HEF4060BT,653
HEF4060BT,653
    NEXPERIA(安世)
    SOIC-16
    14级波纹进位二进制计数器/分压器和振荡器
HEF4060BT,653 数据手册
HEF4060B 14-stage ripple-carry binary counter/divider and oscillator Rev. 9 — 8 July 2019 Product data sheet 1. General description The HEF4060B is a 14-stage ripple-carry binary counter/divider and oscillator with three oscillator terminals (RS, REXT and CEXT), ten buffered outputs (Q3 to Q9 and Q11 to Q13) and an overriding asynchronous master reset input (MR). The oscillator configuration allows design of either RC or crystal oscillator circuits. The oscillator may be replaced by an external clock signal at input RS. The clock input' s Schmitt-trigger action makes it highly tolerant to slower clock rise and fall times. The counter advances on the negativegoing transition of RS. A HIGH level on MR resets the counter (Q3 to Q9 and Q11 to Q13 = LOW), independent of other input conditions. It operates over a recommended VDD power supply range of 3 V to 15 V referenced to VSS (usually ground). Unused inputs must be connected to VDD, VSS, or another input. 2. Features and benefits • • • • • • • Tolerant of slow clock rise and fall times Fully static operation 5 V, 10 V, and 15 V parametric ratings Standardized symmetrical output characteristics Inputs and outputs are protected against electrostatic effects Specified from -40 ° C to +85 ° C Complies with JEDEC standard JESD 13-B 3. Ordering information Table 1. Ordering information All types operate from -40 ° C to +85 ° C. Type number Package Name Description Version HEF4060BT SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 HEF4060BTT TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 HEF4060B Nexperia 14-stage ripple-carry binary counter/divider and oscillator 4. Functional diagram 10 REXT 11 12 RS 9 CEXT CP CD MR Q3 Q4 Q5 Q6 Q7 Q8 Q9 Q11 Q12 Q13 7 Fig. 1. 14-STAGE BINARY COUNTER 5 4 6 14 13 15 1 2 3 001aae652 Functional diagram CEXT REXT FF1 RS CP Q CD FF4 CP Q CD MR FF10 FF12 FF14 CP CP CP Q CD Q3 Q CD Q9 Q CD Q11 Q13 001aae654 Fig. 2. Logic diagram 5. Pinning information 5.1. Pinning HEF4060B Q11 1 16 VDD Q12 2 15 Q9 Q13 3 14 Q7 Q5 4 13 Q8 Q4 5 12 MR Q6 6 11 RS Q3 7 VSS 8 HEF4060B 10 REXT 9 CEXT Q11 1 16 VDD Q12 2 15 Q9 Q13 3 14 Q7 Q5 4 13 Q8 Q4 5 12 MR Q6 6 11 RS Q3 7 10 REXT VSS 8 001aae653 Fig. 3. Pin configuration SOT109-1 (SO16) HEF4060B Product data sheet 9 CEXT aaa-030139 Fig. 4. Pin configuration SOT403-1 (TSSOP16) All information provided in this document is subject to legal disclaimers. Rev. 9 — 8 July 2019 © Nexperia B.V. 2019. All rights reserved 2 / 14 HEF4060B Nexperia 14-stage ripple-carry binary counter/divider and oscillator 5.2. Pin description Table 2. Pin description Symbol Pin Description Q11 to Q13 1, 2, 3 counter output Q3 to Q9 7, 5, 4, 6, 14, 13, 15 counter output VSS 8 ground supply voltage CEXT 9 external capacitor connection REXT 10 oscillator pin RS 11 clock input/oscillator pin MR 12 master reset VDD 16 supply voltage 6. