AV191003C900
AV191003C900
    APEM(埃斐)
    按动开关 1万次 单刀单掷-常开 2A 48V -30℃~+70℃
AV191003C900 数据手册
14-Serie AV-1-A_18-Serie AV-A 04/11/14 14:51 Page76 AV series Anti-vandal and security pushbutton switches Distinctive features ❑ Attractive, robust and durable UG1410A • Irremovable • Anti-jamming construction : reduced travel to prevent insertion of foreign parts • Contact and mechanism protected against crushing • Fire resistant • Long life ❑ Different bushing sizes and actuator shapes ❑ Sealed versions ❑ Degree of protection of sealed versions (switches mounted on vertical panels) : IP65 to IP67 or IP69K depending on models B2 ❑ UL/CSA approved models The AV series is a large range of very robust pushbutton switches, consisting of 2 families : ANTI-VANDAL PUSHBUTTON SWITCHES (pages 77-79) • Great robustness (impact resistance IK08 (Ø 19 mm) and IK10 (Ø 22 mm) • Actuator and bushing : stainless steel • Bushing Ø 19 mm (.748) or 22 mm (.866 SECURITY PUSHBUTTON SWITCHES (pages 80-106) • Large variety of models • Actuator and bushing : nickel plated, chrome plated or polished varnished brass, stainless steel • Bushing diameter 16 mm (.629), 19 mm (.748), 22 mm (.866) or 24 mm (.944) • Marking, illumination, tactile feedback • Numerous electrical functions (momentary or maintained) EXAMPLES OF MOUNTING FOR SEALED VERSIONS Preferred For thin panels ➞ Gasket With boot U2187 (sect. H) Dimensions : first dimensions are in mm while inches are shown as bracketed numbers. Packaging unit : specified on the following pages. Mounting accessories : Standard and special hardware are presented in section I. Sealing boots are available for models with Ø 19 mm (.748) bushing. See Section H. The company reserves the right to change specifications without notice. B2-76 www.apem.com APEM 14-Serie AV-1-A_18-Serie AV-A 31/10/14 09:02 Page77 AV series Anti-vandal pushbutton switches Distinctive features and specifications ❑ Very robust Impact resistance IK08 for model Ø 19 mm (.748) and IK10 for model Ø 22 mm (.866) ❑ Stainless steel actuator and bushing ❑ UL-CSA approved (long case only) B2 SPECIFICATIONS MATERIALS • Max. current/voltage rating with resistive load : - A contacts : 4A 12VDC, 500.000 cycles - C contacts : 2A 48 VDC, 10.000 cycles • Initial contact resistance : 10 mΩ max. • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 2.000 Vrms 50 Hz min. between terminals and frame 2.000 Vrms 50 Hz min. between terminals • Torque : 5 Nm min.- 14 Nm max. applied to nut • Panel thickness : 1 (.039) to 11 mm (.433) max. • Operating temperature : -30°C to +70°C • Low level or mechanical life : 1.000.000 cycles • Hand soldering : 300°C, 3 sec. max. • Packaging unit : 20 pieces (models Ø 22) or 40 pieces (models Ø 19) ROBUSTNESS Model Ø 19 mm (.748) Degree of protection according to EN 50102, June 95 (NFC 20-015) 1.7 Kg 29.5 cm Hammer radius 25 mm CUT-OUT • Panel cut-out : Ø 19,2 mm (.755) or Ø 22,2 mm (.874) • Min. pitch for matrix mounting : 30 mm x 30 mm (1.181x1.181) SEALING Model Ø 22 mm (.866) 5 Kg IK08 Striking energy: 5 joules (5Nm) • Case : PBT • Contacts : silver (A) or brass, silver plated (C) • Bushing : stainless steel • Actuator : stainless steel 40 cm Hammer radius 50 mm ( OPTION T ) 2 IK10 Striking energy: 20 joules (20Nm) Increased impact resistance provided by a nut or mechanical stop. 1 Front panel sealing (IP65) ➀ internal gasket ➁ external gasket Option N does not include ➀ nor ➁. APEM www.apem.com B2-77 14-Serie AV-1-A_18-Serie AV-A 31/10/14 09:02 Page78 AV series Anti-vandal pushbutton switches Ø 19 mm (.748) Momentary (NO) ORDER FORMAT AV 3 SERIES NO (function 3) Case 000 Long 100 Short Function 3 NO A C Contacts Silver Brass, silver pl. Terminals 9 Screw 2 Quickconnect Bush./act. material 40 Stainless steel N T Sealing No Sealed In the following model numbers, replace • with elements selected in the above order format. Hex nut 22 (.866) across flats 7.30 (.287) 5.00 (.196) ø22.00 (.866DIA) 2.80 (.110) 2.80x0.5 (.110x.019) ø15.00 (.590DIA) Solder lug / quick-connect term. AV091003•240• ø19.00x1.00 SI (.748DIAx1.00 IS) ø22.00 (.866DIA) Screw terminals AV091003•940• 3.00 (.118) 1.20 (.047) Flat actuator - short case - 48VDC - AV09100 Screw terminals for wires 1,5 mm2 max. 9.50 (.374) 2.00 (.078) 6.50 (.255) 3.00 (.118) EPOXY Hex nut 22 (.866) across flats Flat actuator - long case - 4A 250VAC/8A125VAC - UL/CSA - AV09000 3.00 (.118) Ø19.00x1.00 SI (.748DIAx1.00 IS) Ø22.00 (.866DIA) Ø22.00 (.866DIA) Screw terminals AV090003A940• Ø15.00 (.590DIA) 5.00 (.196) To order switches marked UL-CSA, add “UU”at the end of model number. 2.00 (.078) Screw terminals for wires 1,5 mm2 max. Curved actuator - AV19 Ø22.00 (.866DIA) Ø22.00 (.866DIA) Screw terminals AV19•003•940• Solder lug/quick-connect term. (short case) AV191003•240• B2-78 7.20 (.283) Flush model - AV9D Ø22.20 Mini (.874DIA Min.) 1.30 Mini (.051 Min.) 1.20 (.047) Ø15.00 (.590DIA) 6.50 (.255) 11.60 (.456) 2.00 (.078) 3.60 (.141) B2 Actuator type 09 Flat 19 Curved 9D Flush 40 Screw terminals AV9D•003•940• Solder lug / quick-connect terminals (short case only) AV9D1003•240• www.apem.com Ø19.20 (.755DIA) Panel cut-out APEM 14-Serie AV-1-A_18-Serie AV-A 31/10/14 09:02 Page79 AV series Anti-vandal pushbutton switches Ø 22 mm (.866) Momentary (NO) ORDER FORMAT AV 3 SERIES NO (function 3) 40 Bushing/act. Case Function configuration 000 Long 3 NO 03 Flat act. 100 Short 02 Curved act. M3 Flat act + flatted bush. M2 Curved act.+ flatted bush. A C Contacts Silver Brass, silver pl. Terminals 9 Screw 2 Quickconnect Bush./act. material 40 Stainless steel N T Sealing No Sealed B2 In the following model numbers, replace • with elements selected in the above order format. Hex nut 25 (.984) across flats Flat actuator - short case - 48VDC - AV03100 ø22.00x1.00 SI (.866DIAx1.00 IS) 2.00 (.078) 1.20 (.047) 2.80 (.110) Solder lug / quick-connect term. AV031003•240• 12.70 (.500) Screw terminals for wires 1,5 mm max. 2 6.30 (.248) 2.80x0.5 (.110x.019) ø15.00 (.59DIA) ø25.00 (.984DIA) Screw terminals AV031003•940• 7.30 (.287) 3.00 (.118) EPOXY 5.00 (.196) Hex nut 25 (.984) across flats Flat actuator - long case - 4A 250VAC/8A125VAC - UL/CSA - AV03000 Ø22.00x1.00 SI (.866DIAx1.00 IS) 2.00 (.078) Ø15.00 (.59DIA) Ø25.00 (.984DIA) Screw terminals AV030003A940• 3.00 (.118) To order switches marked UL-CSA, add “UU” at the end of model number. 15.00 (.590) Screw terminals for wires 1,5 mm2 max. Curved actuator - AV02 Ø15.00 (.590DIA) Flatted bushing - AVM3 and AVM2 Ø15.00 (.590DIA) Screw terminals AV02•003•940• Solder lug / quick-connect (short case) AV021003•240• APEM 5.00 (.196) Ø25.00 (.984DIA) 2.00 (.078) 3.60 (.141) Ø25.00 (.984DIA) 10.00 (.248) Flat actuator, screw terminals AVM3•003•940• Curved actuator, screw terminals AVM2•003•940• www.apem.com Ø22.20 (.874DIA) 10.00 (.393 ) Panel cut-out B2-79 14-Serie AV-1-A_18-Serie AV-A 31/10/14 09:02 Page80 AV series Snap action security pushbutton switches Ø 16 mm (.629) Momentary (NO) ORDER FORMAT AV 3 Bushing/act. configur. Function 3 NO SERIES 06 Flat actuator 16 08 07 6P 6B NO (function 3) Curved actuator Curved act.