1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartOnline 208/240V 5kVA 4.5kW DoubleConversion UPS, 4U Rack/Tower, Extended Run,
Network Card Options, USB, DB9 Serial
Highlights
5kVA / 5000VA / 4500W on-line
double-conversion UPS; 0.9
power factor
200/208/220/230/240V 50/60Hz
output; high efficiency economy
mode option
4U Rack/Tower compatible; Hotswappable batteries;
Expandable runtime
USB, RS232 & EPO ports; Slot
for network management card
options
Front panel LEDs with detailed
LCD monitoring and control
screen
ENERGY STAR Version 2.0
qualified
NEMA L6-30P input (3 wire); L630R & L6-20R outputs
MODEL NUMBER: SU5000RT4UHV
Package Includes
Description
Tripp Lite SU5000RT4UHV 5000VA / 5kVA / 4500 watt on-line, double-conversion UPS system offers
complete power protection for critical server, network and telecommunications equipment in a single 4U
rack/tower compatible housing. Full-time active power conditioning provides clean, continuous dualconversion AC output free of voltage fluctuations, power interruptions and line noise. Fault-tolerant autobypass prevents unexpected service interruptions during UPS overload or internal fault conditions. Single
all-in-one rack / tower housing installs in only 4 rack spaces (4U) with a maximum installed depth of only
20.7 in. / 52.6 cm. Maintains full-time sine wave output within 2% of selectable 200/208/220/230/240V
nominal during brownouts as low 100V and overvoltages as high as 300V. Expandable runtime is
supported with optional BP192V12-3U external battery packs. Battery independent restart ensures
automatic UPS power-up without user interaction after lengthy power outages, even when batteries are
expired and require replacement. Double-conversion operation converts raw input from AC to DC, then
resynthesizes output power back to perfect sine wave AC with enhanced protection from harmonic
distortion, fast electrical impulses and other hard-to-solve power problems not addressed by other UPS
types. Highly efficient operation in optional economy mode significantly reduces BTU heat output and
operating energy costs. Network-grade AC surge and noise suppression. Supports detailed monitoring of
equipment load levels, self-test data and utility power conditions via built-in RS-232 and USB interfaces.
Optional network management and contact-closure communications card accessories available. HIDcompliant USB interface enables integration with built-in power management and auto shutdown features
of Windows and Mac OS X. PowerAlert monitoring software, available via free download, offers detailed
site power and UPS updates with support for safe auto-shutdown of connected systems as UPS batteries
become depleted. Supports Emergency Power Off (EPO) via built-in interface. Front panel LEDs and LCD
readout with scroll controls support front-panel visual monitoring of all major UPS for a variety of control
options to support advanced UPS settings and configurations. LED / LCD display panel rotates for viewing
in rackmount or tower configurations. L6-30P input, plus two L6-30R and two L6-20R outlets. External
battery packs are field replaceable and hot swappable. $250,000 connected equipment insurance;
Features
Tripp Lite SU5000RT4UHV 5000VA / 5kVA / 4500 watt on-line, double-conversion UPS system in a
single 4U rack/tower compatible housing
Full-time active power conditioning maintains clean, continuous dual-conversion AC output free of
Fault tolerant electronic bypass maintains utility output during a variety of UPS fault conditions
L6-30P input plug; 2 L6-30R and 2 L6-20R UPS supported outlets
1/7
SU5000RT4UHV UPS System
4 post rackmount rails
USB, DB9 and EPO Cabling
Cleveland, OH 44122
United States
Included rail kit supports 4U 19 inch rackmount installation in 4 post racks
Optional 2POSTRMKITHD supports installation in 2 post 19 inch racks (1 required for SU5000RT4UHV)
Optional 2-9USTAND supports upright tower placement (1 required for SU5000RT4UHV)
Maximum installed rack depth of only 20.7 in. / 52.6cm inches
Maintains full-time sine wave output within 2% of selected 200/208/220/230/240V nominal in double
conversion mode
Corrects brownouts to 156V at full load (100V at 50% load or less)
Corrects overvoltages to 290V at full load (300V at 90% load or less)
Supports 50/60Hz operation for worldwide frequency compatibility
Double-conversion operation offers full-time AC to DC, then DC to AC conversion to maintain perfectly
regulated sine wave AC output with enhanced protection from harmonic distortion, fast electrical
impulses and other hard-to-solve power problems not addressed by other UPS types
