AW87519FCR
AW87519FCR
    AWINIC(艾为)
    FCQFN-20(2x3)
AW87519FCR 数据手册
AW87519 May 2019 V1.1 8.5V High Efficiency High PSRR Low Noise Large Volume 2-in-1 TLTR-AGC 3rd Generation Smart K Audio Amplifier DESCRIPTION  Triple-Level Triple-Rate AGC algorithm to effectively eliminate noise, pure sound quality  High efficiency large drive ability BOOST  Highest voltage:8.5V  Overall efficiency up to 80%  Output Power:4.3W@8Ω,5.3W@6Ω  High PSRR:-82dB(217Hz)  Low noise:  18 μV (Class D Receiver THD+N=0.03%)  43 μV (Class K Speaker THD+N=0.04%)  Selectable speaker-guard power level: 0.5W~2W@8ohm, 100mW/step  Speaker & receiver 2-in-1 mode application  Battery tracking AGC selectable, for low voltage protection  Shutdown current:0.1μA  Super TDD-Noise suppression  Excellent pop-click suppression  Support 1.8V logic I2C control  FCQFN 2.0mmX3.0mmX0.55mm-20L package AW87519 is specifically designed to improve the musical output dynamic range, enhance the overall sound quality. It is a new high efficiency, high PSRR,low noise, constant large volume, 3rd generation Smart K audio amplifier. AW87519 integrates AWINIC’s proprietary Triple-Level Triple-Rate AGC audio algorithm, effectively eliminating music noise and improving sound quality and volume. AW87519 integrates high voltage synchronous Boost with efficiency up to 88% as the class D power stage supply, significantly improving the dynamic range of music. AW87519 noise floor is as low as to 43μV at speaker mode, with 103dB high signal-to-noise-ratio (SNR). The ultra-low distortion 0.04% and unique Triple-Level Triple-Rate AGC technology bring high quality music enjoyment. e n ti a l FEATURES fi d AW87519 supports speaker and receiver 2-in-1 application. In the receiver mode, its ultra-low noise is 18μV. Class D receiver also has high PSRR performance to completely suppress TDD-noise. AW87519 controls internal registers through the I 2C interface. Register parameters include boost output voltage, boost maximum input peak current, PA gain, Triple-Level Triple-Rate AGC parameters, etc. APPLICATIONS C o n  Smart phone、Tablet PC AW87519 built-in over current protection, over temperature protection and short circuit protection function, effectively protect the chip. AW87519 features small FCQFN 2.0mmX3.0mmX0.55mm-20L package. TYPICAL APPLICATION CIRCUIT VBAT 4 GPIO I2C Interface 9 { 10 5 I2C Address Select 18 SW VREG RSTN SDA VBST 17 C9 22nF 6.3V 19 SCL C5 10 μF 25V AD C6 22 μF 25V See in detail“Boost capacitor selection” Cin68nF Ground Shielding Pseudo-Differential routing MUX Receiver BB C3 0.1uF VDD 8 Speaker Audio DAC See in detail“Boost inductor selection” C2 10uF 3 HPH_L/R a w in ic L 1uH 3.5A(8Ω) / 4A(6Ω) C1 0.1uF Cin+ 68nF 7 AW87519 INN VOP INP VON HPH_REF See in detail“PCB Layout” GND 6,11~15 Figure 1 BGND 16 20 2 B+ See in detail“Bead、Cap、TVS” C7 0.1nF 16V 16V C8 0.1nF 16V 16V SPK B- PGND 1 AW87519 Single-ended Input Mode Application Diagram All trademarks are the property of their respective owners. www.awinic.com.cn COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 1 AW87519 May 2019 V1.1 n fi d e n ti a l PIN CONFIGURATION AND TOP MARK Symbol 1 2 PGND in 3 Description Class D power ground VON Negative audio output terminal VDD Power supply Reset pin, active low reset, the internal 2MΩ pull-down resistor in chip 4 RSTN 5 AD 6 GND Ground 7 INP Positive audio input terminal 8 INN Negative audio input terminal 9 SDA I2C-bus data input/output 10 SCL I2C-bus clock input 11 GND Ground 12~15 TEST1~TEST4 w a C Number ic PIN DESCRIPTION AW87519FCR Pin configuration and Top Mark o Figure 2 www.awinic.com.cn I2C address pin TEST pins,connect to GND in application COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 2 AW87519 May 2019 V1.1 16 BGND Boost power ground 17 VREG Charge pump output pin 18 SW Boost switch pin 19 VBST Boost output pin 20 VOP Positive audio output terminal SW VDD AD CHARGE PUMP n OVP BOOST 2 IC SYSCTRL AD BAT SAFEGUARD AGC INP PEAK CURRENT LIMIT LOW-BAT DETECT INPUT BUFFER OCP ULTRA-LOW EMI OUTPUT STAGE VOP VON o C ic PVDD VOLTAGE SENSING GND BGND PGND AW87519 Functional Diagram a w in Figure 3 OSC CLASS K MODULATOR INN TRIPLE-LEVEL TRIPLE-RATE AGC e SDA BIAS&OT VREG fi d SCL RSTN n RSTN ti a l FUNCTIONAL DIAGRAM www.awinic.com.cn COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 3 AW87519 May 2019 V1.1 TYPICAL APPLICATION CIRCUIT VBAT L 1uH 3.5A(8Ω) / 4A(6Ω) C1 0.1uF See in detail“Boost inductor selection” C2 10uF 3 C3 0.1uF 18 I2C Interface 9 { 5 I C Address Select VREG SDA 10 2 SW RSTN VBST 17 C9 22nF 6.3V 19 SCL C5 10 μF 25V AD l 4 GPIO C6 22 μF 25V ti a VDD See in detail“Boost capacitor selection” Cin68nF HPH_L/R 8 Speaker Ground Shielding Pseudo-Differential routing MUX Receiver BB Cin+ 68nF 7 VOP INP 20 VON HPH_REF See in detail“PCB Layout” GND C7 0.1nF 16V 16V C8 0.1nF 16V 16V B- 2 SPK PGND 1 e 6,11~15 BGND 16 See in detail“Bead、Cap、TVS” n Audio DAC AW87519 INN B+ fi d AW87519 Single-ended Input Mode Application Diagram(Note 1) Figure 4 Note1:When single-ended input, audio signal line from audio DAC (HPH_L or HPH_R) can arbitrarily connected to either of INN or INP input terminal. The other terminal must be connected to reference ground (HPH_REF) through input capacitor and resistor. n VBAT L 1uH 3.5A(8Ω) / 4A(6Ω) C1 0.1uF o C2 10uF 3 C3 0.1uF VDD C GPIO 4 I2C Interface 9 { 10 5 2 ic I C Address Select HPH_L/R in Receiver BB SW VREG RSTN SDA VBST C9 22nF 6.3V 19 SCL C5 10 μF 25V AD 8 Cin+ 68nF 7 AW87519 INN VOP INP VON HPH_REF Figure 5 17 C6 22 μF 25V See in detail“PCB Layout” GND 6,11~15 BGND 16 20 2 B+ See in detail“Bead、Cap、TVS” C7 0.1nF 16V 16V C8 0.1nF 16V 16V SPK/ RCV B- PGND 1 AW87519 Speaker & Receiver 2-in-1 Mode Application Diagram a w Ground Shielding Pseudo-Differential routing MUX 18 See in detail“Boost capacitor selection” Cin68nF Speaker Audio DAC See in detail“Boost inductor selection” www.awinic.com.cn COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 4 AW87519 May 2019 V1.1 ORDERING INFORMATION Temperature Package Marking Moisture Sensitivity Level Environmental Information Delivery Form AW87519FCR -40°C~85°C FCQFN 2.0mmX3.0mm-20L E2Y6 MSL1 ROHS+HF 6000 units/ Tape and Reel ti a l Part Number ABSOLUTE MAXIMUM RATING (Note2) Range Supply Voltage VDD -0.3V to 6V INN,INP -0.3V to VDD+0.3V Boost output voltage PVDD -0.3V to 12V e n Parameter SW -0.3V to PVDD+2V -0.3V to PVDD+0.3V Minimum load resistance RL Package Thermal Resistance θJA Ambient Temperature Range fi d VOP,VON 5Ω 57.9°C/W -40°C to 85°C 165°C Storage Temperature Range TSTG -65°C to 150°C o n Maximum Junction Temperature TJMAX Lead Temperature(Soldering 10 Seconds) 260°C C ESD Rating (Note 3) ±2kV CDM(charged-device model) ±1.5kV ic HBM(human body model) Latch-up +IT:450mA -IT:-450mA in Test Condition:JEDEC STANDARD NO.78E w NOTE2: Conditions out of those ranges listed in "absolute maximum ratings" may cause permanent damages to the device. In spite of the limits above, functional operation conditions of the device should within the ranges listed in "recommended operating conditions". Exposure to absolute-maximum-rated conditions for prolonged periods may affect device reliability. NOTE3: The human body model is a 100pF capacitor discharged through a 1.5kΩ resistor into each pin. Test method: ESDA/JEDEC JS-001-2017 a Test method of the charge device model: ESDA/JEDEC JS-002-2014 www.awinic.com.cn COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 5 AW87519 May 2019 V1.1 ELECTRICAL CHARACTERISTICS Parameter UVLO Test conditions Power supply voltage Min 2.8 Under-voltage protection voltage 2.5 Under-voltage protection hysteresis voltage 100 RSTN, SCL, SDA, AD high-level input voltage 1.3 VIL RSTN, SCL, SDA, AD low-level input voltage 0 ISD Shutdown current TTG Thermal AGC start temperature threshold TTGR Thermal AGC exit temperature threshold TSD Over temperature protection threshold TSDR Over temperature protection recovery threshold TON Turn-On time TST V mV 0.1 VDD V 0.45 V 1 μA 160 °C 130 °C 45 ms VDD=2.8V to 5.5V 8.5 (Note4) V VDD=2.8V to 5.5V VBST+0.5 V VDD=2.8V to 5.5V 500 mV 3.5 (Note4) A 1.6 MHz Soft-start Switching frequency 0.4 MHz The maximum duty cycle 90 % o n fi d ℃ OVP voltage OVP hysteresis voltage C BOOST Output voltage Inductor peak current limit VDD=2.8V to 5.5V Soft-start time No load,COUT=22μF 2 ms Boost efficiency VDD=4.2V, Iload=200mA 88 % w ηCP V 130 in DMAX 5.5 ℃ Boost operating frequency FBST Units 150 ic IL_PEAK Max e VDD=3.6V, RSTN=0V BOOST OVP n VIH VBST Typ ti a VDD RL=8Ω+33μH, f=1kHz(unless otherwise noted) l Test condition:TA=25°C, VDD=4.2V, PVDD=8.5V, CLASS K MODE Output offset voltage No input ηT total efficiency (BOOST+CLASS