1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartOnline 208/240 & 120V 6kVA 4.2kW DoubleConversion UPS, 4U Rack/Tower, Extended Run,
Network Card Options, USB, DB9 Serial, Bypass
Switch
MODEL NUMBER: SU6000RT4U
Highlights
6kVA / 6000VA / 4200W on-line
double-conversion 4U
rack/tower UPS, Sine Wave
Included maintenance bypass
switch enables live replacement
of UPS with zero downtime
Extended runtime options,
Interactive LCD interface
USB, RS232 & EPO ports; Slot
for network management card
options
NEMA L14-30P 208/240V 60Hz
input (4 wire split phase); L630R, L6-20R (208/240V) & 515/20R (120V) outlets
Package Includes
Description
Featuring true on-line operation with pure sine wave output, zero transfer time to battery and complete
UPS replacement capability with no downtime, the SU6000RT4U provides the highest level of protection
available for mission-critical equipment from power outages, voltage fluctuations and transient surges. It
converts incoming AC power to DC, and re-converts it back to filtered AC output with a pure sine wave,
isolating connected components from all power problems. The SU6000RT4U has a 6kVA/4200W
capacity, NEMA L14-30P 4-wire split-phase input and 12 total AC outlets (8 5-15/20R; 2 L6-20R; 2 L630R).
With its detachable PDU, the SU6000RT4U is easily hot-swappable by a user of any skill set—no need for
lengthy and expensive service calls, and no downtime if a repair or battery replacement is needed. In
bypass mode, the PDU passes power to equipment without the use of the power and battery modules,
allowing them to be removed while keeping your application in operation.
UPS battery backup keeps connected equipment operational through short power failures, and provides
time to save data and perform an orderly system shutdown in case of a prolonged blackout. The
SU6000RT4U’s runtime can be expanded with optional external battery packs.
The SU6000RT4U features a highly efficient (94%) economy mode setting that can significantly reduce a
facility's energy costs by minimizing heat output, reducing cooling requirements and consuming less
electricity.
An LCD display with LED indicators enables IT personnel to monitor operating modes and conditions. The
LCD/LED panel rotates for viewing in horizontal rack or vertical tower installations and includes an audible
1/7
SU6000RT4U UPS System
(with SUPDMB56 detachable
PDU module)
USB, DB9 and EPO cabling
Rackmount installation kit for 4
post rack enclosures
Owner's manual and warranty
information
Cleveland, OH 44122
United States
alarm that signals various conditions.
The SU6000RT4U features a USB port and a DB9 port that, when used with Tripp Lite's PowerAlert
software, provides comprehensive network power monitoring and control. An optional network accessory
card enables the UPS to operate as a network managed device.
The unit requires only 4U of rack space in a standard rack enclosure and can be installed in a 2-post rack
using the 2POSTRMKITHD accessory, or in a tower configuration with the 2-9USTAND accessory.
The SU6000RT4U comes with $250,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico
only) for connected equipment.
Features
True on-line, double-conversion UPS provides pure, full-time sine wave AC output free of surges,
voltage fluctuations and line noise
6000VA/4200 watt output power capacity with dual voltage output of 208/120 or 240/120V
4U all-in-one high power density housing supports rackmount installation in only 4 rack spaces
Dual conversion UPS actively converts raw input from AC to DC, then back to perfect sine wave AC
output with enhanced protection from harmonic distortion, fast electrical impulses and other hard-tosolve power problems not addressed by other UPS types
Input cord and outlets are mounted on a detachable backplate with manual bypass switch to enable hotswappable UPS replacement without powering off connected equipment
Optional SUPDMB568HW installable backplate accessories enable hardwire input-output connections
Provides perfectly regulated, sine wave output power free of line noise, transient surges and frequency
variation for the most efficient operation of critical servers, networking and telecommunications
equipment
Maintains output within 3% of selected 208/120 or 240/120V nominal voltage during brownouts and
overvoltages
Supports connected equipment during blackouts for 20/8 minutes at half/full load levels, runtime is
further expandable with optional external battery packs
Intelligent battery management system extends battery life
Some external battery configurations require the use of Tripp Lite's External Battery Configuration
Software (see manual)
Network interfaces support simultaneous communications via DB9 port, USB port and slot for network
management card options
Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX,
SNMPWEBCARD and MODBUSCARD
Includes USB and DB9 serial ports. Built-in DB9 port offers both enhanced RS-232 enabled monitoring
data, plus contact closure monitoring ability. HID-compliant USB interface enables integration with builtin power management and auto shutdown features of Windows and Mac OS X
USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert
software, available via FREE download from tripplite.eaton.com/products/power-alert
Built-in Emergency Power Off (EPO) interface with cable
Includes 12 built-in output receptacles (2 L6-30R, 2 L6-20R, 8 NEMA 5-15/20R)
L14-30P split phase, 4 wire plug-in connection (featured on included detachable PDU).
