1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartOnline 120V 3kVA 2.4kW DoubleConversion UPS, Tower, Extended Run, Network
Card Options, USB, DB9 Serial
Highlights
3000VA / 3kVA / 2400 watt online double-conversion tower
UPS
120V +/-2% output at 50/60Hz,
high efficiency economy mode
option
Expandable runtime, Hotswappable batteries
USB, RS232 & EPO ports;
network management card
options
Front panel status LEDs with
detailed load and battery
metering
2 independently switchable
output load banks
NEMA L5-30P input; L5-30R, 515/20R & 5-15R outlets
To use the Auto Probe feature,
this product requires a
WEBCARDLX network interface
(sold separately) running LX
firmware update 15.5.2 or later
MODEL NUMBER: SU3000XL
Package Includes
Description
3000VA / 3kVA / 2400 watt on-line, double-conversion UPS system for critical server, network and
telecommunications equipment. Attractive upright tower format. Expandable battery runtime with optional
BP72V15-2U (limit 1), BP72V28RT-3U (multi-pack compatible) and BP72V18-2US (multi-pack
compatible) external battery packs. Full time sine wave 120V output with +/-2% voltage regulation.
Uninterruptible Power Supply (UPS) actively converts raw incoming AC power to DC, then re-converts
output back to completely regulated, filtered AC output. Operates continuously without using battery
power during brownouts to 65V and overvoltages to 150V. Up to 97% efficiency in optional economy
mode saves BTU heat output and energy costs. NEMA L5-30P input plug. NEMA L5-30R, NEMA 515/20R and NEMA 5-15R output receptacles. Network-grade AC surge and noise suppression. Zero
transfer time between AC and battery operation. Network management interfaces include USB port, DB9
serial port and slot for network management card options. Built-in DB9 port offers both enhanced RS-232
enabled monitoring data, plus contact closure monitoring ability. HID-compliant USB interface enables
integration with built-in power management and auto shutdown features of Windows and Mac OS X.
Supports simultaneous detailed monitoring of equipment load levels, self-test data and mains power
conditions via all network interfaces. PowerAlert UPS management software is available for free
download. Emergency Power Off (EPO) interface. Integrated two bank PDU switching supports
automated load shedding and remote-reboot of connected equipment. Multi-stage metered current
monitoring and battery charge status LEDs. Mains power and voltage regulation LEDs. Audible Alarm.
Self-test. Fault-tolerant auto-bypass mode. Field replaceable, hot swappable internal batteries and
external battery packs. $250,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only).
Features
SmartOnline high-performance UPS system is ideal for critical voice, data, medical and industrial
network applications
Optional economy-mode operation with 97% efficiency for reduced power consumption and cooler
operation
Economy mode is schedulable via PowerAlert UPS management software for daily or weekly hours of
operation to enable precision output during peak operating hours and high efficiency, low BTU emission
operation during off-peak times
Maintains continuous operation through blackouts, voltage fluctuations and surges
On-line, double-conversion mode provides perfectly regulated sine wave output within 2% of 120V with
zero transfer time
1/6
SU3000XL Online, DoubleConversion UPS System
USB, DB9 and EPO cables
Instruction manual with warranty
information
Cleveland, OH 44122
United States
Supports operation at 50/60Hz (auto-sensing)
Removes harmonic distortion, fast electrical impulses, frequency variations and other hard to solve
power problems not addressed by other UPS types
Corrects line voltage conditions as low as 65V and as high as 150V to within 2% of selected nominal
voltage
Standard internal battery set offers 14 minutes runtime at half load (1200W) and 5 minutes at full load
(2400W)
Expandable battery runtime with optional BP72V15-2U (limit 1), BP72V28RT-3U (multi-pack
compatible) and BP72V18-2US (multi-pack compatible) external battery packs
Intelligent battery management system extends battery life
Some external battery configurations require the use of Tripp Lite's External Battery Configuration
Software (see manual)
Fault tolerant electronic bypass maintains utility output during a variety of UPS fault conditions
Network interfaces support simultaneous communications via built-in USB, DB9 serial / contact-closure
Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX,
SNMPWEBCARD, MODBUSCARD and RELAYIOCARD
HID compliant USB interface enables integration with built-in power management and auto shutdown
USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert
software, available via FREE download from tripplite.eaton.com/products/power-alert
Built-in Emergency Power Off (EPO) interface with cable
NEMA L5-30P input plug / NEMA 5-15R, 5-15/20R & L5-30R output receptacles
Integrated 2 bank switched PDU enables remote outlet management for load shedding or remote reboot
of individual load banks
Front panel LEDs offer current monitoring and battery charge level information
Network grade AC, TEL/DSL or ethernet line surge suppression
Field replaceable, hot swappable internal batteries and external battery packs
Specifications
OVERVIEW
UPC Code
037332119926
UPS Type
On-Line
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
24A
Nominal Input Voltage(s) Supported
120V AC
UPS Input Connection Type
L5-30P
Input Circuit Breakers
40A
UPS Input Cord Length (ft.)
