1000 Eaton Boulevard
Cleveland, OH 44122
United States
1.5kW Single-Phase Local Metered PDU, 100127V Outlets (8 5-15R), 5-15P, 15 ft. (4.57 m)
Cord, 0U Vertical, 24 in.
Highlights
Local Metered single phase 12A
100-127V 0U 24in / 61cm
vertical rackmount PDU
Two-digit current meter reports
output current in amps
Attached 15-ft. (4.57 m) cord
with NEMA 5-15P input plug
8 NEMA 5-15R outlets
Toolless button mount and boltdown bracket installation
hardware included
MODEL NUMBER: PDUMV15-24
Package Includes
Features
15A single phase 120V Local Metered Power Distribution Unit / PDU (Agency de-rated to 12A
continuous)
Two-digit lighted meter reports combined total output current in amps
Attached NEMA 5-15P 15A 120V input plug with 15-ft. (4.57 m) line cord
0U 24in / 61cm vertical rackmount format installs using no rack spaces
Includes 15A circuit breaker and lighted power switch inside a transparent protective cover
Toolless installation supported in button-mount compatible equipment racks
Rear facing installation buttons can be relocated to the left or right surface of the PDU for rear, center or
forward-facing outlet orientation in compatible racks
Included nut and bolt mounting brackets support installation in non button-mount compatible racks,
wallmount and raceway applications
Specifications
OVERVIEW
UPC Code
037332182852
PDU Type
Local Metered
INPUT
PDU Input Voltage
100; 120; 125; 127
Recommended Electrical Service
Single-phase 15A 100-127V service
1/3
PDUMV15 Local Metered
Vertical PDU
Mounting hardware and spare
mounting buttons
Owner's manual with warranty
information
Cleveland, OH 44122
United States
Maximum Input Amps
12
Maximum Input Amps Details
Agency de-rated to 12A continuous
PDU Plug Type
NEMA 5-15P
Input Phase
Single-Phase
Input Cord Length (ft.)
15
Input Cord Length (m)
4.57
OUTPUT
Output Capacity Details
1.52kW (127V), 1.44kW (120V), 1.2kW (100V) / 12A total capacity; 12A max per outlet
Frequency Compatibility
50 / 60 Hz
Output Receptacles
(8) 5-15R
Output Nominal Voltage
100-127V
Overload Protection
15A circuit breaker
USER INTERFACE, ALERTS & CONTROLS
Front Panel LCD Display
Digital meter reports PDU output current in amps
Switches
Lighted on/off switch with integrated safety cover
SURGE / NOISE SUPPRESSION
Automatic Shut-Off
No
PHYSICAL
Material of Construction
Metal
Form Factors Supported
Vertical (0U) mounting in rack enclosures, horziontal mount in raceways and a variety of other applications
PDU Form Factor
Vertical (0U)
Shipping Dimensions (hwd / in.)
1.90 x 5.40 x 27.10
Shipping Dimensions (hwd / cm)
4.83 x 13.72 x 68.83
Shipping Weight (lbs.)
3.40
Shipping Weight (kg)
1.54
Unit Dimensions (hwd / in.)
24.000 x 1.750 x 1.250
Unit Dimensions (hwd / cm)
61 x 4.45 x 3.2
Unit Weight (lbs.)
2.65
Unit Weight (kg)
1.20
ENVIRONMENTAL
Operating Temperature Range
0C ~ 40C (32F ~ 104F)
Storage Temperature Range
-30°C to +50°C (-22°F to +122°F)
2/3
Cleveland, OH 44122
United States
Relative Humidity
5-95% non-condensing
Operating Elevation (ft.)
0-10,000
Operating Elevation (m)
0-3000
STANDARDS & COMPLIANCE
Product Certifications
RETIE (Colombia); CAN/CSA-C22.2 No. 60950-1 (Canada); NOM (Mexico); UL 60950-1
Product Compliance
RoHS; FCC Part 15 Class A (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“PDUMV15-24”相匹配的价格&库存,您可以联系我们找货
