1000 Eaton Boulevard
Cleveland, OH 44122
United States
2kW Single-Phase Local Metered PDU, 100-127V
Outlets (14 5-15/20R), L5-20P/5-20P adapter, 0U
Vertical, 36 in. Height
Highlights
Local Metered single phase
100-127V 20A 0U 36-in. /
91.4cm vertical rackmount PDU
Two-digit current meter reports
output current in amps
Attached 15-ft. (4.57 m) cord
with NEMA L5-20P plug and 520P adapter
14 NEMA 5-15/20R outlets
Toolless button mount and boltdown bracket installation
hardware included
MODEL NUMBER: PDUMV20-36
Package Includes
Features
20A single phase 100-127V Local Metered Power Distribution Unit / PDU (Agency de-rated to 16A
continuous)
Two-digit lighted meter reports combined total output current in amps
Attached NEMA L5-20P input plug with 15-ft. (4.57 m) line cord and 5-20P adapter
0U 36-in. / 91.4cm vertical rackmount format installs using no rack spaces
Includes 20A circuit breaker and lighted power switch inside a transparent protective cover
Toolless installation supported in button-mount compatible equipment racks
Bolt-down installation brackets support installation in other racks and additional surfaces
Specifications
OVERVIEW
UPC Code
037332182821
PDU Type
Local Metered
INPUT
PDU Input Voltage
100; 120; 125; 127
Recommended Electrical Service
Single-phase 20A 100-127V service
Maximum Input Amps
16
Maximum Input Amps Details
Agency de-rated to 16A continuous
1/3
PDUMV20-36 Local Metered
Vertical PDU
(1) L5-20P to 5-20P plug
adapter
Mounting hardware and spare
mounting buttons
Instruction manual with warranty
information
Cleveland, OH 44122
United States
PDU Plug Type
NEMA 5-20P; NEMA L5-20P
Input Phase
Single-Phase
Input Cord Length (ft.)
15
Input Cord Length (m)
4.57
OUTPUT
Output Capacity Details
2.03kW (127V), 1.92kW (120V), 1.6kW (100V) / 16A total capacity; 16A max per outlet
Frequency Compatibility
50 / 60 Hz
Output Receptacles
(14) 5-15/20R
Output Nominal Voltage
100-127V
Overload Protection
20A circuit breaker
USER INTERFACE, ALERTS & CONTROLS
Front Panel LCD Display
Digital meter reports PDU output current in amps
Switches
Lighted on/off switch with integrated transparent saftey cover
SURGE / NOISE SUPPRESSION
Automatic Shut-Off
No
PHYSICAL
Material of Construction
Aluminum
Form Factors Supported
Vertical
PDU Form Factor
Vertical (0U)
Shipping Dimensions (hwd / in.)
2.60 x 38.58 x 6.65
Shipping Dimensions (hwd / cm)
6.60 x 97.99 x 16.89
Shipping Weight (lbs.)
4.90
Shipping Weight (kg)
2.22
Unit Dimensions (hwd / in.)
36.470 x 1.640 x 1.500
Unit Dimensions (hwd / cm)
92.6 x 3.81 x 4.17
Unit Weight (lbs.)
4.19
Unit Weight (kg)
1.90
ENVIRONMENTAL
Operating Temperature Range
0C ~ 40C (32F ~ 104F)
Storage Temperature Range
-30°C to +50°C (-22°F to +122°F)
Relative Humidity
5-95% non-condensing
Operating Elevation (ft.)
0-10,000
2/3
Cleveland, OH 44122
United States
Operating Elevation (m)
0-3000
STANDARDS & COMPLIANCE
Product Certifications
RETIE (Colombia); NOM (Mexico); UL 60950-1
Product Compliance
RoHS; FCC Part 15 Class A (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“PDUMV20-36”相匹配的价格&库存,您可以联系我们找货
