2014-04-25
OSRAM OSTAR Stage
Datasheet
Version 2.0
LE UW S2W
Outstanding brightness and luminance due to surface
emission and low Rth
Extrem hohe Helligkeit und Leuchtdichte dank
Oberflächenemission und niedrigem Rth
Features:
Besondere Merkmale:
• Package: compact lightsource in multi chip SMT
technology with glass window on top
• Technology: ThinGaN
• Viewing angle at 50 % IV: 120°
• Color: Cx = 0.31, Cy = 0.32 acc. to CIE 1931
(ultra white)
• Corrosion Robustness: Improved corrosion
robustness
• Gehäusetyp: Kompakte Lichtquelle in Multi-Chip
SMT Technologie mit Glasabdeckung
• Technologie: ThinGaN
• Abstrahlwinkel bei 50 % IV: 120°
• Farbe: Cx = 0.31, Cy = 0.32 nach CIE 1931 (ultra
weiß)
• Korrosionsstabilität: Verbesserte
Applications
Anwendungen
• Stage and Entertainment Lighting
• Mood Lighting
• Architectural Lighting indoor and outdoor
• Bühnen- und Effektbeleuchtung
• Stimmungsbeleuchtung
• Architekturbeleuchtung innen und außen
2014-04-25
1
Version 2.0
LE UW S2W
Ordering Information
Bestellinformation
Type:
Luminous Flux 1) page 26
Ordering Code
Typ:
Lichtstrom 1) Seite 26
Bestellnummer
IF = 700 mA
ΦV [lm]
LE UW S2W-PXQX-4P7R
Note:
450 ... 820
Q65111A0205
The above Type Numbers represent the order groups which include only a few brightness groups (see page 5). Only one group will be shipped on each
packing unit (there will be no mixing of two groups on each packing unit). E. g. LE UW S2W-PXQX-4P7R means that only one group PX, PY, PZ, QX
will be shippable for any packing unit. In order to ensure availability, single brightness groups will not be orderable.
In a similar manner for colors where color chromaticity coordinate groups are measured and binned, single groups will be shipped on any one packing
unit. LE UW S2W-PXQX-4P7R means that the device will be shipped within the specified limits. In order to ensure availability, single color chromaticity
groups groups will not be orderable (see page 6).
Anm.:
Die oben genannten Typbezeichnungen umfassen die bestellbaren Selektionen. Diese bestehen aus wenigen Helligkeitsgruppen (siehe Seite 5). Es
wird nur eine einzige Helligkeitsgruppe pro Verpackungseinheit geliefert. Z. B. LE UW S2W-PXQX-4P7R bedeutet, dass in einer Verpackungseinheit
nur eine der Helligkeitsgruppen PX, PY, PZ, QX enhalten ist. Um die Liefersicherheit zu gewährleisten, können einzelne Helligkeitsgruppen nicht
bestellt werden.
Gleiches gilt für die Farben, bei denen Farbortgruppen gemessen und gruppiert werden. Pro Verpackungseinheit wird nur eine Farbortgruppe geliefert.
Z.B. LE UW S2W-PXQX-4P7R bedeutet, dass in einer Verpackungseinheit nur eine der Farbortgruppen enthalten ist (siehe Seite 6). LE UW
S2W-PXQX-4P7R bedeutet, dass das Bauteil innerhalb der spezifizierten Grenzen geliefert wird. Um die Liefersicherheit zu gewährleisten, können
einzelne Farbortgruppen nicht bestellt werden.
2014-04-25
2
Version 2.0
LE UW S2W
Maximum Ratings
Grenzwerte
Parameter
Symbol
Values
Unit
Bezeichnung
Symbol
Werte
Einheit
Operating temperature range
Betriebstemperatur
Top
-40 ... 85
°C
Storage temperature range
Lagertemperatur
Tstg
-40 ... 85
°C
Junction temperature
Sperrschichttemperatur
Tj
125
°C
Forward current
Durchlassstrom
(TS = 25 °C; per Chip)
IF
100 ... 1000
mA
Forward current pulsed
Durchlassstrom gepulst
(D = 0.5; f = 120 Hz; TS = 25°C; per Chip)
IF pulse
100 ... 2000
mA
Reverse voltage
Sperrspannung
(TS = 25 °C)
VR
ESD withstand voltage
VESD
ESD Festigkeit
(acc. to ANSI/ESDA/JEDEC JS-001 - HBM, Class
2)
2014-04-25
3
not designed for reverse
operation
V
2
kV
Version 2.0
LE UW S2W
Characteristics (TS = 25 °C; IF = 700 mA; per Chip)
Kennwerte
Parameter
Symbol
Values
Unit
Bezeichnung
Symbol
Werte
Einheit
Chromaticity coordinates acc. to CIE 1931
(typ.)
