1000 Eaton Boulevard
Cleveland, OH 44122
United States
OmniVS 120V 800VA 475W Line-Interactive UPS,
Tower, USB port
MODEL NUMBER: OMNIVS800
Highlights
800VA tower 120V line
interactive UPS
Corrects brownouts as low as
89V without using battery power
6 UPS battery supported outlets,
1 surge-only outlet
USB port, TEL/DSL/ethernet
protection
NEMA 5-15P input plug and 7
NEMA 5-15R outlets
Package Includes
Description
Tripp Lite's OMNIVS800 line interactive UPS system offers voltage regulation, surge suppression and long
lasting battery support for personal computers, inter-networking equipment and other sensitive electronics.
Internal UPS circuits support entry level PC systems for up to 60 minutes during power failures so that
connected equipment can be shut down without data loss. Automatic Voltage Regulation (AVR) circuits
regulate brownouts as low as 89 volts back to usable levels without using battery power. Offers complete
desktop power protection in an attractive black tower configuration. Includes 6 battery supported outlets
for computer, monitor and one vital system peripheral, plus 1 additional surge suppression-only outlet for
printers and other system accessories not requiring battery support. HID-compliant USB port enables
optional unattended system shutdown without data loss in case of extended power failure; USB cable
included. HID-compliant USB port also enables direct integration with built-in power management and
auto-shutdown features of Windows and MAC OS X. PowerAlert software available via free download.
Built-in single line phone/Ethernet suppression jacks protect modem, fax machine, cordless phone or
other peripheral with a standard dialup, DSL, or data line connection. Built-in audible alarm and 4 front
panel LEDs indicate line power status, battery power status, battery low/replace status and voltage boost
operation. 800VA/475 watt power handling ability supports entry-level PCs, network workstations, point-ofsale equipment, small business phone systems, audio/video equipment and home theater systems. Offers
3.5 minutes battery runtime with a full load of 800VA and 11.5 minutes with a half load of 400VA. Supports
battery replacement via built-in access panel. $200,000 Ultimate Lifetime Insurance (U.S., Canada, and
Puerto Rico only)
Features
OMNIVS800 Uninterruptible Power Supply offers voltage regulation, surge suppression and long lasting
battery support
Supports entry level PCs up to 60 minutes during blackouts to enable shutdown without data loss
Regulates brownouts as low as 89 volts back to usable levels without using battery power
6 UPS battery supported/surge protected outlets, plus 1 additional surge suppression-only outlet
USB port enables data-saving unattended shutdown when used with Tripp Lite's PowerAlert software,
available via FREE download from tripplite.eaton.com/products/power-alert
HID-compliant USB port also enables direct integration with built-in power management and autoshutdown features of Windows and Mac OS X
Single line phone/Ethernet suppression jacks protects standard dialup/DSL, or Ethernet connections
Audible alarm and 4 front panel LEDs offer complete UPS and line power status information
1/5
OMNIVS800 Line Interactive
UPS
USB and telephone cable
User manual with warranty
information
Cleveland, OH 44122
United States
800VA/475 watt power handling ability supports a variety of sensitive electronic equipment
3.5 minutes full load runtime (800VA), 11.5 minutes half load runtime (400VA)
Supports battery replacement via built-in access panel
Optional PDUB15 bypass PDU enables hot-swappable UPS replacement with no disruption to
connected equipment
$200,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only)
Specifications
OVERVIEW
UPC Code
037332120953
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
12A
Nominal Input Voltage(s) Supported
120V AC
UPS Input Connection Type
5-15P
UPS Input Cord Length (ft.)
6
UPS Input Cord Length (m)
1.8
Recommended Electrical Service
15A 120V
OUTPUT
Output Capacity (VA)
800
Output Capacity (kVA)
0.8
Output Capacity (Watts)
475
Output Capacity (kW)
0.475
Nominal Voltage Details
115v nominal output in battery mode
Frequency Compatibility
60 Hz
Output Voltage Regulation (Battery
Mode)
+/- 5%
UPS Output Receptacles (Surge
Suppression Only)
6 UPS outlets, 1 surge-only outlet
Hot-Swap PDU options
PDUB15 (2U / 8 5-15R outlets)
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
PWM sine wave
Nominal Output Voltage(s)
Supported
110V; 115V; 120V
2/5
Cleveland, OH 44122
United States
Output Receptacles
(7) 5-15R
Individually Controllable Load Banks
No
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
3.5 min. (475W)
Runtime Half Load (min.)
11.5 min. (238W)
Expandable Runtime
No
DC System Voltage (VDC)
12
Battery Recharge Rate (Included
Batteries)
Less than 4.5 hours from 10% to 90%
Battery Access
Battery access door
Internal UPS Replacement Battery
Cartridge
RBC51
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with input voltage as low as 89
Undervoltage Correction
Input voltages between 89 and 105 are boosted by 14%
USER INTERFACE, ALERTS & CONTROLS
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status
Audible Alarm
Audible alarm indicates power-failure and low-battery conditions
LED Indicators
4 LEDs indicate line power, battery power, overload and battery low/replace status
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
510
UPS AC Suppression Response
Time
Instantaneous
UPS Dataline Suppression
1 line TEL/DSL (1 in / 1 out); 10/100Base T Ethernet
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Tower
Installation Form Factors Supported
with Included Accessories
Tower
with Optional Accessories
Wallmount ( UPSWM - tower mounting kit)
3/5
Cleveland, OH 44122
United States
Primary UPS Depth (mm)
191
Primary UPS Height (mm)
274
Primary UPS Width (mm)
132
Shipping Dimensions (hwd / in.)
8.70 x 13.90 x 7.70
Shipping Dimensions (hwd / cm)
22.10 x 35.31 x 19.56
Shipping Weight (lbs.)
17.50
Shipping Weight (kg)
7.94
UPS Housing Material
PVC
UPS Power Module Dimensions
(hwd, cm)
27.43 x 13.21 x 19.05
(hwd, in.)
10.8 x 5.2 x 7.5
UPS Power Module Weight (kg)
7.21
UPS Power Module Weight (lbs.)
15.9
Unit Weight (lbs.)
15.2500
Unit Weight (kg)
6.92
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
24
Battery Mode BTU / Hr. (Full Load)
631
AC Mode Efficiency Rating (100%
Load)
97%
COMMUNICATIONS
PowerAlert Software
For local monitoring via the UPS’s built-in USB ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB interface cable included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Network UPS Tools (NUT)
Compatibility
NUT compatible. See a full list of NUT compatible Tripp Lite UPS systems at https://networkupstools.org/stablehcl.html?manufacturer=Tripp%20Lite
Network Management Card
Description
Network management not supported
Communications Interface
USB (HID enabled)
LINE / BATTERY TRANSFER
Transfer Time
2-4 milliseconds
4/5
Cleveland, OH 44122
United States
Low Voltage Transfer to Battery
Power (Setpoint)
89
High Voltage Transfer to Battery
Power (Setpoint)
139
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Automatic Voltage Regulation (AVR); Hot swappable batteries; Surge/noise protection
Green Energy-Saving Features
Greater than 95% efficiency - GREEN UPS
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); NOM (Mexico); UL 1778
Product Compliance
RoHS; FCC Part 15 Class B (USA)
WARRANTY & SUPPORT
Product Warranty Period (U.S. &
Canada)
3-year limited warranty
Product Warranty Period (Latin
America)
(International)
2-year limited warranty
Product Warranty Period (Mexico)
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
Insurance
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
