1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartPro 230V 700VA 450W Medical-Grade LineInteractive Tower UPS with 6 Outlets, Full
Isolation, USB, DB9
Highlights
Supports a half load up to 36
minutes; full load up to 14.5
minutes
Six IEC320 C13 hospital-grade
outlets and IEC320 C14
hospital-grade plug
Leakage current less than 100
microamps
Approved for use within the
Patient Care Vicinity
Approved to EN60601-1-2:2015,
4th Edition
340 joule surge suppression
rating protects connected
equipment
Alarm mute/alarm quiet control
is ideal for use around patients
MODEL NUMBER: SMX700HG
Package Includes
Provides UL 60601-1 compliant, medical-grade 700VA/450W power backup, ideal for use in patient-care
vicinities. The built-in isolation transformer offers full isolation while maintaining AC surge protection in all
modes.
Description
Tripp Lite’s SMX700HG medical-grade UPS system provides dependable battery backup and is fully
compliant with UL 60601-1 regulations when plugged into a hospital-grade outlet, making it ideal for use in
patient-care vicinities. The 700VA/450W capacity provides up to 36 minutes of runtime for a half load, or
14.5 minutes for a full load so you can work through short power failures and perform an orderly system
shutdown in a prolonged blackout.
Built-in line-interactive voltage regulation corrects brownouts as low as 155V and overvoltages as high as
274V to normal 230V nominal output, without drawing battery power. The SMX700HG’s built-in isolation
transformer with Faraday shield offers full isolation and removes common mode noise while maintaining
full AC surge suppression in all modes. Cumulative leakage current of all connected equipment is less
than 100 microamps.
This UPS system features six IEC320 C13 hospital-grade outlets and has a hospital-grade IEC320 C14
plug on a 15 cm (6 in.) dongle. All six outlets provide both backup protection and surge protection, rated to
340 joules.
The SMX700HG also features diagnostic LEDs, as well as a USB port and a DB9 serial port that work
with Tripp Lite’s free downloadable PowerAlert software for safe, unattended system shutdown and file
saves in the event of a prolonged power failure.
Application Usage
This UPS contains a lead acid battery designed to be connected continuously to an AC power source,
except during brief power outages. It is not intended for frequent charge/discharge cycles, such as mobile
cart applications where the UPS is often disconnected from the power source. Using the SMX700HG in
this type of application will void the battery warranty.
Features
Provides Ideal UPS Backup in Healthcare Facilities
● Compliant with UL 60601-1 standards for use in patient-care vicinities, when plugged into a hospitalgrade outlet
Built-in isolation transformer with Faraday shield offers full isolation and removes common mode noise
Battery Backup and Full Surge Protection
1/5
SMX700HG 700VA/450W
Medical-Grade Tower UPS
System
USB monitoring cable, 1.8 m (6
ft.)
DB9 serial monitoring cable, 1.8
m (6 ft.)
Owner’s Manual
Cleveland, OH 44122
United States
36 minutes runtime for half load (225W); 14.5 minutes for full load (450W)
All six hospital-grade outlets provide surge protection rated to 340 joules
EMI/RFI noise filtering ensures equipment runs smoothly without line noise interference
Resistant to electrostatic discharge
LEDs and Audible Alarms Keep You Aware of Power Status
● Indicator lights on the front of the unit show you when the UPS is on and supplying utility power, when
operating in voltage correction mode or in battery mode, relative load level and low-battery warning
Audible alarms alert you to power failure, overload and low battery conditions; the alarm’s mute/quiet
mode ensures patients are not disturbed
Saves Your Files, Even When You’re Away
● Works with Tripp Lite PowerAlert software (available as a free download) to enable safe, unattended
system shutdown and files saves during prolonged power failures
Connects to your computer via either the DB9 port or USB port
Specifications
OVERVIEW
UPC Code
037332140418
UPS Type
Line-Interactive
INPUT
Rated input current (Maximum Load)
3.6A
Nominal Input Voltage(s) Supported
230V AC
UPS Input Connection Type
C14 inlet
UPS Input Cord Length (ft.)