(typ.)
Cx
Cy
0.31
0.32
(typ.)
2ϕ
120
Forward voltage 3) page 26
Durchlassspannung 3) Seite 26
(per Chip)
(min.)
(typ.)
(max.)
VF
VF
VF
2.90
3.45
4.00
V
V
V
IR
not designed for
reverse operation
2) page 26
Farbkoordinaten nach CIE 1931 2) Seite 26
Reverse current
Sperrstrom
Partial Flux acc. CIE 127:2007
Partieller Fluss
(typ.)
ΦE/V, 120°
Radiating surface
Abstrahlende Fläche
(typ.)
Acolor
Real thermal resistance junction / solder point
(typ.)
(max.)
"Electrical" thermal resistance junction / solder
point 4) page 26
"Elektrischer" Wärmewiderstand Sperrschicht /
Lötpad 4) Seite 26
(with efficiency η e = 21 %)
(typ.)
(max.)
2014-04-25
4
4) page 26
0.82
2.1 x 2.1
mm²
Rth JS real
Rth JS real
1.8
2.3
K/W
K/W
Rth JS el
Rth JS el
1.4
1.8
K/W
K/W
Realer Wärmewiderstand Sperrschicht / Lötpad
4) Seite 26
Version 2.0
LE UW S2W
Brightness Groups
Helligkeitsgruppen
Group
Luminous Flux
Luminous Flux
Luminous Intensity
1) page 26
1) page 26
5) page 26
1) Seite 26
Lichtstrom
1) Seite 26
Lichtstärke 5) Seite 26
Gruppe
Lichtstrom
(min.) ΦV [lm]
(max.) ΦV [lm]
(typ.) IV [cd]
PX
450
520
160
PY
520
610
185
PZ
610
710
220
QX
710
820
250
Note:
The standard shipping format for serial types includes either a lower family group, an upper family group or
a grouping of all individual brightness groups of only a few brightness groups. Individual brightness groups
cannot be ordered.
Anm.:
Die Standardlieferform von Serientypen beinhaltet entweder eine untere Familiengruppe, eine obere
Familiengruppe oder eine Sammelgruppe, die aus nur wenigen Helligkeitsgruppen besteht. Einzelne
Helligkeitsgruppen sind nicht bestellbar.
2014-04-25
5
Version 2.0
LE UW S2W
Chromaticity Coordinate Groups 2) page 26
Farbortgruppen 2) Seite 26
520
530
540
510
550
0.7
560
0.6
570
500
0.5
580
590
600
610
620
630
0.4
0.3
490
0.2
480
470
460
450
0.1
E
0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9
Cx
7R
7Q
7P
6Q
6R
6P
5P
5Q
5R
4Q
4P
4R
0.25
0.26
0.27
0.28
0.29
0.30
0.31
0.32
0.33
0.34
0.35
0.36
0.37
0.9
Cy 0.8
0.42
Cy 0.41
0.40
0.39
0.38
0.37
0.36
0.35
0.34
0.33
0.32
0.31
0.30
0.29
0.28
0.27
0.26
0.25
0.24
0.23
0.22
0.21
0.20
Cx
OHA03435
Color Chromaticity Groups 2) page 26
Group
Gruppe
4P
5P
6P
2014-04-25
Cx
Cy
Group
Gruppe
0.2787
0.2538
0.2734
0.2607
0.2828
0.2483
0.2787
0.2538
0.2930
0.2824
0.2889
0.2962
0.2756
0.2930
0.2930
0.2824
0.2889
0.2910
0.2962
0.2756
0.2930
0.3072
0.3111
0.3049
0.3090
0.3019
0.3072
0.3072
0.3111
0.3049
0.3223
0.3090
0.3019
0.3072
0.3111
0.3170
0.3182
0.3170
0.3170
0.3309
0.3170
4Q
5Q
6Q
Cx
6
Cy
Group
Gruppe
Cx
Cy
0.2705
0.2647
0.2734
0.2607
0.2910
0.2865
0.2960
0.2824
0.2889
0.2910
0.2865
0.2960
0.2824
0.2889
0.2910
0.3223
0.3035
0.3293
0.3111
0.3049
0.3223
0.3035
0.3293
0.3049
0.3223
0.3309
0.3170
0.3459
0.3459
0.3170
0.3556
4R
5R
6R
Version 2.0
Group
Gruppe
7P
2014-04-25
LE UW S2W
Cx
Cy
Group
Gruppe
0.3170
0.3182
0.3170
0.3309
0.3170
0.3309
0.3170
0.3459
0.3341
0.3652
0.3240
0.3375
0.3601
0.3341
7Q
Cx
7
Cy
Group
Gruppe
Cx
Cy
0.3170
0.3556
0.3220
0.3653
0.3595
0.3300
0.3728
0.3652
0.3341
0.3652
7R
Version 2.0
LE UW S2W
Group Name on Label
Gruppenbezeichnung auf Etikett
Example: PX-4P
Beispiel: PX-4P
Brightness
Helligkeit
Farbort
PX
4P
Note:
No packing unit / tape ever contains more than one group for each selection.
