulation
Resistance
Voltage Proof
No insulation breakdown or other
damage.
TDK MLCC US Catalog
Reflow solder the capacitor on a P.C. board (shown in
Temperature cycle
External
appearance
Preheating condition
Temp. : 150±10ºC
Time : 1 to 2min.
Leave the capacitor in ambient conditions for 24±2h
before measurement.
Characteristics
Completely soak both terminations in solder at
260±5ºC for 5±1s.
Vibration
External
appearance
11
Page 235
Expose the capacitor in the condition step1 through
step 4, and repeat 5 times consecutively.
before measurement.
Step
Temperature (ºC)
Time (min.)
1
Min. operating temp. ±3
30 ± 3
2
Reference Temp.
2–5
3
30 ± 2
4
Reference Temp.
2-5
Version B11
General
Specifications
No.
Item
12
Moisture Resistance (Steady State)
External
appearance
Performance
Capacitance
Characteristics
X7R
X7S
13
Change from the
value before test
± 12.5 %
D.F. (Class 2)
Characteristics:
X7R: 200% of initial spec. max.
X7S: 200% of initial spec. max.
Insulation
Resistance
10MΩ·μF min.
Moisture Resistance
External
appearance
Capacitance
X7R
X7S
Leave the capacitor in ambient condition for 24±2h
before measurement.
Reflow solder the capacitors on P.C. board (shown in
Characteristics
Leave at temperature 40±2ºC and 90 to 95%RH for
500 +24,0h.
Change from the
value before test
Apply the rated voltage at temperature 40±2ºC and 90
to 95%RH for 500 +24,0h.
Charge/discharge current shall not exceed 50mA.
Leave the capacitor in ambient conditions for 48±4h
before measurement.
± 12.5 %
D.F. (Class 2)
Characteristics
Voltage conditioning:
Voltage treat the capacitors under testing temperature
and voltage for 1 hour.
Insulation
Resistance
5MΩ·μF min.
Leave the capacitors in ambient condition for 24±2h
before measurement.
Use this measurement for initial value.
14
Life
External
appearance
Capacitance
Characteristics
X7R
X7S
Apply 1 x rated voltage at 125±2ºC for 1,000 +48, 0h.
Change from the
value before test
± 15 %
D.F. (Class 2)
Characteristics
Insulation
Resistance
10MΩ·μF min.
TDK MLCC US Catalog
before measurement.
Voltage treat the capacitor under testing temperature
before measurement.
Page 236
Version B11
General
Specifications
Appendix - 1
P.C. Board for reliability test
Applied for CLLC1A
50.0
50.0
41.25
41.25
4.0
3.0
1.5
2.5
20.0
2.0
10.0
7.0
20.0
18.0
15.0
4.0
7.0
5.0 5.0
10.0
20.0
19.0
Unit: mm
Material: Glass Epoxy ( As per JIS C6484 GE4 )
P.C. Board thickness: 0.8mm
1.1
0.8
0.4 pitch
Copper ( thickness 0.035mm )
Solder resist
0.6
1.1
0.8
0.6
0.4
0.08
1.2
0.76
0.725 0.725
0.76
0.32
0.25
1.2
0.19
TDK MLCC US Catalog
Page 237
Version B11
General
Specifications
Appendix - 2
Applied for CLLE1A
50.0
50.0
41.25
41.25
4.0
3.0
1.5
2.5
20.0
10.0
7.0
4.0
5.0 5.0
7.0
15.0
2.0
19.0
18.0
10.0
20.0
20.0
Unit: mm
1.5
Material: Glass Epoxy ( As per JIS C6484 GE4)
1.1
P.C. Board thickness: 1.6mm
0.85
0.5 pitch
Solder resist
1.5
1.1
0.85
0.7
8.3
1.05
0.4
1.05
0.9
0.1
0.9
0.3
8.3
0.4
TDK MLCC US Catalog
Page 238
Version B11
Soldering
Information
• Recommended Soldering Land Pattern
• Recommended Soldering Profile
Reflow Soldering
P
A
Preheating
300
B
Temp (ºC)
Temp (ºC)
Peak
Temp
D C
Manual soldering
(Solder iron)
Soldering Natural
cooling
∆T
∆T
Preheating
Over 60 sec.