D) VDD=4.2V, Po=2.5W, RL=8Ω+33μH IQK Speaker Quiescent current VDD=4.2V, input ac grounded, RL=8Ω+33μH a VOS www.awinic.com.cn -30 0 30 80 % 16.5 mA COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 6 mV AW87519 May 2019 V1.1 Test conditions Min Rdson Drain-Source on-state resistance High side MOS + Low side MOS Vinp Recommended input signal amplitude VDD=2.8V to 5.5V Fosc Modulation frequency VDD=2.8V to 5.5V 600 Pagc TLTR AGC power RL=8Ω+33μH 0.72 EN Speaker Output noise Av=18dB Fin W 1.17 W 1kHz -80 dB 103 dB dB 94 53 μV 43 24 (Note4) Speaker Inner input resistance Av=24dB Speaker Inner input resistance Av=18dB Speaker input Cut-off frequency Cin=68nF, Av=24dB Speaker input Cut-off frequency Cin=68nF, Av=18dB 130 VDD=4.2V, Po=0.6W, RL=8Ω+33μH, f=1kHz 0.04 % THD+N=1%, RL=8Ω+33μH, VDD=4.2V, PVDD=8.5V, IL_PEAK=4A 4.3 W THD+N=10%, RL=8Ω+33μH, VDD=4.2V, PVDD=8.5V, IL_PEAK=4A 5.2 W THD+N=1%, RL=6Ω+33μH, VDD=4.2V, PVDD=8.5V, IL_PEAK=4A 5.3 W THD+N=10%,RL=6Ω+33μH, VDD=4.2V, PVDD=8.5V, IL_PEAK=4A 6.3 W VDD=4.2V, input ac grounded, RL=8Ω+33μH 6.8 mA Total harmonic distortion + noise in Speaker Output Power a n VDD=2.8V to 5.5V w Po 0.88 Speaker gain ic THD+N kHz dB o Rini 1.067 1000 -78 C Av (Note4) Vp 217Hz 20Hz to 20kHz, input ac grounded, A-weighting Av=24dB 0.8 (Note4) 1 ti a Signal-to-noise ratio VDD=4.2V, Po=4.3W, Av=18dB ,RL=8Ω+33μH, VDD=4.2V, Po=0.8W, Av=18dB,RL=8Ω+33μH, mΩ n VDD=4.2V, Vpp_sin=200 mV Units e SNR 0.96 Power supply rejection ratio Max 250 fi d PSRR RL=6Ω+33μH Typ l Parameter dB 9 kΩ 18 260 Hz 2-in-1 Receiver MODE IQD D Receiver quiescent current(overall) www.awinic.com.cn COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 7 AW87519 May 2019 V1.1 Parameter Test conditions ηD CLASS D Receiver efficiency VDD=4.2V,Po=0.8W, RL=8Ω+33μH Av gain VDD=2.8V to 5.5V Rini CLASS D Receiver Inner input resistance Fin CLASS D Receiver input cut-off frequency EN CLASS D Receiver output noise Av=9dB 24 kΩ Cin=68nF, Av=9dB 98 Hz CLASS D Receiver Power supply rejection ratio VDD=4.2V, Vp-p_sin=200 mV Po CLASS D Receiver Output Power THD+N=1%, RL=8Ω+33μH, VDD=4.2V, GAIN=7.5~9dB THD+N=1%, RL=8Ω+33μH, VDD=4.2V, GAIN=10.5dB fi d 1kHz n o AGC1 Attack Time TAT2 AGC2 Attack Time TAT3 AGC3 Attack Time TRLT Release time AMAX The maximum attenuation gain ic C TAT1 VDD=2.8V to 5.5V μV 21 μV 0.03 % -82 dB e 217Hz Battery Tracking AGC Triple-Level Triple-Rate AGC ti a Av=9dB 18 n 20Hz to 20kHz, input ac grounded, A-weighting Av=7.5dB l dB PSRR Battery protection Hysteresis voltage Units 7.5 (Note4) VDD=4.2V, Po=0.1W,RL=8Ω+33μH, f=1kHz, CLASS D Receiver VHYS Max % Total harmonic distortion + noise Battery protection threshold voltage Typ 90 THD+N VBSGD Min -80 dB 0.5 W 0.85 W 3.4 (Note4) V 100 mV 0.08 (Note4) ms/dB 0.64 (Note4) ms/dB 41 (Note4) ms/dB 21 (Note4) ms/dB -13.5 dB a w in Note 4:Registers are adjustable; Refer to the list of registers. www.awinic.com.cn COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 8 AW87519 May 2019 V1.1 MEASUREMENT SETUP AW87519 features switching digital output, as shown in Figure 6. Need to connect a low pass filter to VOP/VON output respectively to filter out switch modulation frequency, then measure the differential output of filter to obtain analog output signal. 10nF l 500Ω 30kHz Low-Pass Fliter AW87519 VON INN 500Ω Cin AW87519 Test Setup Low pass filter uses resistance and capacitor values listed in Table 1. 500Ω 10nF 1kΩ 4.7nF 32kHz 34kHz AW87519 Recommended Values for Low Pass Filter o Table 1 Low-pass cutoff frequency fi d Cfilter n Rfilter e Figure 6 n 10nF ti a VOP INP Cin Output Power Calculation C According to the above test methods, the differential analog output signal is obtained at the output of the low pass filter. The valid values Vo_rms of the differential signal , as shown in Figure 7: w in ic Vo_rms Figure 7 Output RMS Value a The power calculation of Speaker is as follows: www.awinic.com.cn PL  (VO_rms )2 RL RL: load impedance of the speaker COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 9 AW87519 May 2019 V1.1 TYPICAL CHARACTERISTICS Class K Efficiency vs Po Class K Efficiency vs Po 90 90 80 80 70 70 40 30 l 50 60 50 40 30 VDD = 4.2V PVDD = 8.5V RL = 8 ohm + 33uH 20 10 VDD = 4.2V PVDD = 8.5V RL = 6 ohm + 33uH 20 10 0 0 0 1 2 3 4 5 0 1 Output Power (W) 4 5 6 7 1.2 1.4 6 7 Class D Efficiency vs Po 100 fi d 90 90 80 80 60 n 60 Efficiency (%) 70 70 50 o 40 VDD = 4.2V Gain = 10.5dB RL = 8 ohm + 33uH 20 10 0 0 0.2 0.4 0.6 0.8 1 50 40 30 VDD = 4.2V Gain = 10.5dB RL = 6 ohm + 33uH 20 C 30 10 0 0 1.2 0.2 0.4 1 ic 2.5 in VDD = 4.2V PVDD = 8.5V RL = 8 ohm + 33uH VDD = 4.2V PVDD = 8.5V RL = 6 ohm + 33uH 2 w I_VDD_supply (A) 1.2 0.8 Class K I_VDD_supply VS Po I_VDD_supply VS Po 1.5 0.6 Output Power (W) Output Power (W) I_VDD_supply (A) 3 e Class D Efficiency vs Po Efficiency (%) 2 Output Power (W) 100 a ti a 60 n Efficiency (%) 100 Efficiency (%) 100 0.9 0.6 0.3 1.5 1 0.5 0 0 0 1 2 3 4 5 0 Output Power (W) www.awinic.com.cn 1 2 3 4 5 Output Power (W) COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 10 AW87519 May 2019 V1.1 Class D Gain vs frequency Class K Gain vs frequency 40 25 VDD = 4.2V PVDD = 8.5V Cin = 1uF RL = 8 ohm + 33uH 35 30 20 Gain = 24dB Gain = 18dB 15 25 15 0 10 -5 5 -10 20 100 1K -15 20 10K 100 Frequency (Hz) Class K PSRR vs frequency -20 -30 VDD = 5.5V VDD = 4.2V VDD = 3.6V -40 -40 -60 o -70 -100 100 1K e -60 -70 -80 -90 C -80 VDD = 5.5V VDD = 4.2V VDD = 3.6V -50 n -50 -90 Cin = 1uF RL = 8 ohm + 33uH fi d PSRR (dB) -10 PVDD = 8.5V Cin = 1uF RL = 8 ohm + 33uH -30 -100 100 10K 1K ic Frequency (Hz) VDD = 4.5V VDD = 4.2V VDD = 3.6V 0.1 0.1 0.001 100 1K 20 10K 100 1K 10K Frequency (Hz) Frequency (Hz) www.awinic.com.cn VDD = 4.5V VDD = 4.2V VDD = 3.6V 0.01 0.01 0.001 20 VDD = 4.2V PVDD = 8.5V Po = 1W RL = 6 ohm + 33uH 1 w THD+N (%) 1 Class K THD+N vs frequency 10 THD+N (%) in VDD = 4.2V PVDD = 8.5V Po = 1W RL = 8 ohm + 33uH 10K Frequency (Hz) Class K THD+N vs frequency 10 10K Class D PSRR vs frequency 0 PSRR (dB) -20 1K Frequency (Hz) 0 -10 ti a l 5 n 20 0 a Gain = 9dB 10 Gain (dB) Gain (dB) VDD = 4.2V Cin = 1uF RL = 8 ohm + 33uH COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 11 AW87519 May 2019 V1.1 Class D THD+N vs frequency Class D THD+N vs frequency 10 10 Receive mode VDD = 4.2V RL = 8 ohm + 33uH Receive mode VDD = 4.2V RL = 6 ohm + 33uH 1 0.01 0.1 l 0.1 Po = 10mW Po = 100mW ti a Po = 10mW Po = 100mW THD+N (%) 0.01 0.001 20 0.001 100 1K 10K 20 100 1K Frequency (Hz) Frequency (Hz) Class K THD+N vs Po 10 1 VDD = 4.2V VDD = 3.6V n THD+N (%) VDD = 4.2V VDD = 3.6V 1 PVDD = 8.5V Fin=1kHz RL = 6 ohm + 33uH Gain=24dB fi d PVDD = 8.5V Fin=1kHz RL = 8 ohm + 33uH Gain=24dB 0.1 o THD+N (%) 100 e Class K THD+N vs Po 100 10 0.001 0.1 0.5 1 2 4 0.1 0.01 C 0.01 0.001 0.1 6 8 0.5 Output Power (W) ic 10 a 6 8 Fin=1kHz RL = 6 ohm + 33uH Gain = 10.5dB THD+N (%) VDD = 4.2V VDD = 3.6V 1 w THD+N (%) VDD = 4.2V VDD = 3.6V 0.1 1 0.1 0.01 0.01 0.2 0.3 0.5 0.7 0.001 0.1 1 1.2 0.2 0.3 0.5 0.7 1 1.2 Output Power (W) Output Power (W) www.awinic.com.cn 4 Class D THD+N vs Po Fin=1kHz RL = 8 ohm + 33uH Gain = 10.5dB 0.001 0.1 2 100 in 10 1 Output Power (W) Class D THD+N vs Po 100 10K n THD+N (%) 1 COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 12 AW87519 May 2019 V1.1 Shutdown sequence ti a l Start-up sequence 50us/div e n 10ms/div Triple-Level Triple Rate AGC Release Timing C o n fi d Triple-Level Triple Rate AGC Attack Timing 200ms/div in ic Po vs Vin 1 w Output Power (W) 2 0.941 0.862 0.6 0.769 0.5 0.20 0.4 a 100ms/div 0.3 0.659 0.184 AGC_TH = 1.2W AGC_TH = 1.0W 0.164 AGC_TH = 0.8W AGC_TH = 0.6W 0.141 0.2 0.1 0.2 0.3 0.4 0.5 0.6 1 Input Level (Vrms) www.awinic.com.cn COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 13 AW87519 May 2019 V1.1 WORKING PRINCIPLE ti a l AW87519 is specifically designed to improve the musical output dynamic range, enhance the overall sound quality. It is a new high efficiency, high PSRR,low noise, constant large volume, 3rd generation Smart K audio amplifier. AW87519 integrates AWINIC’s proprietary Triple-Level Triple-Rate AGC audio algorithm, effectively eliminating music noise and improving sound quality and volume. AW87519 integrates high voltage synchronous Boost with efficiency up to 88% as the class D power stage supply, significantly improving the dynamic range of music. AW87519 noise floor is as low as to 43μV at speaker mode, with 103dB high signal-to-noise-ratio (SNR). The ultra-low distortion 0.04% and unique Triple-Level Triple-Rate AGC technology bring high quality music enjoyment. AW87519 supports speaker and receiver 2-in-1 application. In the receiver mode, its ultra-low noise is 18μV. Class D receiver also has high PSRR performance to completely