+chamfer Flat act.+chamfer Flat act.+knurled nut Curved act.+knurled nut 0 0 Case Short C 9 OPTIONS Contacts C Brass, silver pl. Terminals 9 Screw See “Options” page. SPECIFICATIONS • Travel : 1,60 mm (.063) ± 0,3 mm (.011) • Max. current/voltage rating with resistive load : 200mA 48 VDC - 100mA 48VDC • Initial contact resistance : 50 mΩ max. • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 2.000 Vrms 50 Hz min. between terminals and frame • Electrical life : 50.000 cycles at 200mA 48VDC 100.000 cycles at 100mA 48VDC • Torque : 5 Nm min.- 14 Nm max. applied to nut • Panel thickness : 1 (.039) to 6 mm (.236) max. • Operating temperature : -30°C to +70°C • Low level or mechanical life : 1.000.000 cycles • Packaging unit : 60 pieces • Case : PBT • Contacts : brass, silver plated (C) • Bushing and actuator : see “Options” page CUT-OUT • Panel cut-out : Ø 16,2 mm (.637) • Min. pitch for matrix mounting : 24 mm x 24 mm (.944 x .944) (AV6P & AV6B : 20 mm x 20 mm) To order a product, select a basic model below and add the desired options. BASIC MODEL Hex nut 19 (.748) across flats Flat or curved actuator - screw terminals Curved actuator AV1630C9 Ø12.00 (.472DIA) Ø18.00 (.708DIA) Flat actuator AV0630C9 Ø16.00X1.00 SI (.629DIAX1.00 IS) 3.00 (.118) 3.00 (.118) 1.50 (.059) 11.20 (.440) 9.50 (.374) Screw terminals for wires 1,5 mm2 max. With knurled nut for matrix mounting 20 x 20 - AV6P and AV6B Ø18.00 (.708DIA) Ø18.00 (.708DIA) Ø12.00 (.472DIA) Ø12.00 (.472DIA) Ø18.00 (.708DIA) Ø18.00 (.708DIA) 20.00 (.787) 20.00 (.787) 20.00 (.787) 2.00 (.078) With chamfer 1.50 (.059) B2 MATERIALS Curved actuator AV0830C9 B2-80 Flat actuator AV0730C9 Flat actuator AV6P30C9 www.apem.com Curved actuator AV6B30C9 Wrench available under P/N U1990. APEM 14-Serie AV-1-A_18-Serie AV-A 31/10/14 09:02 Page81 AV series Security pushbutton switches Ø 16 mm (.629) Latching action ORDER FORMAT AV 1 Actuator 06 Flat 16 Curved SERIES ON OFF 1 1 Function Off-On 1 A Case Long OPTIONS Contacts A Silver See “Options” page. Terminals 2 Solder 4 PC 8 Quickconnect SPECIFICATIONS MATERIALS • Max. current/voltage rating with resistive load : 1A 24VDC • Initial contact resistance : 50mΩ max. • Insulation resistance : 1 GΩ min. at 500VDC • Dielectric strength : 1.500 Vrms 50 Hz min. between terminals 1 000 Vrms 50 Hz between terminals and frame • Electrical life : 40.000 cycles • Torque : 5 Nm min. - 14 Nm max. applied to nut • Panel thickness : 1 (.039) to 6 mm (.236) max. • Operating temperature : -30°C to +70°C • Low level or mechanical life : 200.000 cycles • Hand soldering : 300°C, 5 sec. max. • Packaging unit : 25 pieces • Case : PA-6T, UL94-V0 • Contacts : silver (A) Gold plated silver (AD) on request • Bushing and actuator : see “Options” page CUT-OUT • Panel cut-out : Ø 16,2 mm (.637) • Min. pitch for matrix mounting : 24 mm x 24 mm (.944 x .944) To order a product, select a basic model below and add the desired options. BASIC MODEL Hex nut 19 (.748) across flats Flat or curved actuator - solder lug terminals 3.40 (.133) OFF - ON Ø16.00X1.00 SI (.629DIAX1.00 IS) Curved actuator AV1611A2 1.40 (.055) ON 2.30 (.090) Ø12.00 (.472DIA) - Ø18.00 (.708DIA) OFF 3.00 (.118) Ø12.00 (.472DIA) Flat actuator AV0611A2 Ø18.00 (.708DIA) 3.00 (.118) EPOXY 1.50 (.059) 15.20 (.598) Quick-connect terminals 5.08 (.200) EPOXY EPOXY 1.10 (.043) 0.50 (.019) 1.20 (.047) 2.40 (.094) 0.50 (.019) 8.00 (.314) 3.50 (.137) Straight PC terminals 9.00 (.354) 2.80 (.047) Flat actuator AV0611A4 APEM Curved actuator AV1611A4 Flat actuator AV0611A8 Curved actuator AV1611A8 www.apem.com B2-81 B2 14-Serie AV-1-A_18-Serie AV-A 31/10/14 09:02 Page82 AV series Security pushbutton switches Ø 16 mm (.629) Options After selecting basic model number, fill in last 2 boxes with desired options. Bushing/act. material Sealing BASIC MODEL BUSHING/ACTUATOR MATERIALS Flat or curved metal actuator CODE BUSHING ACTUATOR 00 (standard) 10 40 Nickel plated brass Nickel plated brass Stainless steel Nickel plated brass Stainless steel Stainless steel B2 SEALING Blank No sealing K Front panel sealing (IP65) B2-82 www.apem.com APEM 14-Serie AV-1-A_18-Serie AV-A 31/10/14 09:02 Page83 AV series Security pushbutton switches Ø 19 mm (.748) Momentary (NO) ORDER FORMAT AV 3 SERIES 09 19 9P 9B NO (function 3) Bushing/act. config. Case Flat actuator 000 Long Curved actuator 100 Short Flat act., knurled nut Curved act., knurled nut Function 3 NO OPTIONS A C Contacts Terminals See “Options” page. Silver 9 Screw Brass 2 Quicksilver pl. connect SPECIFICATIONS MATERIALS • Max. current/voltage rating with resistive load : - A contacts : 4A 12VDC, 500.000 cycles - C contacts : 2A 48 VDC, 10.000 cycles • Approved ratings of models with long case and A contacts (AV..000) : UL-CSA : 4A 250VAC - 8A 125VAC - 6.000 cycles • Initial contact resistance : 10 mΩ max. • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 2.000 Vrms 50 Hz min. between terminals and frame 2.000 Vrms 50 Hz min. between terminals • Torque : 5 Nm min.- 14 Nm max. applied to nut • Panel thickness : 1 (.039) to 11 mm (.433) max. • Operating temperature : -30°C to +70°C • Low level or mechanical life : 1.000.000 cycles • Hand soldering : 300°C, 3 sec. max. • Packaging unit : 40 pieces • Case : PBT • Contacts : silver (A) or brass, silver plated (C) • Bushing and actuator : see “Options” page B2 CUT-OUT • Panel cut-out : Ø 19,2 mm (.755) • Min. pitch for matrix mounting : 30 mm x 30 mm (1.181x1.181) (AV9P & AV9B : 25 mm x 25 mm) To order a product, select a basic model below and add the desired options. BASIC MODEL Hex nut 22 (.866) across flats Flat actuator - short case - 48VDC - AV09100 Solder lug / quick-connect term. AV091003•2 Screw terminals for wires 1,5 mm2 max. 2.80 (.110) 13.50 (.531) 5.50 (.216) 2.80x0.5 (.110x.019) ø15.00 (.590DIA) ø22.00 (.866DIA) Screw terminals AV091003•9 7.30 (.287) 3.00 (.118) 1.20 (.047) 2.00 (.078) ø19.00x1.00 SI (.748DIAx1.00 IS) 5.00 (.196) EPOXY Contacts : remplace • with A (silver) or C (silver plated brass). Screw terminals AV191003•9 Solder lug / quick-connect terminals AV191003•2 APEM With knurled nut for matrix mounting 25 x 25 - AV9P and AV9B Ø22.00 (.866DIA) Ø22.00 (.866DIA) Ø15.00 (.590DIA) 25.00 (.984) Flat actuator, screw terminals AV9P1003•9 Flat actuator, solder lug term. AV9P1003•2 Curved actuator, screw terminals AV9B1003•9 Curved actuator, solder lug term. AV9B1003•2 www.apem.com 25.00 (.984) 25.00 (.984) Ø15.00 (.590DIA) 4.50 (.177) Ø15.00 (.590DIA) 2.00 (.078) 3.60 (.141) Ø22.00 (.866DIA) 4.50 (.177) Curved actuator - short case Wrench available under P/N U1929 B2-83 14-Serie AV-1-A_18-Serie AV-A 31/10/14 09:02 Page84 AV series Security pushbutton switches Ø 19 mm (.748) Momentary (NO) Hex nut 22 (.866) across flats Flat actuator - long case - 4A 250VAC/8A 125VAC - UL/CSA - AV09000 3.00 (.118) Ø19.00x1.00 SI (.748DIAx1.00 IS) Ø22.00 (.866DIA) Screw terminals AV090003A9 Ø15.00 (.590DIA) 5.00 (.196) To order switches marked UL-CSA, add “UU” at the end of model number. 