1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartOnline 208/240, 230V 6kVA 4.2kW DoubleConversion UPS, 6U Rack/Tower, Extended Run,
Network Card Options, DB9 Serial, Hardwire
MODEL NUMBER: SU6000RT3UHV
Highlights
6000VA / 6kVA / 4200W on-line
double-conversion UPS
200/208/220/230/240V 50/60Hz
output, Economy mode option
6U Rack/Tower compatible; Hotswappable battery modules
RS232 & EPO ports; Slot for
network card options
Front panel LEDs with detailed
LCD monitoring and control
screen
Ships with standard capacity
BP240V7RT3U battery pack
Hardwire input (3 wire);
Hardwire output
Package Includes
Description
Tripp Lite Smart Online UPS systems offer high performance power protection ideal for critical server and
network equipment in datacenters, computer rooms and network closets. Online, double-conversion
Uninterruptible Power Supply (UPS) maintains perfectly regulated output power by continuously
converting raw AC input to DC, then re-converting output back to AC. Fully regulated sine wave AC output
with +/-2% voltage regulation powers network equipment continuously, even during severe brownouts and
overvoltages, all without depleting UPS battery reserves. Maintains battery-derived AC output during
power failures with zero transfer time. Extended runtime options available. Interactive LCD interface
reports UPS operating mode, detailed UPS and site-power data, plus enables a variety of UPS setup and
configuration options. Highly efficient operation in optional economy mode saves BTU heat output and
energy costs. Network management interfaces support communications via RS-232, contact-closure and
slot for network management card options. Built-in DB9 port offers both enhanced RS-232 data and basic
contact closure monitoring ability. PowerAlert monitoring software is available via free download.
Emergency Power Off (EPO) interface. LED display reports UPS operating mode, line power availability,
battery mode operation, inverter operation, ECO mode status and output power availability. Audible alarm
with push-button momentary alarm-cancel and silent-mode LCD configuration options. Programmable
self-test. Fault-tolerant auto-bypass mode. Field-replaceable, hot-swappable internal batteries and
external battery packs.
Features
True on-line, double conversion UPS provides pure, sine wave AC output at all times
World-wide compatibility with Euro 50Hz and High Voltage North American 60Hz power
Maintains continuous operation through blackouts, voltage fluctuations and surges with zero transfer
time
Removes harmonic distortion, electrical impulses, frequency variations and other hard to solve power
problems
1/6
SU6000RT3UPM 3U Power
Module
BP240V7RT3U non-expandable
3U battery pack
Serial and EPO cables
Complete mounting hardware
for 4 post rack installation
2-9USTAND tower stand set
Warranty information
Instruction manual
Cleveland, OH 44122
United States
6000VA/4200 watt power capacity with hardwire input/output connections
Accepts input voltages between 156 and 276, regulating output within 2% of selectable
200/208/220/230/240v AC output
20 minutes runtime at half load (2100W) / 8 minutes at full load (4200W) with included BP240V7RT3U
Expandable runtime with multiple external battery packs
Intelligent battery management system extends battery life
Innovative design makes unit adaptable for rackmount, tower, or stacking applications
Power module and battery pack require only 3 rack spaces each (6U total rack space usage)
DB9 serial port for network interface; SNMP compatible
Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX,
SNMPWEBCARD, MODBUSCARD and RELAYIOCARD
Serial port enables data-saving unattended shutdown when used with Tripp Lite's PowerAlert software,
available via FREE download from tripplite.eaton.com/products/power-alert
Fault tolerant electronic bypass maintains utility output during a variety of UPS fault conditions
Diagnostic LEDs
Mounting hardware included with each 3U module for 4 post rackmount installation, 2 post telecom rack
compatible with separate purchase 2POSTRMKITHD (2 required)
Includes RJ11 EPO (emergency power off) port and interconnection cable
$250,000 Ultimate Lifetime Insurance (USA , Puerto Rico, & Canada Only)
Specifications
OVERVIEW
UPC Code
037332121400
UPS Type
On-Line
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
30A
Nominal Input Voltage(s) Supported
200V AC; 208V AC; 220V AC; 230V AC; 240V AC
UPS Input Connection Type
Hardwire
UPS Input Connection Description
Supports North American 208/240V input (L1,L2,G) and International 230/220/240V (L,N,PE) input wiring; Optional
SUPDM11 backplate adds 2 L6-30R outlets and L6-30P input cord
Input Circuit Breakers
40A double-pole
Recommended Electrical Service
30A 208/220/230/240V
OUTPUT
Output Capacity (VA)
6000
Output Capacity (kVA)
6
Output Capacity (Watts)
4200
Output Capacity (kW)
4.2
2/6
Cleveland, OH 44122
United States
Output Capacity Details
Supports up to 102% load continuously in double conversion mode, 102 to 125% for 1 minute, 126% to 150% for 30
seconds; Loads over 150% trigger immediate bypass mode operation to support loads directly from mains power;
Double conversion mode is automatically restored as load levels are reduced to 90% or less
Power Factor
0,7
Crest Factor
3:1
Nominal Voltage Details
Voltage selection via front panel LCD interface
Frequency Compatibility
50 / 60 Hz
Frequency Compatibility Details
Output frequency matches input nominal on startup
Output Voltage Regulation (Line
Mode)
+/- 2%
(Economy Line Mode)
+/- 10%
Output Voltage Regulation (Battery
Mode)
+/- 2%
Output Receptacle Backplate
Options
Optional SUPDM11 backplate adds 2 L6-30R outlets and L6-30P input cord
Output Circuit Breakers
40A double-pole
Output AC Waveform (AC Mode)
Pure Sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
200V; 208V; 220V; 230V; 240V
Output Receptacles
Hardwire
Individually Controllable Load Banks
No
BATTERY
Runtime Full Load (min.)
