1000 Eaton Boulevard
Cleveland, OH 44122
United States
TAA-Compliant OmniVS 120V 1500VA 940W
Line-Interactive UPS, Extended Run, Tower, USB
port
Highlights
Federal Trade Agreements Act /
TAA Compliant for GSA
Schedule purchases
1500VA / 1.5kVA tower 120V
line interactive extended-run
UPS
Corrects brownouts and
overvoltages from 75 to 147V
6 UPS battery supported outlets,
2 surge-only outlets
USB port, TEL/DSL/ethernet
protection, External battery pack
options
NEMA 5-15P input plug and 8
NEMA 5-15R outlets
MODEL NUMBER: OMNIVS1500XLTAA
Package Includes
Description
Tripp Lite's OMNIVS1500XLTAA is compliant with the Federal Trade Agreements Act (TAA) for GSA
Schedule purchases. This line interactive UPS system offers voltage regulation, surge suppression and
long lasting, expandable battery support for personal computers, internetworking equipment and other
sensitive electronics. Internal UPS batteries support entry level PC systems for up to 75 minutes during
power failures so that connected equipment can be shut down without data loss. Automatic Voltage
Regulation (AVR) circuits regulate brownouts as low as 75 and overvoltages up to 147 volts back to
usable 120V levels without using battery power. Offers complete desktop power protection in an attractive
black tower configuration. Includes 6 battery supported outlets for computer, monitor and vital system
peripherals, plus 2 additional surge suppression only outlets for printers and other system accessories not
requiring battery support. USB port enables optional unattended system shutdown without data loss in the
case of extended power failure (USB cable included). PowerAlert software available via free download.
Built-in data line suppression offers protection for equipment with single line TEL/DSL or network Ethernet
connection. Built-in audible alarm and 5 front panel LEDs indicate status of line power, battery power,
battery low/replace, voltage regulation and overload. 1500VA power handling ability supports entry-level
PCs, network workstations, point-of-sale equipment, small business phone systems, audio/video
equipment and home theater systems. Offers 4 minutes battery runtime with a full load of 1500VA and
11.4 minutes with a half load of 750VA. Supports hot-swappable battery replacement via built-in access
panel. Extended runtime available with optional BP24V15RT2U, BP24V28-2U, or BP24V70-3U external
battery packs.
Features
Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases
OMNIVS1500XLTAA Uninterruptible Power Supply offers voltage regulation, surge suppression and
long lasting battery support
Supports entry level PCs up to 75 minutes during blackouts to enable shutdown without data loss
Regulates brownouts as low as 75V and overvoltages to 147V back to usable 120V nominal levels
6 UPS battery supported outlets, plus 2 additional surge suppression-only outlets
USB port enables data-saving unattended shutdown when used with Tripp Lite's PowerAlert software,
available via FREE download from tripplite.eaton.com/products/power-alert
Data line surge suppression protects standard dialup/DSL or Ethernet line connection
1/5
OMNIVS1500XLTAA TAA
Compliant Line Interactive UPS
USB and telephone cable
Owner's manual with warranty
information
Cleveland, OH 44122
United States
Built-in audible alarm and 5 front panel LEDs indicate status of line power, battery power, battery
1500VA power handling ability supports a variety of sensitive electronic equipment
4 minutes full load runtime (940 watts), 11.4 minutes half load runtime (470 watts)
Runtime is expandable with the addition of external battery packs
Supports hot swappable battery replacement via built-in access panel
$200,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only)
Specifications
OVERVIEW
UPC Code
037332152725
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
12A
Nominal Input Voltage(s) Supported
120V AC
UPS Input Connection Type
5-15P
UPS Input Cord Length (ft.)