suppress TDD-noise. n AW87519 controls internal registers through the I2C interface. Register parameters include boost output voltage, boost maximum input peak current, PA gain, Triple-Level Triple-Rate AGC parameters, etc. e AW87519 built-in over current protection, over temperature protection and short circuit protection function, effectively protect the chip. AW87519 features small FCQFN 2.0mmX3.0mmX0.55mm-20L package. CONSTANT OUTPUT POWER o n fi d In the mobile phone audio applications, the AGC function to promote music volume and quality is very attractive, but as the lithium battery voltage drops, general power amplifier output power will reduce gradually. So, it is hard to provide high quality music within the battery voltage range. AW87519 uses unique Triple-Level Triple-Rate technology, within lithium battery voltage range (3.3V~4.35V), to guarantee that output power is constant, and the output power will not drop along with the decrease of lithium battery voltage. In the process of using the phone, even if the battery voltage drops, AW87519 can still provide high quality large volume music enjoyment. The output power of AW87519 can be configured from 0.5W to 2W via I2C, matching general speakers. Unique Triple-Level Triple-Rate AGC technology can bring high-quality music enjoyment. C Triple-Level Triple-Rate AGC technology a w in ic AWINIC proprietary Triple-Level Triple-Rate AGC technology is designed for the protection of the high voltage power amplifier, which is divided into AGC1, AGC2 and AGC3 power levels, to obtain a large volume while maintaining excellent sound quality. In practical applications, speaker can continuously work long hours at rated power, and also can work short-term at high power. For example, in the standard reliability of the loudspeaker experiment, the powder of peak power reached around four times of the rated power. For achieving larger volume and better sound quality, speakers need to work at high power for short periods of time, in order to improve the performance of the speaker. AW87519 Triple-Level Triple-Rate AGC technology can fit the speaker better and perform better overall performance. AGC1 prevents output signal clipping by detecting output voltage in a very short time after clipping, which can effectively restrain the noise clipping; AGC2 can improve the dynamic range of the music in a relatively short period of time; AGC3 can make the speaker work under rated power, which can effectively improve the volume and protect the speaker. Triple-Level Triple-Rate AGC can obtain more excellent overall performance. Triple-Level Triple-Rate AGC detects the peak output voltage of the power amplifier, when the output peak voltage is higher than the compression threshold voltage, the amplifier gain decreases in 0.5dB step. When the output peak voltage is lower than the release threshold voltage, the amplifier gain is recovery to the initial gain in 0.5dB step. The detailed process can be described as follows: www.awinic.com.cn COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 14 AW87519 May 2019 V1.1 Vin AGC1 Compression threshold voltage Vth_at1 Vth_at2 Vth_at3 Vth_rt B C D E F G H e A AGC1 compression AGC2 compression Figure 8 fi d Gain n Vout ti a The release threshold voltage l AGC2 Compression threshold voltage AGC3 Compression threshold voltage AGC3 compression hold release Triple-Level Triple-Rate AGC Operation Principle n A: Small input signal, the output voltage is lower than threshold voltage Vth of AGC, AGC don't work. a w in ic C o B: Input voltage becomes large. It leads to the output voltage clipping, AGC1 starts fast compression, the attack time is set through the I2C register 0x0Ah [2:1], when the output voltage is higher than Vth_at1, and gain register began to decrease. Gain decreases when the output signal passes through the zero. It eliminates the clipping noise as soon as possible. C: When the output voltage is not clipping and higher than threshold voltage Vth_at2, AGC2 starts work, the attack time is set through the I2C register 0x09h [4:2], gain register begins to decrease at a certain rate. Gain register began to decrease. Gain decreases when the output signal passes through the zero. The output voltage gradually decreases to below the AGC2 attack threshold voltage Vth_at2, which can protect the speaker and enhance the sound. D: When the output voltage is lower than the AGC2 attack threshold voltage Vth_at2 and higher than the AGC3 attack threshold voltage Vth_at3, AGC3 starts work, the attack time is set through the I2C register 0x07h [4:2], and gain register began to decrease at a certain rate. Gain decreases when the output signal passes through the zero, so the output voltage gradually decreases to below of the AGC3 attack threshold voltage Vth_at3, matching the speaker to achieve greater volume and better sound quality. E: Triple-Level Triple-Rate AGC attack time ends, Amplifier output power is close to the speaker rated power. F: Input voltage decreases, the output voltage becomes lower than the release threshold voltage Vth_rt, at this point, gain remains the same in the maintain time (10ms~20ms). G: Gain increases when the time of output voltage lower than the release threshold voltage Vth_rt is longer than the holding time. The release time can be set through I2C register 0x07h [7:5]. H: Stop release when the output signal is larger than the release threshold or the gain is equal to the initial value. The output voltage remains constant. Triple-Level Triple-Rate AGC can switch independently according to different application requirements. Such as close AGC1 and AGC2, retain only AGC3, this is the single-AGC mode, similar to AW8736 (AGC3 attack time is set to 1.28ms/dB; release time is set to 41ms/dB); Close AGC2, open AGC1 and AGC3, this is www.awinic.com.cn COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 15 AW87519 May 2019 V1.1 Multi_level AGC. It can be set similar to AW8738 (AGC1 attack time is set to 80us/dB; AGC3 attack time is set to 0.64ms/dB; release time is set to 10.24ms/dB). Zero-Crossing Adjustment Technology zero-crossing adjustment Figure 9 fi d e n ti a no zero-crossing adjustment l Traditional AGC doesn’t contain zero adjustment technology; AGC gain changes generally at the peak, the gain variation at the peak would generate a certain transient distortion, such distortions are audibly imperceptible. Such as individual songs have a slight click. Zero-adjust Comparison o n As shown above, when there is no zero-adjustment technology, it can be seen the obvious step change at the peak of large signal, the steps sound slightly perceived in special audio. Gain changes at zero. The steps disappear by using zero-crossing detection technology. Using zero detection technology can make the music pure and natural. C Low-voltage protection AGC technology a w in ic Mobile phone battery voltage will decrease in use, but the current will increase. When the battery voltage is low, high current maybe cause the battery protection or mobile phone automatically shut down. Awinic proprietary low voltage protection AGC technology can solve the problems, to prevent high current when the battery voltage is too low. AW87519 is built-in low voltage protection AGC technology to real-time detection the battery voltage. Gain decreases rapidly when the battery voltage is below the safety threshold, so as to decrease the output voltage and the power supply current, which effectively prevents high current. www.awinic.com.cn COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 16 AW87519 May 2019 V1.1 Maximum output amplitude(Vp) Low-voltage protection Unprotected(V) Protection limit(V) ti a l Lower limit protection(V) The battery voltage(V) Low voltage protection n Figure 10 e The protection safety threshold voltage is set to 3.3V~3.6V through the I2C register 0x02h [4:3]. The maximum protection output voltage is set to 5Vp ~ 6.5Vp through I2C register 0x02h [1:0]. Only when the register 0x02h [2] is set to 1, low voltage protection AGC technology is enabled. fi d Synchronous Boost technology o n AW87519 integrated peak current mode synchronous PWM Boost as Class D power stage supply, significantly increase the output voltage dynamic range. Reduces the size of external components and saves PCB space by using 1.6MHz switching frequency. Boost output voltage can be set through the I2C register 0x03h [4:0]; Boost current limit can be set through register 0x04h [4:2]. AW87519 synchronous Boost with soft-start function to prevent overshoot current at powering-on; integrated the output protection circuit and self-recovery function; integrated Anti-Ring circuit to reduce EMI