Anm.:
In einer Verpackungseinheit / Gurt ist immer nur eine Gruppe für jede Selektion enthalten.
2014-04-25
8
Version 2.0
LE UW S2W
Relative Spectral Emission - V(λ) = Standard eye response curve 5) page 26
Relative spektrale Emission - V(λ) = spektrale Augenempfindlichkeit 5) Seite 26
Φrel = f (λ); TJ = 25 °C; IF = 700 mA; per Chip
LE UW S2W
Φrel 1.0
: ultra white
: Vλ
0.8
0.6
0.4
0.2
0.0
350
400
450
500
550
600
650
700
750
800
λ [nm]
Radiation Characteristics 5) page 26
Abstrahlcharakteristik 5) Seite 26
Irel = f (ϕ); TJ = 25 °C
40˚
30˚
20˚
10˚
ϕ
0˚
OHL03736
1.0
50˚
0.8
60˚
0.6
70˚
0.4
80˚
0.2
90˚
100˚
2014-04-25
1.0
0.8
0.6
0.4
0˚
9
20˚
40˚
60˚
80˚
100˚
120˚
Version 2.0
LE UW S2W
Relative partial flux 5) page 26
Relativer zonaler Lichtstromanteil 5) Seite 26
ΦV (2ϕ)/ΦV(180°) = f (ϕ); TJ = 25 °C
ΦV(2ϕ) 1.0
ΦV(180°)
0.9
0.8
0.7
0.6
0.5
0.4
0.3
0.2
0.1
0.0
10
40
50
60
70
80
10
90 100 110 120 130 140 150 160 170 180
2*ϕ [°]
Version 2.0
LE UW S2W
Forward Current 5) page 26
Durchlassstrom 5) Seite 26
IF = f (VF); TJ = 25 °C; per Chip
IF [mA]
Relative Luminous Flux 5) page 26 , 6) page 26
Relativer Lichtstrom 5) Seite 26 , 6) Seite 26
ΦV/ΦV (700 mA) = f(IF); TJ = 25 °C; per Chip
ΦV
LE UW S2W
1000
LE UW S2W
1,4
ΦV(700mA)
1,2
800
1,0
0,8
600
0,6
400
0,4
0,2
200
0,0
2,8
3,0
3,2
3,4
Chromaticity Coordinate Shift
Farbortverschiebung 5) Seite 26
Cx, Cy = f(IF); TJ = 25 °C
5) page 26
3,6
LE UW S2W
0,03
: ∆Cx
: ∆Cy
0,02
0,01
0,00
-0,01
-0,02
-0,03
00
10
IF [mA]
2014-04-25
00
10
IF [mA]
VF [V]
∆Cx
∆Cy
11
Version 2.0
LE UW S2W
Relative Forward Voltage 5) page 26
Relative Vorwärtsspannung 5) Seite 26
ΔVF = VF - VF(25 °C) = f(Tj); IF = 700 mA; per
Chip
∆VF [V]
ΦV/ΦV (25 °C) = f(Tj); IF = 700 mA; per Chip
Φv
weiß 125-2
1,2
Φv(25°C)
LE UW S2W
0,3
1,0
0,2
0,8
0,1
0,6
0,0
0,4
-0,1
-0,2
0,2
-0,3
0,0
-40 -20
-40 -20
60
Tj [°C]
2014-04-25
60
80 100 120
Tj [°C]
80 100 120
12
Version 2.0
LE UW S2W
Chromaticity Coordinate Shift 5) page 26
Cx, Cy = f(Tj); IF = 700 mA; per Chip
∆Cx
∆Cy
LE UW S2W
0,03
: ∆ Cx
: ∆ Cy
0,02
0,01
0,00
-0,01
-0,02
-0,03
-40 -20
60
80 100 120
Tj [°C]
2014-04-25
13
Version 2.0
LE UW S2W
Max. Permissible Forward Current
Max. zulässiger Durchlassstrom
IF = f (T); for 4 chips operated
LECWUW S2W
IF [mA] 1100
1000
900
800
700
600
500
400
300
200
100
Donot usebelow100mA
60
80
100
TS [°C]
2014-04-25
14
Version 2.0
LE UW S2W
Package Outline 7) page 26
Maßzeichnung 7) Seite 26
Approximate Weight:
66 mg
Gewicht:
66 mg
Corrosion robustness:
Test conditions: 40 °C / 90 % rh / 15 ppm H2S /
336 h
= Stricter than IEC 60068-2-43 (H 2S) [25°C / 75
% rh / 10 ppm H 2S / 21 days]
= Regarding relevant gas (H2S) stricter than EN
60068-2-60 (method 4) [25 °C / 75 % rh / 200
ppb SO2, 200 ppb NO2,10 ppb Cl2 / 21 days]
Korrosionsfestigkeit:
Test Kondition: 40°C / 90 % rh / 15 ppm H 2S /
336 h
= Besser als IEC 60068-2-43 (H2S) [25°C / 75 %
rh / 10 ppm H2S / 21 Tage]
= Bezogen auf das Gas (H 2S) besser als EN
60068-2-60 (method 4) [25°C / 75 % rh / 200ppb
SO2, 200ppb NO2,10ppb Cl2 / 21 Tage]
Note:
Package not suitable for wetcleaning.
