1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartPro 120V 700VA 450W Medical-Grade LineInteractive Tower UPS with 4 Outlets, Full
Isolation, USB, DB9
Highlights
Supports a half load up to 42
minutes; full load up to 18
minutes
Four hospital-grade outlets and
hospital-grade plug
480 joule surge suppression
rating protects connected
equipment
Alarm mute/alarm quiet control
is ideal for use around patients
Approved for use within the
Patient Care Vicinity
Approved to EN60601-1-2:2015
& IEC60601-1-2:2014, 4th
Edition
MODEL NUMBER: SMART700HG
Package Includes
Provides UL 60601-1 compliant, medical-grade 700VA/450W power backup, ideal for use in patient-care
vicinities. The built-in isolation transformer offers full isolation while maintaining AC surge protection in all
modes.
Description
Tripp Lite’s SMART700HG medical-grade UPS system provides dependable battery backup and is fully
compliant with UL 60601-1 regulations when plugged into a hospital-grade outlet, making it ideal for use in
patient-care vicinities. The 700VA/450W capacity provides up to 42 minutes of runtime for a half load, or
18 minutes for a full load so you can work through short power failures and perform an orderly system
shutdown in a prolonged blackout.
Built-in line-interactive voltage regulation corrects brownouts as low as 81V and overvoltages as high as
143V to normal 120V nominal output, without drawing battery power. The SMART700HG’s built-in
isolation transformer with Faraday shield offers full isolation and removes common mode noise while
maintaining full AC surge suppression in all modes.
This UPS system features four NEMA 5-15R-HG hospital-grade outlets and has a hospital-grade NEMA
5-15P-HG plug with a 6 ft. cord for flexibility in placement. All four outlets provide both backup protection
and surge protection, rated to 480 joules.
The SMART700HG also features diagnostic LEDs, as well as a USB port and a DB9 serial port that work
with Tripp Lite’s free downloadable PowerAlert software for safe, unattended system shutdown and file
saves in the event of a prolonged power failure.
Application Usage
This UPS contains a lead acid battery designed to be connected continuously to an AC power source,
except during brief power outages. It is not intended for frequent charge/discharge cycles, such as mobile
cart applications where the UPS is often disconnected from the power source. Using the SMART700HG in
this type of application will void the battery warranty. For mobile applications, Tripp Lite recommends the
SMART700HGL with lithium iron phosphate (LiFePo4) battery.
Features
Provides Ideal UPS Backup in Healthcare Facilities
● Compliant with UL 60601-1 standards for use in patient-care vicinities, when plugged into a hospitalgrade outlet
Built-in isolation transformer with Faraday shield offers full isolation and removes common mode noise
Hospital-grade plug with 6 ft. cord provides flexibility in placement so healthcare workers can focus on
treating the patient
1/5
SMART700HG 700VA/450W
Medical-Grade Tower UPS
System
USB monitoring cable, 6 ft.
DB9 serial monitoring cable, 6 ft.
Owner’s Manual
Cleveland, OH 44122
United States
Battery Backup and Full Surge Protection
● 42 minutes runtime for half load (225W); 18 minutes for full load (450W)
All four hospital-grade outlets provide surge protection rated to 480 joules
EMI/RFI noise filtering ensures equipment runs smoothly without line noise interference
Resistant to electrostatic discharge
LEDs and Audible Alarms Keep You Aware of Power Status
● Indicator lights on the front of the unit show you when the UPS is on and supplying utility power, when
operating in voltage correction mode or in battery mode, relative load level and low-battery warning
Audible alarms alert you to power failure, overload and low battery conditions; the alarm’s mute/quiet
mode ensures patients are not disturbed
Saves Your Files, Even When You’re Away
● Works with Tripp Lite PowerAlert software (available as a free download) to enable safe, unattended
system shutdown and files saves during prolonged power failures
Connects to your computer via either the DB9 port or USB port
Specifications
OVERVIEW
UPC Code
037332095107
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
5.5A
Nominal Input Voltage(s) Supported
120V AC
UPS Input Connection Type
5-15P-HG
Input Circuit Breakers
10A
UPS Input Cord Length (ft.)
