SANGDEST
MICROELECTRONICS
MBRF30200CT
Green Products
Technical Data
Data Sheet N0855, Rev. A
MBRF30200CT SCHOTTKY RECTIFIER
Applications:
Switching power supply
Converters
Free-Wheeling diodes
Reverse battery protection
Features:
150 °C T J operation
Center tap configuration
Low forward voltage drop
High purity, high temperature epoxy encapsulation for enhanced
mechanical strength and moisture resistance
High frequency operation
Guard ring for enhanced ruggedness and long term reliability
This is a Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
OUTLINE DRAWING
Mechanical Dimensions: In mm
Dim
A
OPTION 1(CJ)
Min
Max
4.4
4.6
OPTION 2(HD)
Min
Max
4.30
4.70
b
0.6TYP
0.50
0.75
b1
1.3TYP
1.30
1.40
b2
1.7TYP
1.70
1.80
b3
1.6TYP
1.50
1.75
b4
1.2TYP
1.10
1.35
C
0.60TYP
0.50
0.75
D
14.8
15.1
14.80
15.20
E
10.06
10.26
9.96
10.36
e
2.55TYP
2.54TYP
F
2.9
3.1
2.80
3.20
G
6.5
6.9
6.50
6.90
L
12.7
13.7
12.8
13.2
L1
3.4
3.8
3.60
4.00
L2
2.6
3.0
Q
2.5
2.9
2.50
2.90
Q1
2.5
2.9
ØR
3.5REF
2.70REF
3.50REF
• Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113 (86) 25-87123907 •
• FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn •
SANGDEST
MICROELECTRONICS
MBRF30200CT
Green Products
Technical Data
OPTION 3
OPTION 4
Dim
Min
Max
Min
Max
A
4.53
4.93
4.50
4.90
b
0.71
0.91
0.70
0.90
b1
1.15
1.39
1.33
1.47
C
0.36
0.53
0.45
0.60
D
15.67
16.07
15.67
16.07
E
9.96
10.36
9.96
10.36
e
2.54TYP
2.54 BSC
F
2.34
2.76
2.34
2.74
G
6.50
6.90
6.48
6.88
L
12.37
12.77
12.78
13.18
L1
2.23
2.63
3.03
3.43
Q
2.56
2.96
2.56
2.96
Q1
3.10
3.50
3.10
3.50
ØR
2.98
3.38
3.08
3.28
SANGDEST
MICROELECTRONICS
MBRF30200CT
Green Products
Technical Data
OPTION 5 (SR)
ITO-220AB
SANGDEST
MICROELECTRONICS
MBRF30200CT
Green Products
Technical Data
Marking Diagram:
Where XXXXX is YYWWL
MBR
F
30
200
CT
SSG
YY
WW
L
= Device Type
= Package type
= Forward Current (30A)
= Reverse Voltage (200V)
= Configuration
= SSG
= Year
= Week
= Lot Number
Cautions:Molding resin
Epoxy resin UL:94V-0
Ordering Information:
Device
Package
ITO-220AB
(Pb-Free)
MBRF30200CT
Shipping
50pcs / tube
For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging
Specification.
Maximum Ratings:
Characteristics
Peak Inverse Voltage
Max. Average Forward
Current
Peak Repetitive Forward
Current (per leg)
Max. Peak One Cycle NonRepetitive Surge Current
(per leg)
Symbol
VRWM
IF(AV)
IFRM
IFSM
Condition
50% duty cycle @TC =133°C,
rectangular wave form
Rated VR square wave
20KHz TC =133°C
Max.
200
Units
V
30
A
A
8.3 ms, half Sine pulse
150
A
SANGDEST
MICROELECTRONICS
MBRF30200CT
Green Products
Technical Data
Electrical Characteristics:
Characteristics
Max. Forward Voltage Drop
(per leg)*
Max. Reverse Current (per
leg)*
Symbol
Units
@ 15A, Pulse, TJ = 25 °C
0.90
V
VF2
@ 15 A, Pulse, TJ = 125 °C
@VR = rated VR
TJ = 25 °C
@VR = rated VR
TJ = 125 °C
@VR = 5V, TC = 25 °C
fSIG = 1MHz
Clip mounting, the epoxy body
away from the heatsink edge by
more than 0.110" along the lead
direction.
Clip mounting, the epoxy body is
inside the heatsink.
Screw mounting, the epoxy body
is inside the heatsink.
0.75
V
1.0
mA
6.0
mA
400
pF
10,000
V/µs
IR1
CT
dv/dt
VISO
Max.
VF1
IR2
Max. Junction Capacitance
(per leg)
Max. Voltage Rate of Change
RSM Isolation Voltage
(t = 1.0 second, R. H. < =30%,
TA = 25 °C)
Condition
4500
V
3500
1500
Pulse Width < 300µs, Duty Cycle
很抱歉,暂时无法提供与“MBRF30200CT”相匹配的价格&库存,您可以联系我们找货
