1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartOnline 208/240, 230V 6kVA 5.4kW DoubleConversion UPS, 4U Rack/Tower, Extended Run,
Network Card Options, USB, DB9 Serial, Bypass
Switch, Hardwire
MODEL NUMBER: SU6000RT4UHVHW
Highlights
6000VA / 6kVA / 5400W on-line
double-conversion 4U
rack/tower UPS, Sine Wave
Included maintenance bypass
switch enables live replacement
of UPS with zero downtime
Extended runtime options,
Interactive LCD interface,
Economy-mode option, 0.9
power factor
Add optional WEBCARDLX with
latest version of PADM20 for
enhanced remote management
Hardwire 200-240V 50/60Hz (3
wire) input; Hardwire (3 wire)
output; Configurable for
200/208/220/230/240V 50/60Hz
output
Package Includes
Description
Featuring true on-line operation with pure sine wave output, zero transfer time to battery and complete
UPS replacement capability with no downtime, the SU6000RT4UHVHW provides the highest level of
protection available for mission-critical equipment from power outages, voltage fluctuations and transient
surges. It converts incoming AC power to DC, and re-converts it back to filtered AC output with a pure
sine wave, isolating connected components from all power problems in high-voltage environments. The
SU6000RT4UHVHW has a 6kVA/5400W capacity and hardwire output.
With its detachable PDU with bypass switch, the SU6000RT4UHVHW is easily hot-swappable by a user
of any skill set—no need for lengthy and expensive service calls, and no downtime if a repair or battery
replacement is needed. In bypass mode, the PDU passes power to equipment without the use of the
power and battery modules, allowing them to be removed while keeping your application in operation.
UPS battery backup keeps connected equipment operational through short power failures, and provides
time to save data and perform an orderly system shutdown in case of a prolonged blackout. The
SU6000RT4UHVHW’s runtime can be expanded with optional external battery packs.
The SU6000RT4UHVHW features a highly efficient (96%) economy mode setting that can significantly
reduce a facility's energy costs by minimizing heat output, reducing cooling requirements and consuming
less electricity.
An LCD display with LED indicators enables IT personnel to operating modes and conditions. The
LCD/LED panel rotates for viewing in horizontal rack or vertical tower installations and includes an audible
alarm that signals various conditions.
The SU6000RT4UHVHW features a USB port and a DB9 ports for comprehensive network power
monitoring and control. Network management card options available.
The unit requires only 4U of rack space in a standard rack enclosure and can be installed in a 2-post rack
using the 2POSTRMKITHD accessory, or in a tower configuration with the 2-9USTAND accessory.
The SU6000RT4UHVHW comes with $250,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto
Rico only) for connected equipment.
Features
Tripp Lite SU6000RT4UHVHW 6000VA / 6kVA / 5400 watt on-line, double-conversion UPS system in a
single 4U rack/tower compatible housing
Full-time active power conditioning maintains clean, continuous dual-conversion AC output free of
voltage fluctuations, power interruptions and line noise
Fault tolerant electronic bypass maintains utility output during a variety of UPS fault conditions
1/7
SU6000RT4UHVPM Hotswappable UPS Power Module
SUPDMB6KHW Detachable
PDU with Maintenance Bypass
Switch
1 x 6-ft. USB Cable
1 x 6-ft. DB9 Cable
4-Post Rackmount Hardware
Cleveland, OH 44122
United States
Detachable back panel PDU contains hardwire input and output connections, plus manual bypass
switch to support hot-swappable whole UPS replacement with no interruption to connected equipment
Hardwire input and output connections supported
Included rail kit supports 4U 19 inch rackmount installation in 4 post racks
Optional 2POSTRMKITHD supports installation in 2 post 19 inch racks (1 required for
SU6000RT4UHVHW)
Optional 2-9USTAND supports upright tower placement (1 required for SU6000RT4UHVHW)
Maximum installed rack depth of only 20.7 in. / 52.6cm inches
Maintains full-time sine wave output within 2% of selected 200/208/220/230/240V nominal in double
conversion mode
Corrects brownouts to 156V at full load (100V at 50% load or less)
Corrects overvoltages to 290V at full load (300V at 90% load or less)
Supports 50/60Hz operation for worldwide frequency compatibility
Double-conversion operation offers full-time AC to DC, then DC to AC conversion to maintain perfectly
regulated sine wave AC output with enhanced protection from harmonic distortion, fast electrical
impulses and other hard-to-solve power problems not addressed by other UPS types