Anm.:
Das Gehäuse ist nicht für nasschemische
Reinigung geeignet.
2014-04-25
15
Version 2.0
LE UW S2W
Electrical Circuit
Elektrisches Ersatzschaltbild
Recommended Solder Pad 7) page 26
Empfohlenes Lötpaddesign 7) Seite 26
2014-04-25
Reflow soldering
Reflow-Löten
16
Version 2.0
LE UW S2W
Note:
For superior solder joint connectivity results we
recommend soldering under standard nitrogen
atmosphere. Package not suitable for any kind
of wet cleaning or ultrasonic cleaning.
Anm.:
Um eine verbesserte Lötstellenkontaktierung zu
erreichen, empfehlen wir, unter StandardStickstoffatmosphäre zu löten. Das Gehäuse ist
für alle Arten einer nasschemischen Reinigung
und Ultraschallreinigung nicht geeignet.
2014-04-25
17
Version 2.0
LE UW S2W
Reflow Soldering Profile
Reflow-Lötprofil
Preconditioning: JEDEC Level 2 acc. to JEDEC J-STD-020D.01
OHA04525
300
˚C
T 250
Tp 245 ˚C
240 ˚C
tP
217 ˚C
200
tL
150
tS
100
50
25 ˚C
100
150
200
250
s 300
t
OHA04612
Profile Feature
Profil-Charakteristik
Symbol
Symbol
Pb-Free (SnAgCu) Assembly
Minimum
Ramp-up rate to preheat*)
25 °C to 150 °C
Time tS
TSmin to TSmax
tS
60
Ramp-up rate to peak*)
TSmax to TP
Recommendation
Maximum
2
3
100
120
2
3
Unit
Einheit
K/s
s
K/s
Liquidus temperature
TL
217
Time above liquidus temperature
tL
80
100
s
Peak temperature
TP
245
260
°C
Time within 5 °C of the specified peak
temperature TP - 5 K
tP
s
3
6
K/s
10
Ramp-down rate*
TP to 100 °C
480
Time
25 °C to TP
All temperatures refer to the center of the package, measured on the top of the component
* slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range
2014-04-25
°C
18
s
Version 2.0
LE UW S2W
Taping 7) page 26
Gurtung 7) Seite 26
2014-04-25
19
Version 2.0
LE UW S2W
Pin - Asignment
Anschlussbelegung
Pin / Anschluss
Description / Function / Beschreibung /
Funktion
1
Cathode; Chip 1
2
Anode; Chip 1
3
Cathode; Chip 2
4
Anode; Chip 2
5
Cathode; Chip 3
6
Anode; Chip 3
7
Cathode; Chip 4
8
Anode; Chip 4
2014-04-25
Version 2.0
LE UW S2W
Tape and Reel
Gurtverpackung
12 mm tape with 500 pcs. on 180 mm reel
W1
D0
P0
A
N
F
W
E
13.0 ±0.25
P2
Label
P1
Direction of unreeling
W2
Leader: min. 400 mm *
Trailer: min. 160 mm *
*) Dimensions acc. to IEC 60286-3; EIA 481-D
OHAY0324
Tape dimensions in mm (inch)
Tape dim ensions in m m ( inch)
W
P0
P1
P2
D0
E
F
12 +0.3/-0.1
4 ± 0.1
(0.157 ±
0.004)
4 ± 0.1
(0.157 ±
0.004)
or
8 ± 0.1
(0.315 ±
0.004)
2 ± 0.05
(0.079 ±
0.002)
1.5 ± 0.1
(0.059 +
0.004)
1.75 ± 0.1
(0.069 ±
0.004)
5.5 ± 0.05
(0.217 ±
0.002)
Reel dimensions in mm (inch)
Reel dim ensions in m m ( inch)
A
W
Nmin
W1
W2max
180 (7)
12 (0.472)
60 (2.362)
12.4 + 2 (0.488 +
0.079)
18.4 (0.724)
2014-04-25
21
Version 2.0
LE UW S2W