in DCM mode; built-in substrate switching shutdown circuit, effectively preventing the input and output leakage current anti-irrigation. C Speaker & Receiver 2-in-1 application w in ic AW87519 built-in speaker and receiver 2-in-1 application mode, through the register settings, class D-type 2-in-1 receiver mode gain can be adjusted through the I2C register 0x05, adjustable range of 7.5~10.5dB, the application is very flexible. The 2-in-1 receiver mode uses the signal path of the speaker, with ultra-low distortion and strong drive capability, and eliminates the need for additional peripheral components, saving system cost and PCB layout space. In the typical application case of Figure 5, the input capacitance Cin = 68nF, the gain is 24dB in the speaker application mode, the input high-pass cutoff frequency is 260Hz; In 7.5dB gain class D-type 2-in-1 receiver application mode, the output noise is 18μV, the input high-pass cut-off frequency is 78Hz, which is very suitable for high-definition voice applications. AW87519 can achieve speaker and receiver's 2-in-1 application without changing any hardware in the case. RNS(RF TDD Noise Suppression) TDD Noise Causes a GSM cell phones use TDMA (Time Division Multiple Access) slot sharing technology. The time is divided into periodic frames in TDMA, and each frame is subdivided into a plurality of time slots. In order to transmit signals to the base station, the signals sent from the base stations to the plurality of mobile terminals are arranged in a predetermined time slot in the transmission. In this case, each TDMA frame contains 8 time slots, the entire frame is about 4.615ms long, and each slot time is 0.577ms. With GSM handset, the RF power amplifier will transmit once every 4.615ms (217Hz), and the signal will produce intermittent Burst current and strong electromagnetic radiation. Intermittent Burst current will form a www.awinic.com.cn COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 17 AW87519 May 2019 V1.1 power fluctuation of 217 Hz; High frequency (900MHz and 1800MHz) RF signals form a 217Hz RF envelope signal. 217Hz power fluctuations will be conducted through the conduction to the audio signal path, 217Hz RF envelope signal will be coupled through the radiation into the audio signal path, if the protection is not good, it will produce an audible TDD Noise, which includes the 217Hz noise And a harmonic noise signal of 217 Hz. ti a l VBAT Voltage 4.615ms Figure 11 e n RF Signal Schematic Diagram of Power Supply Voltage and RF Signal during GSM RF Operation fi d RNS fully inhibit the conduction and radiation interference by the AWINIC unique circuit architecture. Effectively improve the ability to suppress TDD Noise. Conduction noise suppression o n When the RF power amplifier is operating, it will draw the current from the battery by 217Hz frequency, Power supply will be introduced to 217Hz power ripple since the battery has a certain internal resistance, it will be coupled to the speaker through the audio power amplifier. The ability to suppress power fluctuations depends on the PSRR of the audio power amplifier. vout ac ) vdd ac C PSRR  20 log( a w in ic Due to the input and output of the fully differential amplifier is perfectly symmetrical, theoretically, the effect of the power supply fluctuation on the two outputs is exactly the same, and the differential output is completely unaffected by the power supply fluctuation. In practice, due to process bias and other factors, the amplifier will have a certain mismatch, PSRR is generally better than -60dB, it shows the output relative to the power fluctuations can be reduced by 1000 times, such as 500mVp power fluctuations, the differential output of 0.5 MV, which basically can meet the application requirements. But in practical applications, the power amplifier may encounter conduction of TDD Noise problem even if its PSRR is -60dB or -80dB, why is this? Because we also need to consider the impact of peripheral power mismatches of audio power amplifiers For conventional audio power amplifiers, when the input resistor Rin and the input capacitor Cin mismatch, will greatly affect the audio power amplifier PSRR indicators, in the case of 24 times the gain, PSRR will be weakened to -46dB or so if the input resistance and Capacitor with 1% mismatch. PSRR will be weakened to -28dB or so if the input resistance and input capacitance mismatch with 10% mismatch, when the power fluctuations, it is easy to produce audible TDD Noise. In order to enhance the audio power amplifier PSRR in the input resistance and input capacitance mismatch case, AW87519 features a unique conduction noise suppression circuit, making the power amplifier to maintain a high PSRR value even in the input resistance, the input capacitance deviation of 10% or more, this greatly inhibits the generation of conducted noise. www.awinic.com.cn COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 18 AW87519 May 2019 V1.1 Radiation noise suppression VDD INN AW87519VON fi d VOP Rin n Cin INP e n ti a l Input traces, output traces, horn loops, and even power and ground loops are likely to be subject to RF radiation interference in the audio signal module, longer input traces and output traces similar to the antenna, especially vulnerable RF radiation effects. The reasonable PCB layout can reduce the influence of RF radiation in the design, such as shorten the line length of input and output as much as possible; audio devices should be shielded and far away from the RF antenna, maintain the integrity of the device to audio signal pathway; to increase the small bypass capacitor RF signals in the sensitive nodes. However, in practical applications, PCB layout is difficult to fully consider the influence of RF radiation on the audio signal path, and some RF energy will still be coupled to the audio signal path to form audible TDD Noise. Therefore, AW87519 features a unique RF radiation suppression circuit, a shielding layer inside the chip, effectively prevent high frequency energy into RF chip, to ensure that the drive single of the amplifier provided to the speaker will not be affected by the antenna RF radiation, thus avoiding the antenna RF Radiation caused by TDD Noise. C o GND Figure 12 RF Radiation Coupling Graph Class D amplifier without filter w in ic When the traditional class D amplifier is in idle state of no input signal, the output will have the inverse square wave, it will directly above the load of the speaker, will form a large current power switch on the speaker, therefore we need to increase the LC filter to restore the analog audio signal at the amplifier output. The LC filter increase the cost and PCB layout area, while increase the power consumption, reduce the performance of THD+N. The AW87519 features a Class D amplifier without a filter, eliminating the need for an output LC filter. In the idle state of no input signal, the two outputs (VOP, VON) of the amplifier are in-phase square waves and not generate idle switching currents on the speaker load. When the input signal is added to the input terminal, the duty ratio of the output is changed. The duty cycle of the VOP becomes larger and the duty cycle of the VON becomes smaller, and the difference value of the output forms the differential amplified signal on the speaker. a EEE The AW87519 features a unique Enhanced Emission Elimination (EEE) technology, that controls fast transition on the output, greatly reduces EMI over the full bandwidth, fully meet FCC CLASS B specification requirements. www.awinic.com.cn COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 19 AW87519 May 2019 V1.1 Pop-Click Suppression The AW87519 features unique timing control circuit, that comprehensively suppresses pop-click noise, eliminates audible transients on shutdown, wakeup, and power-up/down. Thermal AGC/ over temperature protection e Automatic recovery of overcurrent protection n ti a l The AW87519 features the thermal AGC patented technology, can according to the chip temperature, automatically adjust the gain of the system, reduce the power consumption of the chip, to prevent damage in case of excessive temperature. The AW87519 has an automatic temperature detection mechanism, when the chip temperature exceeds the preset threshold of thermal AGC temperature (150°C), the chip will start the automatic gain control circuit to decrease the gain of the system, thereby reducing the energy consumption of the chip, thus slow or stop chip temperature continues to rise. When the chip temperature is restored to normal operating range (below 130°C), the automatic gain control circuit will restore the system gain to the original