2.00 (.078) 14.80 (.582) 10.50 (.413) Screw terminals for wires 1,5 mm2 max. Screw terminals AV190003A9 B2-84 With knurled nut for matrix mounting 25 x 25 - AV9P and AV9B Ø22.00 (.866DIA) Ø22.00 (.866DIA) Ø15.00 (.590DIA) 25.00 (.984) Ø15.00 (.590DIA) Flat actuator, screw terminals AV9P0003A9 www.apem.com 25.00 (.984) 25.00 (.984) Ø15.00 (.590DIA) 2.00 (.078) 3.60 (.141) Ø22.00 (.866DIA) 4.50 (.177) Curved actuator - long case 4.50 (.177) B2 Curved actuator, screw terminals AV9B0003A9 Wrench available under P/N U1929. APEM 14-Serie AV-1-A_18-Serie AV-A 31/10/14 09:02 Page85 AV series Security pushbutton switches Ø 19 mm (.748) Options After selecting basic model number, fill in last 3 boxes with desired options. Bush./actuator material Marking Sealing BASIC MODEL BUSHING/ACTUATOR MATERIALS Flat or curved metal actuator CODE BUSHING ACTUATOR 00 (standard) 10 12 20 30 40 80 Nickel plated brass Nickel plated brass Nickel plated brass Chrome plated brass Chrome plated brass Stainless steel Varnished polished brass Nickel plated brass Stainless steel Chrome plated brass Chrome plated brass Stainless steel Stainless steel Varnished polished brass CODE BUSHING ACTUATOR COLOUR 0• (standard) 2• 8• Nickel plated brass Chrome plated brass Varnished polished brass Replace • with one of the following codes. B2 Flat thermoplastic actuator Select an option from each of the two tables below. MARKING - By engraving on flat or curved brass actuator (stainless steel on request) - by hot stamping on flat thermoplastic actuator Ø15.00 (0.590DIA) 8.00 (0.314) 1 : blue - 1/4 : dark blue - 2 : black - 3 : green 4 : grey - 5 : yellow - 6 : red - 7/1: white 9 : orange 1.50 (0.059) TYPE OF MARKING CODE TYPE 0 to 9 X Y A to N P to W 0 Numbers 0 to 9 Symbol * Symbol # Letters A to N Letters P to W Letter O Letter O : same code and same design as number 0. For special symbols, consult factory. Minimum order : 500 pieces COLOUR OF MARKING CODE Brass actuator 0 (standard) 2 COLOUR Same as finish Black Note : a finished product supplied in version “0” cannot be modified to version "2". Thermoplastic actuator 2 Black 7 White SEALING Blank No sealing 2 1 K Frontal panel sealing (IP65) APEM ➀ internal gasket ➁ external gasket www.apem.com B2-85 14-Serie AV-1-A_18-Serie AV-A 31/10/14 09:02 Page86 AV series Security pushbutton switches Ø 19 mm (.748) Momentary (NC/NO) ORDER FORMAT 3 1 2 Series Bushing diameter Bush./act. config. AV 19 L Actuator style 40 P B 4 Bush./act. Contact/ matl terminals 7 See below Combined NC/NO SPECIFICATIONS • Max. current/voltage rating with resistive load : 5A 250VAC - 5A 125VAC - 6.000 cycles 5A 15VDC - 3A 30VDC - 50.000 cycles • Initial contact resistance : 100 mΩ max. • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 2.000 Vrms 50 Hz min. between term. and frame • Torque : 5 Nm min.- 14 Nm max. applied to nut • Panel thickness : 1 (.039) to 9 mm (.354) max. • Operating temperature : -20°C to +85°C • Low level or mechanical life : 1.000.000 cycles • Front panel sealing : IP65 and IP69K • Packaging unit : 20 pieces • Case : PA 6/6 • Contacts : silver • Bushing : stainless steel (std) • Actuator : stainless steel (std) CUT-OUT • Panel cut-out : Ø 19,2 mm (.755) • Min. pitch for matrix mounting : 30 mm x 30 mm (1.181x1.181) All model numbers below are for switches with standard bushing/actuator material. BASIC MODEL Hex nut 22 (.866) across flats ➞ O-ring Solder lug terminals - AV19..407 2.00 (.078) 3 1 2 Ø15.00 (.590) Ø22.00 (.866DIA) Curved actuator AV19LB407 Ø15.00 (.590) 4 Flat actuator AV19LP407 0.50 (.019) Ø19.00X1.00 SI (.748DIAX1.00 IS) 1.50 (.059) 2.00 (.078) 3.60 (.141) Ø22.00 (.866DIA) B2 MATERIALS 13.10 (.515) BUSHING/ACTUATOR MATERIALS 3.60 (.141) For non-standard material, replace 40 with one of the following codes. CODE BUSHING ACTUATOR 00 20 Nickel plated brass Chrome plated brass Nickel plated brass Chrome plated brass B2-86 12.60 (.496) www.apem.com APEM 14-Serie AV-1-A_18-Serie AV-A 31/10/14 09:02 Page87 AV series Security pushbutton switches Ø 19 mm (.748) With illuminated ring - momentary (NC/NO) ORDER FORMAT Options : see next page. 2 AV 9 SERIES Bushing dia. 19 mm 0 1 2 4 LED colour 0 : no LED - 1 : blue - V : green 5 : yellow - 6 : red - 7 : white - 9 : amber SPECIFICATIONS • Case : polyamide, glass filled • Contacts : silver • Bushing : see next page • Actuator : see next page • Elastomeric membrane : silicone • LED B2 CUT-OUT • Panel cut-out : Ø 19,2 mm (.755) • Min. pitch for matrix mounting : 30 mm x 30 mm (1.181x1.181) To order a product, select a basic model below and add the desired LED colour and voltage. Then select the desired options on next page. ** Resistor value = supply voltage - LED forward voltage LED forward current Hex nut 22 (.866) across flats Flat actuator - solder lug terminals 2.20 (.086) NC 2.80x0.50 (.110x.019) Ø22.00 (.866DIA) + - - 3.00 (.118) NO Illuminated (select LED colour above) * AV9•022 ON - MOM ON Terminals 2 Solder / quick-connect F Flying leads C Cable MATERIALS • Travel : 2 mm ± 0,3 mm (.003) • Max. current/voltage rating with resistive load : 1A 30VDC • LED voltage : 12VDC, 24VDC or 48VDC (If not supplied by APEM, a resistor must be series-connected by the user)** • Initial contact resistance : 100 mΩ max. • Insulation resistance : 10 MΩ min. at 500VDC • Dielectric strength : 500 Vrms 50 Hz min. between terminals 1.000 Vrms 50 Hz min. between terminals and frame • Electrical life : 250.000 cycles at full load • Operating force : 5N ± 2N • Torque : 5 Nm min.- 14 Nm max. applied to nut • Panel thickness : 1 (.039) to 6 mm (.236) max. • Low level or mechanical life : 1.000.000 cycles • Operating temperature : -30°C to +85°C • Hand soldering : 350°C, 5 seconds max. • Packaging unit : flying lead/cable models : 1 piece - other models : 40 pieces Non-illuminated AV90022 Contacts 2 Silver MOM Ø19.00x1.00 SI (.748DIAx1.00 IS) NC/NO LED resistor No resistor supplied 12VDC resistor 24VDC resistor 48VDC resistor NC NO 11.60 (.456) 22.00 (.866) 12.10 (.476) 8.30 (.326) * No LED resistor supplied on this model. Hex nut 22 (.866) across flats Flat actuator - flying lead terminals Illuminated (select LED colour & resistor above) AV9••2F ON - MOM Non-illuminated AV9002F ON - 3.00 (.118) Ø15.00 (.590DIA) Ø19.00x1.00 SI (.748DIAx1.00 IS) Ø22.00 (.866DIA) 2.20 (.086) MOM 11.60 (.456) 12.10 (.476) 200 (7.874) Ø12.00 (.472DIA) Wire colours : black: NC, orange: NO, red: LED anode (+), blue : LED cathode (-) APEM www.apem.com B2-87 14-Serie AV-1-A_18-Serie AV-A 31/10/14 09:02 Page88 AV series Security pushbutton switches Ø 19 mm (.748) With illuminated ring - momentary (NC/NO) Hex nut 22 (.866) across flats Flat actuator - cable terminals 2.20 (.086) 3.00 (.118) Ø19.00x1.00 SI (.748DIAx1.00 IS) Non-illuminated AV9002C ON - MOM Ø22.00 (.866DIA) Illuminated (select colour & resistor) AV9••2C ON - MOM 11.60 (.456) 200 (7.874) 12.10 (.476) B2 After selecting basic model No., fill in last 5 boxes with desired options. Flying lead protection Flying lead/ cable length Ring colour Bushing / plunger mat. Sealing BASIC MODEL FLYING LEAD PROTECTION No protection and/or no flying leads Heat-shrink sleeves Tube + epoxy 0 1 2 FLYING LEAD/CABLE LENGTH No flying leads / no cable Length 20 cm (standard) Length in centimeters 000 020 XXX RING COLOURS BUSHING/PLUNGER MATERIALS CODE COLOUR CODE BUSHING ACTUATOR 00 40 4A 4B 70 Nickel plated brass Stainless steel 303 Stainless steel 304 Stainless steel 316 Chrome pl. brass, black Nickel plated brass Stainless steel 303 Stainless steel 304 Stainless steel 316 Chrome pl. brass, black 1 2 3 4 5 Blue Black * Green Grey * Yellow CODE COLOUR 6 7 8 9 Red Opal white (std) Translucent Orange * non-illuminated only Other : on request. SEALING Blank No sealing 2 1 K Front panel sealing (IP67) B2-88 ➀ internal membrane ➁ external gasket www.apem.com APEM 14-Serie AV-1-A_18-Serie AV-A 31/10/14 09:02 Page89 AV series Security pushbutton switches Ø 19 mm (.748) Illuminated and non-illuminated - latching ORDER FORMAT AV 1 Bush./act. config. Actuator type 09 Flat 19 Curved SERISE E Illumin. 0 No L Illum. 0 1 3 5 6 LED colour No LED Blue Green Yellow Red A OPTIONS See next page. Function Terminals 2 Solder Contacts 4 PC 8 Quickconnect SPECIFICATIONS MATERIALS • Max. current/voltage rating with resistive load : 2A 48 VDC • LED voltage and consumption : blue 3,5V 10mA, green : 2V 10mA yellow & red : 2V 20mA (a resistor must be series-connected by the user)** • Initial contact resistance : 50 mΩ max. • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 1 000 Vrms 50 Hz min. between terminals 500 Vrms 50 Hz min. between terminals and frame • Electrical life : 500.000 cycles at 2A 48VDC • Torque : 5 Nm min.- 14 Nm max. applied to nut • Panel thickness : 1 (.039) to 9 mm (.354) max. • Operating temperature : -30°C to +70°C • Low level or mechanical life : 1.000.000 cycles • Hand soldering : 300°C, 4 seconds max. • Packaging unit : 20 pieces • Case : PA6T UL94-V0 • Contacts : silver • Bushing and actuator : see next page • LED CUT-OUT • Panel cut-out : Ø 19,2 mm (.755) • Min. pitch for matrix mounting : 30 mm x 30 mm (1.181 x 1.181) To order a product, select a basic model below and add the desired options selected on next page. ** Resistor value = supply voltage - LED forward voltage LED forward current Standard actuator position : the actuator is flush in the non-latched position and recessed in the latched position. Hex nut 22 (.866) across flats Ø19.00x1.00 SI (.748DIAx1.00 IS) 3.60 (.141) 3.00 (.118) 2.00 (.078) NC ON Curved actuator AV19100EA2 ON - ON NO 1.40 (.055) - Ø15.00 (.590DIA) ON Ø22.00 (.866DIA) 2.30 (.090) Flat actuator * AV09100EA2 0.50 (.019) Non-illuminated - solder lug terminals NC 13.50 (.531) 10.70 (.421) 2.80 (.110) * Also available with prominent actuator in the non-latched position Hex nut 22 (.866) across flats Ø19.00x1.00 SI (.748DIAx1.00 IS) 3.00 (.118) 2.00 (.078) 2.30 (.090) ON Ø3.20 (.125DIA) NO 1.40 (.055) - Ø15.00 (.590DIA) ON Ø22.00 (.866DIA) Flat actuator AV091L•EA2 NC 0.50 (.019) Illuminated - solder lug terminals NC 13.50 (.531) 10.70 (.421) 2.80 (.110) Replace • with desired LED colour. APEM www.apem.com B2-89 B2 14-Serie AV-1-A_18-Serie AV-A 31/10/14 09:02 Page90 AV series Security pushbutton switches Ø 19 mm (.748) Latching - Options Quick-connect terminals 8.00 (.314) 3.40 (.133) Straight PC terminals 1.20 (.047) 2.40 (.094) 1.10 (.043) 2.80 (.110) Replace 2 with 4 at the end of the model numbers shown on previous page. Replace 2 with 8 at the end of the model numbers shown on previous page. B2 After selecting basic model number, fill in last 2 boxes with desired options. Bushing/ act. material Sealing BASIC MODEL BUSHING/ACTUATOR MATERIALS CODE BUSHING ATUATOR 00 (std) 10 40 50 Nickel plated brass Nickel plated brass Stainless steel Stainless steel Nickel plated brass Stainless steel Stainless steel Nickel plated brass SEALING Blank No sealing 1 K 2 Frontal panel sealing (IP65) B2-90 ➀ elastomeric membrane ➁ external gasket www.apem.com APEM 14-Serie AV-1-A_18-Serie AV-A 31/10/14 09:02 Page91 AV series Tactile security pushbutton switches Ø 19 mm (.748) Illuminated and non-illuminated - momentary (NO) ORDER FORMAT AV SERIES NO (function 3) C7 3 Case Actuator type 09 Flat 19 Curved 0 L D OPTIONS Function Illumin. No Illum. Contact Terminals 2 Solder 9 Screw SPECIFICATIONS See next page MATERIALS • Travel : 0,7 mm (.027) ±0,1 mm (.003) • Max. current/voltage rating with resistive load : 50mA 24VDC • LED voltage and consumption : 2-colour LED : 2V (3V max.) 20mA Other colours : 2V (3V max.) 10mA A resistor must be series-connected by the user ** • Initial contact resistance : 100 mΩ max. • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 500 Vrms 50 Hz min. between terminals 2.000 Vrms 50 Hz min. between terminals and frame • Electrical life : 1.000.000 cycles at full load • Operating force : 7 N ±-2N • Torque : 5 Nm min.- 14 Nm max. applied to nut • Panel thickness : 1 (.039) to 6 mm (.236) max. • Operating temperature : -30°C to +70°C • Hand soldering : 270°C, 3 seconds max. • Packaging unit : 40 pieces • Case : PBT UL94-V0 • Terminals : brass, gold plated • Contacts : gold plated dome • Bushing and actuator : see next page • LED CUT-OUT • Panel cut-out : Ø 19,2 mm (.755) • Min. pitch for matrix mounting : 30 mm x 30 mm (1.181x1.181) To order a product, select a basic model below and add the desired options selected on next page. ** Resistor value = supply voltage - LED forward voltage LED forward current Hex nut 22 (.866) across flats Flat actuator - non-illuminated Ø19.00x1.00 SI (.748DIAx1.00 IS) 2.00 (.078) 2.00 (.078) 3.00 (.118) Ø15.00 (.590DIA) Ø22.00 (.866DIA) Screw terminals AV09C703D9 Ø15.00 (.590DIA) Ø22.00 (.866DIA) 1.10 (.043) Solder lug terminals AV09C703D2 1.90 (.074) EPOXY 4.15 (.163) 13.50 (.531) Also available with curved actuator : AV19C703D2 or AV19C703D9 3.90 (.153) 13.50 (.531) 13.20 (.519) Hex nut 22 (.866) across flats Flat actuator - illuminated Ø19.00x1.00 SI (.748DIAx1.00 IS) 2.00 (.078) 2.00 (.078) 3.00 (.118) Ø10.00 (.393DIA) Ø15.00 (.590DIA) Ø22.00 (.866DIA) - Ø15.00 (.590DIA) + Ø22.00 (.866DIA) Screw terminals AV09C7L3D9 1.10 (.043) Solder lug terminals AV09C7L3D2 1.90 (.074) EPOXY 4.15 (.163) 13.50 (.531) APEM www.apem.com 13.20 (.519) 13.50 (.531) 3.90 (.153) B2-91 B2 14-Serie AV-1-A_18-Serie AV-A 31/10/14 09:02 Page92 AV series Tactile security pushbutton switches Ø 19 mm (.748) Options Bushing/act. material After selecting basic model no., fill in last 4 boxes with desired options. LED colour Marking Sealing BASIC MODEL BUSHING/ACTUATOR MATERIALS Non-illuminated models CODE BUSHING ACTUATOR CODE BUSHING ACTUATOR 00 (std) 10 30 40 80 Nickel plated brass Nickel plated brass Chrome plated brass