Barcode-Product-Label (BPL)
Barcode-Produkt-Etikett (BPL)
OSRAM Opto
EX
A
RoHS Compliant
(6P) BATCH NO: 1234567890
(1T) LOT NO: 1234567890
BIN1: XX-XX-X-XXX-X
LX XXXX
Semiconductors
MP
ML Temp ST
X XXX °C X
(9D) D/C: 1234
Pack: RXX
LE
DEMY
XXX
X_X123_1234.1234 X
(X) PROD NO: 123456789(Q)QTY:
9999
(G) GROUP:
XX-XX-X-X
OHA04563
Dry Packing Process and Materials
Trockenverpackung und Materialien
Moisture-sensitive label or print
Barcode label
L
VE
l
LE
k,
see
labe
code
blan
If
bar
(RH
idity
N s IVE RS
Otain
TO
SIT
UC
TIcon
SEN
U
RH
hum
0%
e
tive d
˚C/6
kag
rela are
30
_
infr pac
of
90% to ak
ns
ed (pe
or
rs
e).
ND
Hou
rs
rs
rs
Hou
and ject
ditio
cod
˚C,
72
sing
Hou
e
5
bag E
48
˚C sub
Hou
con
s UR ICO
ces
24 6
dat
40 be
time
˚C
ory
ThiISTSEM
pro
time
or
23
time
at t will ˚C).
or
l with
fact
ent
MO
Flo
time
s
TO
at
or
at
Flo
l
tica
d
tha
or
ival
ure
nth
OP
Flo
4
if: rea
w
Flo
labe
mo ices
iden
5
ced
equ
el
n
e
5a
is
el
ing,
belo
or
24
pro
6
Lev
e
dev
el
cod
e
unt whe
Lev
el
re
ow,
see
bag
Lev
l dat
re
mo
bak
bar
ned
Lev
refl
istu
10%
re
led
time
sea
for
istu
ore>
re
ope e
Mo
see
istu
k,
is
or .
sea is has k,
Mo
bef
istu
d
033
Mo
in
Flo
RH
blan
Mo
or-p blan in
bag
Car
ing,
r
TDlife
(if
If with
t.
r
lf
10%bak or
J-S
thisvapp.
Yea
_
eks rs
r
ed
icat med, C
1
Yea
tem
She
ow,
at
uire not
y
1
WeHou
unt
DE
Afte
Ind
4
uire
refl
is
red req
bod Mo
/JE
time
168
req
2b
a)
Sto ices idity
time
or
is IPC
or
time
b)
ned Flo
or
Hum ing ce
time
or
Dev 2a
e
Flo
a)
ope
or
3.
b) bakren
Flo
1
l dat
Flo
If
2
refe
time el
2a
4.
el
sea
3
Lev
el
and
Lev
el
re
Bag
e
Lev
re
Lev
istu
Dat
re
istu
re
Mo
istu
Mo
istu
Mo
Mo
A
C
1.
2.
M
RA
OS
Humidity indicator
Barcode label
Please check the HIC immidiately after
bag opening.
Discard if circles overrun.
Avoid metal contact.
Do not eat.
Comparator
check dot
WET
If wet,
examine units, if necessary
bake units
15%
If wet,
bake units
10%
5%
If wet,
parts still adequately dry.
change desiccant
Humidity Indicator
MIL-I-8835
AM
Desiccant
OSR
OHA00539
Note:
Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card.
Regarding dry pack you will find further information in the internet and in the Short Form Catalog in
chapter “Tape and Reel” under the topic “Dry Pack”. Here you will also find the normative references
like JEDEC.
Anm.:
Feuchteempfindliche Produkte sind verpackt in einem Trockenbeutel zusammen mit einem
Trockenmittel und einer Feuchteindikatorkarte.
Bezüglich Trockenverpackung finden Sie weitere Hinweise im Internet und in unserem Short Form
Catalog im Kapitel “Gurtung und Verpackung” unter dem Punkt “Trockenverpackung”. Hier sind
Normenbezüge, unter anderem ein Auszug der JEDEC-Norm, enthalten.
