Jul. 2019
Ver.3.2
TDK Corporation
Multilayer High Pass Filter
For LTE
DEA Series
P/N:
1.6x0.8mm [EIA 0603] TYPE
DEA162300HT-8045A1
All specifications are subject to change without notice.
TDK Technology - Proprietary and Confidential Information of TDK Group Companies
Jul. 2019
Ver.3.2
TDK Corporation
DEA162300HT-8045A1
■ SHAPES AND DIMENSIONS
[Top View]
[Bottom View]
(4)
(4)
(1)
(3)
(3)
(2)
(2)
Dimensions (mm)
L
W
T
a
b
1.60 0.80 0.65 0.225 0.65
+/-0.10 +/-0.10
(1)
Max
c
d
e
f
0.40 0.30 0.21 0.22
+/-0.05 +/-0.05 +/-0.05 +/-0.05 +/-0.05 +/-0.05
Terminal functions
Input Port
(1)
GND
(2)
(3)
(4)
Output Port
GND
■ TERMINATION FINISH
Material
Ag
Jul. 2019
Ver.3.2
TDK Corporation
DEA162300HT-8045A1
■ ELECTRICAL CHARACTERISTICS
( Measurement )
Insertion Loss (dB)
2300 to
2496 to
2500 to
TDK Spec
Min. Typ. Max.
2400 0.92 1.10
2690 0.45 0.60
2690 0.44 0.60
Insertion Loss (dB)
(–40 to +85 °C)
2300 to
2496 to
2500 to
2400
2690
2690
1.30
0.80
0.80
VSWR
2300 to
2496 to
2500 to
2400
2690
2690
1.31 2.00
1.22 2.00
1.22 2.00
Attenuation (dB)
1710 to
1995 to
1995
2010
25
25
Parameter
Frequency (MHz)
Characteristic Impedance (ohm)
Ta = +25+/-5°C
27
30
50 (Nominal)
■ MAXIMUM RATINGS
Parameter
Operating temperature (°C)
Storage temperature (°C)
Power Handling (W)
TDK Spec
Min. Max.
–40 to +85 °C
–40 to +85 °C
1
Human Body Model : HBM
@Each Port (V) -1000 1000
Machine Model : MM
@Each Port (V) -150
150
Charged Device Model : CDM @Each Port (V) -500
500
Conditions
CW
100pF / 1500ohm
200pF / 0ohm
Relative humidity : 51%RH max
Ambient temperature : +25+/-5°C
Jul. 2019
Ver.3.2
TDK Corporation
DEA162300HT-8045A1
■ FREQUENCY CHARACTERISTICS
S11
POLA
REF 1.0 U
SCALE 1.0U FS
S21
1 jV
VSWR
0.8
0.6
0.4
0.2
U
-0.2
-0.4
Log MAG
REF 0.0dB
SCALE 1dB/
0.0
MARKER 1
2300.0 MHz
0.92 dB
MARKER 2
2400.0 MHz
0.63 dB
MARKER 3
2496.0 MHz
0.45 dB
MARKER 4
2500.0 MHz
0.44 dB
MARKER 5
2690.0 MHz
0.36 dB
MARKER 6
MHz
dB
INSERTION LOSS
MARKER 1
2300.0 MHz
1.31
MARKER 2
2400.0 MHz
1.31
MARKER 3
2496.0 MHz
1.16
MARKER 4
2500.0 MHz
1.14
MARKER 5
2690.0 MHz
1.22
MARKER 6
MHz
0.5
1.0
1.5
2.0
2.5
-0.6
3.0
-0.8
3.5
2100
-1
S21
Log MAG
REF 0.0dB
SCALE 5.0dB/
S11
10
15
45
S21
Log MAG
REF 0.0dB
SCALE 5.0dB/
MARKER 1
2300.0 MHz
17.5 dB
MARKER 2
2400.0 MHz
17.4 dB
MARKER 3
2496.0 MHz
22.9 dB
MARKER 4
2500.0 MHz
23.9 dB
MARKER 5
2690.0 MHz
20.2 dB
MARKER 6
MHz
dB
25
40
3000
2800
2500
2700
15
35
2000
REF 0.0dB
2600
10
35
1500
2500
5
30
1000
Log MAG
2400
RETURN LOSS
30
500
2300
MARKER 1
1710.0 MHz
29.9 dB
MARKER 2
1920.0 MHz
26.6 dB
MARKER 3
1995.0 MHz
29.6 dB
MARKER 4
2010.0 MHz
32.3 dB
MARKER 5
ATTENUATION
2200
45
1000
3500
1500
2000
2500
3000
3500
4000
SCALE 5.0dB/
MARKER 1
1710.0 MHz
29.9 dB
MARKER 2
1920.0 MHz
26.6 dB
MARKER 3
2010.0 MHz
32.35 dB
MARKER 4
2300.0 MHz
0.92 dB
MARKER 5
2496.0 MHz
0.45 dB
MARKER 6
2690.0 MHz
0.36 dB
MARKER 7
0.0 MHz
0.0 dB
5
10