Stainless steel Varnished polished brass Nickel plated brass Stainless steel Stainless steel Stainless steel Varnished polished brass 00 (std) 20 40 50 80 Nickel plated brass Chrome plated brass Stainless steel Stainless steel Varnished polished brass Nickel plated brass Chrome plated brass Stainless steel Nickel plated brass Varnished polished brass LED COLOURS No LED Blank 1: Blue - 3 : Green - 5 : Yellow - 6 : Red - 7 : White - 9 : Amber - 2 : Red/green Select an option from each of the two tables below. MARKING For flat or curved actuator. TYPE OF MARKING - by engraving on non-illuminated brass actuator (stainless steel on request). - by hot stamping on thermoplastic insert (illuminated actuators) Ø10.00 (0.393DIA) 8.00 (0.314) B2 Illuminated models 1.00 (0.039) 1.50 (0.059) CODE TYPE 0 to 9 X Y A to N P to W 0 Numbers 0 to 9 Symbol * Symbol # Letters A to N Letters P to W Letter O Letter O : same code and same design as number 0. For special symbols, consult factory. Minimum order : 500 pieces COLOUR OF MARKING CODE COLOUR Non-illuminated actuators 0 (standard) Same as finish 2 Black Note : a finished product supplied in version “0” cannot be modified to version "2". Illuminated actuators 2 Black (on white) SEALING Blank No sealing 2 1 K Front panel sealing (IP65) B2-92 ➀ internal gasket ➁ external gasket www.apem.com APEM 14-Serie AV-1-A_18-Serie AV-A 31/10/14 09:02 Page93 AV series Tactile security pushbuttons Ø 19 mm (.748) with overmolded actuator Illuminated and non-illuminated - momentary (NO) ORDER FORMAT AV 9 SERIES Bush./act. configuration NO (function 3) D Illumination S0 No SL Illum. Contacts OPTIONS See next page Terminals 2 Solder 9 Screw SPECIFICATIONS MATERIALS • Travel : 0,7 mm (.027) ± 0,1 mm (.003) • Max. current/voltage rating with resistive load : 50mA 24VDC • LED voltage and consumption : 2-colour LED : 2V (3V max.) 20mA Other colours : 2V (3V max.) 10mA (a resistor must be series-connected by the user)** • Initial contact resistance : 100 mΩ max. • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 500 Vrms 50 Hz min. between terminals 2.000 Vrms 50 Hz min. between terminals and frame • Electrical life : 1.000.000 cycles at full load • Operating force : 7 N ±2N - Sealing option K will increase the operating force. • Torque : 5 Nm min.- 14 Nm max. applied to nut • Panel thickness : 1 (.039) to 6 mm (.236) max. • Operating temperature : -30°C to +70°C • Hand soldering : 270°C, 3 sec. max. • Packaging unit : 16 pieces ** Resistor value = supply voltage - LED forward voltage LED forward current • Case : PBT UL94-V0 • Terminals : brass, gold plated • Contacts : gold plated dome • Bushing : see next page • Actuator : stainless steel, with thermoplastic overmolding • LED CUT-OUT • Panel cut-out : Ø 19,2 mm (.755) • Min. pitch for matrix mounting : 30 mm x 30 mm (1.181x1.181) To order a product, select a basic model below and add the desired options selected on next page. Hex nut 22 (.866) across flats Flat actuator - solder lug terminals 2.00 (.078) 3.00 (.118) 2.00 (.078) 1.90 (.074) Ø15.00 (.590DIA) Ø22.00 (.866DIA) Ø15.00 (.590DIA) Ø22.00 (.866DIA) 1.10 (.043) Illuminated AV9SLD2 Non-illuminated AV9S0D2 B2 4.15 (.163) 4.30 (.169) 9.80 (.385) Also available with bushing Ø 22 (.866) : on request. Hex nut 22 (.866) across flats Flat actuator - screw terminals 2.00 (.078) 9.00 (.354) Ø15.00 (.590DIA) Ø22.00 (.866DIA) Ø15.00 (.590DIA) Non-illuminated AV9S0D9 Ø22.00 (.866DIA) Illuminated AV9SLD9 3.00 (.118) 2.00 (.078) 9.80 (.385) 4.30 (.169) Also available with bushing Ø 22 (.866) : on request. APEM www.apem.com B2-93 14-Serie AV-1-A_18-Serie AV-A 31/10/14 09:02 Page94 AV series Tactile security pushbuttons Ø 19 mm (.748) with overmolded actuator Options Bushing material After selecting basic model no., fill in last 5 boxes with desired options. B2 Overmolding LED colour Actuator type Sealing BASIC MODEL BUSHING MATERIALS OVERMOLDING COLOURS LED COLOURS CODE MATERIAL CODE COLOUR CODE COLOUR CODE 0 (std) 2 4 5 6 7 8 9 Nickel plated brass Chrome plated brass Stainless steel Gold plated brass Chrome plated brass, satin Chrome pl. brass, black Varnished polished brass Polished brass 1 2 3 4 5 Blue Black * Green Grey * Yellow 6 7 8 9 Red White Translucent Orange Blank 1 2 3 ** V ** 5 6 7 9 * non-illuminated only COLOUR No LED Blue Red/green Green Green, high intensity Yellow Red White Amber ** To order a green LED for actuator style 002, always use code V. Other actuator styles can be ordered with LED code 3 or V. ACTUATOR STYLES The ring and symbols are obtained by photochemical engraving of a stainless steel insert. The insert is then overmolded in the desired colour. The following actuator styles are available. For other types, consult factory. CODE 001 002 003 004 005 DESCRIPTION Illuminated ring and disc Illuminated ring Arrow Loudspeaker OFF Opening CODE 006 008 009 010 011 DESCRIPTION Validation Closing Standby Cancel Power RING/SYMBOL SYMBOL SEALING Blank No sealing Recommended panel mounting for IP69K 2 1 K Front panel sealing (IP67) B2-94 ➀ internal membrane ➁ external gasket www.apem.com K Front panel sealing (IP69K) APEM 14bis-Serie AV-2-A_18-Serie AV-A 31/10/14 09:01 Page95 AV series Tactile security pushbuttons Ø 22 mm (.866) with overmolded actuator Illuminated and non-illuminated - momentary (NO) UG1410A ORDER FORMAT AV 3 SERIES Bush./act. configuration NO (function 3) D Illumination S0 No SL Illum. Contacts OPTIONS See next page Terminals 2 Solder 9 Screw SPECIFICATIONS MATERIALS • Travel : 0,7 mm (.027) ± 0,1 mm (.003) • Max. current/voltage rating with resistive load : 50mA 24VDC • LED voltage and consumption : 2-colour LED : 2V (3V max.) 20mA Other colours : 2V (3V max.) 10mA (a resistor must be series-connected by the user)** • Initial contact resistance : 100 mΩ max. • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 500 Vrms 50 Hz min. between terminals 2.000 Vrms 50 Hz min. between terminals and frame • Electrical life : 1.000.000 cycles at full load • Operating force : 7 N ±2N - sealing option K will increase the operating force. • Torque : 5 Nm min.