state. When the chip operates in a fault condition, the chip temperature is too high, up to a preset temperature protection temperature threshold (160°C), the system starts overheating protection, the chip will be turned off, restarts to resume normal work when the chip temperature returns to normal operating range (less than 130°C). a w in ic C o n fi d AW87519 with automatic recovery of the output overcurrent protection function, when the overcurrent occurs, AW87519 internal protection circuit will chip off to ensure that the chip is not damaged, when the short-circuit fault is eliminated, the chip will automatically resume working without restarting. www.awinic.com.cn COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 20 AW87519 May 2019 V1.1 Device Address The I2C device address (7-bit) is decided by the connection of the AD pin. The connection of AD pin configures the two LSB bits of the following 7-bit binary address A6-A0 of 10110A1A0. The permitted I2C A1 A0 Connects to GND Connects to SCL Connects to SDA Connects to VDD 0 0 I2C address (7-bit) 0x58 0 1 0x59 1 0 0x5A 1 1 0x5B n AW87519 Address selection e Table 2 fi d I2C Timing feature Parameter MIN Sym 1 fSCL SCL Clock frequency 2 tLOW SCL Low level Duration 3 tHIGH SCL High level Duration 4 tRISE SCL, SDA rise time 5 tFALL SCL, SDA fall time 6 tSU:STA Setup time SCL to START state 7 tHD:STA 8 tSU:STO tSU:DAT tHD:DAT UNIT 400 kHz 1.3 μs 0.6 μs C o MAX 0.3 μs 0.3 μs (Repeat-start) Start condition hold time 0.6 μs Stop condition setup time 0.6 μs the Bus idle time START state to STOP state 1.3 μs SDA setup time 0.1 μs SDA hold time 10 ns ic μs a 11 TYP 0.6 in tBUF w 10 Name n No. 9 ti a AD pin l addresses are 0x58(7bit) through 0x5B(7-bit). The address information is as following table. www.awinic.com.cn COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 21 AW87519 May 2019 V1.1 (3) (2) tHI GH tLOW tRI SE tFALL (4) (5) SCL tSU:DAT tHD:DAT (10) (11) SDA Figure 13 SCL and SDA timing relationships in the data transmission process tSU:STO (7) (8) (6) (9) tSU:STA tBUF SDA the Timing Relationship between START and STOP State n Figure 14 ti a tHD:STA l SCL e General I2C Operation n fi d The I2C bus employs two signals, SDA (data) and SCL (clock), to communicate between integrated circuits in a system. The device is addressed by a unique 7-bit address; the same device can send and receive data. In addition, Communications equipment has distinguish master from slave device: In the communication process, only the master device can initiate a transfer and terminate data and generate a corresponding clock signal. The devices using the address access during transmission can be seen as a slave device. SDA and SCL connect to the power supply through the current source or pull-up resistor. SDA and SCL default is a high level. All data to start transmission and end of transmission requires the main device to issue START state and STOP status: START state:The SCL maintain a high level, SDA from high to low level ic C o STOP state:The SCL maintain a high level, SDA pulled low to high level Start and Stop states can be only generated by the master device. In addition, if the device does not produce STOP state after the data transmission is completed, instead re-generate a START state (Repeated START, Sr), and it is believed that this bus is still in the process of data transmission. Functionally, Sr state and START state is the same. As shown in Figure 15. SCL START (S) STOP (P) in SDA Figure 15 START and STOP State Generation Process a w In the data transmission process, when the clock line SCL maintains a high level, the data line SDA must remain the same. Only when the SCL maintain a low level, the data line SDA can be changed, as shown in Figure 16. Each transmission of information on the SDA is 9 bits as a unit. The first eight bits are the data to be transmitted, and the first one is the most significant bit (Most Significant Bit, MSB), the ninth bit is an confirmation bit (Acknowledge, ACK or A ), as shown in Figure 17. When the SDA transmits a low level in ninth clock pulse, it means the acknowledgment bit is 1, namely the current transmission of 8 bits data are confirmed, otherwise it means that the data transmission has not been confirmed. Any amount of data can be transferred between START and STOP state. www.awinic.com.cn COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 22 AW87519 May 2019 V1.1 SCL SDA Data cable Remains the same: At this point the data is valid l The Data Transfer Rules on the I2C Bus ti a Figure 16 Data transmission: In this case the data is invalid The whole process of actual data transmission is shown in Figure 17. When generating a START condition, the master device sends an 8-bit data, including a 7-bit slave addresses (Slave Address), and followed by a START or repeated START (S or Sr) 1 2 8 9 R/W ACK 1 SDA Figure 17 9 MSB STOP or Repeated START (P or Sr) ACK Data Transmission on the I2C Bus o I2C Read/Write Processes 8 n MSB 2 fi d SCL e n "read / write" flag ( R/W ). The flag is used to specify the direction of transmission of subsequent data. The master device will produce the STOP state to end the process after the data transmission is completed. However, if the master device intends to continue data transmission, you can directly send a Repeated START state, without the need to use the STOP state to end transmission. C The following describes two kinds of ways of the I2C bus data transmission: Write Process in ic Writing process refers to the master device write data into the slave device. In this process, the transfer direction of the data is always unchanged from the master device to the slave device. All acknowledge bits are transferred by the slave device, in particular, AW87519 as the slave device, the transmission process in accordance with the following steps, as shown in Figure 18: Master device generates START state. The START state is produced by pulling the data line SDA to a low level when the clock SCL signal is a high level. Master device transmits the 7-bits device address of the slave device, followed by the "read / write" flag (flag R/W = 0); a w The slave device asserts an acknowledgment bit (ACK) to confirm whether the device address is correct; The master device transmits the 8-bit AW87519 register address to which the first data byte will written; The slave device asserts an acknowledgment (ACK) bit to confirm the register address is correct; Master sends 8 bits of data to register which needs to be written; The slave device asserts an acknowledgment bit (ACK) to confirm whether the data is sent successfully; If the master device needs to continue transmitting data, it does not need further to send the register address for AW87519, within AW87519 each send confirmation bit(ACK) regret automatic accumulation register address then only need to repeat the sixth step and seven step: The master device generates the STOP state to end the data transmission. www.awinic.com.cn COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 23 AW87519 May 2019 V1.1 (1) (2) slave device address R/W (4) (5) A Register address ‘0’(write) data transmission direction (6) (7) (6r) (7r) A write data A write data A (9) STOP Data Transmission: 8 + 1 bit data acknowledge bit (ACK) Register address auto increment - (8) From the master to the slave device From slave to master device Figure 18 Writing Process (Data Transmission Direction Remains the Same) ti a Read Process l START (3) n Reading process refers to the slave device reading data back to the master device. In this process, the direction of data transmission will change. Before and after the change, the master device sends START state and slave address twice, and sends the opposite "read/write" flag. In particular, AW87519 as the slave device, the transmission process carried out by following steps listed in Figure 19: Master device asserts a start condition; fi d e Master device transmits the 7 bits address of AW87519, and followed by a "read / write" flag ( R/W = 0); The slave device asserts an acknowledgment bit (ACK) to confirm whether the device address is correct; The master device sends the 8bit address that the AW87519 register needs to read the data; The slave device asserts an acknowledgment (ACK) bit to confirm whether the register address is correct or not; The master device restarts the data transfer process by continuously generating STOP state and START state or a separate Repeated START. C o n Master sends 7-bits address of the slave device and followed by a read / write flag (flag R/W = 1) again. The slave device asserts an acknowledgment (ACK) bit to confirm whether the register