15
30
35
40
45
2000
3000
4000
5000
6000
7000
8000
9000
10000
11000
12000
13000
Jul. 2019
Ver.3.2
TDK Corporation
DEA162300HT-8045A1
■ RECOMMENDED LAND PATTERN
■ EVALUATION BOARD
Thru hole
Resist
Surface Pattern
DUT (LPF)
Material, Layer
Thickness
Top Resist
Resist
Copper Surface Pattern
0.035mm
FR-4
0.10mm
Copper Inner GND
0.018mm
FR-4
0.30mm
Copper Bottom GND
0.035mm
■ ENVIRONMENT INFORMATION
RoHS Statement
RoHS Compliance
Jul. 2019
Ver.3.2
TDK Corporation
DEA162300HT-8045A1
■ RECOMMENDED REFLOW PROFILE
Pb free solder
3oC/sec
or lower
Preheating
Temp.
T1
T2
Time
t1
150°C 200°C 60 to 120sec
6oC/sec
or lower
Soldering
Critical zone (T3 to T4)
Peak
Temp.
Time
Temp.
Time
T3
t2
T4
t3 *
217°C
60 to 120sec 240 to 260°C 30 sec Max
* t3 : Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
Note:
Lead free solder is recommended.
Recommended solder is Sn-3.0Ag-0.5Cu. (M705 by Senju Metal Industry)
Jul. 2019
Ver.3.2
TDK Corporation
DEA162300HT-8045A1
■ PACKAGING STYLE
Reel Dimensions
13.0+/-1.0
13+/-0.2
Label
2.0+/-0.5
A
60+1.0/-0
Label
B
21+/-0.8
180 +0/-1.5
Unit : mm
9.0 +1.0/-0
Carrier Tape
Sprocket hole
Loading Direction
J
E
K
C
D
A
B
t
H
Dimensions (mm)
A
B
C
0.97 1.8 8.0
+/-0.05
+/-0.05
+/-0.2
G
F
D
3.5
E
1.75
F
4.0
G
2.0
H
4.0
J
1.5
K
0.8
t
0.25
+/-0.05
+/-0.1
+/-0.1
+/-0.05
+/-0.1
+0.1/-0
MAX
+/-0.05
STANDARD PACKAGE QUANTITY
( pieces/reel )
4,000
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this specification sheet are intended for use in general electronic equipment
(AV equipment, telecommunications equipment, home appliances, amusement equipment,
computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed
below, whose performance and/or quality require a more stringent level of safety or reliability,
or whose failure, malfunction or trouble could cause serious damage to society, person or property.
Please understand that we are not responsible for any damage or liability caused by use of the
products in any of the applications below or for any other use exceeding the range or
conditions set forth in this specification sheet.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
Aerospace/Aviation equipment
Transportation equipment (cars, electric trains, ships, etc.)
Medical equipment
Power-generation control equipment
Atomic energy-related equipment
Seabed equipment
Transportation control equipment
Public information-processing equipment
Military equipment
Electric heating apparatus, burning equipment
Disaster prevention/crime prevention equipment
Safety equipment
Other applications that are not considered general-purpose applications
When using this product in general-purpose applications, you are kindly requested to take into
consideration securing protection circuit/equipment or providing backup circuits, etc.,
to ensure higher safety.
很抱歉,暂时无法提供与“DEA162300HT-8045A1”相匹配的价格&库存,您可以联系我们找货