- 14 Nm max. applied to nut • Panel thickness : 1 (.039) to 6 mm (.236) max. • Operating temperature : -30°C to +70°C • Hand soldering : 270°C, 3 sec. max. • Packaging unit : 16 pieces ** Resistor value = supply voltage - LED forward voltage LED forward current • Case : PBT UL94-V0 • Terminals : brass, gold plated • Contacts : gold plated dome • Bushing : see next page • Actuator : stainless steel, with thermoplastic overmolding • LED CUT-OUT • Panel cut-out : Ø 22,2 mm (.874) • Min. pitch for matrix mounting : 30 mm x 30 mm (1.181x1.181) To order a product, select a basic model below and add the desired options selected on next page. Hex nut 25 (.984) across flats Flat actuator - solder lug terminals 2.00 (.078) 4.00 (.157) 2.00 (.078) 1.90 (.074) Ø15.00 (.590DIA) Ø25.00 (.984DIA) Ø15.00 (.590DIA) Ø25.00 (.984DIA) 1.10 (.043) Illuminated AV3SLD2 Non-illuminated AV3S0D2 B2 EPOXY 4.15 (.163) 4.80 (.188) 9.30 (.366) Hex nut 25 (.984) across flats Flat actuator - screw terminals 2.00 (.078) 4.00 (.157) 2.00 (.078) 9.00 (.354) Ø15.00 (.590DIA) Ø25.00 (.984DIA) Ø15.00 (.590DIA) Non-illuminated AV3S0D9 Ø25.00 (.984DIA) Illuminated AV3SLD9 9.30 (.366) APEM www.apem.com 4.80 (.188) B2-95 14bis-Serie AV-2-A_18-Serie AV-A 31/10/14 09:01 Page96 AV series Tactile security pushbuttons Ø 22 mm (.866) with overmolded actuator Options Bushing material After selecting basic model no., fill in last 5 boxes with desired options. B2 Overmolding LED colour Actuator type Sealing BASIC MODEL BUSHING MATERIALS OVERMOLDING COLOURS LED COLOURS CODE MATERIAL CODE COLOUR CODE COLOUR CODE 0 (std) 2 4 5 6 7 8 9 Nickel plated brass Chrome plated brass Stainless steel Gold plated brass Chrome plated brass, satin Chrome pl. brass, black Varnished polished brass Polished brass 1 2 3 4 5 Blue Black * Green Grey * Yellow 6 7 8 9 Red White Translucent Orange Blank 1 2 3 ** V ** 5 6 7 9 * non-illuminated only COLOUR No LED Blue Red/green Green Green, high intensity Yellow Red White Amber ** To order a green LED for actuator style 002, always use code V. Other actuator styles can be ordered with LED code 3 or V. ACTUATOR STYLES The ring and symbols are obtained by photochemical engraving of a stainless steel insert. The insert is then overmolded in the desired colour. The following actuator styles are available. For other types, consult factory. CODE 001 002 003 004 005 DESCRIPTION Illuminated ring and disc Illuminated ring Arrow Loudspeaker OFF Opening CODE 006 008 009 010 011 DESCRIPTION Validation Closing Standby Cancel Power RING/SYMBOL SYMBOL SEALING Blank No sealing Recommended panel mounting for IP69K 2 1 K Front panel sealing (IP67) B2-96 ➀ internal membrane ➁ external gasket www.apem.com K Front panel sealing (IP69K) APEM 14bis-Serie AV-2-A_18-Serie AV-A 31/10/14 09:01 Page97 AV series Security pushbutton switches Ø 22 mm (.866) Momentary (NO) ORDER FORMAT AV SERIES NO (function 3) 3 Bushing/act. configuration 03 Flat actuator 02 Curved actuator M2 Curved act.+flatted bush. M3 Flat act.+flatted bush. Case 000 Long 100 Short Function 3 NO OPTIONS A C Contacts Silver Brass, silver pl. SPECIFICATIONS 9 2 Terminals Screw Quickconnect See “Options” page. MATERIALS • Max. current/voltage rating with resistive load : - A contacts : 4A 12VDC, 500.000 cycles - C contacts : 2A 48 VDC, 10.000 cycles • Approved ratings of models with long case and A contacts (AV..000) : UL-CSA : 4A 250VAC - 8A 125VAC - 6.000 cycles • Initial contact resistance : 10 mΩ max. • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 2.000 Vrms 50 Hz min. between terminals and frame 2.000 Vrms 50 Hz min. between terminals • Torque : 5 Nm min.- 14 Nm max. applied to nut • Panel thickness : 1 (.039) to 11 mm (.433) max. • Operating temperature : -30°C to +70°C • Low level or mechanical life : 1.000.000 cycles • Hand soldering : 300°C, 3 sec. max. • Packaging unit : 20 pieces • Case : PBT • Contacts : silver (A) or brass, silver plated (C) • Bushing and actuator : see “Options” page B2 CUT-OUTS • Panel cut-out : Ø 22,2 mm (.874) • Min. pitch for matrix mounting : 30 mm x 30 mm (1.181x1.181) To order a product, select a basic model below or on next page and add the desired options. BASIC MODEL Hex nut 25 (.984) across flats Flat actuator - short case - 48VDC - AV03100 ø22.00x1.00 SI (.866DIAx1.00 IS) 2.00 (.078) 1.20 (.047) 2.80 (.110) 12.70 (.500) Screw terminals for wires 1,5 mm2 max. 6.30 (.248) 2.80x0.5 (.110x.019) ø15.00 (.59DIA) Solder lug / quick-connect term. AV031003•2 ø25.00 (.984DIA) Screw terminals AV031003•9 7.30 (.287) 3.00 (.118) EPOXY 5.00 (.196) Contacts : remplace • with A (silver) or C (silver plated brass). Curved actuator - short case Ø15.00 (.590DIA) Ø15.00 (.590DIA) Screw terminals AV021003•9 Solder lug / quick-connect terminals AV021003•2 APEM Flatted bushing - short case - AVM3 and AVM2 Ø25.00 (.984DIA) 2.00 (.078) 3.60 (.141) Ø25.00 (.984DIA) Flat actuator, screw terminals AVM31003•9 Curved actuator, screw terminals AVM21003•9 www.apem.com Ø22.20 (.874DIA) 10.00 (.393 ) B2-97 14bis-Serie AV-2-A_18-Serie AV-A 31/10/14 09:01 Page98 AV series Security pushbutton switches Ø 22 mm (.866) Momentary (NO) - momentary (NC) - alternate action Hex nut 25 (.984) across flats Flat actuator - long case - 4A 250VAC/8A 125VAC - UL/CSA - AV03000 Ø22.00x1.00 SI (.866DIAx1.00 IS) 2.00 (.078) Ø15.00 (.59DIA) Ø25.00 (.984DIA) Screw terminals AV030003A9 3.00 (.118) To order switches marked UL-CSA, add “UU” at the end of model number. 15.00 (.590) Screw terminals for wires 1,5 mm2 max. B2 Curved actuator - long case Ø15.00 (.590DIA) Ø25.00 (.984DIA) 2.00 (.078) 3.60 (.141) 5.00 (.196) Flatted bushing - long case - AVM3 and AVM2 Ø25.00 (.984DIA) Ø15.00 (.590DIA) 10.00 (.248) Ø22.20 (.874DIA) Flat actuator, screw terminals AVM30003•9 Curved actuator, screw terminals AVM20003•9 Screw terminals AV020003A9 10.00 (.393 ) MOMENTARY NORMALLY CLOSED MODEL (NC) Hex nut 25 (.984) across flats Bushing Ø 22 (.866) - AV..1200 ON - 13.20 (.519) Ø15.00 (.59DIA) 7.00 (.275) Hex nut 25 (.984) across flats 3.00 (.118) 8.40 (.330) Ø15.00 (.59DIA) 3.60 (.141) ON Ø22.00x1.00 SI (.866DIAx1.00 IS) 15.40 (.606) 5.80 (.228) 1.60 (.063) 14.00 (.551) Ø25.00 (.984DIA) • Double pole, solder lug/quick-connect term., curved actuator • Silver contacts • Max. current/voltage rating with resistive load : 3(1,5)A 250VAC - 6A 125VAC - 3A 24VAC or DC • Dielectric strength : 3.000 Vrms min. between terminals and frame • Electrical life : 10.000 cycles at full load 50.000 cycles at 1A 24VAC or DC • Mechanical life : 100.000 cycles • Packaging unit : 10 pieces Ø3.00x0.50 (.118DIAx.0.50) Ø25.00 (.984DIA) 3.60 (.141) Curved actuator AV021202C900 Bushing Ø 22 (.866) - alternate action - AV..4700 AV044746A200 3.00 (.118) 0.50x2.80 (.019x.110) Flat actuator AV031202C900 Ø22.00x1.00 SI (.866DIAx1.00 IS) 2.00 (.078) Ø15.00 (.59DIA) • Single pole, screw terminals, without marking • Silver plated copper contacts (C) • Max. current/voltage rating with resistive load : 2A 250VAC - 3A 125VAC - 2,5A 24VDC • Dielectric strength : 2.000 Vrms 50 Hz min. betw. term. and frame 2.000 Vrms. 50 Hz min. between terminals • Electrical life : 100.000 cycles at 0,3A 24VAC or DC 10.000 cycles at full load • Packaging unit : 20 pieces 14.00 (.551) 20.60 (.811) 7.20 (.283) Further specifications : see previous page. Bushing/actuator materials, marking and sealing : see ”options” on next page. B2-98 www.apem.com APEM 14bis-Serie AV-2-A_18-Serie AV-A 31/10/14 09:01 Page99 AV series Security pushbutton switches Ø 22 mm (.866) Options After selecting basic model number, fill in last 3 boxes with desired options. Bush./actuator material Marking Sealing BASIC MODEL BUSHING/ACTUATOR MATERIALS Flat or curved metal actuator CODE BUSHING ACTUATOR 00 (standard) 10 12 20 30 40 80 ** Nickel plated brass Nickel plated brass Nickel plated brass