CLLE1AX7S0G225M085AC 数据手册
MULTILAYER CERAMIC CHIP CAPACITORS
CLL Series
Commercial Grade
Ultra Low Inductance
Type:
CLLC1A [EIA CC0603]
CLLE1A [EIA CC0805]
CLLG1A [EIA CC1206]
lssue date:
Dec 2014
20141224 / mlcc_commercial_uli_en
REMINDERS
Please read before using this product
SAFETY REMINDERS
REMINDERS
1.
If you intend to use a product listed in this catalog for a purpose that may cause loss of life or other damage,
you must contact our company’s sales window.
2.
We may modify products or discontinue production of a product listed in this catalog without prior notification.
3.
We provide “Delivery Specification” that explain precautions for the specifications and safety of each product
listed in this catalog. We strongly recommend that you exchange these delivery specifications with customers
that use one of these products.
4.
If you plan to export a product listed in this catalog, keep in mind that it may be a restricted item according
to the “Foreign Exchange and Foreign Trade Control Law”. In such cases, it is necessary to acquire export
permission in harmony with this law.
5.
Any reproduction or transferring of the contents of this catalog is prohibited without prior permission from our
company.
6.
We are not responsible for problems that occur related to the intellectual property rights or other rights of our
company or a third party when you use a product listed in this catalog. We do not grant license of these rights.
7.
This catalog only applies to products purchased through our company or one of our company’s official agencies.
This catalog does not apply to products that are purchased through other third parties.
Notice: Effective January 2013, TDK will use a new catalog number which adds product thickness and packaging
specification detail. This new catalog number should be referenced on all catalog orders going forward, and
is not applicable for OEM part number orders. Please be aware the last five digits of the catalog number will
differ from the item description (internal control number) on the product label. Contact your local TDK Sales
representative for more information.
(Example)
Catalog Issued date
Catalog Number
Item Description (On Delivery Label)
Prior to January 2013
C1608C0G1E103J
C1608C0G1E103JT000N
January 2013 and Later
C1608C0G1E103J080AA
C1608C0G1E103JT000N
Page 1
CLL Series
Type: CLLC1A [EIA CC0603], CLLE1A [EIA CC0805],
CLLG1A [EIA CC1206]
Features
• Features a unique internal structure that cancels magnetic fields to
reduce equivalent series inductance.
• Eight side terminal electrodes in one capacitor.
• Small and low profile design enables undersurface mounting for
semiconductor packages.
Shape &
Dimensions
L
W
T
C
P
Applications
• Decoupling CPU power line
• High speed digital IC, decoupling
• GPU, CPU
Design
Structure
Body Length
Body Width
Body Height
Terminal Width
Terminal Spacing
Catalog Number
Construction
Internal Electrode
Terminations
CLL • E1A • X7S • 0G • 685 • M • 050 • A • C
Series Name
Dimensions L x W (mm)
Code
C1A
E1A
G1A
Length
1.60 ± 0.10
2.00 ± 0.15
3.20 ± 0.15
Width
0.80 ± 0.10
1.25 ± 0.15
1.60 ± 0.15
Temperature Characteristics
Temperature
Characteristics
X6S
X7R
X7S
Capacitance
Change
±22%
±15%
±22%
Temperature
Range
-55 to +105°C
-55 to +125°C
-55 to +125°C
Rated Voltage (DC)
Code
0G
0J
1A
Voltage (DC)
4.0V
6.3V
10V
Nominal Capacitance (pF)
The capacitance is expressed in three digit codes and in units of pico
Farads (pF). The first and second digits identify the first and second
significant figures of the capacitance. The third digit identifies the
multiplier. R designates a decimal point.
Capacitance Tolerance
Code
M
Tolerance
± 20%
([5 S) S) S) Q) ȝ)
Nominal Thickness
Code
050
055
085
Thickness
0.50 mm
0.55 mm
0.85 mm
Packaging Style
Code
A
Style
178 mm Reel, 4 mm Pitch
Special Reserved Code
Code
C
Description
TDK Internal Code
Page 2
• All specifications are subject to change without notice.