Front panel LEDs and LCD readout with scroll button enables visual confirmation of all major UPS
functions and current site electrical conditions
Front panel switches enable power on/off control, self-test and alarm cancel functions
Included adjustable mounting rails support installation in 4 post 19 inch rack enclosures
Optional 2-9USTAND set of tower stands supports upright tower installation
2/7
Cleveland, OH 44122
United States
Optional 2POSTRMKITHD accessory enables 2 post rackmount installation
UPS ships fully assembled in full compliance with DOT regulations, no time consuming connection of
internal batteries by user is required
Fault tolerant electronic bypass maintains utility output during a variety of UPS fault conditions
Detachable PDU with built-in manual bypass switch enables hot-swappable UPS replacement without
$250,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only)
Specifications
OVERVIEW
UPC Code
037332125217
UPS Type
On-Line
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
24A
Nominal Input Voltage(s) Supported
120/208V (Split phase L1,L2,N,G); 120/240V (Split phase L1,L2,N,G)
UPS Input Connection Type
L14-30P
UPS Input Connection Description
4 wire split-phase input (L1, L2, N, G)
UPS Input Cord Length (ft.)
10
UPS Input Cord Length (m)
3.1
Recommended Electrical Service
30A 208/120V Split Phase
3
OUTPUT
Output Capacity (VA)
6000
Output Capacity (kVA)
6
Output Capacity (Watts)
4200
Output Capacity (kW)
4.2
Output Capacity Details
6,000VA / 4200W (240V) / 5400VA / 4200W (208V); Supports up to 105% load continuously in double conversion
mode, 106 to 125% for 3 minutes, 126 to 150% for 30 seconds; Loads over 150% trigger immediate bypass mode
operation to support equipment directly from mains power; Double conversion mode is automatically restored as the
overload is cleared
Power Factor
0.7
Crest Factor
3:1
Nominal Voltage Details
240/120 or 208/120 split phase output
Frequency Compatibility
60 Hz
Output Voltage Regulation (Line
Mode)
+/- 3%
3/7
Cleveland, OH 44122
United States
(Economy Line Mode)
+/- 10%
Output Voltage Regulation (Battery
Mode)
+/- 3%
Output Circuit Breakers
20A branch rated breakers (x4) protect 2 5-15/20R outlets each, 20A double pole breakers (x2) protect one L6-20R
each, L6-30R outlets are unbreakered
Output AC Waveform (AC Mode)
Pure Sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
120V; 208V; 240V
Output Receptacles
(8) 5-15/20R; (2) L6-20R; (2) L6-30R
Individually Controllable Load Banks
No
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
8 min. (4200w)
Runtime Half Load (min.)
20 min. (2100w)
Expandable Runtime
Yes
External Battery Pack Compatibility
BP192V12-3U ; BP192V5RT2U (limit 1); BP192V787C-1PH
DC System Voltage (VDC)
192
Battery Recharge Rate (Included
Batteries)
Less than 6 hours from 10% to 80% (typical, full load discharge)
Battery Access
Front panel battery access door
Internal UPS Replacement Battery
Cartridge
RBC9-192
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
+/-3% output voltage regulation in online, double-conversion mode
Overvoltage Correction
Corrects overvoltages to 140 (measured L1-N : L2-N)
Undervoltage Correction
Corrects undervoltages to 65 (measured L1-N : L2-N)
USER INTERFACE, ALERTS & CONTROLS
Front Panel LCD Display
Selectable LCD display with scroll and selection buttons enables UPS control and detailed monitoring options;
LED/LCD panel rotates for viewing in rack/tower formats
Switches
Includes main power off/on switch, plus 2 switches to set and execute scrollable LCD functions. A manual bypass
switch featured on the detachable PDU allows for complete removal of the UPS during routine maintenance without
disrupting power to connected loads. Battery Charge level switch allows the charger output to be adjusted to a
higher charge rate when external battery packs are added.