6
UPS Input Cord Length (m)
1.8
Recommended Electrical Service
15A 120V
6
1.83
OUTPUT
Output Capacity (VA)
700
Output Capacity (kVA)
0.7
Output Capacity (Watts)
450
2/5
Cleveland, OH 44122
United States
Output Capacity (kW)
0.45
Power Factor
0.6
Frequency Compatibility
60 Hz
Output Voltage Regulation (Line
Mode)
-18%, +8%
Output Voltage Regulation (Battery
Mode)
115V (+/- 5%)
Output Receptacle Details
Hospital grade output receptacles
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
PWM sine wave
Nominal Output Voltage(s)
Supported
115V; 120V
Output Receptacles
(4) 5-15R
Individually Controllable Load Banks
No
BATTERY
Runtime Full Load (min.)
18
Runtime Half Load (min.)
42
Expandable Runtime
No
DC System Voltage (VDC)
36
Battery Recharge Rate (Included
Batteries)
Less than 4 hours from 10% to 90%
Battery Access
Battery access door
Internal UPS Replacement Battery
Cartridge
RBC36SLT
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 81 to 143
Overvoltage Correction
Input voltages between 126 and 143 are reduced by 9%
Undervoltage Correction
Input voltages between 96 and 106 are boosted by 10%
Severe Undervoltage Correction
Input voltages between 81 and 95 are boosted by 21%
USER INTERFACE, ALERTS & CONTROLS
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status
Audible Alarm
Audible alarm indicates power-failure, overload and low-battery conditions
LED Indicators
5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status
3/5
Cleveland, OH 44122
United States
ISOLATION
Output Isolation Transformer
Hospital grade load isolation transformer
Leakage Current
Equal to 100 microamps
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
480
UPS AC Suppression Response
Time
Instantaneous
EMI / RFI AC Noise Suppression
Yes
480
AC Suppression Response Time
Instantaneous
PHYSICAL
Primary Form Factor
Tower
Cooling Method
Fan
Installation Form Factors Supported
with Optional Accessories
Wallmount ( UPSWM - tower mounting kit)
Primary UPS Depth (mm)
229
Primary UPS Height (mm)
325
Primary UPS Width (mm)
191
Shipping Dimensions (hwd / in.)
17.00 x 11.20 x 13.00
Shipping Dimensions (hwd / cm)
43.18 x 28.45 x 33.02
Shipping Weight (lbs.)
45.30
Shipping Weight (kg)
20.55
UPS Housing Material
PVC
UPS Power Module Dimensions
(hwd, cm)
32.51 x 19.05 x 22.86
(hwd, in.)
12.8 x 7.5 x 9
UPS Power Module Weight (kg)
20.05
UPS Power Module Weight (lbs.)
44.2
Unit Weight (lbs.)
44.200
Unit Weight (kg)
20.05
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0 to 95%, non-condensing
4/5
Cleveland, OH 44122
United States
AC Mode BTU / Hr. (Full Load)
97.7
Battery Mode BTU / Hr. (Full Load)
189.1
AC Mode Efficiency Rating (100%
Load)
94%
COMMUNICATIONS
Network Monitoring Port Description
Supports detailed monitoring of UPS and site power conditions
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB and DB9 serial cabling included
Network Management Card
Description
Network management not supported
Communications Interface
USB; DB9 Serial
LINE / BATTERY TRANSFER
Transfer Time
2-4 milliseconds
Low Voltage Transfer to Battery
Power (Setpoint)
81
High Voltage Transfer to Battery
Power (Setpoint)
143
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Hot swappable batteries; Surge/noise protection
Green Energy-Saving Features
Greater than 95% efficiency - GREEN UPS
Grounding Lug
Grounding lug
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); UL 1778; UL 60601-1
Product Compliance
RoHS; FCC Part 15 Class A (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
很抱歉,暂时无法提供与“SMART700HG”相匹配的价格&库存,您可以联系我们找货