2014-04-25
22
Version 2.0
LE UW S2W
Transportation Packing and Materials
Kartonverpackung und Materialien
Barcode label
DE
MY
8
1
T6
PL 76
R1
Q-
lti LS
TO Y
1+
POU
GR
(G)
Mu
: 01
(9D
D/C
21
00
21
99
8
4
Y:
23
LO
(X)
PR
OD
NO
11
00
(1T
QT
(Q)
H
Se
3G
H1
BA
TC
: 12
(6P
5
NO
T
14
2
O
SR
mi AM
co
nd O
uc pt
to o
rs
NO
see
labe
44
l
k,
N
O
TI
U
A
C
00
L
VE
LE
code (RH
blan
If
y
bar
idit
RH
hum
60%
e
tive d
˚C/
kag
rela are
30
E S
s
_
infr pac
OR
of
tainITIV
90% to ak
urs
CT
e).
or
urs
ted (pe
ons
con NS
Ho
g
urs
SE DU
Ho
and jec
diti
cod
˚C,
72
sin
Ho urs
e
5
bag E ON
48
˚C sub
e
Ho
con
s UR
ces
24 6
dat
e
MIC
40 be
tim
˚C
e
ThiISTSE
pro
tory
tim
or
t
with
23
tim e
at t will ˚C)
or
fac
MO
Flo
al
len
tim
s
TO
at
or
at
Flo
d
or
iva
ure
el
nth s tha
OP
ntic
Flo
4
if: rea
Flo
lab
ow
mo ice equ
ide
5
ced
el
e
5a
is
el
ingen
bel
or
24
pro
6
Lev
e
dev,
el
cod
e
unt wh
Lev
el
re
ow
see
bag
Lev
l dat
re
mo
bak
e
bar
ned
Lev
refl
istu
10%
re
tim
sea
for
istu
ore>
re
ope e
Mo
see
3
istu
is
or .
sea is has
Mo
nk,
bef
istu
nk, Flo
rd
-03
Mo
in
RH
bla
Mo
or-p bla in
bag
ingCa
r
TD
life
(if
If with
t.
r
lf
vapp.
10%baktor
J-S
this
Yea
_
eks
r
ed
ica med, C
1
urs
Yea
tem
She
ow
at
uire not
y
1
WeHo
unt
DE
Afte
Ind
1.
e
4
uire
refl
red req
2.
bod Mo
e
ity is
/JE
tim
s
168
req
e
2b
a)
Sto
tim
or
mid
is IPC
tim e
vice or
b)
ned Flo
or
Hu
tim
ing ce
or
De
e
2a
Flo
a)
ope
or
3.
b) bakren
Flo
e
1
l dat
Flo
If
2
el
refe
tim
2a
4.
el
sea
3
Lev
el
and
Lev
el
re
Bag
te
Lev
re
Lev
istu
Da
re
istu
re
Mo
istu
Mo
istu
Mo
Mo
P:
Muster
ED Bin
Bin 1:
Bin 2: P-1
3: Q-1 -20
ML
-20
2
Tem
2a
220
3
240 p ST
Ad 260 C R
C
R0 diti
R
ona C RT
PA 77
l TE
CK
VA
XT
R:
Barcode label
DE
MY
1
T6
PL 76
R1
8
lti LS
TO Y
Mu
1+
Q-
P:
PGR
(G)
44
: 01
D/C
(9D
QT
Y:
LO
(1T
NO
OD
Packing
Sealing label
Dimensions of transportation box in mm (inch):
Width / Breite
Length / Länge
Height / Höhe
195 ± 5 (7.677 ± 0.1968)
195 ±5 (7,677 ±0,1968)
30 ± 5 (1.181 ± 0.196)
2014-04-25
M
RA
OS
(X)
PR
5
14 2
110 0
(Q)
ico AM
nd O
uc pt
to o
rs
SR
NO
23
4
m
O
H
H1
Se
3G
TC
998
NO
: 12
BA
021
T
(6P
210
OU
Muster
ED Bin
Bin 1:
Bin 2: P-1
3: Q-1 -20
ML
-20
2
Te
2a
220 mp
3
240
ST
Ad 260 C R
C
R0 diti
R
ona C RT
PA 77
l TE
CK
VA
XT
R:
led
23
OHA02044
Version 2.0
LE UW S2W
Notes
Hinweise
The evaluation of eye safety occurs according to the
standard IEC 62471:2008 ("photobiological safety of
lamps and lamp systems"). Within the risk grouping
system of this CIE standard, the LED specified in this
data sheet fall into the class Moderate risk (exposure
time 0.25 s). Under real circumstances (for exposure
time, eye pupils, observation distance), it is
assumed that no endangerment to the eye exists
from these devices. As a matter of principle,
however, it should be mentioned that intense light
sources have a high secondary exposure potential
due to their blinding effect. As is also true when
viewing other bright light sources (e.g. headlights),
temporary reduction in visual acuity and afterimages
can occur, leading to irritation, annoyance, visual
impairment, and even accidents, depending on the
situation.