Chrome plated brass Chrome plated brass Stainless steel Varnished polished brass Nickel plated brass Stainless steel Chrome plated brass Chrome plated brass Stainless steel Stainless steel Varnished polished brass CODE BUSHING ACTUATOR COLOUR 0• (standard) 2• 8• Nickel plated brass Chrome plated brass Varnished polished brass Replace • with one of the following codes. B2 Flat thermoplastic actuator Select an option from each of the two tables below. MARKING - By engraving on flat or curved brass actuator (stainless steel on request) - by hot stamping on flat thermoplastic actuator Ø15.00 (0.590DIA) 8.00 (0.314) 1 : blue - 1/4 : dark blue - 2 : black - 3 : green 4 : grey - 5 : yellow - 6 : red - 7/1: white 9 : orange 1.50 (0.059) TYPE OF MARKING CODE TYPE 0 to 9 X Y A to N P to W 0 Numbers 0 to 9 Symbol * Symbol # Letters A to N Letters P to W Letter O Letter O : same code and same design as number 0. For special symbols, consult factory. Minimum order : 500 pieces COLOUR OF MARKING CODE Brass actuator 0 (standard) 2 COLOUR Same as finish Black Note : a finished product supplied in version “0” cannot be modified to version "2". Thermoplastic actuator 2 Black 7 White SEALING Blank No sealing 2 1 K Frontal panel sealing (IP65) APEM ➀ internal gasket ➁ external gasket www.apem.com B2-99 14bis-Serie AV-2-A_18-Serie AV-A 31/10/14 09:01 Page100 AV series Security pushbutton switches Ø 22 mm (.866) With illuminated ring - momentary (NC/NO) ORDER FORMAT Options : see next page. 2 AV 3 SERIES Bushing dia. 22 mm LED colour 0 : no LED - 1 : blue - V : green 5 : yellow - 6 : red - 7 : white - 9 : amber NC/NO LED resistor No resistor supplied 12VDC resistor 24VDC resistor 48VDC resistor 0 1 2 4 SPECIFICATIONS MATERIALS • Travel : 2 mm ± 0,3 mm (.003) • Max. current/voltage rating with resistive load : 1A 30VDC • LED voltage : 12VDC, 24VDC or 48VDC (If not supplied by APEM, a resistor must be series-connected by the user)** • Initial contact resistance : 100 mΩ max. • Insulation resistance : 10 MΩ min. at 500VDC • Dielectric strength : 500 Vrms 50 Hz min. between terminals 1.000 Vrms 50 Hz min. between terminals and frame • Electrical life : 250.000 cycles at full load • Operating force : 5N ± 2N • Torque : 5 Nm min.- 14 Nm max. applied to nut • Panel thickness : 1 (.039) to 6 mm (.236) max. • Low level or mechanical life : 1.000.000 cycles • Operating temperature : -30°C to +85°C • Hand soldering : 350°C, 5 seconds max. • Packaging unit : flying lead/cable models : 1 piece - other models : 40 pieces • Case : polyamide, glass filled • Contacts : silver • Bushing : see next page • Actuator : see next page • Elastomeric membrane : silicone • LED CUT-OUT • Panel cut-out : Ø 22,2 mm (.874) • Min. pitch for matrix mounting : 30 mm x 30 mm (1.181x1.181) To order a product, select a basic model below and add the desired LED colour and voltage. Then select the desired options on next page. ** Resistor value = supply voltage - LED forward voltage LED forward current Hex nut 25 (.984) across flats Flat actuator - solder lug terminals 4.00 (.157) 2.20 (.086) - ON - MOM NO NC 11.60 (.456) 25.00 (.984) 12.10 (.476) Ø22.00x1.00 SI (.866DIAx1.00 IS) + Ø25.00 (.984DIA) Illuminated (select LED colour above) * AV3•022 ON - MOM 2.80x0.50 (.110x.019) NO NC Non-illuminated AV30022 Terminals 2 Solder / quick-connect F Flying leads C Cable 8.30 (.326) * No LED resistor supplied on this model. Hex nut 25 (.984) across flats Flat actuator - flying lead terminals 2.20 (.086) Illuminated (select LED colour & resistor above) AV3••2F ON - MOM Non-illuminated AV3002F ON - 4.00 (.157) Ø22.00x1.00 SI (.866DIAx1.00 IS) Ø15.00 (.590DIA) Ø25.00 (.984DIA) B2 Contacts 2 Silver MOM 11.60 (.456) 12.10 (.476) 200 (7.874) Ø12.00 (.472DIA) Wire colours : black: NC, orange: NO, red: LED anode (+), blue : LED cathode (-) B2-100 www.apem.com APEM 14bis-Serie AV-2-A_18-Serie AV-A 31/10/14 09:01 Page101 AV series Security pushbutton switches Ø 22 mm (.866) With illuminated ring - momentary changeover (NC/NO) Hex nut 25 (.984) across flats Flat actuator - cable terminals 2.20 (.086) 4.00 (.157) Ø22.00x1.00 SI (.866DIAx1.00 IS) Non-illuminated AV3002C ON - Ø25.00 (.984DIA) Illuminated (select colour & resistor) AV3••2C ON - MOM MOM 12.10 (.476) 11.60 (.456) 200 (7.874) B2 Flying lead protection After selecting basic model No., fill in last 5 boxes with desired options. Flying lead/ cable length Ring colour Bushing / plunger mat. Sealing BASIC MODEL FLYING LEAD PROTECTION No protection and/or no flying leads Heat-shrink sleeves Tube + epoxy 0 1 2 WIRE/CABLE LENGTH No flying leads / no cable Length 20 cm (7.874) - standard Length in centimeters 000 020 XXX RING COLOURS BUSHING/PLUNGER MATERIALS CODE COLOUR CODE BUSHING ACTUATOR 00 40 4A 4B 70 Brass, nickel plated Stainless steel 303 Stainless steel 304 Stainless steel 316 Chrome pl. brass, black Brass, nickel plated Stainless steel 303 Stainless steel 304 Stainless steel 316 Chrome pl. brass, black 1 2 3 4 5 Blue Black * Green Grey * Yellow CODE COLOUR 6 7 8 9 Red Opal white (std) Translucent Orange * non-illuminated only Other : on request. SEALING Blank No sealing 2 1 K Front panel sealing (IP67) APEM ➀ internal membrane ➁ external gasket www.apem.com B2-101 14bis-Serie AV-2-A_18-Serie AV-A 31/10/14 09:01 Page102 AV series Security pushbutton switches Ø 22 mm (.866) Illuminated and non-illuminated - latching ORDER FORMAT AV 1 Actuator type 03 Flat 02 Curved SERIES Bush./act. config. E Illumin. 0 No L Illum. 0 1 3 5 6 LED colour No LED Blue Green Yellow Red A See next page. Function Terminals 2 Solder Contacts 4 PC 8 Quickconnect SPECIFICATIONS MATERIALS • Max. current/voltage rating with resistive load : 2A 48 VDC • LED voltage and consumption : blue 3,5V 10mA, green : 2V 10mA yellow & red : 2V 20mA (a resistor must be series-connected by the user)** • Initial contact resistance : 50 mΩ max. • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 1 000 Vrms 50 Hz min. between terminals 500 Vrms 50 Hz min. between terminals and frame • Electrical life : 500.000 cycles at 2A 48VDC • Torque : 5 Nm min.