R F
C o m p o n e n t s
August 2018
Multilayer Low Pass Filter
For 699-2690MHz
DEA162690LT-5064A1
1.6x0.8mm [EIA 0603]*
* Dimensions Code JIS[EIA]
RF Components
Conformity to RoHS Directive
For 699-2690MHz
DEA162690LT-5064A1
SHAPES AND DIMENSIONS
[Top view]
0.60±0.10
0.80±0.10
1.60±0.10
Marking
0.22±0.05
[Bottom view]
0.225±0.05
(1)
(3)
0.40±0.05
(3)
0.30±0.05
0.21±0.05
0.65±0.05
(4)
Terminal functions
1 Input / Output Port
2 GND
3 Output / Input Port
4 GND
Dimensions in mm
RECOMMENDED LAND PATTERN
0.275
0.450
0.700
0.245
0.210
0.250
Dimensions in mm
RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/
• All specifications are subject to change without notice.
• Before using these products, be sure to request the delivery specifications.
20180826 / rf_lpf_dea162690lt-5064a1_en.fm
RF Components
DEA162690LT-5064A1
ELECTRICAL CHARACTERISTICS
Frequency Range
(MHz)
Item
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
Power Handling (dBm)
Characteristic Impedance ()
699 to 2690
699 to 2690
699 to 2690
5150 to 5960
Min.
Typ.
Max.
15
23
0.09
22
29
50 (Nominal)
0.18
0.23 (–40 to +90°C)
35
・Ta: +25±5°C
TEMPERATURE RANGE
Operating temperature
(°C)
–40 to +90
Storage temperature
(°C)
–40 to +90
RF Components
DEA162690LT-5064A1
FREQUENCY CHARACTERISTICS
INSERTION LOSS
ATTENUATION
10
1.0
Attenuation(dB)
Insertion Loss(dB)
0.5
1.5
2.0
40
2.5
3.0
500
1000
1500
2000
2500
Frequency (MHz)
3000
3500
4000
1500
2000
2500
Frequency (MHz)
3000
3500
4000
50
1000
2000
3000
4000
5000
Frequency (MHz)
6000
7000
8000
RETURN LOSS
Return Loss(dB)
10
40
50
500
1000
RF Components
DEA162690LT-5064A1
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Peak
T4
T: Temperature
3°C/sec
or lower
6°C/sec
or lower
T3
T2
T3
t3
T1
t1
t2
t: Time
Preheating
Temp.
T1
150°C
T2
200°C
Time
t1
60 to 120sec
Soldering
Critical zone (T3 to T4)
Temp.
Time
T3
t2
217°C
60 to 120sec
Peak
Temp.
T4
240 to 260°C
Time
t3
30sec max.
t3
: Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
RF Components
REMINDERS FOR USING THESE PRODUCTS
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment,
home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality
require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person
or property.
Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below
or for any other use exceeding the range or conditions set forth in this catalog.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/
equipment or providing backup circuits, etc., to ensure higher safety.
很抱歉,暂时无法提供与“DEA162690LT-5064A1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.40284
- 100+0.37599
- 300+0.34913
- 500+0.32227
- 2000+0.30885
- 5000+0.30079