Peak Temp time
Reflow Soldering
Unit: mm
CLLC1A
(C1608/CC0603)
CLLE1A
(C2012/CC0805)
A
0.25
0.3
Type
Symbol
B
0.4
0.3 ~ 0.6
C
1.2
1.3 ~ 1.8
D
0.4
0.5 ~ 0.8
P
0.4
0.5
Recommended soldering duration
Temp./
Dura.
Reflow Soldering
Peak temp
(°C)
Duration
(sec.)
Sn-Pb Solder
230 max.
20 max.
Lead-Free Solder
260 max.
10 max.
Solder
Recommended solder compositions
Sn-37Pb (Sn-Pb solder)
Sn-3.0Ag-0.5Cu (Lead Free Solder)
• Recommended Solder Amount
Excessive
solder
3sec. (As short as possible)
Preheating Condition
Higher tensile
force on the chip
capacitor may
cause cracking.
Soldering
Temp. (ºC)
Reflow soldering
∆T ≤ 150
Manual soldering
∆T ≤ 150
Maximum amount
Adequate
solder
Insufficient
solder
TDK MLCC US Catalog
Minimum amount
Small solder fillet
may cause
contact failure or
failure to hold the
chip capacitor to
the P.C. board.
Page 239
Version B11
Packaging
Information
• Carrier Tape Configuration
Blank
Blank
Chips
160mm min.
160mm min.
Leader
Drawing direction
400mm min.
• Peel Back Force (Top Tape)
Direction & angle of pull force
Top cover tape
Carrier tape
0~15°
• Carrier tape shall be flexible enough to be
wound around a minimum radius of 30mm with
components in tape.
• The missing of components shall be less than
0.1%
• Components shall not stick to the cover tape.
• The cover tape shall not protrude beyond the
edges of the carrier tape and shall not cover the
sprocket holes.
Direction of pull force
• Chip Quantity Per Reel and Structure of Reel
Top cover tape
Pitch hole
Cavity (Chip insert)
Plastic carrier tape
Series
Taping
Material
CLLC1A
CLLE1A
Plastic
TDK MLCC US Catalog
Chip quantity (pcs.)
φ178mm (7”) reel φ330mm (13”) reel
4,000
10,000
4,000
10,000
Page 240
Version B11
Additional
Information
• Inside Structure & Material System
A’
No.
NAME
MATERIAL
(1)
Ceramic Dielectric
BaTiO3
(2)
Internal Electrode
Nickel (Ni)
Class 2
B’
(3)
(4)
B
Copper (Cu)
Termination
(5)
A
3
4
Nickel (Ni)
Tin (Sn)
5
2
1
• Equivalent Circuit
• Environmental Information
TDK Corporation established internal product environmental
assurance standards that include the six hazardous
substances banned by the EU RoHS Directive1 enforced on
July 1, 2006 along with additional substances independently
banned by TDK and has successfully completed making
general purpose electronic components conform to the
RoHS Directive2.
+ 1) 3) 5) 7)
- 2) 4) 6) 8)
8 terminals are connected and
measured at the same time.
1.
Abbreviation for Restriction on Hazardous
Substances, which refers to the regulation EU
Directive 2002/95/EC on hazardous substances by
the European Union (EU) effective from July 1, 2006.
The Directive bans the use of six specific hazardous
substances in electric and electronic devices and
products handled within the EU. The six substances
are lead, mercury, cadmium, hexavalent chromium,
PBB (polybrominated biphenyls), and PBDE
(polybrominated diphenyl ethers).
2.
This means that, in conformity with the EU Directive
2002/95/EC, lead, cadmium, mercury, hexavalent
chromium, and specific bromine-based flame
retardants, PBB and PBDE, have not been used,
except for exempted applications.
• Shape & Dimensions
L
T
W
P
Case Code
Series
JIS
EIA
CLLC1A C1608 CC0603
CLLE1A C2012 CC0805
TDK MLCC US Catalog
C
L
1.60
2.00
Dimensions (mm)
W
T
P
0.80
0.55 max.
0.40
1.25
0.95 max.
0.50
C
0.25
0.25
Page 241
For REACH (SVHC : 15 substances according to ECHA /
October 2008) : All TDK MLCC do not contain these
15 substances.
For European Directive 2000/53/CE and 2005/673/CE :
Cadmium, Hexavalent Chromium, Mercury, Lead are
not contained in all TDK MLCC.
For European Directive 2003/11/CE : Pentabromodiphenylether, Octabromodiphenyl-ether are not contained in
all TDK MLCC.
Version B11
