1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton Tripp Lite series SmartOnline 120V 1kVA
900W Double-Conversion UPS, Tower, Extended
Run, Network Card Options, LCD, USB, DB9
Highlights
1000VA / 1kVA / 900 watt online double-conversion tower
UPS
100/110/120/127V 50/60Hz
output, high efficiency economy
mode option
Interactive LCD with 10
selectable screens of UPS and
site power data
Expandable runtime, Hotswappable batteries
USB, RS232 & EPO ports,
Network Management Card
options
2 independently switched load
banks
NEMA 5-15P input; 6 5-15R
outlets
To use the Auto Probe feature,
this product requires a
WEBCARDLX network interface
(sold separately) running LX
firmware update 15.5.2 or later
MODEL NUMBER: SU1000XLCD
Package Includes
Description
Do you need to protect small- to medium-size servers, networking equipment and telecom systems
against data loss, downtime and equipment damage due to power outages, voltage fluctuations and
transient surges? Tripp Lite’s SU1000XLCD SmartOnline® Tower UPS System is the solution! Featuring a
1000VA/900W capacity and true on-line operation with pure sine wave output and zero transfer time to
battery, it provides the highest level of power protection for mission-critical equipment. The
SU1000XLCD’s large internal battery set supports connected equipment during blackouts, and runtime is
expandable with optional external battery packs (Tripp Lite model BP24V15RT2U, BP24V28-2U or
BP24V70-3U), sold separately. The SU1000XLCD has 6 5-15R outlets, including 2 single-outlet load
banks that are individually controllable to reboot select equipment on demand or maximize battery runtime
for mission-critical equipment. USB and DB9 communication ports support messaging of detailed UPS
operational parameters and line power status. PowerAlert UPS management software is available via free
download. It comes backed by $250,000 of Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico
only).
Features
Ideal for Protection of Mission-Critical Equipment
True On-Line Operation with Pure Sine Wave Output and Zero Transfer Time
Individually Controllable Outlets
Reliable, Expandable Battery Backup
High Power Factor and Highly Efficient Operation Reduces BTU Output
1/6
Tower UPS System
USB, DB9 and EPO Cables
Owner’s Manual
Cleveland, OH 44122
United States
AC Line and Tel/Ethernet Surge Suppression
EMI/RFI Line Noise Filtering
LCD Screen and Audible Alarm
USB/DB9 Ports, Network Management Cards and PowerAlert Software
tripplite.eaton.com/products/power-alert
Emergency Power Off (EPO) Capability
Peace of Mind
Specifications
OVERVIEW
UPC Code
037332174666
UPS Type
On-Line
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
10A
Nominal Input Voltage(s) Supported
100V AC; 110V AC; 120V AC; 127V AC
Nominal Input Voltage Description
120V factory default
UPS Input Connection Type
5-15P
Input Circuit Breakers
15A
UPS Input Cord Length (ft.)
10
UPS Input Cord Length (m)
3.1
Recommended Electrical Service
15A 120V
OUTPUT
Output Capacity (VA)
1000
Output Capacity (kVA)
1
2/6
Cleveland, OH 44122
United States
Output Capacity (Watts)
900
Output Capacity (kW)
0.9
Output Capacity Details
ON LINE MODE: Maximum output capacity rating is reduced to 810W at 100V nominal; FREQUENCY
REGULATION / CONVERSION MODE: Maximum output ratings are reduced in frequency regulation / conversion
mode (127/120/115/110V 630 watts / 100V 567 watts)
OVERLOAD CAPACITY: Supports inverter operation up to 105% load continuously, 125% load for 3 minutes; 150%
load for 30 seconds and >150% load for 0.5 seconds before switching to BYPASS (when bypass input voltage and
frequency are WITHIN bypass limits) or SHUTDOWN (when bypass input voltage or frequency are OUTSIDE
bypass limits)
Power Factor
0.9
Crest Factor
3:1
Nominal Voltage Details
120V default
Frequency Compatibility
50 / 60 Hz; Supports 50 to 60 Hz and 60 to 50 Hz conversion
Frequency Compatibility Details
ON LINE MODE: Output frequency is automatically configured to match nominal input frequency on startup; Output
matches input frequency when +/-5Hz of nominal; Output is regulated to +/-0.05Hz when input frequency exceeds
+/-5Hz of nominal. UPS switches to battery mode when input frequency is below 40Hz or above 70Hz.
FREQUENCY REGULATION / CONVERSION MODE: Output is regulated to +/-0.05Hz of selected output frequency
when input is 40 to 70Hz; UPS switches to battery mode when input frequency is below 40Hz or above 70Hz.