4/7
Cleveland, OH 44122
United States
Alarm Cancel Operation
Alarm cancel switch
Audible Alarm
Unique audible alarms for all major UPS, environmental and power conditions (see manual)
LED Indicators
6 LEDs indicate line power, online mode, economy/bypass mode, on-battery, charger and AC output status; LCD
screen offers additional information and control options
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
1810
UPS AC Suppression Response
Time
Instantaneous
EMI / RFI AC Noise Suppression
Yes
AC Suppression Response Time
Instantaneous
PHYSICAL
Primary Form Factor
Rackmount
Rack Height
4U
Cooling Method
Fan
Included Mounting Accessory
Description
4 post rackmount installation accessories included
Installation Form Factors Supported
with Included Accessories
4 post 19 inch rackmount
with Optional Accessories
2 post rackmount ( 2POSTRMKITHD ); Tower
( 2-9USTAND )
Maximum Device Depth (cm)
77.72
Maximum Device Depth (in.)
30.6
Maximum Device Depth (mm)
777
Minimum Required Rack Depth with
External Battery Pack (cm)
87
External Battery Pack (in.)
34.2
without External Battery Pack (cm)
87
without External Battery Pack (in.)
34.2
Primary UPS Depth (mm)
782
Primary UPS Height (mm)
175
Primary UPS Width (mm)
445
Shipping Dimensions (hwd / in.)
13.25 x 23.50 x 37.00
Shipping Dimensions (hwd / cm)
33.66 x 59.69 x 93.98
Shipping Weight (lbs.)
222.00
Shipping Weight (kg)
100.70
5/7
Cleveland, OH 44122
United States
Unit Dimension Details
MINIMUM REQUIRED RACK DEPTH specifications refer to the internal FRONT RAIL to REAR DOOR dimension a
compatible rack enclosure is required to accommodate for the UPS configuration described; All minimum required
rack depth figures include any additional distance required to accommodate connected equipment plugs
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, cm)
17.50 x 44.45 x 78.23
(hwd, in.)
6.89 x 17.5 x 30.8
UPS Power Module Weight (kg)
67.86
UPS Power Module Weight (lbs.)
149.6
ENVIRONMENTAL
Operating Temperature Range
+32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius.
Storage Temperature Range
+5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius.
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
1593
AC Economy Mode BTU / Hr. (Full
Load)
914
Battery Mode BTU / Hr. (Full Load)
1419
AC Economy Mode Efficiency Rating
(100% Load)
94%
Operating Elevation (ft.)
0-3000m (0 to 10,000 ft.)
Audible Noise
60 dBA at front side 1 meter
Operating Elevation (m)
0-3000 m
COMMUNICATIONS
Network Management Cards
SNMPWEBCARD; TLNETCARD ; WEBCARDLX ; MODBUSCARD ; RELAYIOCARD
Network Monitoring Port Description
RS232 and contact closure communications are supported on one DB9 port
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB and DB9 cabling included
Description
Network management card optional
Communications Interface
Contact closure; DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled)
LINE / BATTERY TRANSFER
Transfer Time
No transfer time (0 ms.) in online, double-conversion mode
Low Voltage Transfer to Battery
Power (Setpoint)
65V (L1-N:L2-N)
6/7
Cleveland, OH 44122
United States
High Voltage Transfer to Battery
Power (Setpoint)
140V (L1-N:L2-N)
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Auto Probe Monitoring (requires WEBCARDLX); Automatic inverter bypass; Expandable battery backup; Hot
swappable batteries; Hot swappable UPS power module; Manual bypass switch; On-Line/Double-Conversion;
Remote management; Sine wave output; Surge/noise protection; Zero transfer time
Green Energy-Saving Features
High efficiency economy mode operation; Schedulable daily hours of economy mode operation
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
Insurance
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
7/7