0.50
UPS Input Cord Length (m)
0.2
Recommended Electrical Service
10A 230V
Voltage Compatibility (VAC)
230
Input Phase
Single-Phase
OUTPUT
Output Capacity (VA)
700
Output Capacity (kVA)
0.7
Output Capacity (Watts)
450
Output Capacity (kW)
0.45
Nominal Voltage Details
230v nominal inverter output voltage
Frequency Compatibility
50 / 60 Hz
Frequency Compatibility Details
Automatic frequency selection
2/5
Cleveland, OH 44122
United States
Output Voltage Regulation (Line
Mode)
-18%, +8%
Output AC Waveform (Battery
Mode)
PWM sine wave
Nominal Output Voltage(s)
Supported
220V; 230V; 240V
Output Receptacles
(6) C13
Individually Controllable Load Banks
No
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
14.5 min. (450W)
Runtime Half Load (min.)
36 min. (225W)
Expandable Runtime
No
DC System Voltage (VDC)
36
Battery Recharge Rate (Included
Batteries)
Less than 3.6 hours from 10% to 90% (typical, full load discharge)
Battery Access
Battery access door allows hot swap battery replacement without powering connected equipment off
Internal UPS Replacement Battery
Cartridge
RBC36SLT
Typical Battery Lifespan
3-6 years, depending on usage
VOLTAGE REGULATION
Voltage Regulation Description
Line interactive UPS offers 2 boost levels of brownout correction and a single level of overvoltage adjustment to
maintain usable, computer grade output without consuming battery power over an input voltage range of 155 to
274V AC
Overvoltage Correction
Input voltages between 206 and 245V AC are reduced by 9%
Undervoltage Correction
Input voltages between 183 and 199 are boosted by 10%
Severe Undervoltage Correction
Input voltages between 155 and 182 are boosted by 21%
USER INTERFACE, ALERTS & CONTROLS
Switches
Yes, includes 2 front panel mounted push-button switches for system enable, self-test and alarm cancel functions
Audible Alarm
3 function audible alarm indicates power failure conditions (4 short beeps every 10 seconds), overload (continuous
short beeps) and low battery (continuous tone). Audible Alarm is factory muted for silent operation; Audible alarm
can be restored to indicate power failure, overload conditions and Low Battery events, using our Free PowerAlert
UPS management software.
LED Indicators
5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
340
EMI / RFI AC Noise Suppression
Yes
AC Suppression Response Time
Instantaneous
3/5
Cleveland, OH 44122
United States
PHYSICAL
Primary Form Factor
Tower
Cooling Method
Cooling via rear-exit cooling fan
Installation Form Factors Supported
with Included Accessories
Tower
with Optional Accessories
Wallmount ( UPSWM - tower mounting kit)
Primary UPS Depth (mm)
229
Primary UPS Height (mm)
325
Primary UPS Width (mm)
191
Shipping Dimensions (hwd / in.)
18.50 x 12.20 x 13.38
Shipping Dimensions (hwd / cm)
46.99 x 30.99 x 33.99
Shipping Weight (lbs.)
45.40
Shipping Weight (kg)
20.59
UPS Housing Material
PVC
UPS Power Module Dimensions
(hwd, cm)
32.51 x 19.05 x 22.86
(hwd, in.)
12.8 x 7.5 x 9
UPS Power Module Weight (kg)
19.10
UPS Power Module Weight (lbs.)
42.1
Unit Weight (lbs.)
42.1000
Unit Weight (kg)
19.10
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
208.6
Battery Mode BTU / Hr. (Full Load)
189.1
COMMUNICATIONS
Network Management Card
Description
Network management not supported
Communications Interface
USB; DB9 Serial
LINE / BATTERY TRANSFER
Transfer Time
5 milliseconds
4/5
Cleveland, OH 44122
United States
Low Voltage Transfer to Battery
Power (Setpoint)
155
High Voltage Transfer to Battery
Power (Setpoint)
274
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Surge/noise protection
Grounding Lug
Equipotential connection (back panel grounding lug)
STANDARDS & COMPLIANCE
Product Certifications
UL 60601-1
Product Compliance
RoHS; CE (Europe)
WARRANTY & SUPPORT
Product Warranty Period
(International)
2-year limited warranty
Product Warranty Period (Mexico)
Product Warranty Period (Puerto
Rico)
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
很抱歉,暂时无法提供与“SMX700HG”相匹配的价格&库存,您可以联系我们找货