High efficiency ECONOMY MODE operation significantly reduces BTU heat output and operating
energy costs
Supports detailed monitoring of equipment load levels, self-test data and utility power conditions via
built-in RS-232, USB and optional network management card interfaces
UPS card slot supports network management card accessory options
Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX,
SNMPWEBCARD, MODBUSCARD and RELAYIOCARD
Optional RELAYIOMINI interface module offers three configurable hard contact closure outputs for
custom event notification (requires removal of USB interface module)
HID-compliant USB interface enables integration with built-in power management and auto shutdown
features of Windows and Mac OS X
USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert
software, available via FREE download from tripplite.eaton.com/products/power-alert
Front panel LEDs and LCD readout with scroll controls support front-panel visual monitoring of all major
UPS functions with support for a variety of control options to support advanced UPS settings and
configurations
LED/LCD display panel rotates for viewing in rackmount or tower configurations Supports Emergency
Battery independent restart ensures automatic UPS power-up without user interaction after lengthy
power outages, even when batteries are expired and require replacement
BP192V12-3U external battery packs are field replaceable and hot swappable
Intelligent battery management system with temperature-compensated charging extends battery life
Some external battery configurations require the use of Tripp Lite's External Battery Configuration
Software (see manual)
Frequency conversion mode enables conversion of 60Hz to 50Hz or 50Hz to 60Hz (no de-rating)
Specifications
OVERVIEW
UPC Code
037332146823
UPS Type
On-Line
INPUT
2/7
Cleveland, OH 44122
United States
Input Phase
Single-Phase
Rated input current (Maximum Load)
24A (200V), 24A (208V), 23.6A (220V), 23A (230V), 21.7A (240V)
Nominal Input Voltage(s) Supported
200V AC; 208V AC; 240V AC
Nominal Input Voltage Description
Factory configured to 208V
UPS Input Connection Type
L6-30P
UPS Input Cord Length (ft.)
10
UPS Input Cord Length (m)
3.1
Recommended Electrical Service
30A
OUTPUT
Output Capacity (VA)
5000
Output Capacity (kVA)
5
Output Capacity (Watts)
4500
Output Capacity (kW)
4.5
Output Capacity Details
Supports up to 105% load continuously in double conversion mode, 106 to 125% for 1 minute, 126% to 150% for 30
seconds; Loads over 150% trigger immediate bypass mode operation to support loads directly from mains power;
Double conversion mode is automatically restored as the overload is cleared
Power Factor
0.9
Crest Factor
3:1
Nominal Voltage Details
208V default
Frequency Compatibility
50 / 60 Hz; Supports 50 to 60 Hz and 60 to 50 Hz conversion
Frequency Compatibility Details
Output frequency matches input nominal on startup; Frequency conversion mode enables conversion of 60Hz to
Output Voltage Regulation (Line
Mode)
+/- 2%
(Economy Line Mode)
+/- 10%
Output Voltage Regulation (Battery
Mode)
+/- 2%
Output Circuit Breakers
20A breaker protects L6-20R outlets, L6-30R outlets are unbreakered
Output AC Waveform (AC Mode)
Pure Sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
200V; 208V; 240V
Output Receptacles
(2) L6-20R; (2) L6-30R
Individually Controllable Load Banks
No
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
3/7
Cleveland, OH 44122
United States
Runtime Full Load (min.)
3.5 min. (4500W)
Runtime Half Load (min.)
11 min. (2250W)
Expandable Runtime
Yes
External Battery Pack Compatibility
BP192V1037C-1PH; BP192V12-3U ; BP192V1407C-1PH;
BP192V557C-1PH; BP192V787C1PH ; BP192V5RT2U (limit 1)
DC System Voltage (VDC)
192
Battery Recharge Rate (Included
Batteries)
6 hours from 10% to 90% (typical, full load discharge)
Battery Access
Front panel battery access
Internal UPS Replacement Battery
Cartridge
RBC5-192 (qty 1)
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Online, double-conversion power conditioning
Overvoltage Correction
2% output voltage regulation during overvoltages to 280V (full load) / 300V (90% load or less)
Undervoltage Correction
2% output voltage regulation during undervoltages to 156V (full load) / 100V (50% load or less)
USER INTERFACE, ALERTS & CONTROLS
Front Panel LCD Display
Selectable LCD display with scroll and selection buttons enables UPS control and detailed monitoring options;
LED/LCD panel rotates for viewing in rack/tower formats (see manual)
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation; 2 additional switches support set and
execute scrolling LCD functions.