BATTERY MODE: Output is regulated to +/-0.05Hz of selected nominal.
Output Voltage Regulation (Line
Mode)
+/- 2%
(Economy Line Mode)
+/- 10%
Output Voltage Regulation (Battery
Mode)
+/- 3%
Load Management Receptacles
Two switchable single-outlet 5-15R load banks
Output AC Waveform (AC Mode)
Pure Sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
100V; 110V; 115V; 120V; 127V
Output Receptacles
(6) 5-15R
Individually Controllable Load Banks
Yes
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
3.8 min. (900W)
Runtime Half Load (min.)
12.8 min. (450W)
Expandable Runtime
Yes
Expandable Runtime Description
External battery configurations require the use of Tripp Lite's External Battery Configuration Software, see manual
for details
External Battery Pack Compatibility
BP24V15RT2U (limit 1); BP24V28-2U (limit 1); BP24V70-3U (multi-pack
compatible)
3/6
Cleveland, OH 44122
United States
DC System Voltage (VDC)
24
Battery Recharge Rate (Included
Batteries)
Less than 3 hours from 10% to 90% (typical, full load discharge)
Battery Access
Battery access door
Internal UPS Replacement Battery
Cartridge
RBC24V-LCD
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Online, double-conversion power conditioning
Overvoltage Correction
2% output voltage regulation during overvoltages to 150
Undervoltage Correction
2% output voltage regulation during undervoltages to 55V (33% load), 70V (70% load), 100V (100% load)
USER INTERFACE, ALERTS & CONTROLS
Front Panel LCD Display
Front panel LCD information and configuration screen offers detailed UPS and site power status and operating data,
plus configuration of voltage, frequency, operating mode, alarm function and a variety of additional options
Switches
2 switches control off/on power status and alarm-cancel/self-test operation
Alarm Cancel Operation
Power-fail alarm can be temporarily silenced using alarm-cancel switch; silent mode alarm configuration option
available
Audible Alarm
Audible alarm indicates UPS startup, power-failure, low-battery, overload, UPS fault and remote shutdown
conditions
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
570
UPS AC Suppression Response
Time
Instantaneous
UPS Dataline Suppression
1 line TEL/DSL (1 in / 1 out); 10/100Base T Ethernet
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Tower
Cooling Method
Fan
Installation Form Factors Supported
with Included Accessories
Tower
Primary UPS Depth (mm)
335
Primary UPS Height (mm)
254
Primary UPS Width (mm)
173
Shipping Dimensions (hwd / in.)
13.90 x 9.80 x 18.00
Shipping Dimensions (hwd / cm)
35.31 x 24.89 x 45.72
Shipping Weight (lbs.)
33.50
4/6
Cleveland, OH 44122
United States
Shipping Weight (kg)
15.20
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, cm)
25.40 x 17.27 x 33.53
(hwd, in.)
10 x 6.8 x 13.2
UPS Power Module Weight (kg)
13.02
UPS Power Module Weight (lbs.)
28.7
Unit Weight (lbs.)
28.7000
Unit Weight (kg)
13.02
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
341
AC Economy Mode BTU / Hr. (Full
Load)
128
Battery Mode BTU / Hr. (Full Load)
585
AC Mode Efficiency Rating (100%
Load)
90%
AC Economy Mode Efficiency Rating
(100% Load)
95%
Audible Noise
< 50 dB at front side 1m
Operating Elevation (m)
Up to 3000m
COMMUNICATIONS
SNMPWEBCARD; TLNETCARD ; WEBCARDLX ; MODBUSCARD ; RELAYIOCARD
Network Monitoring Port Description
Supports detailed monitoring of UPS and site power conditions; DB9 port supports RS232 and contact closure
communications
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB and DB9 cabling included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Description
Network management card optional
Communications Interface
Contact closure; DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled)
5/6
Cleveland, OH 44122
United States
LINE / BATTERY TRANSFER
Transfer Time
Zero transfer time (0 ms.) in online, double-conversion and frequency regulation / conversion modes;
Low Voltage Transfer to Battery
Power (Setpoint)
High Voltage Transfer to Battery
Power (Setpoint)
150
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Auto Probe Monitoring and Reboot (requires WEBCARDLX); Automatic inverter bypass; Hot swappable batteries;
Remote management; Surge/noise protection; Zero transfer time
Green Energy-Saving Features
High efficiency economy mode operation; Individually controllable load banks; Schedulable daily hours of economy
mode operation
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); NOM (Mexico); UL 1778
Product Compliance
RoHS; FCC Part 15 Class B (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
$250,000 Ultimate Lifetime
Insurance
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
6/6