Die Bewertung der Augensicherheit erfolgt nach
dem Standard IEC 62471:2008 ("photobiological
safety of lamps and lamp systems"). Im
Risikogruppensystem dieser CIE- Norm erfüllen die
in diesem Datenblatt angegebenen LEDs folgende
Gruppenanforderung - Moderate risk
(Expositionsdauer 0,25 s). Unter realen Umständen
(für Expositionsdauer, Augenpupille,
Betrachtungsabstand) geht damit von diesen
Bauelementen keinerlei Augengefährdung aus.
Grundsätzlich sollte jedoch erwähnt werden, dass
intensive Lichtquellen durch ihre Blendwirkung ein
hohes sekundäres Gefahrenpotenzial besitzen.
Nach einem Blick in eine helle Lichtquelle (z.B.
Autoscheinwerfer), kann ein temporär
eingeschränktes Sehvermögen oder auch
Nachbilder zu Irritationen, Belästigungen,
Beeinträchtigungen oder sogar Unfällen führen.
Subcomponents of this LED contain, among other
substances, goldplated and Ag-filled materials. In
spite of the improved corrosion stability of this LED,
it can be affected by environments that contain very
high concentrations of aggressive substances.
Therefore, we recommend avoiding aggressive
atmospheres during storage, production and use.
Einzelkomponenten dieser LED enthalten u.a.
goldbeschichtete und Ag-gefüllte Materialien. Trotz
der verbesserten Korrosionsstabilität dieser LED
können Einzelkomponenten durch sehr hohe
Konzentration aggressiver Substanzen angegriffen
werden. Aus diesem Grund wird empfohlen,
aggressive Umgebungen während der Lagerung,
Produktion und im Betrieb zu vermeiden.
2014-04-25
24
Version 2.0
LE UW S2W
Disclaimer
Disclaimer
Attention please!
The information describes the type of component and
shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved.
Due to technical requirements components may contain
dangerous substances.
For information on the types in question please contact
our Sales Organization.
If printed or downloaded, please find the latest version in
the Internet.
Packing
Please use the recycling operators known to you. We
can also help you – get in touch with your nearest sales
office.
By agreement we will take packing material back, if it is
sorted. You must bear the costs of transport. For
packing material that is returned to us unsorted or which
we are not obliged to accept, we shall have to invoice
you for any costs incurred.
Components used in life-support devices or
systems must be expressly authorized for such
purpose!
Critical components* may only be used in life-support
devices** or systems with the express written approval
of OSRAM OS.
Bitte beachten!
Lieferbedingungen und Änderungen im Design
vorbehalten. Aufgrund technischer Anforderungen
können die Bauteile Gefahrstoffe enthalten. Für weitere
Informationen zu gewünschten Bauteilen, wenden Sie
sich bitte an unseren Vertrieb. Falls Sie dieses
Datenblatt ausgedruckt oder heruntergeladen haben,
finden Sie die aktuellste Version im Internet.
Verpackung
Benutzen Sie bitte die Ihnen bekannten Recyclingwege.
Wenn diese nicht bekannt sein sollten, wenden Sie sich
bitte an das nächstgelegene Vertriebsbüro. Wir nehmen
das Verpackungsmaterial zurück, falls dies vereinbart
wurde und das Material sortiert ist. Sie tragen die
Transportkosten. Für Verpackungsmaterial, das
unsortiert an uns zurückgeschickt wird oder das wir nicht
annehmen müssen, stellen wir Ihnen die anfallenden
Kosten in Rechnung.
Bauteile, die in lebenserhaltenden Apparaten und
Systemen eingesetzt werden, müssen für diese
Zwecke ausdrücklich zugelassen sein!
Kritische Bauteile* dürfen in lebenserhaltenden
Apparaten und Systemen** nur dann eingesetzt
werden, wenn ein schriftliches Einverständnis von
OSRAM OS vorliegt.
*) A critical component is a component used in a
life-support device or system whose failure can
reasonably be expected to cause the failure of that
life-support device or system, or to affect its safety or the
effectiveness of that device or system.