CLLC1A(1608) [EIA CC0603]
Capacitance
Range Chart
Capacitance Range Chart
Temperature Characteristics: X6S (± 22%), X7R (±15%), X7S (± 22%)
Rated Voltage: 4V (0G)
Capacitance
(pF)
47,000
100,000
330,000
470,000
680,000
1,000,000
2,200,000
4,700,000
Code
473
104
334
474
684
105
225
475
Tolerance
X6S
X7R
X7S
0G
(4V)
0G
(4V)
0G
(4V)
M: ± 20%
CLLE1A(2012) [EIA CC0805]
Capacitance
Range Chart
Temperature Characteristics: X7R (±15%), X7S (± 22%)
Rated Voltage: 10V (1A), 6.3V (0J), 4V (0G)
Capacitance
(pF)
47,000
100,000
150,000
220,000
330,000
470,000
680,000
1,000,000
1,500,000
2,200,000
4,700,000
6,800,000
X7R
Code
473
104
154
224
334
474
684
105
155
225
475
685
Tolerance
1A
(10V)
0J
(6.3V)
X7S
0G
(4V)
1A
(10V)
0J
(6.3V)
0G
(4V)
M: ± 20%
CLLG1A(3216) [EIA CC1206]
Capacitance
Range Chart
Capacitance
(pF)
1,000,000
2,200,000
X7R
Code
105
225
Tolerance
1A
(10V)
0J
(6.3V)
M: ± 20%
Standard Thickness
0.50 mm
0.85 mm
Page 3
Capacitance
Range Table
Class 2 (Temperature Stable)
Temperature Characteristics: X6S (-55 to +105ºC, ±22%)
Capacitance
Size
Thickness
(mm)
Capacitance
Tolerance
4.7 μF
1608
0.50 ± 0.05
± 20%
Catalog Number
Rated Voltage Edc: 10V
Rated Voltage Edc: 6.3V
Rated Voltage Edc: 4.0V
CLLC1AX6S0G475M050AC
CLLE1AX7R0G473M050AC
CLLC1AX7R0G104M050AC
Temperature Characteristics: X7R (-55 to +125ºC, ±15%)
Capacitance
Size
47 nF
2012
1608
100 nF
150 nF
220 nF
330 nF
470 nF
680 nF
1 μF
1.5 μF
2.2 μF
2012
2012
2012
2012
2012
2012
2012
3216
2012
3216
Thickness
(mm)
Capacitance
Tolerance
0.50 ± 0.05
0.50 ± 0.05
0.50 +0.05/-0.10
0.50 ± 0.05
0.50 +0.05/-0.10
0.50 +0.05/-0.10
0.50 +0.05/-0.10
0.50 +0.05/-0.10
0.50 +0.05/-0.10
0.85 ± 0.10
0.85 ± 0.10
0.85 ± 0.10
0.85 ± 0.10
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
Catalog Number
CLLE1AX7R1A104M050AC
CLLE1AX7R0G104M050AC
CLLE1AX7R1A154M050AC
CLLE1AX7R1A224M050AC
CLLE1AX7R1A334M050AC
CLLE1AX7R0J474M050AC
CLLE1AX7R0J684M050AC
CLLE1AX7R0J105M085AC CLLE1AX7R0G105M085AC
CLLG1AX7R1A105M085AC
CLLE1AX7R0J155M085AC
CLLG1AX7R0J225M085AC
Temperature Characteristics: X7S (-55 to +125ºC, ±22%)
Capacitance
47 nF
100 nF
150 nF
220 nF
330 nF
470 nF
680 nF
1 μF
1.5 μF
Size
1608
2012
1608
2012
2012
2012
1608
2012
1608
2012
1608
2012
1608
2012
2012
1608
2.2 μF
2012
4.7 μF
2012
6.8 μF
2012
Thickness
(mm)
Capacitance
Tolerance
0.50 ± 0.05
0.50 ± 0.05
0.50 ± 0.05
0.50 ± 0.05
0.50 ± 0.05
0.50 ± 0.05
0.50 +0.05/-0.10
0.50 ± 0.05
0.50 +0.05/-0.10
0.50 ± 0.05
0.50 +0.05/-0.10
0.50 ± 0.05
0.50 +0.05/-0.10
0.50 +0.05/-0.10
0.50 +0.05/-0.10
0.85 ± 0.10
0.50 ± 0.05
0.50 +0.05/-0.10
0.85 ± 0.10
0.50 ± 0.05
0.85 ± 0.10
0.50 ± 0.05
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
Catalog Number
CLLC1AX7S0G473M050AC
CLLE1AX7S0G473M050AC
CLLC1AX7S0G104M050AC
CLLE1AX7S0G104M050AC
CLLE1AX7S1A154M050AC
CLLE1AX7S1A224M050AC
CLLC1AX7S0G334M050AC
CLLE1AX7S1A334M050AC
CLLC1AX7S0G474M050AC
CLLE1AX7S0J474M050AC
CLLC1AX7S0G684M050AC
CLLE1AX7S0J684M050AC
CLLC1AX7S0G105M050AC
CLLE1AX7S0G105M050AC
CLLE1AX7S0G155M050AC
CLLE1AX7S0J155M085AC
CLLC1AX7S0G225M050AC
CLLE1AX7S0G225M050AC
CLLE1AX7S0G475M050AC
CLLE1AX7S0G475M085AC
CLLE1AX7S0G685M050AC
Page 4