address is correct or not. The master transmits 8 bits of data to register which needs to be read; The slave device sends an acknowledgment bit (ACK) to confirm whether the data is sent successfully. AW87519 automatically increment register address once after the slave sent each acknowledge bit (ACK). The master device generates the STOP state to end the data transmission. (2) START slave device address R/W (3) (4) (5) (6) A Register address A Sr ic (1) (7) slave device address ‘0’(write) From the master to the slave device From slave to master device R/W A (9) (10) Read data A (9r) (10r) Read data A (12) STOP ‘1’(read) Data Transmission: 8 + 1 bit data acknowledge bit (ACK) Sr = repeated START or Send STOP state before sending START state Register address auto increment - (11) in data transmission direction (8) Reading Process (Data Transmission Direction Remains the Same) a w Figure 19 www.awinic.com.cn COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 24 AW87519 May 2019 V1.1 Register List name addres s Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 Chip ID 0x00 0 1 0 1 1 0 0 1 SYSCTRL 0x01 EN_SW EN_CP EN_BOOST EN_PA 0 0 BAT_SFGD _VTH(2) [1] BAT_SFGD _VTH(2) [0] BST_VOUT(4) [4] BST_VOUT(4) [3] BST_IPEAK[1 ] 0 BSTVOUT 0x03 1 1 FORCE_BOO ST BSTCP 0x04 0 0 0 BST_IPEAK[2] 0 0 BAT_SFGD_L EVEL(3) [1] BST_VOUT(4) [1] BAT_SFGD_L EVEL(3) [0] BST_VOUT(4) [0] l 0x02 0 EN_BAT_SFG D BST_VOUT(4) [2] BST_IPEAK[0 ] (1) 0 1 ti a BATSAFE RCV_MODE 0x05 0 0 0 PA_GAIN[4] PA_GAIN[3] PA_GAIN[2] PA_GAIN[1] PA_GAIN[0] 0x06 0 1 0 PD_AGC3 AGC3_Po[3] AGC3_Po[2] AGC3_Po[1] AGC3_Po[0] AGC3 0x07 AGC3_RT[2] AGC3_RT[1] AGC3_RT[0] AGC3_AT[2] AGC3_AT[1] AGC3_AT[0] 1 0 AGC2_Po 0x08 0 0 0 0 AGC2_Po[3] AGC2_Po[2] AGC2_Po[1] AGC2_Po[0] AGC2 0x09 0 0 0 AGC2_AT[2] AGC2_AT[1] AGC2_AT[0] 0 0 0x0A 0 1 0 0 1 AGC1_AT[1] AGC1_AT[0] PD_AGC1 (2) (3) (4) register 0x00 0x01 0x02 0x03 0x04 0xC8 Default 0x59 0x70 0x09 e RCV_MODE: enable 2-in-1 receiver application BAT_SFGD_VTH: Battery voltage when enter into battery safe_guard mode BAT_SFGD_LEVEL: Maxim output level when enter into battery safe_guard mode BST_VOUT: Boost output voltage (1) fi d AGC1 n PAGAIN AGC3_Po 0x05 0x06 0x05 (RCV_MODE=1) 0x11 0x53 0x10 (RCV_MODE=0) 0x09 0x4E 0x08 0x03 0x4A AW87519 Register Initial Value ic C Any register address which is more than 0x0A and all reserved bits are reserved for debugging and testing purposes. Changing their values may affect the normal function of the power amplifier; Reading them will get any possible values. AW87519’s I2C address is 10110A2A1, as shown in Table 4, in order to avoid conflict with other I2C devices address, you can connect AD pin to GND,SCL,SDA,VDD to set the value of A2 and A1, respectively. The following lists specific information about all visible registers, including default values and programmable ranges. Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 1 0 1 1 0 A2 A1 R/W w in Bit7 Table 4 AW87519 Address Byte CHIP ID Register (address: 0x00) Name R/W Default 7:0 IDCODE R 0x59 a I2C Bit Description Chip ID will be returned after reading. All configuration registers will be reset to default values after 0xAA is written. SYSTEM CONTROL (SYSCTRL) Register (address: 0x01) I2C Bit Name R/W Default 7 EN_SW R/W 0 www.awinic.com.cn Description Chip Software Enable 0: Chip Software Disable: COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 25 0x0A 0x4B o Table 3 0x08 0x0B 0x43 n 0xE8 0x07 AW87519 EN_CP R/W 1 5 EN_BOOST R/W 1 4 EN_PA R/W 1 3 RCV_MODE R/W 0 2:0 -- -- 000 ti a 6 Shutdown the whole chip except PORN. 1: Chip Software Enable Chargepump Enable: 0: Disable Chargepump, PVDD=VBAT 1: Enable Chargepump BOOST enable 0: Disable BOOST,BOOST power down 1: Enable BOOST PA output Enable 0: Disable PA 1: Enable PA CLASS D receiver function enable 0:Receiver mode disabled 1:Enable Receiver mode Reserved and Unused R/W -- Default 000 4:3 BAT_SFGD_ VTH R/W 01 2 EN_BAT_SF GD R/W 0 1:0 BAT_SFGD_ LEVEL R/W Description Reserved and Unused Setting Battery Threshold Voltage for Triggering Battery Safeguard Mode: 00:threshold voltage is 3.3V 01:threshold voltage is 3.4V 10:threshold voltage is 3.5V 11:threshold voltage is 3.6V Software control battery safeguard,when FORCE_BOOST=0, this bit is set to be 0. 0: Software control battery safeguard disable 1: Software control battery safeguard enable Setting Maximum Output Level when Battery Safeguard Mode Triggered 00: 5.0Vp 01: 5.5Vp 10: 6.0Vp 11: 6.5Vp o n fi d e Name -- n BATTERY SAFEGUARD (BATSAFE)Register (address: 0x02) I2C Bit 7:5 l May 2019 V1.1 C 01 BOOST OUTPUT VOLTAGE (BSTVOUT) Register (address: 0x03) Name -- R/W -- Default 11 5 FORCE_ BOOST R/W 1 Description Reserved and Unused Boost output voltage enable 0:direct through mode,PVDD=VBAT 1:force boost output voltage BOOST output voltage set 01001~11111: Unavailable 01000: 8.5V 00111: 8.25V 00110: 8.0V 00101: 7.75V 00100: 7.5V 00011: 7.25V 00010: 7.0V 00001: 6.75V 00000: 6.5V w in ic I2C Bit 7:6 BST_VOUT R/W 01000 a 4:0 BOOST CONTROL PARAMETER (BSTCP) Register (address: 0x04) I2C Bit Name www.awinic.com.cn R/W Default Description COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 26 AW87519 May 2019 V1.1 -- 000 4:2 BST_IPEAK R/W 100 1:0 -- -- 01 Reserved and Unused BOOST peak current limit 000: 2.5A 001: 2.75A 010: 3.0A 011: 3.25A 100: 3.5A 101: 3.75A 110: 4.0A 111: 4.25A Reserved and Unused GAIN CONTROL (Gain) Register (address: 0x05) For RCV_MODE=1, (Speaker & Receiver 2-in-1Mode): I C Bit 7:5 Name -- R/W -- Default 000 Description Reserved and Unused Setting Class D Amplifying Gain n 2 R/W 00000~00100 00101: 7.5dB 00110: 9.0dB 00111: 10.5dB 00101 fi d Gain For RCV_MODE=0,(Speaker Mode): I2C Bit 7:5 R/W -- Default 000 Reserved and Unused Rini=30kΩ Rini=24kΩ Rini=28kΩ Description Reserved and Unused Setting Class D Amplifying Gain n Name -- e Gain 4:0 l -- ti a 7:5 Gain R/W 10000 ic 4:0 C o Gain 01000: 12dB 01001: 13.5dB 01010: 15.0dB 01011: 16.5dB 01100: 18.0dB 01101: 19.5dB 01110: 21dB 01111: 22.5dB 10000: 24dB 10001: 25.5dB 10010: 27dB 10011~11111: Unavailable Rini=36.5kΩ Rini=30kΩ Rini=25kΩ Rini=21.5kΩ Rini=18kΩ Rini=15.5kΩ Rini=12.5kΩ Rini=11kΩ Rini=9kΩ Rini=7.5kΩ Rini=6.5kΩ Name -- R/W -- Default 010 w I2C Bit 7:5 in CLASS D AGC3 OUTPUT POWER (AGC3_Po) Register (address: 0x06) PD_AGC3 R/W 0 3:0 AGC3_Po R/W 0011 a 4 www.awinic.com.cn Description Reserved and Unused Disable AGC3 0:Enable AGC3 1:Disable AGC3 Setting AGC3 Output Power for Protecting Speaker and stereo Receiver 0000: 0.5W@8Ω 0.667W@6Ω 0001: 0.6W@8Ω 0.8W@6Ω 0010: 0.7W@8Ω 0.933W@6Ω 0011: 0.8W@8Ω 1.067W@6Ω 0100: 0.9W@8Ω 1.2W@6Ω 0101: 1.0W@8Ω 1.333W@6Ω 0110: 1.1W@8Ω 1.467W@6Ω COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 27 AW87519 May 2019 V1.1 1.6W@6Ω 1.733W@6Ω 1.867W@6Ω 2.0W@6Ω 2.133W@6Ω 2.267W@6Ω 2.4W@6Ω 2.533W@6Ω 2.667W@6Ω l 0111: 1.2W@8Ω 1000: 1.3W@8Ω 1001: 1.4W@8Ω 1010: 1.5W@8Ω 1011: 1.6W@8Ω 1100: 1.7W@8Ω 1101: 1.8W@8Ω 1110: 1.9W@8Ω 1111: 2.0W@8Ω R/W Default 7:5 AGC3_RT R/W 010 4:2 AGC3_AT R/W 011 1:0 -- -- 10 Description Setting Release Time of AGC3: 000: 5.12ms/dB 001: 10.24ms/dB 010: 21 ms/dB 011: 41 ms/dB 100: 82 ms/dB 101: 164 ms/dB 110: 328 ms/dB 111: Unavailable Setting Attack Time of AGC3: 000: 1.28ms/dB 001: 2.56ms/dB 010: 10.24ms/dB 011: 20.48ms/dB 100: 41ms/dB 101: 82ms/dB 110: 164ms/dB 111: 328ms/dB Reserved and Unused n Name o n fi d e I2C Bit ti a CLASS D AGC3 PARAMETER (AGC3) Register (address: 0x07) CLASS D AGC2 OUTPUT POWER(AGC2_Po) Register (address: 0x08) Name R/W 7:4 -- -- Default C I2C Bit 0000 Setting AGC2 Output Power: in ic 0000: 1.0W@8Ω 0001: 1.2W@8Ω 0010: 1.4W@8Ω 0011: 1.6W@8Ω 0100: 1.8W@8Ω 0101: 2.0W@8Ω 0110: 2.2W@8Ω 0111: 2.4W@8Ω 1000: 2.6W@8Ω 1001: 2.8W@8Ω 1010: 3.0W@8Ω 1011: AGC2 OFF 1100~1111: Unavailable AGC2_Po R/W 0011 a w 3:0 Description Reserved and Unused 1.333W@6Ω 1.6W@6Ω 1.867W@6Ω 2.133W@6Ω 2.4W@6Ω 2.667W@6Ω 2.933W@6Ω 3.2W@6Ω 3.467W@6Ω 3.733W@6Ω 4W@6Ω CLASS D AGC2 PARAMETER (AGC2) Register (address: 0x09) 2 I C Bit 7:5 Name -- R/W -- Default 000 4:2 AGC2_AT R/W 010 www.awinic.com.cn Description Setting Attack Time of AGC2: 000: 0.16ms/dB 001: 0.32ms/ dB COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 28 AW87519 May 2019 V1.1 1:0 -- -- 010: 0.64ms/dB 011: 2.56ms/dB 100: 10.24ms/dB 101: 41ms/dB 110: 82ms/dB 111: 164ms/dB Reserved and Unused 00 Name -- R/W -- Default 01001 2:1 AGC1_AT R/W 01 0 PD_ AGC1 R/W 0 Description Reserved and Unused Setting Fastest Level AGC Attack Time: 00: 0.04ms/dB 01: 0.08ms/dB 10: 0.16ms/dB 11: 0.32ms/dB AGC1 control bit 0: AGC1 Enable 1: AGC1 Disable a w in ic C o n fi d e n ti a I C Bit 7:3 l CLASS D AGC1 PARAMETER (AGC1) Register (address: 0x0A) 2 www.awinic.com.cn COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 