8 min. (4200w)
Runtime Half Load (min.)
20 min. (2100w)
Expandable Runtime
Yes
Expandable Runtime Description
Includes one non-expandable BP240V7RT3U (limit 1) external battery pack. No additional BP240V7RT3U external
battery packs can be connected to the host UPS, beyond the one included with the SU6000RT3UHV UPS bundle.
All additional battery packs connected beyond the included BP240V7RT3U, must be BP240V10RT3U , BP240V557C-1PH, BP240V787C-1PH , BP240V1037C-1PH or BP240V1407C-1PH
External Battery Pack Compatibility
BP240V10RT3U ; BP240V557C-1PH; BP240V787C-1PH ; BP240V1037C-1PH; BP240V1407C-1PH
DC System Voltage (VDC)
240
Battery Recharge Rate (Included
Batteries)
Less than 6 hours from 10% to 80% (typical, full load discharge)
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
3/6
Cleveland, OH 44122
United States
Voltage Regulation Description
Online, double-conversion power conditioning
Overvoltage Correction
2% output voltage regulation during overvoltages to 276
Undervoltage Correction
2% output voltage regulation during undervoltages to 156
USER INTERFACE, ALERTS & CONTROLS
Front Panel LCD Display
Selectable LCD display with scroll and selection buttons enables UPS control and detailed monitoring options;
LED/LCD panel rotates for viewing in rack/tower formats (see manual)
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation; 2 additional switches support set and
execute scrolling LCD functions
Alarm Cancel Operation
Alarm cancel switch
Audible Alarm
Unique audible alarms for all major UPS, environmental and power conditions (see manual)
LED Indicators
6 LEDs indicate line power, online mode, economy/bypass mode, on-battery, charger and AC output status; LCD
screen offers additional information and control options
SURGE / NOISE SUPPRESSION
UPS AC Suppression Response
Time
Instantaneous
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Rackmount
Rack Height
6U
Cooling Method
Fan
Included Battery Pack Dimensions
(hwd / in.)
5.2 x 17.5 x 25
Included Battery Pack Weight (lbs.)
136.5
Included Battery Pack Weight (kg)
61.92
Included Mounting Accessory
Description
2 sets of adjustable 4 post rack rails included (for UPS and battery pack components); 2-9USTAND tower kit
included (supports up to 9U in tower format)
Installation Form Factors Supported
with Optional Accessories
2 post rackmount ( 2POSTRMKITHD )
Maximum Device Depth (cm)
66.04
Maximum Device Depth (in.)
26
Maximum Device Depth (mm)
660
Minimum Required Rack Depth (cm)
83.82
(inches)
33
Optional Mounting Accessory Notes
2 sets of 2POSTRMKITWM required for 2 post rackmount
installation of separate power module and battery pack
Primary UPS Depth (mm)
660
Primary UPS Height (mm)
132
4/6
Cleveland, OH 44122
United States
Primary UPS Width (mm)
445
Shipping Dimensions (hwd / in.)
24.50 x 24.00 x 35.00
Shipping Dimensions (hwd / cm)
62.23 x 60.96 x 88.90
Shipping Weight (lbs.)
323.00
Shipping Weight (kg)
146.51
Unit Dimension Details
Includes 3U UPS/power module and 3U battery pack
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, cm)
13.21 x 44.45 x 66.04
(hwd, in.)
5.2 x 17.5 x 26
UPS Power Module Weight (kg)
19.87
UPS Power Module Weight (lbs.)
43.8
ENVIRONMENTAL
Operating Temperature Range
+32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius.
Storage Temperature Range
+5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius.
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
1418
Battery Mode BTU / Hr. (Full Load)
1593
AC Mode Efficiency Rating (100%
Load)
91%
AC Economy Mode Efficiency Rating
(100% Load)
94%
Operating Elevation (ft.)
0-3000m (0 to 10,000 ft.)
Audible Noise
60 dBA at front side 1 meter
Operating Elevation (m)
0 - 3000 m
COMMUNICATIONS
Network Management Cards
SNMPWEBCARD; TLNETCARD ; WEBCARDLX ; MODBUSCARD ; RELAYIOCARD
Network Monitoring Port Description
RS232 and contact closure communications are located on two separate DB9 ports
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
DB9 cable included
Communications Interface
DB9 Serial; Contact closure; EPO (emergency power off); Slot for SNMP/Web interface
LINE / BATTERY TRANSFER
5/6
Cleveland, OH 44122
United States
Transfer Time
No transfer time (0 ms.) in online, double-conversion mode
Transfer Time (Economy Mode)
Less than 1ms typical power failure response in optional economy mode
Low Voltage Transfer to Battery
Power (Setpoint)
156
High Voltage Transfer to Battery
Power (Setpoint)
276
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Automatic inverter bypass; Hot swappable batteries
Green Energy-Saving Features
High efficiency economy mode operation; Schedulable daily hours of economy mode operation
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
Insurance
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
6/6