**) Life support devices or systems are intended (a) to be
implanted in the human body, or (b) to support and/or
maintain and sustain human life. If they fail, it is
reasonable to assume that the health and the life of the
user may be endangered.
*) Ein kritisches Bauteil ist ein Bauteil, das in
lebenserhaltenden
Apparaten
oder
Systemen
eingesetzt wird und dessen Defekt voraussichtlich zu
einer Fehlfunktion dieses lebenserhaltenden Apparates
oder Systems führen wird oder die Sicherheit oder
Effektivität
dieses
Apparates
oder
Systems
beeinträchtigt.
**) Lebenserhaltende Apparate oder Systeme sind für
(a) die Implantierung in den menschlichen Körper oder
(b) für die Lebenserhaltung bestimmt. Falls Sie
versagen, kann davon ausgegangen werden, dass die
Gesundheit und das Leben des Patienten in Gefahr ist.
2014-04-25
25
Version 2.0
LE UW S2W
Glossary
Glossar
1)
Brightness: Brightness values are measured during
a current pulse of typically 25 ms, with an internal
reproducibility of ± 8 % and an expanded uncertainty
of ± 11 % (acc. to GUM with a coverage factor of
k = 3).
1)
Helligkeit: Helligkeitswerte werden während eines
Strompulses einer typischen Dauer von 25 ms, mit
einer internen Reproduzierbarkeit von ± 8 % und
einer erweiterten Messunsicherheit von ± 11 %
gemessen (gemäß GUM mit Erweiterungsfaktor
k = 3).
2)
Chromaticity coordinate groups: Chromaticity
coordinates are measured during a current pulse of
typically 25 ms, with an internal reproducibility of
± 0.005 and an expanded uncertainty of ± 0.01 (acc.
to GUM with a coverage factor of k = 3).
2)
Farbortgruppen: Farbkoordinaten werden während
eines Strompulses einer typischen Dauer von 25 ms,
mit einer internen Reproduzierbarkeit von ± 0,005
und einer erweiterten Messunsicherheit von ± 0,01
k = 3).
3)
Forward Voltage: The forward voltage is measured
during a current pulse of typically 8 ms, with an
internal reproducibility of ± 0.05 V and an expanded
uncertainty of ± 0.1 V (acc. to GUM with a coverage
factor of k = 3).
3)
Durchlassspannung: Vorwärtsspannungen
werden während eines Strompulses einer typischen
Dauer
von
8 ms,
mit
einer
internen
Reproduzierbarkeit von ± 0,05 V und einer
erweiterten Messunsicherheit von ± 0,1 V gemessen
(gemäß GUM mit Erweiterungsfaktor k = 3).
4)
Thermal Resistance: Rth max is based on statistic
values (6σ).
4)
Wärmewiderstand: Rth
statistischen Werten (6σ).
5)
Typical Values: Due to the special conditions of the
manufacturing processes of LED, the typical data or
calculated correlations of technical parameters can
only reflect statistical figures. These do not
necessarily correspond to the actual parameters of
each single product, which could differ from the
typical data and calculated correlations or the typical
characteristic line. If requested, e.g. because of
technical improvements, these typ. data will be
changed without any further notice.
5)
Typische Werte: Wegen
der
besonderen
Prozessbedingungen bei der Herstellung von LED
können typische oder abgeleitete technische
Parameter nur aufgrund statistischer Werte
wiedergegeben werden. Diese stimmen nicht
notwendigerweise mit den Werten jedes einzelnen
Produktes überein, dessen Werte sich von typischen
und abgeleiteten Werten oder typischen Kennlinien
unterscheiden können. Falls erforderlich, z.B.
aufgrund technischer Verbesserungen, werden
diese typischen Werte ohne weitere Ankündigung
geändert.
6)
Relative Brightness Curve: In the range where the
line of the graph is broken, you must expect higher
brightness differences between single LEDs within
one packing unit.
6)
Relative Helligkeitskurve: Im
gestrichelten
Bereich der Kennlinien muss mit erhöhten
Helligkeitsunterschieden zwischen Leuchtdioden
innerhalb einer Verpackungseinheit gerechnet
werden.
7)
Tolerance of Measure: Unless otherwise noted in
drawing, tolerances are specified with ±0.1 and
dimensions are specified in mm.
7)
Maßtoleranz: Wenn in der Zeichnung nicht anders
angegeben, gilt eine Toleranz von ±0,1. Maße
werden in mm angegeben.
2014-04-25
26
max
basiert
auf
Version 2.0
LE UW S2W
Published by OSRAM Opto Semiconductors GmbH
Leibnizstraße 4, D-93055 Regensburg
www.osram-os.com © All Rights Reserved.
2014-04-25
27