10
UPS Input Cord Length (m)
3.1
2/6
Cleveland, OH 44122
United States
Recommended Electrical Service
30A 120V
OUTPUT
Output Capacity (VA)
3000
Output Capacity (kVA)
3
Output Capacity (Watts)
2400
Output Capacity (kW)
2.4
Output Capacity Details
OVERLOAD CAPACITY: Supports inverter operation up to 105% load continuously, 125% load for 3 minutes; 150%
load for 30 seconds and >150% load for 0.5 seconds before switching to BYPASS (when bypass input voltage and
frequency are WITHIN bypass limits) or SHUTDOWN (when bypass input voltage or frequency are OUTSIDE
bypass limits)
Power Factor
0.8
Crest Factor
3:1
Frequency Compatibility
50 / 60 Hz
Frequency Compatibility Details
Output frequency matches input nominal on startup, defaults to 60 Hz on cold-start
Output Voltage Regulation (Line
Mode)
+/- 2%
(Economy Line Mode)
+/- 10%
Output Voltage Regulation (Battery
Mode)
+/- 2%
Load Management Receptacles
Two switchable four-outlet load banks, (bank 1 - four 5-15/20R, bank 2 - four 5-15R outlets)
Output Circuit Breakers
15A branch rated breaker (x2) protects 4 outlets each, L5-30R outlet is unbreakered
Output AC Waveform (AC Mode)
Pure Sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
120V
Output Receptacles
(4) 5-15R; (4) 5-15/20R; (1) L5-30R
Individually Controllable Load Banks
Yes
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
5 min. (2400w)
Runtime Half Load (min.)
14 min. (1200W)
Expandable Runtime
Yes
External Battery Pack Compatibility
BP72V15-2U (limit 1); BP72V28RT-3U (multi-pack compatible); BP72V18-2US (multi-pack compatible)
DC System Voltage (VDC)
72
3/6
Cleveland, OH 44122
United States
Battery Recharge Rate (Included
Batteries)
Less than 6 hours from 10% to 80% (typical, full load discharge)
Battery Access
Front panel battery access door
Internal UPS Replacement Battery
Cartridge
RBC96-3U
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Online, double-conversion power conditioning
Overvoltage Correction
2% output voltage regulation during overvoltages to 150
Undervoltage Correction
2% output voltage regulation during undervoltages to 80
Severe Undervoltage Correction
2% output voltage regulation during undervoltages to 65 (under 70% load only)
USER INTERFACE, ALERTS & CONTROLS
Switches
2 switches control off/on power status and alarm-cancel/self-test operation
Audible Alarm
Audible alarm indicates UPS startup, power-failure, low-battery, overload, UPS fault and remote shutdown
conditions
LED Indicators
14 LEDs indicate line power, online mode, economy/bypass mode, on-battery, overload, battery low, replace battery
and fault status information - includes 4-LED meter display for load and battery charge level
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
570
UPS AC Suppression Response
Time
Instantaneous
UPS Dataline Suppression
1 line TEL/DSL (1 in / 1 out); 10/100Base T Ethernet
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Tower
Cooling Method
Fan
Installation Form Factors Supported
with Included Accessories
Tower
Primary UPS Depth (mm)
521
Primary UPS Height (mm)
262
Primary UPS Width (mm)
229
Shipping Dimensions (hwd / in.)
14.70 x 23.10 x 12.60
Shipping Dimensions (hwd / cm)
37.34 x 58.67 x 32.00
Shipping Weight (lbs.)
76.77
Shipping Weight (kg)
34.82
UPS Housing Material
Steel
4/6
Cleveland, OH 44122
United States
UPS Power Module Dimensions
(hwd, cm)
26.16 x 22.86 x 52.07
(hwd, in.)
10.3 x 9 x 20.5
UPS Power Module Weight (kg)
31.43
UPS Power Module Weight (lbs.)
69.3
ENVIRONMENTAL
Operating Temperature Range
+32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius
Storage Temperature Range
+5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
1117
AC Economy Mode BTU / Hr. (Full
Load)
253
Battery Mode BTU / Hr. (Full Load)
1225
AC Mode Efficiency Rating (100%
Load)
88%
AC Economy Mode Efficiency Rating
(100% Load)
97%
Audible Noise
< 45 dB at front side 1m
COMMUNICATIONS
Network Management Cards
SNMPWEBCARD; TLNETCARD ; WEBCARDLX ; MODBUSCARD ; RELAYIOCARD
Network Monitoring Port Description
Supports detailed monitoring of UPS and site power conditions; DB9 port supports RS232 and contact closure
communications; Economy-mode setting option is available using PowerAlert software and DB9 Serial cable
connection OR via select Network Management Card options
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB and DB9 cabling included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Description
Network management card optional
Communications Interface
Contact closure; DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled)
LINE / BATTERY TRANSFER
Transfer Time
No transfer time (0 ms.) in online, double-conversion mode
Low Voltage Transfer to Battery
Power (Setpoint)
80V (100% load), 65V (