Alarm Cancel Operation
Alarm cancel switch
Audible Alarm
Unique audible alarms for all major UPS, environmental and power conditions (see manual)
LED Indicators
6 LEDs indicate line power, online mode, economy/bypass mode, on-battery, charger and AC output status; LCD
screen offers additional information and control options
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
2595
UPS AC Suppression Response
Time
Instantaneous
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Rackmount
Rack Height
4U
Cooling Method
Fan
4/7
Cleveland, OH 44122
United States
Included Mounting Accessory
Description
4 post rackmount installation accessories included
Installation Form Factors Supported
with Included Accessories
4 post 19 inch rackmount
with Optional Accessories
2 post rackmount ( 2POSTRMKITHD ); Tower
( 2-9USTAND )
Minimum Required Rack Depth (cm)
60.96
(inches)
24
Minimum Required Rack Depth with
External Battery Pack (cm)
74
External Battery Pack (in.)
29
without External Battery Pack (cm)
65
without External Battery Pack (in.)
25.75
Primary UPS Depth (mm)
525
Primary UPS Height (mm)
174
Primary UPS Width (mm)
445
Shipping Dimensions (hwd / in.)
12.00 x 24.00 x 29.00
Shipping Dimensions (hwd / cm)
30.48 x 60.96 x 73.66
Shipping Weight (lbs.)
152.00
Shipping Weight (kg)
68.95
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, cm)
17.40 x 44.45 x 52.50
(hwd, in.)
6.85 x 17.5 x 20.67
UPS Power Module Weight (kg)
51.53
UPS Power Module Weight (lbs.)
113.6
Unit Weight (lbs.)
113.560
Unit Weight (kg)
51.51
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
5% to 90% (non-condensing)
AC Mode BTU / Hr. (Full Load)
1767
5/7
Cleveland, OH 44122
United States
AC Economy Mode BTU / Hr. (Full
Load)
640
Battery Mode BTU / Hr. (Full Load)
1708
AC Mode Efficiency Rating (100%
Load)
90%
AC Economy Mode Efficiency Rating
(100% Load)
96%
Operating Elevation (ft.)
0 to 6560 ft. / 0 to 2000 m
Audible Noise
65 dB at 1m front side
Operating Elevation (m)
0-2000 m
COMMUNICATIONS
Network Management Cards
SNMPWEBCARD; TLNETCARD ; WEBCARDLX ; MODBUSCARD ; RELAYIOCARD
Network Monitoring Port Description
Two contact closure monitoring options available - RELAYIOCARD with six configurable contact closure outputs
(uses UPS card slot) and RELAYIOMINI with 3 configurable contact closure outputs (requires removal of USB port
module)
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB, DB9 serial and EPO cables included
WatchDog Compatibility
Yes
Description
Network management card optional
Communications Interface
DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled)
LINE / BATTERY TRANSFER
Transfer Time
No transfer time (0 ms.) in online, double-conversion mode
Transfer Time (Economy Mode)
8 ms. typical power failure response in optional economy mode
Low Voltage Transfer to Battery
Power (Setpoint)
156V (full load) / 100V (50% load or less, derates linearly)
High Voltage Transfer to Battery
Power (Setpoint)
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Auto Probe Monitoring (requires WEBCARDLX); Automatic inverter bypass; Hot swappable batteries; Remote
management; Surge/noise protection; Zero transfer time
Green Energy-Saving Features
High efficiency economy mode operation; Support for daily startup and shutoff; Schedulable daily hours of economy
mode operation
STANDARDS & COMPLIANCE
6/7
Cleveland, OH 44122
United States
Product Certifications
CSA (Canada); UL 1778
Product Compliance
RoHS; ENERGY STAR Qualified; FCC Part 15 Class A (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
$250,000 Ultimate Lifetime
Insurance
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
7/7
