(0.80 mm) .0315" PITCH • QTE/QSE SERIES
QTE
Board Mates:
QSE
QTE
QSE
LEAD
STYLE
–020,
–040, –060
Board Mates:
QTE
–014,
–028, –042
Cable Mates:
EQCD, EQDP
Standoffs:
SO
= Gold flash
on contact,
Matte Tin on tail
–L
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
(14 pairs per bank =
–D–DP)
SPECIFICATIONS
Insulator Material:
Liquid Crystal Polymer
Contact Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating:
Contact:
2 A per pin (2 pins powered)
Ground Plane:
23 A per ground plane
(1 ground plane powered)
Operating Temp Range:
-55 °C to +125 °C
Voltage Rating:
225 VAC when mated
& 5 mm Stack Height
Max Cycles:
100
- A
–D
A
HEIGHT
WITH QSE*
–01
(4.27) .168
(5.00) .197
–02
(7.26) .286
(8.00) .315
–03
(10.27) .404
(11.00) .433
–04
(15.25) .600
(16.00) .630
–05
(18.26) .718
(19.00) .748
–07
(24.24) .954
(25.00) .984
–09
(13.26) .522
(14.00) .551
OTHER
OPTIONS
–K
= SingleEnded
–D–DP
= Differential
Pair
(–01 only)
”X”R
Leave blank
for Tray
Packaging
= (7.00 mm)
.275" DIA
Polyimide
film Pick &
Place Pad
–TR
=Tape & Reel
(Not available
with –05 & –07
lead style)
–L
= Latching
Option
(N/A on
–042 & –060
positions)
= 50 µ" (1.27 µm)
Electro-Polished
Selective Gold
on contact,
Matte Tin on tail
(passes 10 year
MFG testing)
–FR
= Full Reel
Tape & Reel
(must order
max. quantity
per reel;
contact Samtec
for quantity
breaks)
(Not available
with –05 & –07
lead style)
–D–DP = (No. of Positions per Row/14)
x (20.00) .7875
–D = (No. of Positions per Row/20)
x (20.00) .7875
(5.97)
.235
*Processing conditions will affect mated
height. See SO Series for board space
tolerances.
(7.11)
.280
(0.76)
.030
A
View complete specifications at: samtec.com?QTE
QSE
PINS PER ROW
NO. OF PAIRS
–F
= Gold flash
on contact,
Matte Tin on tail
(40 total pins per
bank = –D)
–L
–014,
–028, –042
=10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
(14 pairs per bank
= –D–DP)
EXTENDED LIFE
PRODUCT
TYPE
–D
= SingleEnded
–D–DP
= Differential
Pair
–C
HIGH MATING
CYCLES
–D–DP = (No. of Positions per Row/14) x
(20.00) .7875 + (1.27) .050
–D = (No. of Positions per Row/20) x
(7.24)
.285
PLATING
OPTION
01
–020,
–040, –060
10 YEAR MFG
= 50 µ" (1.27 µm)
Electro-Polished
Selective Gold
on contact,
Matte Tin on tail
(passes 10 year
MFG testing)
- A
OTHER
OPTIONS
–GP
= Guide Post
–K
= (8.25 mm)
.325" DIA
Polyimide Film
Pick &
Place Pad
–L
= Latching
Option
(Not available
on –042 & –060
positions)
”X”R
Leave blank for
Tray Packaging
–TR
=Tape & Reel
(40 positions
max. with –GP)
–FR
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec for
quantity breaks)
(40 positions max.
with –GP)
(7.49)
.295
(3.25)
.128
F-224
TYPE
–C
QTE
LEAD
STYLE
PROCESSING
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
PLATING
OPTION
–F
Specify
LEAD
STYLE
from
Chart
(40 total pins per
bank = –D)
QTE/QSE
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max
(020-060)
Board Stacking:
For applications requiring
more than two connectors
contact ipg@samtec.com
PINS PER ROW
NO. OF PAIRS
(0.76)
.030
(3.05)
.120
View complete specifications at: samtec.com?QSE
samtec.com/QStrip
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
QTE-040-01-F-D-GP-K 价格&库存
很抱歉,暂时无法提供与“QTE-040-01-F-D-GP-K”相匹配的价格&库存,您可以联系我们找货