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; ↑ = LOW-to-HIGH clock transition; ↓ HIGH-to-LOW clock transition. Output Input RS MR Q3 to Q9 and Q11 to Q13 ↑ L no change ↓ L count X H L 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VDD supply voltage IIK input clamping current VI input voltage IOK output clamping current II/O input/output current IDD supply current Tstg storage temperature Tamb ambient temperature Ptot total power dissipation Tamb -40 °C to +85 °C P power dissipation per output [1] Conditions VI < -0.5 V or VI > VDD + 0.5 V VO < -0.5 V or VO > VDD + 0.5 V [1] Min Max Unit -0.5 +18 V - ±10 mA -0.5 VDD + 0.5 - ±10 mA - ±10 mA - 50 mA -65 +150 °C -40 +85 °C - 500 mW - 100 mW V For SOT109-1 (SO16) package: Ptot derates linearly with 12.4 mW/K above 110 °C. For SOT403-1 (TSSOP16) package: Ptot derates linearly with 8.5 mW/K above 91 °C. HEF4060B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 8 July 2019 © Nexperia B.V. 2019. All rights reserved 3 / 14 HEF4060B Nexperia 14-stage ripple-carry binary counter/divider and oscillator 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions Min Typ Max Unit VDD supply voltage 3 - 15 V VI input voltage 0 - VDD V Tamb ambient temperature in free air -40 - +85 °C Δt/ΔV input transition rise and fall rate input MR VDD = 5 V - - 3.75 µs/V VDD = 10 V - - 0.5 µs/V VDD = 15 V - - 0.08 µs/V 9. Static characteristics Table 6. Static characteristics VSS = 0 V; VI = VSS or VDD unless otherwise specified. Symbol Parameter VIH VIL VOH VOL IOH IOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage |IO| < 1 μA |IO| < 1 μA |IO| < 1 μA VDD Tamb = -40 °C Tamb = 25 °C Tamb = 85 °C Min Max Min Max Min Max 3.5 - 3.5 - 3.5 - V 10 V 7.0 - 7.0 - 7.0 - V 15 V 11.0 - 11.0 - 11.0 - V 5V - 1.5 - 1.5 - 1.5 V 10 V - 3.0 - 3.0 - 3.0 V 15 V - 4.0 - 4.0 - 4.0 V 5V 4.95 - 4.95 - 4.95 - V 10 V 9.95 - 9.95 - 9.95 - V 15 V 14.95 - 14.95 - 14.95 - V 5V - 0.05 - 0.05 - 0.05 V 10 V - 0.05 - 0.05 - 0.05 V 5V Unit LOW-level output voltage |IO| < 1 μA 15 V - 0.05 - 0.05 - 0.05 V HIGH-level output current VO = 2.5 V 5V - -1.7 - -1.4 - -1.1 mA VO = 4.6 V 5V - -0.52 - -0.44 - -0.36 mA VO = 9.5 V 10 V - -1.3 - -1.1 - -0.9 mA VO = 13.5 V 15 V - -3.6 - -3.0 - -2.4 mA VO = 0.4 V 5V 0.52 - 0.44 - 0.36 - mA VO = 0.5 V 10 V 1.3 - 1.1 - 0.9 - mA VO = 1.5 V 15 V 3.6 - 3.0 - 2.4 - mA 15 V - ±0.3 - ±0.3 - ±1.0 µA 5V - 20 - 20 - 150 µA 10 V - 40 - 40 - 300 µA 15 V - 80 - 80 - 600 µA - - - - 7.5 - - pF LOW-level output current II input leakage current IDD supply current CI Conditions input capacitance HEF4060B Product data sheet IO = 0 A All information provided in this document is subject to legal disclaimers. Rev. 9 — 8 July 2019 © Nexperia B.V. 2019. All rights reserved 4 / 14 HEF4060B Nexperia 14-stage ripple-carry binary counter/divider and oscillator 10. Dynamic characteristics Table 7. Dynamic characteristics Tamb = 25 °C; VSS = 0 V; CL = 50 pF; tr = tf ≤ 20 ns; unless otherwise specified. Symbol Parameter Conditions VDD tpd propagation delay RS → Q3; see Fig. 5 5V transition time tW pulse width trec recovery time fmax [1] [2] [3] [2] 183 ns + (0.55 ns/pF) CL Min Typ Max Unit - 210 420 ns 10 V 69 ns + (0.23 ns/pF) CL - 80 160 ns 15 V 42 ns + (0.16 ns/pF) CL - 50 100 ns 5V - - 25 50 ns 10 V - - 10 20 ns 15 V - - 6 12 ns MR → Qn; HIGH to LOW see Fig. 5 5V 73 ns + (0.55 ns/pF) CL - 100 200 ns 10 V 29 ns + (0.23 ns/pF) CL - 40 80 ns 15 