DATA SHEET
GAS DISCHARGE TUBES
TELEPHONE INTERFACE
2R-8x6 series
Product specification– November 05, 2018 V.0
RoHS compliant & Halogen free
Circuit Protection
Product Specification
GAS DISCHARGE TUBS
2
7
2R-8x6
Gas Discharge Tube (GDT) Data Sheet
Features
■ Provide ultra-fast response to surge voltage from slow-rising
surge of 100V/s to rapid-rising surge of 1KV/μs.
■ Stable breakdown voltage.
■ High insulation resistance.
■ Low capacitance (≤1.5pF)
■ High holdover voltage
■ Large absorbing transient current capability.
■ Micro-Gap Design
■ Size: 8.0mm*6.0mm
■ Storage and operating temperature: -40℃ ~ +85℃
■ Meets MSL level 1, per J-STD-020
■ Safety certification: E244458
Applications
Repeaters, Modems.
Telephone Interface, Line cards.
Data communication equipment.
Line test equipment
Part Number Code
2
8
R
Electrical
Characteristics
M: 10KA
P: 20KA
Electrode Numbers
2R: 2 Electrodes
DC
Spark-over
Voltage
Lead Type
L: Lead
M: SMD
Packing Code
No suffix: Bulk
TR: Tape & Reel packing
Dimensions
8: 8.0mm×6.0mm
Marking
: BritghtKing Logo
2RM090-8 : Device Marking Code
YXXX
: Date Code
www.yageo.com
Nov. 05, 2018 V.0
Circuit Protection
GAS DISCHARGE TUBS
3
7
2R-8x6
Dimensions
L Type
Dimension (mm)
Symbol
D
d
L
D
T
M Type
Spec.
Tolerance
D
8.0
+0.3, -0.5
T
6.0
+0.3, -0.5
d
0.8
±0.1
L
30.0
Max.
D
8.0
+0.3, -0.5
T
6.0
+0.3, -0.5
B
0.5
±0.1
6.0
8.0
B
D
T
1.5
Recommended Pad Size
Electrical Characteristics
Part
Number
DC
Spark-over
Voltage
Maximum
Impulse
Spark-over
Voltage
Nominal
Impulse
Discharge
Current
Alternating
Discharge
Current
Impulse
Life
100V/s
1000V/μs
8/20μs
10times
50Hz,1sec
10/1000μs
100A
Test
Voltage
(V)
(V)
(KA)
(A)
(times)
DC(V)
Minimum
Insulation
Resistance
(GΩ)
Maximum
Capacitance
1MHz
Device
Marking
Code
(pF)
2RM075L-8
2RM075M-8
75±20%
600
10
10
500
25
1.0
1.5
2RM075-8
2RM090L-8
2RM090M-8
90±20%
600
10
10
500
50
1.0
1.5
2RM090-8
2RM120L-8
2RM120M-8
120±20%
600
10
10
500
50
1.0
1.5
2RM120-8
2RM145L-8
2RM145M-8
145±20%
700
10
10
500
100
1.0
1.5
2RM145-8
2RM150L-8
2RM150M-8
150±20%
700
10
10
500
100
1.0
1.5
2RM150-8
2RM230L-8
2RM230M-8
230±20%
700
10
10
500
100
1.0
1.5
2RM230-8
2RM250L-8
2RM250M-8
250±20%
800
10
10
500
100
1.0
1.5
2RM250-8
2RM300L-8
2RM300M-8
300±20%
900
10
10
500
100
1.0
1.5
2RM300-8
2RM350L-8
2RM350M-8
350±20%
900
10
10
500
100
1.0
1.5
2RM350-8
2RM400L-8
2RM400M-8
400±20%
1000
10
10
500
100
1.0
1.5
2RM400-8
2RM470L-8
2RM470M-8
470±20%
1100
10
10
500
250
1.0
1.5
2RM470-8
2RM600L-8
2RM600M-8
600±20%
1300
10
10
500
250
1.0
1.5
2RM600-8
2RM800L-8
2RM800M-8
800±20%
1500
10
10
500
250
1.0
1.5
2RM800-8
2RP075L-8
2RP075M-8
75±20%
600
25
1.0
1.5
2RP075-8
2RP090L-8
2RP090M-8
90±20%
600
50
1.0
1.5
2RP090-8
2RP120L-8
2RP120M-8
120±20%
600
50
1.0
1.5
2RP120-8
2RP145L-8
2RP145M-8
145±20%
700
100
1.0
1.5
2RP145-8
2RP150L-8
2RP150M-8
150±20%
700
100
1.0
1.5
2RP150-8
www.yageo.com
Nov. 05, 2018 V.0
Circuit Protection
GAS DISCHARGE TUBS
4
7
2R-8x6
2RP230L-8
2RP230M-8
230±20%
700
100
1.0
1.5
2RP230-8
2RP250L-8
2RP250M-8
250±20%
800
100
1.0
1.5
2RP250-8
2RP300L-8
2RP300M-8
300±20%
900
100
1.0
1.5
2RP300-8
2RP350L-8
2RP350M-8
350±20%
900
100
1.0
1.5
2RP350-8
2RP400L-8
2RP400M-8
400±20%
1000
100
1.0
1.5
2RP400-8
2RP470L-8
2RP470M-8
470±20%
1100
250
1.0
1.5
2RP470-8
2RP600L-8
2RP600M-8
600±20%
1300
250
1.0
1.5
2RP600-8
2RP800L-8
2RP800M-8
800±20%
1500
250
1.0
1.5
2RP800-8
Notes: The surface for 2RXXXXM-8 series products is default for nickel plating, please change to use tin plating if used on PCB
boards while soldering, and adding the code “Sn” as suffix of the part number to distinguish.