- 14 Nm max. applied to nut • Panel thickness : 1 (.039) to 9 mm (.354) max. • Operating temperature : -30°C to +70°C • Low level or mechanical life : 1.000.000 cycles • Hand soldering : 300°C, 4 seconds max. • Packaging unit : 20 pieces • Case : PA6T UL94-V0 • Contacts : silver • Actuator and bushing : see next page • LED CUT-OUT • Panel cut-out : Ø 22,2 mm (.874) • Min. pitch for matrix mounting : 30 mm x 30 mm (1.181x1.181) To order a product, select a basic model below and add the desired options selected on next page. ** Resistor value = supply voltage - LED forward voltage LED forward current Standard actuator position : the actuator is flush in the non-latched position and recessed in the latched position. Hex nut 25 (.984) across flats Ø22.00x1.00 SI (.866DIAx1.00 IS) ON Curved actuator AV02100EA2 ON - ON 2.30 (.090) NO 1.40 (.055) - NC Ø15.00 (.590DIA) ON Ø25.00 (.984DIA) Flat actuator * AV03100EA2 3.00 (.118) 2.00 (.078) 3.80 (.149) 0.50 (.019) Non-illuminated - solder lug terminals NC 12.70 (.500) 2.80 (.110) 11.50 (.045) * Also available with prominent actuator in the non-latched position Hex nut 25 (.984) across flats Ø22.00x1.00 SI (.866DIAx1.00 IS) 3.00 (.118) 2.00 (.078) - ON Ø3.20 (.125DIA) NO 1.40 (.055) ON 2.30 (.090) Ø15.00 (.590DIA) Flat actuator AV031L•EA2 NC 0.50 (.019) Illuminated - solder lug terminals Ø25.00 (.984DIA) B2 OPTIONS NC 12.70 (.500) 11.50 (.045) 2.80 (.110) Replace • with desired LED colour. B2-102 www.apem.com APEM 14bis-Serie AV-2-A_18-Serie AV-A 31/10/14 09:01 Page103 AV series Security pushbutton switches Ø 22 mm (.866) Illuminated and non-illuminated - latching Quick-connect terminals 8.00 (.314) 3.40 (.133) Straight PC terminals 1.20 (.047) 2.40 (.094) 1.10 (.043) 2.80 (.110) Replace 2 with 4 at the end of the model numbers shown on previous page. Replace 2 with 8 at the end of the model numbers shown on previous page. B2 After selecting basic model number, fill in last 2 boxes with desired options. Bushing/ act. material Sealing BASIC MODEL BUSHING/ACTUATOR MATERIALS CODE BUSHING ACTUATOR 00 (std) 10 40 50 Nickel plated brass Nickel plated brass Stainless steel Stainless steel Nickel plated brass Stainless steel Stainless steel Nickel plated brass SEALING Blank No sealing 1 K 2 Frontal panel sealing (IP65) APEM ➀ elastomeric membrane ➁ external gasket www.apem.com B2-103 14bis-Serie AV-2-A_18-Serie AV-A 31/10/14 09:01 Page104 AV series Security pushbutton switches Ø 22 mm (.866) or 24 mm (.944) with large actuator Momentary (combined NC+NO) ORDER FORMAT AV SERIES Combined NC+NO L Bushing diameter 22 22 mm 24 24 mm OPTIONS Bush./act. config. P B C Act. style Flat Curved Recessed Bush./actuator material See next page SPECIFICATIONS MATERIALS • Max. current/voltage rating with resistive load : 5A 250VAC • Initial contact resistance : 100 mΩ max. • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 2.000 Vrms 50 Hz min. between terminals and frame • Electrical life : 1.000.000 cycles at 1A 250VAC 100.000 cycles at full load • Torque : 5 Nm min.- 14 Nm max. applied to nut • Panel thickness : 1 (.039) to 6 mm (.236) max. • Operating temperature : -20°C to +55°C • Low level or mechanical life : 3.000.000 cycles • Front panel sealing : IP65 • Hand soldering : 300°C, 5 sec. max. • Packaging unit : 20 pieces (except black chrome plated : 16 pieces) • Case : polyester, glass filled • Contacts : silver/nickel alloy • Bushing and actuator : see next page. CUT-OUT • Panel cut-out : Ø 22,2 mm (.874) or Ø 24,2 mm (.952) • Min. pitch for matrix mounting : 30 mm x 30 mm (1.181x1.181) or 33 mm x 33 mm (1.299x1.299) To order a product, select a basic model below or on next page and add the desired bushing/actuator materials. BASIC MODEL Flat actuator - AV22LP Hex nut 25 (.984) across flats ➞ O-ring 3.60 (.141) 3.00 (.118) Curved actuator - AV22LB Quick-connect terminals AV22LB••4 Solder lug terminals AV22LB••2 B2-104 12.50 (.492) 12.80 (.503) 2.80X0.50 (.110X.019) 1.30 (.051) Ø22.00X1.00 SI (.866DIAX1.00 IS) Solder lug terminals AV22LP••2 0.50 (.019) Quick-connect terminals AV22LP••4 Ø20.00 (.787DIA) 7.10 (.279) 4.00 (.157) Ø26.00 (1.023DIA) B2 Terminals Quickconnect 2 Solder lug 4 2.40 (.250) Recessed actuator - AV22LC Quick-connect terminals AV22LC••4 Solder lug terminals AV22LC••2 www.apem.com APEM 14bis-Serie AV-2-A_18-Serie AV-A 31/10/14 09:01 Page105 AV series Security pushbutton switches Ø 22 mm (.866) or 24 mm (.944) with large actuator Momentary (combined NC+NO) BASIC MODEL Hex nut 27 (1.062) across flats ➞ O-ring Flat actuator - low profile - AV24LP 4.00 (.157) Quick-connect terminals AV24LB••4 Solder lug terminals AV24LB••2 1.30 (.051) 2.80X0.50 (.110X.019) 2.40 (.250) 1.30 (.051) Curved actuator - AV24LB Ø24.00X1.00 SI (.944DIAX1.00 IS) Solder lug terminals AV24LP••2 0.50 (.019) Ø30.00 (1.181DIA) Quick-connect terminals AV24LP••4 Ø20.00 (.787DIA) 7.10 (.279) 3.60 (.141) 14.20 (.559) B2 13.00 (.511) Recessed actuator - AV24LC Quick-connect terminals AV24LC••4 Solder lug terminals AV24LC••2 BUSHING/ACTUATOR MATERIALS Models with non-anodized actuator CODE BUSHING 40 (standard) Stainless steel 20 Chrome plated brass ACTUATOR Stainless steel Chrome plated brass Models with anodized actuator CODE BUSHING ACTUATOR COLOUR 1• 2• 4• Black chrome plated brass Chrome plated brass Stainless steel Replace • with one of the following codes : 1 : blue - 2 : black - 3 : pale green - 3F : dark green - 4 : natural - 5 : gold yellow APEM 6 : red - 6B : maroon www.apem.com B2-105 14bis-Serie AV-2-A_18-Serie AV-A 31/10/14 09:01 Page106 AV series Mushroom head security pushbutton switches Ø 22 mm (.866) Momentary (combined NC+NO) ORDER FORMAT AV 22 SERIES Bushing diameter PNA OPTIONS Bush./act. config. Actuator colour See below Combined NC+NO Terminals Quickconnect 2 Solder lug 4 SPECIFICATIONS • Max. current/voltage rating with resistive load : 5A 250VAC • Initial contact resistance : 100 mΩ max. • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 2.000 Vrms 50 Hz min. between terminals and frame • Electrical life : 1.000.000 cycles at 1A 250VAC 50.000 cycles at full load • Torque : 5 Nm min.- 14 Nm max. applied to nut • Panel thickness : 1 (.039) to 6 mm (.236) max. • Operating temperature : -20°C to +55°C • Low level or mechanical life : 1.000.000 cycles • Front panel sealing : IP65 • Hand soldering : 300°C, 5 sec. max. • Packaging unit : 16 pieces • Case : polyester, glass filled • Contacts : silver/nickel alloy • Bushing : brass, nickel plated • Actuator : aluminium, anodized CUT-OUT • Panel cut-out : Ø 22,2 mm (.874) • Min. pitch for matrix mounting : 30 mm x 30 mm (1.181x1.181) To order a product, select a basic model below and add the desired actuator colour. BASIC MODEL Mushroom head actuator - AV22PNA Hex nut 25 (.984) across flats ➞ O-ring 10.80 (.425) 8.60 (.338) Ø22.00X1.00 SI (.866DIAX1.00 IS) 12.80 (.503) 2.80X0.50 (.110X.019) 1.30 (.051) Solder lug terminals AV22PNA•2 0.50 (.019) Quick-connect terminals AV22PNA•4 3.60 (.141) 7.10 (.279) 4.00 (.157) Ø30.00 (1.181DIA) B2 MATERIALS 2.40 (.250) ACTUATOR ANODIZATION COLOURS 1 : blue - 2 : black - 3 : pale green - 3F : dark green - 4 : natural - 5 : gold yellow - 6 : red - 6B : maroon B2-106 www.apem.com APEM
AV191003C900 价格&库存
很抱歉,暂时无法提供与“AV191003C900”相匹配的价格&库存,您可以联系我们找货
AV191003C900
  • 1+231.53084
  • 10+224.55357
  • 50+217.58672
  • 100+212.95256
  • 250+208.34964
库存:317
AV191003C900
    • 1+133.81200
    • 200+53.39520
    • 500+51.61320
    AV191003C900
    • 1+155.370081+20.11400
    • 10+137.4763410+17.79750
    • 20+131.4535720+17.01780
    • 40+125.5180840+16.24940
    • 60+119.4953160+15.46970
    • 100+113.55982100+14.70130
    • 200+107.53705200+13.92160
    • 260+95.57879260+12.37350
    库存:451
    AV191003C900
    • 1+103.02110
    • 10+88.30390
    • 30+77.26580
    • 100+65.06600
    • 500+61.81270
    库存:1