29 AW87519 May 2019 V1.1 APPLICATION INFORMATION EXTERNAL COMPONENTS BOOST INDUCTOR SELECTION o n fi d e n ti a l Selecting inductor needs to consider Inductance, size, magnetic shielding, saturation current and temperature current. a) Inductance Inductance value is limited by the boost converter's internal loop compensation. In order to ensure phase margin sufficient under all operating conditions, recommended 1μH inductor. b) Size For a certain value of inductor, the smaller the size, the greater the parasitic series resistance of the inductor DCR, the higher the loss, corresponds to the lower efficiency. c) Magnetic shielding Magnetic shielding can effectively prevent the inductance of the electromagnetic radiation interference. It is much better to choose inductance with magnetic shielding in the application of EMI sensitive environment. d) Saturation current and temperature rise of current Inductor saturation current and temperature rise current value are important basis for selecting the inductor. As the inductor current increases, on the one hand, since the magnetic core begins to saturate, inductance value will decline; on the other hand, the inductor's parasitic resistance inductance and magnetic core loss can lead to temperature rise. In general, the current value is defined as the saturation current ISAT when the inductance value drops to 70%; the current value is defined as temperature rise current IRMS when inductance temperature rise 40℃. For particular applications, need to calculate the maximum IL_PEAK and IL_RMS, which is a basis of selecting the inductor. When VDD = 4.2V, PVDD=8 .5V, RL = 8Ω,amplifier RDSON = 250mΩ, when THD = 1% (the maximum power without distortion), the output power is calculated as follows: 2 ic C 2   RL 8   VOUT    8.5   RL  RDSON  8  0.25  POUT     4.3 W 2  RL 28 In such a large output power, the overall efficiency of the power amplifier is typically 80%, in order to calculate the maximum average current IMAX_AVG_VDD and maximum peak current IMAX_PEAK_VDD drawn from VDD: P 4.3 IMAX _ AVG_VDD  OUT  A  1.28A VDD  η 4.2  0.8 in IMAX _ PEAK_VDD  2  IMAX _ AVG_VDD  2.56A If inductor DCR is 50mΩ, the inductor power loss at this time is: 2 2 PDCR,LOSS  1.5  IMAX _ AVG_VDD  DCR  1.5  1.28  0.05W  123mW w Wherein the coefficient 1.5 is the square of the ratio of the sine wave current RMS value and average value (there is no consideration of the impact of the inductor ripple, the actual DCR loss will be even greater). If the a loss which is resulting from DCR is less than 1% at maximum efficiency (POUT = 2.5W, η = 80%), then: IAVG_VDD  DCR  POUT 2.5   0.74A VDD  η 4.2  0.8 PDCR ,LOSS POUT 0.01 2.5  0.01    38m 2 2 1.5  IAVG 1 . 5  I   1 . 5  0.742  0.8 _ VDD AVG_ VDD www.awinic.com.cn COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 30 AW87519 May 2019 V1.1 According to the working principle of the Boost, we can calculate the size of the inductor current ripple ΔIL: VDD  VOUT  VDD  4.2  8.5  4.2  A  1.33A VOUT  f  L 8.5  1.6  106  1 10 6 IL _ PEAK  IMAX _ PEAK _VDD  ti a Thus, the maximum peak inductor current IL_PEAK and maximum effective inductor current IL_RMS is: ΔIL 1.33  2.56  A  3.23A 2 2 ΔIL2 1.332  2.562  A  2.6 A 12 12 n 2 IL_RMS  IMAX _ PEAK _ VDD  l ΔIL  n fi d e From the above calculation results: 1) For typical DCR about 38mΩ inductance, the efficiency loss caused by around1.5%; 2) In practice, the maximum output power of the amplifier is likely to reach 4.3W in an instant, so the selected inductor saturation current ISAT requires more than the maximum inductor peak current IL_PEAK; 3) In some cases, if the IL_PEAK calculated according to the above method is greater than the set of input inductor current limit value ILIMIT, shows the power amplifier is restricted by inductance input current limit, the actual maximum output power is less than the calculated value, the measured value shall prevail, and ISAT need greater than the set current limiting value ILIMIT, and cannot be less than 2.56A; 4) Take PVDD = 8.5V for example, under different conditions, the typical method of selecting I SAT in the following table: RL (Ω) ILIMIT (A) 4.2 8.5 8 4 4.2 8.5 6 4 PO (W) IL_PEAK (A) Inductor saturation current ISAT minimum value (A) 80 4.3 3.23 4.2 75 5.3 4 4.2 o PVDD (V) Efficiency(η) (%) C VDD (V) a w in ic 5) As the result of the action of AGC,amplifier will not work long hours at maximum power without distortion, the actual average inductor current is far less than the maximum inductor current effective I L_RMS, so when selecting the inductor, the inductor temperature rise current is not usually a limiting factor; 6) Inductor Selection example: the inductor package size is 252012, inductance value is 1μH, DCR Typical value is 47mΩ, the typical saturation current ISAT is 4.2A, the typical temperature rise current IRMS is 2.8A, suitable for VDD=3.6V, PVDD=8.5V, speaker impedance RL=8Ω, inductor input current limit ILIMIT= 4.2A. If you choose ISAT or IRMS of the inductance is too small, it is possible to cause the chip don’t work properly, or the temperature of the inductance is too high. www.awinic.com.cn Inductance value size DCR(Ω) 1uH 2.5×2.0×1.2mm 0.047 ISAT(A) IRMS(A) 4.2 2.8 COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 31 AW87519 May 2019 V1.1 Capacitor Selection BOOST CAPACITOR SELECTION a) ti a l The output capacitor of chargepump is usually within the range 0.1μF~47μF, It needs to use Class II type (EIA) multilayer ceramic capacitors (MLCC). Its internal dielectric is ferroelectric material (typically BaTiO3), a high the dielectric constant in order to achieve smaller size, but at the same Class II type (EIA) multilayer ceramic capacitors has poor temperature stability and voltage stability as compared to the Class I type (EIA) capacitance. Capacitor is selected based on the requirements of temperature stability and voltage stability, considering the capacitance material, capacitor voltage, and capacitor size and capacitance values. temperature stability b) e n Class II capacitance have different temperature stability in different materials, usually choose X5R type in order to ensure enough temperature stability, and X7R type capacitance has better properties, the price is relatively more expensive. X5R capacitance change within ±15% in temperature range of 55°C to 85°C, X7R capacitance change within ±15% in temperature range of -55°C~125°C. The output capacitance of the AW87519’s chargepump recommends X5R ceramic capacitors. Voltage Stability a w in ic C o n fi d Class II type capacitor has poor voltage stability ——Capacitance values falling fast along with the DC bias voltage applied across the capacitor increasing. The rate of decline is related to capacitance material, capacitors rated voltage, capacitance volume. Take for TDK C series X5R for example, its pressure voltage value is 16V or 25V, the package size is 0805, 1206 or 0603, the capacitance value is 10μF. The capacitor’s voltage stability of different types of capacitor is as shown below: Figure 20 Different Types of Capacitive Voltage Stability It can be found that the rate of capacitance capacity value descent becomes slow along with "large capacitor size, capacitance pressure voltage rise”. The larger the package size, the better voltage stability. The higher the height, the better voltage stability with the same length and width of the capacitance. Voltage stability of www.awinic.com.cn COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 32 AW87519 May 2019 V1.1 material size (mm3) rated voltage (V) quantity value@8.5V 10uF X5R 1.60×0.80×0.80 (0603) 16 4 6uF 10uF X5R 2.00×1.25×1.25 (0805) 25 3 6.3uF ti a value l smaller package size (0603) capacitor change affected by the pressure value is very small. In AW87519 typical applications, it is necessary to ensure the output value of the PVDD capacitor ≥6μF when PVDD=8.5V. Take the following capacitances as the Boost of the output capacitor for example: n As for the different manufacturers’ capacitors, it’s important to determine the type and quantity of the capacitors through the capacitor voltage stability data provided by the manufacturer. Input Capacitor-Cin(input high-pass cutoff frequency) 1 (Hz) 2  π  Rintotal  Cin fi d fH ( 3dB)  e The input capacitors and input resistors form a high-pass filter to filter out the DC component of the input signal. The -3dB frequency points of the high pass filter is shown below: n The selection of a smaller Cin capacitor in the application helps to filter out 217Hz noise, which comes from the input coupling, and the smaller capacitor is advantageous to reduce the pop-click noise when the power