Electrical Ratings
Items
DC Spark-over
Voltage
Maximum Impulse
Spark-over Voltage
Test Condition/Description
Requirement
The voltage is measured with voltage ramp dv/dt=100V/s.
The maximum impulse spark-over voltage is measured with voltage
ramp dv/dt=1000V/μs.
Maximum 8/20μs surge current that can be applied between two
electrodes, 5 positive and 5 negative surges, with 3 minutes interval
time.
Crest value
Impulse
Discharge Current
Current (%)
100
90
50
20µs
10
To meet
the specified
value
8µs
Time
Impulse Width
Alternating
Discharge Current
Insulation
Resistance
Capacitance
Rated RMS value of AC current at 50Hz, 1 sec. for 10 times with interval
time 3 min.
The resistance of gas tube shall be measured between two electrodes.
The capacitance of gas tube shall be measured between two electrodes.
Test frequency: 1MHz
www.yageo.com
Nov. 05, 2018 V.0
Circuit Protection
GAS DISCHARGE TUBS
5
7
2R-8x6
Recommended Soldering Conditions
Wave Soldering
300
Preheating
Maximum Wave 265℃
Soldering
Cooling
Temperature (℃)
250
200
150
100
50
1
1.5
2
2.5
Time (minutes)
3
3.5
Item
Conditions
Peak Temperature
265℃
Dipping Time
10 seconds
Soldering
1 time
4
Reflow Soldering
Critical Zone
TL to TP
tP
TP
Ramp-up
TL
tL
Temperature
TS max
TS min
Ramp-down
tS
Preheat
25
t 25℃ to Peak
Time
Profile Feature
Average ramp-up rate (TL to TP)
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (ts)
TS max to TL
-Ramp-up Rate
Time maintained above:
-Temperature (TL)
-Time (tL)
Peak Temperature (TP)
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
Time 25℃ to Peak Temperature
Pb-Free Assembly
3℃/second max.
150℃
200℃
60-180 seconds
3℃/second max.
217℃
60-150 seconds
260℃
20-40 seconds
6℃/second max.
8 minutes max.
www.yageo.com
Nov. 05, 2018 V.0
Circuit Protection
GAS DISCHARGE TUBS
6
7
2R-8x6
Packaging
Axial Packing (Bulk)
Skin packing
Dimension (mm)
Symbol
Spec.
Tolerance
A
264.0
±1.0
B
145.0
±1.0
H
6.5
±0.5
Quantity: 100pcs
Inner box
A0
270.0
±2.0
B0
150.0
±1.0
H0
50.0
±1.0
Quantity: 500pcs
Axial Packing (Tape & Reel)
Tape
Dimension (mm)
Symbol
Reel
Spec.
Tolerance
P
10.0
±0.3
W
65.0
±0.3
E
6.0
±0.3
F
26.5
±0.3
d
0.8
±0.05
A1
330.0
±1.0
B1
70.0
±1.0
C1
82.0
±1.0
D
25.0
±0.2
t
2.0
±0.2
Quantity: 500pcs
www.yageo.com
Nov. 05, 2018 V.0
Circuit Protection
GAS DISCHARGE TUBS
7
7
2R-8x6
Packaging
SMD Packing (Tape & Reel)
Tape
Dimension (mm)
Symbol
Reel
Spec.
Tolerance
W
16.00
±0.20
P0
4.00
±0.10
P1
12.00
±0.20
P2
2.00
±0.10
D0
1.55
±0.05
E
1.75
±0.10
F
7.50
±0.10
A0
8.20
±0.10
K0
8.50
±0.10
B0
7.50
±0.10
t0
0.50
±0.10
D
330.00
±1.00
d
13.00
±0.50
L
20.00
±0.50
t
2.00
±0.20
t
D
d
L
Quantity: 500pcs
www.yageo.com
Nov. 05, 2018 V.0
很抱歉,暂时无法提供与“2RP090M-8/S”相匹配的价格&库存,您可以联系我们找货