6
UPS Input Cord Length (m)
1.8
Recommended Electrical Service
15A 120V
OUTPUT
Output Capacity (VA)
1500
Output Capacity (kVA)
1.5
Output Capacity (Watts)
940
Output Capacity (kW)
0.94
Output Capacity Details
940W watts maximum when used with internal batteries or 1 BP24V15RT2U battery pack; Output is reduced to
600W maximum in all other external battery pack configurations
Nominal Voltage Details
115v nominal output in battery mode
Frequency Compatibility
60 Hz
Output Voltage Regulation (Line
Mode)
-18%, +8%
Output Voltage Regulation (Battery
Mode)
+/- 5%
UPS Output Receptacles (Surge
Suppression Only)
6 UPS outlets, 2 surge-only outlets
Output AC Waveform (AC Mode)
Sine wave
2/5
Cleveland, OH 44122
United States
Output AC Waveform (Battery
Mode)
PWM sine wave
Nominal Output Voltage(s)
Supported
110V; 115V; 120V
Output Receptacles
(8) 5-15R
Individually Controllable Load Banks
No
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
4 min. (940W)
Runtime Half Load (min.)
11.4 min. (470W)
Expandable Runtime
Yes
External Battery Pack Compatibility
BP24V15RT2U (limit 1); BP24V28-2U (limit 1); BP24V70-3U (multi-pack
compatible)
DC System Voltage (VDC)
24
Battery Recharge Rate (Included
Batteries)
Less than 4.5 hours from 10% to 90%
Battery Access
Battery access door
Internal UPS Replacement Battery
Cartridge
RBC24-SLT
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 75 to 147
Overvoltage Correction
Input voltages between 128 and 147 are reduced by 12%
Undervoltage Correction
Input voltages between 93 and 107 are boosted by 14%
Severe Undervoltage Correction
Input voltages between 75 and 92 are boosted by 30%
USER INTERFACE, ALERTS & CONTROLS
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status
Audible Alarm
Audible alarm indicates power-failure and low-battery conditions
LED Indicators
5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
510
UPS AC Suppression Response
Time
Instantaneous
3/5
Cleveland, OH 44122
United States
UPS Dataline Suppression
1 line TEL/DSL (1 in / 1 out); 10/100Base T Ethernet
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Tower
Cooling Method
Fan
Installation Form Factors Supported
with Included Accessories
Tower
with Optional Accessories
Wallmount ( UPSWM - tower mounting kit)
Primary UPS Depth (mm)
191
Primary UPS Height (mm)
300
Primary UPS Width (mm)
183
Shipping Dimensions (hwd / in.)
15.50 x 10.50 x 10.60
Shipping Dimensions (hwd / cm)
39.37 x 26.67 x 26.92
Shipping Weight (lbs.)
31.00
Shipping Weight (kg)
14.06
UPS Housing Material
Polycarbonate
UPS Power Module Dimensions
(hwd, cm)
29.97 x 18.29 x 19.05
(hwd, in.)
11.8 x 7.2 x 7.5
UPS Power Module Weight (kg)
12.70
UPS Power Module Weight (lbs.)
28
Unit Weight (lbs.)
28.0000
Unit Weight (kg)
12.70
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
205
Battery Mode BTU / Hr. (Full Load)
611
AC Mode Efficiency Rating (100%
Load)
90%
COMMUNICATIONS
PowerAlert Software
For local monitoring via the UPS’s built-in USB port, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
4/5
Cleveland, OH 44122
United States
Communications Cable
USB cable included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Network Management Card
Description
Network management not supported
Communications Interface
USB
LINE / BATTERY TRANSFER
Transfer Time
2-4 milliseconds
Low Voltage Transfer to Battery
Power (Setpoint)
75
High Voltage Transfer to Battery
Power (Setpoint)
147
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Automatic Voltage Regulation (AVR); Expandable battery backup; Hot swappable batteries; Surge/noise protection
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); NOM (Mexico); UL 1778
Product Compliance
RoHS; FCC Part 15 Class B (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period (U.S. &
Canada)
3-year limited warranty
Product Warranty Period (Latin
America)
(International)
2-year limited warranty
Product Warranty Period (Mexico)
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
Insurance
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