High efficiency ECONOMY MODE operation significantly reduces BTU heat output and operating
energy costs
Network-grade AC surge and noise suppression
Supports detailed monitoring of equipment load levels, self-test data and utility power conditions via
built-in RS-232, USB and network management card options
Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX,
SNMPWEBCARD, MODBUSCARD and RELAYIOCARD
Optional WEBCARDLX (sold separately) with the latest version of PowerAlert Device Manager firmware
(PADM20) provides enhanced remote management capabilities
PADM20 and PowerAlert Element Manager (PAEM) form a powerful tool for expanding maintenance
functions in large installations, including firmware update checks and backup and restoration of device
configurations
Optional RELAYIOMINI interface module offers three configurable hard contact closure outputs for
custom event notification (requires removal of USB interface module)
HID-compliant USB interface enables integration with built-in power management and auto shutdown
features of Windows and Mac OS X
USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert
software, available via FREE download from tripplite.eaton.com/products/power-alert
Front panel LEDs and LCD readout with scroll controls support front-panel visual monitoring of all major
UPS functions with support for a variety of control options to support advanced UPS settings and
configurations
LED/LCD display panel rotates for viewing in rackmount or tower configurations
Supports Emergency Power Off (EPO) via built-in interface
Battery independent restart ensures automatic UPS power-up without user interaction after lengthy
power outages, even when batteries are expired and require replacement
BP192V12-3U external battery packs are field replaceable and hot swappable
Intelligent battery management system with temperature-compensated charging extends battery life
Some external battery configurations require the use of Tripp Lite's External Battery Configuration
Software (see manual)
Frequency conversion mode enables conversion of 60Hz to 50Hz or 50Hz to 60Hz (no de-rating)
Specifications
2/7
Cleveland, OH 44122
United States
OVERVIEW
UPC Code
037332157089
UPS Type
On-Line
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
31.9A (200V), 30.6A (208V), 29A (220V), 27.7A (230V), 26.6A (240V)
Nominal Input Voltage(s) Supported
200V AC; 208V AC; 220V AC; 230V AC; 240V AC
UPS Input Connection Type
Hardwire
UPS Input Connection Description
Supports North American 208/240V input (L1,L2,G) or International 230/220/240V (L,N,PE) input wiring
Recommended Electrical Service
40A (200/208v); 30A (220/230/240v)
OUTPUT
Output Capacity (VA)
6000
Output Capacity (kVA)
6
Output Capacity (Watts)
5400
Output Capacity (kW)
5.4
Output Capacity Details
Supports up to 105% load continuously in double conversion mode, 106 to 125% for 1 minute, 126% to 150% for 30
seconds; Loads over 150% trigger immediate bypass mode operation to support loads directly from mains power;
Double conversion mode is automatically restored as the overload is cleared
Power Factor
0,9
Crest Factor
3:1
Nominal Voltage Details
Voltage selection via front panel LCD interface
Frequency Compatibility
50 / 60 Hz
Frequency Compatibility Details
Output frequency matches input nominal on startup; Frequency conversion mode enables conversion of 60Hz to
Output Voltage Regulation (Line
Mode)
+/- 2%
(Economy Line Mode)
+/- 10%
Output Voltage Regulation (Battery
Mode)
+/- 2%
Output Receptacle Details
Hardwire input and output connections are mounted on a detachable PDU backplate with bypass switch to enable
hot-swappable power module replacement
Output AC Waveform (AC Mode)
Pure Sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
200V; 208V; 220V; 230V; 240V
Output Receptacles
Hardwire
3/7
Cleveland, OH 44122
United States
Individually Controllable Load Banks
No
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
2 min. (5400W)
Runtime Half Load (min.)
8.5 min. (2700W)
Expandable Runtime
Yes
External Battery Pack Compatibility
BP192V1037C-1PH; BP192V12-3U ; BP192V1407C-1PH;
BP192V557C-1PH; BP192V787C1PH ; BP192V5RT2U (limit 1)
DC System Voltage (VDC)
192
Battery Recharge Rate (Included
Batteries)
6 hours from 10% to 90% (typical, full load discharge)
Battery Access
Front panel battery access door
Internal UPS Replacement Battery
Cartridge
RBC5-192
Battery Replacement Description
Hot-swappable, user replaceable internal batteries
VOLTAGE REGULATION
Voltage Regulation Description
Online, double-conversion power conditioning
Overvoltage Correction
Corrects overvoltages as high as 300V (
