R F
C o m p o n e n t s
July 2015
Multilayer Diplexer
For 2400-2500MHz / 4900-5950MHz
DPX165950DT-8130A1
1.6x0.8mm [EIA 0603]*
* Dimensions Code JIS[EIA]
Caution
The products in this catalog will be or have been
stopped production
Discontinue Issue Date
Sep. 20, 2019
Last Purchase Order Date
Sep. 30, 2020
Last Shipment Date
Dec. 31, 2020
Please refer to our Web site about replacement information.
RF Components
Multilayer Diplexer
Conformity to RoHS Directive
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
DPX165950DT-8130A1
SHAPES AND DIMENSIONS
1.60±0.10
[Top view]
0.40max.
(5)
(4)
(2)
(3)
0.80±0.15
(6)
(1)
0.22±0.05
[Bottom view]
0.22±0.05
(1)
(6)
(2)
(3)
(5)
(4)
0.225±0.05
Marking
Terminal functions
1 GND
2 Common
3 GND
4 Low-band
5 GND
6 High-band
0.35±0.05
Dimensions in mm
0.225
0.35
0.22
RECOMMENDED LAND PATTERN
Dimensions in mm
Th
e
0.22
RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/
• All specifications are subject to change without notice.
• Before using these products, be sure to request the delivery specifications.
20150701 / rf_dpx_dpx165950dt-8130a1_en.fm
RF Components
DPX165950DT-8130A1
ELECTRICAL CHARACTERISTICS
Item
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
LOW-BAND
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
Frequency Range
(MHz)
Min.
Typ.
Max.
2400 to 2500
2400 to 2500
4800 to 6000
7200 to 7500
9.54
20.1
32
27
50 (Nominal)
0.80
Frequency Range
(MHz)
Min.
Typ.
Max.
4900 to 5950
4900 to 5950
1800 to 2500
9800 to 11900
9.54
15.0
31
34
50 (Nominal)
1.20
Frequency Range
(MHz)
Min.
Typ.
Max.
2400 to 2500
4900 to 5950
9.54
9.54
18.2
18.2
50 (Nominal)
Characteristic Impedance (:)
・Ta: +25±5°C
HIGH-BAND
Item
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
・Ta: +25±5°C
COMMON
Item
Return Loss (dB)
・Ta: +25±5°C
TEMPERATURE RANGE
Storage temperature
(°C)
–40 to +85
Th
e
Operating temperature
(°C)
–40 to +85
RF Components
DPX165950DT-8130A1
FREQUENCY CHARACTERISTICS
0.0
0.0
0.5
Insertion Loss(dB)
1.0
1.5
2.0
2.5
3.0
2000
2500
Return Loss
Frequency (MHz)
3500
2.0
3.0
3500
4000
4000
4500
5000
5500
Frequency (MHz)
6000
6500
7000
4500
5000
5500
Frequency (MHz)
6000
6500
7000
Return Loss
10
Return Loss(dB)
Return Loss(dB)
1.5
40
40
50
2000
2500
Attenuation
Frequency (MHz)
3500
50
3500
4000
4000
Attenuation
10
Th
e
40
50
1000
1.0
2.5
Attenuation (dB)
Insertion Loss(dB)
0.5
Attenuation (dB)
HIGH-BAND
Insertion Loss
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
LOW-BAND
Insertion Loss
2000
3000
4000
5000
6000
Frequency (MHz)
40
7000
8000
9000
50
2000
4000
6000
8000
Frequency (MHz)
10000
12000
RF Components
DPX165950DT-8130A1
COMMON
Return Loss
Isolation(dB)
Return Loss(dB)
Isolation
30
40
40
2000
3000
4000
5000
6000
Frequency (MHz)
7000
8000
9000
50
1000
2000
3000
4000
5000
6000
Frequency (MHz)
7000
8000
9000
Th
e
50
1000
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
RF Components
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Peak
T4
T: Temperature
3°C/sec
or lower
6°C/sec
or lower
T3
T2
T1
t1
T3
t3
t2
t: Time
Preheating
Temp.
T1
150°C
t3
T2
200°C
Time
t1
60 to 120sec
Soldering
Critical zone (T3 to T4)
Temp.
Time
T3
t2
217°C
60 to 120sec
Th
e
: Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
Peak
Temp.
T4
240 to 260°C
Time
t3
30sec max.
RF Components
REMINDERS FOR USING THESE PRODUCTS
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment,
home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality
require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person
or property.
Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below
or for any other use exceeding the range or conditions set forth in this catalog.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
Th
e
When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/
equipment or providing backup circuits, etc., to ensure higher safety.
很抱歉,暂时无法提供与“DPX165950DT-8130A1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+7.495391+0.90922
- 10+6.6731810+0.80948
- 25+6.0270425+0.73110
- 100+5.27200100+0.63951
- 250+4.62667250+0.56123
- 500+4.08874500+0.49598