V 22 ns + (0.16 ns/pF) CL - 30 60 ns see Fig. 5 5V [3] 10 ns + (1.00 ns/pF) CL - 60 120 ns Qn → Qn + 1; see Fig. 5 tt Extrapolation formula[1] 10 V 9 ns + (0.42 ns/pF) CL - 30 60 ns 15 V 6 ns + (0.28 ns/pF) CL - 20 40 ns minimum width; 5 V RS HIGH; 10 V see Fig. 5 15 V 120 60 - ns 50 25 - ns 30 15 - ns minimum width; 5 V MR HIGH; 10 V see Fig. 5 15 V 50 25 - ns 30 15 - ns input MR; see Fig. 5 maximum frequency input RS; see Fig. 5 20 10 - ns 5V 160 80 - ns 10 V 80 40 - ns 15 V 60 30 - ns 5V 4 8 - MHz 10 V 10 20 - MHz 15 V 15 30 - MHz The typical values of the propagation delay and transition times are calculated from the extrapolation formulas shown (CL in pF). tpd is the same as tPHL and tPLH. tt is the same as tTHL and tTLH. HEF4060B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 8 July 2019 © Nexperia B.V. 2019. All rights reserved 5 / 14 HEF4060B Nexperia 14-stage ripple-carry binary counter/divider and oscillator Table 8. Power dissipation Dynamic power dissipation PD and total power dissipation Ptot can be calculated from the formulas shown. Tamb = 25 °C. Symbol Parameter Conditions VDD Typical formula for PD and Ptot (μW)[1] PD per device 5V PD = 700 x fi + ∑(fo x CL) x VDD dynamic power dissipation 2 2 10 V PD = 3300 x fi + ∑(fo x CL) x VDD 2 15 V PD = 8900 x fi + ∑(fo x CL) x VDD Ptot [1] total power dissipation 5V when using the on-chip oscillator 2 2 Ptot = 700 x fosc + ∑(fo x CL) x VDD + 2 x Ct x VDD x fosc + 690 x VDD 2 2 2 2 10 V Ptot = 3300 x fosc + ∑(fo x CL) x VDD + 2 x Ct x VDD x fosc + 6900 x VDD 15 V Ptot = 8900 x fosc + ∑(fo x CL) x VDD + 2 x Ct x VDD x fosc + 22000 x VDD Where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VDD = supply voltage in V; ∑(fo x CL) = sum of the outputs; Ct = timing capacitance (pF); fosc = oscillator frequency (MHz). 10.1. Waveforms and test circuit tr MR input tf 10 % 90 % VM tW 1/fmax trec VM RS input tPHL Qn output tPLH VM tW tPHL 90 % 10 % tt tt 001aaj472 Measurement points are given in Table 9. Fig. 5. Waveforms showing propagation delays for MR to Qn and CP to Q0, minimum MR, and CP pulse widths Table 9. Measurement points Supply voltage Input Output VDD VM VM 5 V to 15 V 0.5VDD 0.5VDD HEF4060B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 8 July 2019 © Nexperia B.V. 2019. All rights reserved 6 / 14 HEF4060B Nexperia 14-stage ripple-carry binary counter/divider and oscillator VDD VI G VO DUT CL RT 001aag182 Test data is given in Table 10. Definitions for test circuit: DUT = Device Under Test; CL = load capacitance including jig and probe capacitance; RT = termination resistance should be equal to the output impedance Zo of the pulse generator. Fig. 6. Test circuit for measuring switching times Table 10. Measurement point and test data Supply voltage Input Load VDD VI tr, tf CL 5 V to 15 V VSS or VDD ≤ 20 ns 50 pF 11. RC oscillator HEF4060B MR (from logic) 11 RS C2 R2 REXT CEXT 10 9 Rt Ct 001aae655 Typical formula for oscillator frequency: Fig. 7. External component connection for RC oscillator 11.1. Timing component limitations The oscillator frequency is mainly determined by Rt x Ct, provided Rt
HEF4060BT,653 价格&库存
很抱歉,暂时无法提供与“HEF4060BT,653”相匹配的价格&库存,您可以联系我们找货