amplifier turn on.Better matching of the input capacitors improves performance of the circuit and also helps to suppress pop-click noise. A capacitor value deviation of 10% or better capacitance is recommended. Take typical application as an example, the input high-pass cutoff frequency is calculated as below: o 1 1  (Hz)  260Hz 2  π  Rintotal  Cin 2  π  9kΩ  68nF C fH (3dB)  Class D-type speaker & receiver 2-in-1 application (Gain=9dB), the input high pass frequency is as follows: 1 1  (Hz)  98Hz 2  π  Rintotal  Cin 2  π  24kΩ  68nF ic fH (3dB)  in Supply Decoupling Capacitor(CS) a w A good decoupling capacitor can improve the efficiency and the best performance of the power amplifier. At the same time, in order to get good high frequency transient performance, the ESR value of the capacitor should be as small as possible. In AW87519 applications, low ESR (equivalent-series-resistance) X7R or X5R ceramic capacitors are recommended. Generally, 10μF ceramic capacitors are used to bypass the VDD to the ground, and the decoupling capacitor should be placed as close to the VDD chip as possible in the layout. If you want to filter out low-frequency noise better, you need to add a 10μF or greater decoupling capacitor depending on your application. Meanwhile, a 33pF~0.1μF ceramic capacitor is placed on the pin of the power supply to filter the high frequency interference on the power supply. The capacitor should be placed as close as possible to the pin3 and inductor. Output beads, capacitors, TVS Using EEE technology, in the class K mode, the AW87519 can also meet the FCC CLASS B specification www.awinic.com.cn COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 33 AW87519 May 2019 V1.1 requirements. It is recommended to Use ferrite chip beads and capacitors if device near the EMI sensitive circuits, there are long leads from amplifier to speaker, placed as close as possible to the output pin. Waveform before Bead Waveform after Bead l Bead 0.1nF ti a VOP 16V Bead VON Ferrite Chip Bead and Capacitor e Figure 21 16V n 0.1nF a w in ic C o n fi d Amplifier output is a square wave signal. The voltage across the capacitor will be much larger than the PVDD voltage after increasing the bead capacitor. It suggested the use of rated voltage above 16V capacitor. At the same time a square wave signal at the output capacitor switching current form, the static power consumption increases, so the output capacitance should not be too much which is recommended 0.1nF ceramic capacitor rated voltage of 16V. If you want to get better EMI suppression performance, can use 1nF, rated voltage 16V capacitor, but quiescent current will increase. Power amplifier output PWM signals of high voltage to PVDD voltage, voltage to 8.5 V, will produce some ringing after bead capacitor, resulting in higher peak voltage. Recommended choose the operating voltage of 16V TVS. www.awinic.com.cn COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 34 AW87519 May 2019 V1.1 PCB AND DEVICE LAYOUT CONSIDERATION C o n fi d e n ti a l EXTERNAL COMPONENTS PLACEMENT Figure 22 AW87519 External Components Placement ic LAYOUT CONSIDERATIONS a w in This device is a power a power amplifier chip. To obtain the optimal performance, PCB layout should be considered carefully. The suggested Layout is illustrated in the following diagram: www.awinic.com.cn COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 35 AW87519 Figure 23 fi d e n ti a l May 2019 V1.1 AW87519 Board Layout a w in ic C o n In order to obtain excellent performance of AW87519, PCB layout must be carefully considered. The design consideration should follow the following principles: 1. In AW87519 peripheral device layout, you first need to guarantee the chargepump output capacitance close to VBST pin. 2. All the filter capacitors of the audio PA (including CVDD, CVBST and CVREG) should be placed close to the pins of the chip. 3. Please place the VREG capacitor close to the VBST capacitor. The parasitic inductance of the CVREG capacitor should be less than 3nH. Minimize inductance as much as possible. 4. Traces of SW pin should support currents up to device over-current limit (peak current 3.5A). 5. Try to provide a separate short and thick power line to AW87519, the copper width is recommended to be larger than 0.75mm. The decoupling capacitors should be placed as close as possible to boost power supply pin. 6. The input capacitors should be close to AW87519 INN and INP input pin, the input line should be parallel to suppress noise coupling. 7. The beads and capacitor should be placed near to AW87519 VON and VOP pin. The output line from AW87519 to speaker should be as short and thick as possible. The width is recommended to be larger than 0.5mm. www.awinic.com.cn COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 36 AW87519 May 2019 V1.1 TAPE & REEL DESCRIPTION TAPE DIMENSIONS REEL DIMENSIONS P1 P0 P2 K0 W l B0 Cavity ti a D1 A0 e n A0:Dimension designed to accommodate the component width B0:Dimension designed to accommodate the component length K0:Dimension designed to accommodate the component thickness W:Overall width of the carrier tape P0:Pitch between successive cavity centers and sprocket hole P1:Pitch between successive cavity centers P2:Pitch between sprocket hole D1:Reel Diameter D0:Reel Width fi d D0 Pin 1 Q3 Q4 Q1 Q2 Q1 Q2 o Q2 Q3 Q4 Q3 Q4 Q1 Q2 Q3 Q4 Sprocket Holes User Direction of Feed C Q1 n QUADRANT ASSIGNMENTS FOR PIN 1 ORIENTATION IN TAPE a w in ic Pocket Quadrants www.awinic.com.cn COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 37 AW87519 May 2019 V1.1 PACKAGE DESCRIPTION 2.000±0.100 fi d e n ti a 3.000±0.100 l PIN1 Corner 0.152 Ref. 0.550±0.050 n 0.000~0.050 o e 0.400 TYP d 10 C 7 6 SYMM ℄ in 0.400 TYP b 1 16 20 0.150 REF 17 SYMM ℄ 19X(0.300±0.050) a Note: a=b=c=d=e=f=0.120mm a w 0.250±0.050 20X(0.200±0.050) c ic f 11 www.awinic.com.cn COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 38 AW87519 May 2019 V1.1 LAND PATTERN 20X0.20 20X0.40 20 17 1 16 ti a 8X 0.12 REF l 8X 0.12 REF 0.40 TYP n 3.20 SYMM fi d e ℄ 6 11 7 SYMM o 0.40 TYP n 10 ℄ C 2.20 ic 0.05 MIN ALL AROUND SOLDER MASK OPENING SOLDER MASK DEFINED a NON-SOLDER MASK DEFINED www.awinic.com.cn METAL UNDER SOLDER MASK SOLDER MASK OPENING METAL w in 0.05 MAX ALL AROUND Unit:mm COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 39 AW87519 May 2019 V1.1 VERSION INFORMATION V1.0 2019-01-28 AW87519FCR datasheet V1.0 V1.1 2019-05-24 1. Modify PCB and Device Layout 2. Modify package description and Land pattern a w in ic C o n fi d e n ti a Date l Description Version www.awinic.com.cn COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 40 AW87519 May 2019 V1.1 DISCLAIMER Information in this document is believed to be accurate and reliable. However, Shanghai AWINIC Technology Co., Ltd (AWINIC Technology) does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. ti a l AWINIC Technology reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. Customers shall obtain the latest relevant information before placing orders and shall verify that such information is current and complete. This document supersedes and replaces all information supplied prior to the publication hereof. fi d e n AWINIC Technology products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an AWINIC Technology product can reasonably be expected to result in personal injury, death or severe property or environmental damage. AWINIC Technology accepts no liability for inclusion and/or use of AWINIC Technology products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. n Applications that are described herein for any of these products are for illustrative purposes only. AWINIC Technology makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. All products are sold subject to the general terms and conditions of commercial sale supplied at the time of order acknowledgement. o Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. ic C Reproduction of AWINIC information in AWINIC data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. AWINIC is not responsible or liable for such altered documentation. Information of third parties may be subject to additional restrictions. a w in Resale of AWINIC components or services with statements different from or beyond the parameters stated by AWINIC for that component or service voids all express and any implied warranties for the associated AWINIC component or service and is an unfair and deceptive business practice. AWINIC is not responsible or liable for any such statements. www.awinic.com.cn COPYRIGHT ©2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 41
AW87519FCR 价格&库存
很抱歉,暂时无法提供与“AW87519FCR”相匹配的价格&库存,您可以联系我们找货
